NAD M23 Power Amplifier Class D Stereo Purifi 2x380W 4 Ohm
The NAD M23 is a high-end power amplifier using Class D Eigentakt™ amplifier modules from Purifi. These, in addition to offering a consequent power that can reach 2x380W under 4Ω, ensure a perfectly linear frequency response whatever the load of the associated speakers. Moreover, they have incredible performance, with a particularly low level of noise and harmonic distortion.
By buying this product you get 379 loyalty points
Reference : 17324
3 799,00 €tax incl.
3 165,83 € tax excl.
NAD M23
Class D Stereo Power Amplifier Purifi 2x380W 4 Ohm
NAD M23 Amplificateur de Puissance Stéréo Class D 2x380W 4Ω
Incredible amplification quality
Thanks to its flawless design, the NAD M23 can deliver a power of 2x380W under 4Ω or 2x200W under 8Ω, and this with high efficiency. Its impeccable performance allows the amplifier to reveal a sound as dynamic and lively as precise and detailed, perfectly respecting the original audio signal for a transparent sound reproduction.
Another advantage of the M23 is that it has a very low output impedance and a high damping factor. This means it maintains perfect control of your speakers at all times.
Particularity of the M23, it can be associated with a second identical unit in mono bridge mode, each delivering then a power of 700W continuous under 8Ω.
A perfectly tuned power supply
The NAD M23 also comes with its own switch mode power supply, which is capable of providing large current reserves to meet every need and power demand. This means that the amplifier section never runs out of power and can easily meet a sudden high demand.
An adapted connectivity
The NAD M23 connectivity remains simple but will adapt to most situations. The inputs are single-ended stereo RCA and balanced stereo XLR, with automatic detection of the active source. A three-level gain switch maximizes the versatility of this amplifier. A 12V trigger input on Jack 3.5mm allows to automatically switch on and off the M23 according to a signal received from another device. Finally, the output is classically done on speaker terminals.
1Speaker outputs
2Balanced XLR input
3Single-ended RCA input
4Right channel input selection
512V trigger input
6Gain selection
7Bridge mode
8LED level
9Left channel input selection
Product typePower amplifier
Amplification typeClass D
Amplification modulePurifi Eigentakt™
Inputs1* Balanced stereo XLR
1* Single-ended stereo RCA
OutputsSpeaker terminals
Nominal output power (stereo)2*380W @ 4Ω
2*200W @ 8Ω
Bridge mode nominal output power (mono)700W @ 8Ω
IHF dynamic power (stereo, 1kHz)2*520W @ 4Ω
2*260W @ 8Ω
IHF dynamic power (mono, 1kHz)1017W
Input impedanceSingle-ended: 56kΩ + 200pF
Balanced: 56kΩ + 200pF
Frequency responseStereo: ±0.06dB 20Hz-20kHz -3dB @ 60kHz
Mono: ±0.054dB 20Hz-20kHz -3dB @ 60kHz
THD (20Hz / 20kHz)XLR: < 0.00069%
RCA: < 0.0013%
SNR> 101.7dB (1W @ 8Ω)
> 127dB (200W @ 8Ω)
Peak output current> 25A @ 1Ω, 1ms
Damping factor> 800 (8Ω, 20Hz-6.5kHz)
> 127dB (200W @ 8Ω)
Channels separationHigh gain, RCA: > 97dB @ 1kHz / > 75dB @ 10kHz
Low gain, XLR: > 115dB @ 1kHz / > 96dB @ 10kHz
Input sensitivity @ stereo, 200W, 8ΩLow gain: 4.5V
Mid gain: 2.5V
High gain: 1.4V
GainLow gain: 19dB
Mid gain: 23.9dB
High gain: 29.2dB
Supply voltage100-240VAC
Dimensions (L*P*H)435*396*133mm
Weight9.7kg
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipPurifi 1ET400A
Power (W)380.0
The NAD M23 is a high-end power amplifier using Class D Eigentakt™ amplifier modules from Purifi. These, in addition to offering a...
