PANGEA AC-14 IEC Power Cable 1.5m
The power cable Pangea AC-14 is specifically designed for source components, which do not require the same current levels as receivers and amplifiers. The AC-14 delivers more current while offering multiple layers of shielding and other features that ensure extremely clean and noise-free power to your equipment.
Reference : 21664
59,90 €tax incl.
49,92 € tax excl.
Pangea AC-14 IEC Triple Shielded Power Cable OFC Copper Gold Plated 3x2mm² 1.5m
https://www.audiophonics.fr/images2/6059/6059_PANGEAAC14_1.jpg
Pangea designed the AC-14 specifically for powering AV components. It helps improve the performance of preamplifiers, CD players, DVD/Blu-ray players, DACs, and other line-level components.
The AC-14 is made of 99.99% OFC conductors ensuring maximum conductivity.
Spiral counter-conductors provide superior noise protection, while the triple shielding effectively protects against RFI and EMI interference while optimizing the isolation of sensitive source components.
The contacts on the AC-14 connectors are plated with 24-karat gold to provide superior conductivity and high resistance to oxidation.
https://www.audiophonics.fr/images2/6059/6059_PANGEAAC14_2.jpg
Technical specifications
Product typePower cable
Connectors1x Schuko 24k gold-plated
1x IEC-C14 24k gold-plated
Cable conductor materialOFC Copper (99.99%)
Cross-section14AWG (2.08mm²)
Triple shielding
Outer diameter12mm
Cable length1.5m
Packaging1x Pangea AC-14 IEC 1.5m
Length (m)1.5
ShieldingYes
Section (mm²)2.00
ConnectorSchuko
Le compagnon idéal pour mes sources Hi-Fi
Client fidèle d'Audiophonics, j'ai une nouvelle fois franchi le pas pour ce Pangea AC-14 (1.5m) afin d'alimenter ma platine. La qualité de fabrication est au rendez-vous : le câble est sérieux, bien blindé et reste assez souple pour une installation aisée derrière le meuble.
À l'écoute, on sent tout de suite que le "bruit de fond" recule. Le silence entre les notes est plus profond, ce qui laisse plus de place aux micro-détails. Pour ce prix, c'est un upgrade indispensable avant de passer sur des solutions beaucoup plus onéreuses.
Expédition rapide et emballage soigné, comme toujours avec l'équipe d'Audiophonics. Je recommande les yeux fermés !
This review has been posted for PANGEA AC-14 IEC Power Cable Triple Shielding OFC Copper Gold Plated 3x2mm² 1.5m
The power cable Pangea AC-14 is specifically designed for source components, which do not require the same...
