FX-AUDIO TUBE-03 Valves 6K4 Stereo preamplifier Silver
Introducing the all-new 6K4 FX-Audio TUBE-03 tube buffer preamplifier. The latter now offers bass and treble tuning accessible from the front.
4.8 / 5
Reference : 12401
38,90 €tax incl.
32,42 € tax excl.
Shipping date: 08-08-2025.
FX-AUDIO TUBE-03
Tubes preamplifier 6K4 Stereo Silver
fx-audio tube-03 préamplificateur à tubes
Introducing the all-new 6K4 FX-Audio TUBE-03 tube buffer preamplifier. The latter now offers bass and treble controls accessible from the front.
This TUBE-03 acts as a clever little tool to improve the sound of a desktop DAC or HiFi installation lacking punch. With a gold-plated stereo RCA stereo input and output, it will be a quality companion coupled with a class D power amplifier to restore dynamics and sound to any missing installation.
At the proposed price, this device has qualities usually absent in this category.
Moreover, this preamplifier does not have the caricatural sound impastoed in the lower midrange of classical tube productions. On the contrary, the terms transparency, dynamics, musical untiedness, sound matter are the ones that immediately come to mind.
An entry level excellence for any enthusiast who wants an affordable tube preamplifier of high quality.
Output power2000mW
Impedance600Ω
Frequency response20Hz to 20kHz
SNR100dB
Input sensitivity300mV-2000mV
Gain Max : 6dB
Output level Max : 2.7V RMS
Compatible tubesEF95
6AK5
6J1
Connectors
InputsGold plated RCA
OutputsGold plated RCA
Power supply connector formatJack DC 5.5/2.5mm (5.5/2.1mm compatible)
Dimensions100 x 95 x 32mm
Weight480g
ColorBlack & Silver
AccessoriesPower supply adapter 220V to 12V DC 1A
ColorSilver
ClassTube amp
17 reviews
Gain trop important
Testé sur un ampli à transistor en remplacement de son préampli.
Le + :
- Le son à l'air déjà bon avec ses tubes d'origine,
- pas de ronflette,
- punch
le moins :
inutilisable sur mon ampli (Roksan kandy KII) du fait du gain élevé qui arrive dès le début de la course du potentiomètre de volume.
Le volume est trop fort alors que je ne suis même pas au quart et n'est pas gérable sur mon installation. Dommage.
Mais peut-être qu'un remplacement du potar serait une solution ?
This review has been posted for FX-AUDIO TUBE-03 Valves 6K4 Stereo preamplifier Silver
Qualité et subtilité du son
J'ai acheté un 2 em pour mettre entre la platine CD et l'ampli HG MARANZ pm8006 ..une seulle critique et un défaut a signaler au fabricant ''les slots dans lesquels rentre les tubes sont de mauvaises factures car les lampes fournient 6k4 pour les rentrer c'est du délire de fou
preampli FX AUDIO
Agréablement surpris il a tout d'un grand ..Bien entendue pour moi il se place entre la sortie casque de mon PM8006 MARANTZ afin déjà de profité de ces qualités pour venir se brancher dans un AMPLI casque de classe A et de lui donner chaleur et détails encore plus précisément
Un must
Pas l'habitude de donner mon avis, mais c'est vraiment bluffant ce petit préampli au prix ridicule comparé à la HIFI des grandes marques. Après avoir dépensé des milliers d'euros je me suis tourné vers des produits moins ésotériques et c'est gagné à 100%. il faut vraiment remplacer rapidement les tubes d'origines par les GE 5654, le son n'est plus le même. Pour info je fonctionne avec un lecteur maison sous Daphile, un dac Dopping D70, le superbe ampli AUDIOPHONICS MPA-S125NC (extra avec le tube 03) et des enceintes Higland Audio Aingel 3205, dans une pièce de + de 40 m2 c'est juste incroyable.
bon produit, mais cable alimentation trop court !
bon produit que une très bonne sonorité, mais, malgré ceci j'ai constaté
que le bloc alimentation, n'a pas interrupteur en amont pour l’éteindre
et ce bloc reste en permanent sous tension, raccordé au secteur 220 v.
sa LED rouge est aussi désagréable, et difficile a masquer, car le câble
qui fait seulement 1.20 est bien trop court.
si l'on n'a pas une prise a proximité immédiate il faut faire l'achat
en supplément, d'une rallonge avec interrupteur pour couper l'alimentation, électrique du transformateur d'alimentation du
pré ampli.!
