FURUTECH ORIGIN POWER NCF-E (R) Power Cable 1.5m
The Furutech Origin Power NCF-E power cable embodies the full expertise of the Japanese brand in pure transmission, relying on its proprietary Pure Transmission technology designed to optimize every stage of power and signal transfer while reducing contact resistance, EMI and RFI interference.
By buying this product you get 142 loyalty points
Reference : 21640
1 429,00 €tax incl.
1 190,83 € tax excl.
Furutech Origin Power NCF-E (R) Schuko to IEC C15 NCF Power Cable OFC Copper Alpha Treatment Rhodium Plated 1.5m
The Furutech Origin Power NCF-E power cable embodies the full expertise of the Japanese brand in pure transmission, relying on its proprietary Pure Transmission technology designed to optimize every stage of power and signal transfer while reducing contact resistance, EMI and RFI interference. This cable features high-end α (Alpha) μ-OFC copper conductors, composed of 3 cores each made up of 7 bundles of 35 strands of 0.18mm (equivalent 9AWG / 6.22mm²), benefiting from the exclusive Alpha Process (deep cryogenic treatment and demagnetization) to maximize conductivity and signal purity. The polyethylene (PE) insulation, resistant to high voltage and heat, helps reduce capacitance while improving mechanical damping.
Its highly advanced multi-layer construction includes a first inner sheath made of RoHS-compliant PVC incorporating NCF (Nano Crystal² Formula) material and carbon particles to combat static electricity and vibrations, a braided shield made of α μ-OFC conductors (9 x 24 strands of 0.12mm) ensuring excellent protection against external interference, a second intermediate sheath enriched with carbon to reinforce damping, as well as a flexible outer PVC sheath (Ø 18mm) completed by a nylon braid (Ø ≈ 19mm) for a robust and durable finish. The cable also benefits from the patented Ground/Earth Jumper technology, which uses a copper plate in contact with the mounting screws to drain electromagnetic interference generated notably when the cable is bent, thus stabilizing the electrical potential and significantly improving sound quality.
The connectors feature high-end designs with rhodium-plated, non-magnetic pure copper contacts treated with Alpha µ technology. Thanks to a highly precise conductor clamping system that ensures firm and stable contacts, as well as an ultra-flexible, lead-free triple-shielded anti-resonance structure, the Furutech Origin Power NCF-E delivers a perfectly clean and stable power supply. The result is highly precise sound reproduction, with enhanced resolution, powerful dynamics, and an extremely quiet soundstage, allowing the music to express itself fully without coloration or harshness in the high frequencies. True to the philosophy of the Origin line, this cable offers a remarkable balance between high-end audiophile performance and affordability.
Technical Specifications
Product typeAC power cable
Connectors1x Male Schuko (Type E/F)
1x IEC C15
FI-28M NCF(R) / FI-28 NCF(R)
Cable conductorsOFC copper with Alpha treatment
Cable conductors structure3x 7 bundles of 35 strands α (Alpha) μ-OFC of 0.18mm
Cross-section9AWG (6.22mm²)
Connectors contacts materialRhodium plated copper
InsulationPolyethylene (red/natural/yellow) approx. 5.5mm diameter
Inner sheathRoHS-compliant vibration-damping PVC incorporating special NCF material and a carbon particle compound as an anti-static material (black), 13.5 mm diameter
ShieldingBraided shield of 9 x 24 strands of α (Alpha) μ–OFC conductor of 0.12mm
Intermediate sheathFormulated with carbon particles and RoHS-compliant vibration-damping PVC (black)
Outer sheathFlexible RoHS-compliant PVC (pearl blue), 18mm diameter
Total cable diameter19mm
Length1.5m
Sheath colorBlack
Packaging1x Furutech Origin Power NCF-E
Length (m)1.5
ShieldingYes
Section (mm²)6.22
ConnectorIEC C15
ConnectorSchuko
FURUTECH ORIGIN POWER NCF-E (R) Power Cable Schuko IEC C15 OFC Copper Alpha Treatment Rhodium Plated 1.5m
The Furutech Origin Power NCF-E power cable embodies the full expertise of the Japanese brand in pure transmission, relying on its proprietary Pure...
