By buying this product you get 258 loyalty points
Eversolo has designed the AMP-F10 class AB power amplifier to accompany its new streamer, the DMP-A10. This amplifier features a dual mono balanced architecture with no less than 5 MOSFET transistors per channel. This architecture gives it a substantial power reserve, as it is capable of developing up to 2x320W under 4 ohm and 2x200W under 8 ohm. Added to this is the possibility of bridging it in mono mode and achieving an output power of 950W at 4 ohms and 650W at 8 ohms. The AMP-F10 can therefore easily drive demanding loudspeakers with hard-to-move drivers.
In addition to this exceptional power, Eversolo has ensured ultra-clean sound reproduction with a THD level of just 0.008%, an SNR of 113dB for fine, detailed reproduction, and an extended frequency response of 10Hz-30Khz (8Ω).
In terms of connectivity, the AMP-F10 aims for simplicity and efficiency: a signle-ended RCA input and a balanced XLR input with output on speaker terminals. What's more, the AMP-F10's design matches the elegance of the DMP-A10, featuring two backlit vumeters on the front panel for a touch that's both classic and modern.
The AMP-F10 uses dual differential amplifiers within a balanced circuit to handle low-level signals, limit distortion and extend its dynamic range. As a result, the AMP-F10 guarantees a faithful and coherent listening experience, whatever the volume level.
Capable of reproducing deep, punchy bass while retaining exemplary clarity and detail, the AMP-F10 adapts easily to different musical styles, delivering a reliable and emotionally engaging sound experience.
Each channel of the amplifier is equipped with five carefully matched MOSFET transistors. These components ensure an ideal combination of power and stability, contributing to distortion-free sound reproduction.
The components of this power amplifier have been chosen with meticulous care. Eversolo has left nothing to chance, including a linear power supply capable of delivering 1000W per channel thanks to its large toroidal transformer. This configuration avoids any interference between the two channels and delivers a clean current. What's more, this generous power output delivers impressive, immersive sound dynamics.
To protect the audio circuitry, a DC filter is placed between the main AC supply and the internal circuitry. This system effectively eliminates low-frequency DC interference, ensuring exceptionally pure power.
1 | Balanced XLR input |
2 | Single-ended RCA input |
3 | Sensitivity switch : 29dB/23dB |
4 | Operating mode switch: Bridge mono / Stereo |
5 | Standby mode: Trigger / Signal |
6 | Trigger in / out |
7 | Right channel output on speaker terminal |
8 | Left channel output on speaker terminal |
9 | Power supply input / Fuse / Power switch |
10 | Current selection switch 100-120 AC/220-240V AC |
Product type | Power amplifier |
Class | AB |
Transistors | 5x MOSFET transistors (left channel) 5x MOSFET transistors (right channel) |
Inputs | 1x Single-ended RCA stereo input 1x Balanced XLR stereo input |
Output | Speaker terminal output |
Other connectors | Trigger in / out |
Input sensitivity adjustment | 23dB/29dB |
Output power | 2x 320W @ 4 ohm 2x 200W @ 8 ohm 2x 450W @ 2 ohm 1x 950W @ 4 ohm 1x 650W @ 8 ohm |
THD+N | 0.008% |
SNR | 200W @ 8Ω/1kHz Gain 23dB : ≥ 113dB @A-wt Gain 29dB : ≥ 110dB @A-wt |
Frequency response | 10Hz-30kHz @ 8 ohm (±0.5dB) |
Crosstalk | 200W @ 8ohm/1kHz ≤ -95dB |
Input impedance | RCA : 10KΩ XLR : 10KΩ |
Input sensitivity (200W @ 8ohm/1kHz) | RCA input gain 23dB: 2.65V RCA input gain 29dB: 1.3V XLR 23dB input gain: 5.2V XLR 29dB input gain: 2.4V |
Damping factor | >600 @ 8ohm/1kHz |
Power supply | 100-120V AC / 220-240V AC 50/60Hz (selector switch available on bottom of unit) |
Net weight | 18Kg |
Gross weight | 21.5Kg |
Color | Black |
Dimensions | 430 x 310 x 147mm |
Package | 1x Power amplifier AMP-F10 1x Trigger cable 1x Mains cable |
Input | XLR |
Input | RCA |
Output | Speaker terminal |
Color | Black |
Channel | 2 (Stereo) |
Channel | 1 (Mono) |
Channel | Dual Mono |
Class | Class A / AB |
Amplifier chip | MOSFET |
Power (W) | 320.0 |
Power (W) | 950.0 |
Remote Control | No |
