By buying this product you get 189 loyalty points
Oyaide's Vontida-Xe is a high-quality power cable, consisting of 3 twisted 102SSC copper conductors, each with a cross-section of 4mm². These are insulated with a polyolefin sheath, and then shielded with copper foil. The whole is protected by a polyolefin sheath and covered with a PVC outer sheath.
The connectors contacts are made of beryllium copper, with different plating on each end. The mains connector features platinum and palladium plating, providing protection against oxidation while guaranteeing high mechanical resistance. The IEC13 connector, on the other hand, features gold plating to offer rock-solid protection against oxidation, while maintaining excellent conductivity levels.
Technical specifications
| Specifications | |
| Product type | Power cable |
| Length | 1.8m |
| Connectors | 1x Schuko (Type E/F) 1x IEC C13 |
| Conductors | 102SSC Copper |
| Cross-section | 3x 4mm² |
| Insulation | Polyolefin |
| Shielding | Copper foil |
| External sheath | Polyolefin + PVC |
| Outer diameter | Ø13mm |
| Connector material | Beryllium copper |
| Connector plating | Schuko: Platinum and Palladium IEC C13: 24K Gold |
| General | |
| Color | Red |
| Package | Sold individually |
| Length (m) | 1.8 |
| Shielding | Yes |
| Section (mm²) | 4.00 |
| Connector | Type E (CEE 7/5 - CEE 7/6) |
| Connector | Schuko |
| Connector | Type F (CEE 7/3 - CEE 7/4) |
| Connector | IEC C13 |
| Conductors material (Cable) | Beryllium Copper |
| Conductors Plating (Cable) | None |
