BRZHIFI FV3-PRO Passive RCA Preamplifier / Analog Volume Control
The BRZHIFI FV3-PRO is a passive stereo preamplifier / analog volume controller designed to precisely adjust the level of a signal between an audio source and an amplifier or active speakers, without signal amplification (0 dB gain).
Reference : 22474
74,91 €tax incl.
62,42 € tax excl.
Shipping date: 19-11-2026.
BRZHIFI FV3-PRO Passive RCA Preamplifier / Analog Volume Controller 50 Kohm ALPS RK27
BRZHIFI FV3-PRO
The BRZHIFI FV3-PRO is a passive stereo preamplifier / analog volume controller designed to precisely adjust the level of a signal between an audio source and an amplifier or active speakers, without signal amplification (0 dB gain). It uses a 50kΩ ALPS RK27 potentiometer for volume control and features RCA connectivity for integration into a Hi-Fi system. Its passive operation allows direct control of the signal level while maintaining a simple design, while a remote control allows adjustments to be made remotely. The FV3-PRO is powered via USB-C 5V / 1A or higher, and its compact enclosure measures 69 × 112 × 49mm and weighs 464g, making it easy to integrate into a desktop or Hi-Fi audio setup.
Rear panel of the BRZHIFI FV3-PRO
Technical Specifications
Product typePassive RCA preamplifier / Analog volume controller
Resistance50K ALPS RK27 Rotary Potentiometer
Input1x RCA Stereo single-ended
Output1x RCA Stereo single-ended
Gain0dB
EnclosureAluminum
Power supply5V 1A or higher via USB-C
Dimensions69 x 112 x 49mm
Weight464g
Package contents1x BRZHIFI FV3-PRO
1x Remote Control
1x Stereo RCA Interconnect Cable
1x USB-A to USB-C Cable
ClassN/A
Remote ControlYes
BRZHIFI FV3-PRO Passive RCA Preamplifier / Analog Volume Control 50kOhm ALPS RK27
The BRZHIFI FV3-PRO is a passive stereo preamplifier / analog volume controller designed to precisely adjust the level of a signal between an audio...
