DIY Furutech cable kit FP-3TS20 + FI-11-N1G / FI-E11-N1G 1.5m
Reference : 7976
219,00 €tax incl.
182,50 € tax excl.
Audiophonics offers here cables in kit for more ease.
All necessary components are provided to build a complete high end power cable based on FURUTECH products.
This kit includes:
FURUTECH FP-3TS20 Copper Cable OCC (Alpha) 1.5m Ø 14.3mm
FURUTECH FI-11-N1G IEC Gold Connector
FURUTECH FI-E11-N1 (G) Gold SCHUKO Plug
1.5m
IEC
x1
Schuko
x1
Result when mounted:
[Img-8400-left-thickbox_default]
[Img-8401-left-thickbox_default]
If you want this cable mounted, we offer a mounting package.
Please go tothe fiche nextto take advantage of our offer:
https://www.audiophonics.fr/images2/5188/5188_CABLE_ASSEMBLY_5.jpg
FURUTECH FP-3TS20 High-End Power Cable Copper μ-OCC (Alpha α)
Very high performance mains cable 3 conductorsdedicated to Uncompromised Audio Applications, the FP-3TS20testifies to a quality of manufacture and a technicality that leaves no doubt as to its positioning high-end.
Specifications:
  • Cable Sector 3 DriversVery High Performance
  • 3 Drivers ofSingle Section 2.16mm² Consisting of a total of 85 Copper Strands μ-OCC (Alpha) of each one0.18mm Diameter
  • Insulatingpolyethylene of 3.53mm Diameter Covered with a Teflon film and marked with a color code (Red / White / Yellow)
  • Internal wrapping inPVC Black High Flexibilityof 9.6mm of Diameter
  • Braided Shielding 9 x 24 μm OF-copper wire (Alpha) of 0.12mm of Diameter
  • Envelope ExtPVC Blue Night(Dark blue)very high resistance
  • Maximum Resistance of Conductors:0.008Ω / M
  • Total Cable Diameter: 14.3mm
  • Color code: Red = Phase / Yellow = Neutral / White = Earth
Cable also sold at the cut
IEC connector specifications :
  • Conductors: Phosphor bronze plated 24k gold treated with the anti-magnetism process "Furutech Alpha α"
  • Jumper system for disconnection of the mass
  • Insulation: Nylon / Fiberglass
  • Housing: Polycarbonate
  • This connector adapts to an external cable diameter of 6.6mm up to 18mm
  • 250V / 10A
  • Dimensions:
    • Diameter: 38mm
    • Body Length: 48.2mm
    • Overall Length: 74mm
IEC
IEC connector also sold individually
Connector specifications schuko :
  • 250V / 16A
  • Dimensions:
    • Diameter: 39mm
    • Body Length: 56mm
    • Overall Length: 88mm
Schuko
Schuko
Schuko connector also sold individually
Length (m)1.5
