AIYIMA T20 Tube Balanced Preamplifier
The Aiyima T20 is a simple yet elegant balanced preamplifier. It features two ECC83 tubes combined with LME49720 and OPA1612 chips to deliver the warm, smooth sound typical of tube amplification. For further convenience, the T20 incorporates two 12V trigger outputs, allowing for seamless integration into your audio system while protecting the tubes.
Reference : 21019
165,00 €tax incl.
137,50 € tax excl.
Shipping date: 04-06-2026.
Aiyima T20 Tube Balanced Preamplifier 2xECC83
Aiyima T20 : Front view
One trigger is dedicated to turning on the DAC, while the other turns on the amplifier. This protects the tubes and allows them to warm up before processing the audio signal.
Aiyima T20: Twin ECC83 tube
The T20's amplification stage relies on two ECC83 tubes. These are combined with pre-amplification by LME49720 and OPA1612 chips, mounted to take full advantage of the character of the ECC83 tubes and provide them with a 180V signal. Furthermore, the T20 offers sound customisation through the use of interchangeable tubes such as 12AX7-S, 12AX7B, 7025 or 12AX7, depending on listening preferences.
Aiyima T20 : OPA
Aiyima T20 : Aluminum chassis
Aiyima T20: A sleek design
The T20's aesthetic is both sober and elegant: a large, minimalist volume display makes it easy to read the settings, while the CNC-machined aluminium casing ensures a neat finish, good heat dissipation and a visually striking appearance.
Aiyima T20 Overview
Aiyima T20 : Overview
1Infrared receiver
2Input mode indicator light
3Display
4ON / OFF / Volume control
52x Trigger output
612V DC power socket
7Stereo XLR output
8Stereo RCA output
9Stereo RCA input
10Stereo XLR input
Product typePréamplificateur
Supplied tubes2x ECC83
Inputs1x Single-ended stereo RCA
1x Balanced stereo XLR
OPA3x LME49720
2x OPA1612
Noise20µV
Signal-to-noise ratio (SNR)≥ 112dB
Dynamic range109dB
Total harmonic distortion more noise (THD+N)0.003%
Frequency response20Hz-20kHz (±0.2dB)
Compatible tubesECC83
12AX7-S
12AX7B
7025
12AX7
Output levelRCA : 4V RMS
XLR : 6V RMS
Power supply12V DC 2A via jack DC 5.5/2.1 mm
Dimensions90 x 142 x 46mm
Weight1015g
Package1x Aiyima T20
1x Remote control
2x ECC83 tubes
1x AC adapter to DC jack
Aiyima T20 : Measurements
InputXLR
ClassTube amp
Remote ControlYes
6 reviews
Très bien
Objectivement excellent rapport qualité prix, Très bon résultat "out of the box" chez moi avec un ampli de puissance AUDIOPHONICS HPA-Q250NC.
This review has been posted for AIYIMA T20 Tube Balanced Preamplifier 2xECC83
Amazing value for money once upgraded!
In stock form, this preamplifier is pretty good value for money. However, it was transformed into something special once I installed 3 dual OPA627 Opamps and NOS Tesla ECC83 tubes. The sound opened up, was more dynamic and detailed and sounded pure & transparent. Amazing value for money!
Dommage qu'il n'y ait que 5 étoiles possibles !
REMARQUABLE rapport qualité/prix (inégalable de mon Pt de vue.)
Audiophonics nous propose ici un préampli hybride extrêmement musical, offrant des possibilités rarement vues à ce prix: hybride, semis conducteurs /tubes, entrées et sorties RCA, ou symetriques XLR et même télécommande de surcroît.
Et justement à propos du Px il faut féliciter l'équipe d'AUDIOPHONICS car il suffit de scroller sur le web pour constater que même les fameuses plateformes Chinoises ne font pas mieux !
Parvenir à proposer ces éléments à ce prix en France mérite un grand bravo ! ! !
Precisons que la fabrication même du produit est d'excellent niveau avec notamment un boitier en aluminium injecté massif (et non pas une simple tôle ferreuse), un circuit imprimé de qualité et des composants internes de très bon niveau.
D'emblée, ce qui est rare, le concepteur évoque pour les puristes de potentielles évolutions extrêmement faciles à mettre en œuvre.
Par exemple il est possible de remplacer les AOP de sortie par d'autres références ou bien remplacer le modèle de tube ECC83 (au demeurant plutôt bons) par d'autre marques.
La troisième évolution possible est de remplacer l'alimentation à découpage fournie par une autre de plus haut de gamme si possible linéaire.
J'insiste sur l'excellente musicalité, précision, absence de distorsion et de coloration gênante, dès le déballage.
En bref, tel quel ce préampli dépasse en performances certains préamplis haut de gamme très onéreux.
Toutefois j'ai mis tour à tour en œuvre chacune des évolutions et vous fais pars des résultats.
Attention, vu l'incidence souvent oubliée en Hifi des phénomènes de compensation, cela peut dépendre largement des éléments du systeme ou de l'acoustique du local.
1) Remplacement des tubes ECC 83 : léger progrès avec certains tubes dont les Jj ECC83 S mais version Gold ( broches dorées); la version courante actuelle Jj ECC83 S n'a pas été d'un apport évident.
Différence assez nette avec ECC83 Nos Mazda ou Telefunken, mais à pondérer car vu les Px de ces tubes il y a disproportion entre le progrès et la dépense somptuaire engagée.
2) Remplacement des AOP par d'autres AOP classiques bien cotés tels 5532- AOP 275 - 2604, etc.
Certes un peu différents chaque fois, mais sans grand intérêt vu le résultat obtenu avec l'excellent AOP LM d'origine.
Donc a tester si ça vous amuse (comme moi) mais...
En revanche, exceptionnel bon en avant en utilisant les AOP discrets SPARKOS doubles.
Sans hésitation excellent résultat rendant le préampli comparables aux plus hauts de gamme, donc dépense largement justifiée; ce préampli le mérite.
3) Remplacement de l'alimentation par une 12 V régulée de qualité ( kit Audiophonics) complétée ici par un bloc boitier super capas proposé aussi chez Audiophonics .
Pour conclure, après des décennies d'expérience pro en Hifi je ne peux que recommander ce preamplificateur ne coûtant qu'environ 160 € .
Bravo à AUDIOPHONICS pour nous proposer ces " trouvailles" ainsi que de nombreuses autres.
Christian CB
Bon rqp
D’ origine, sans tweak, c’ est deja un bon élément au vu du tarif. Rca et xlr dans un preampli a tube, c’ est rare et merite d’ etre souligné. Les aop lme49720 sont tres bon. Les tubes assez punch pas mauvais mais il peut y avoir mieux.
J’ ai essayé des jj ecc83s gold, bof... des pavane série art ecc83s doivent coller a merveille.
très bon
Ce pre ampli a tube est excellent pour son tarif.
Comparativement a mon dac et son réglage volume, l' ajout de ce pre ampli a complètement propulser les capacités de la chaîne.
Tel quel d' origine, déjà très bien. En upgradant tube, et opamp, il sera parmi les pré ampli hdg j' en suis certain.
Très recommandable.
The Aiyima T20 is a simple yet elegant balanced preamplifier. It features two ECC83 tubes combined with LME49720 and OPA1612 chips to deliver the...
