HATTOR AUDIO THE BIG Balanced Passive / Active Preamplifier Takman REX OPA2134 Black
This beautifully crafted Hattor Audio passive/active preamplifier features two high precision attenuators with Takman REX AMRT carbon film resistors, ensuring very low distortion for pure and transparent sound reproduction. It offers the latest refinement in high-end preamplification.
By buying this product you get 230 loyalty points
Reference : 17494
2 300,00 €tax incl.
1 916,67 € tax excl.
Shipping date: 14-10-2025.
HATTOR AUDIO the big
High-Fidelity Passive / Active Preamplifier Balanced Takman REX OPA2134 Black
Hattor Audio Préamplificateur Passif / Actif Haute Fidélité Symétrique Takman REX OPA2134 Noir
Both a passive preamplifier and a input selector with generous connectivity - two RCA and three XLR inputs as well as two RCA and two XLR outputs - this impeccably finished, hand-assembled unit is a great addition to any ambitious hi-fi setup.
This model also integrates an active buffer using two OPA2134 and is equipped with a separate gain section. This active stage can be activated or not via the remote control supplied with the unit and offers three gain levels: +3dB, +6dB and +9dB.
Takman REX AMRT resistors
CMC and Neutrik 24k PTFE gold plated connectors and silver wire cabling allow the Hattor Audio preamplifier to compete with the best high-end products on the market. The attenuation stage here is equipped with individually tested 64-position ultra-low distortion Takman REX AMRT resistors with solid gold tracks and constant impedance inputs.
Each passive mono attenuator is equipped with an insulated aluminum shielding to guarantee optimal channel separation for very low crosstalk. Purists of perfect correction as well as experimenters will appreciate the two dissociable potentiometers allowing to control the left or right channel separately - or conversely - to couple them with an individual level per channel.
The flexibility of its operation, its outputs, its internal design and the quality of its components make the Hattor Audio a high performance device for the most demanding ears.
Télécommande IR et Alimentation HiFi
L'appareil est livré avec sa télécommande assortie pour un pilotage à distance confortable et accessible. Un bloc d'alimentation faible bruit externe est également fourni, permettant de délivrer un signal électrique propre et stable à l'appareil.
Product typePassive / Active preamplifier
Impedance10K
Inputs2* Single-endedd RCA
3* Balanced XLR
Outputs2* Balanced XLR
2* Single-ended RCA
IR remote controlYes
DisplayLED Matrix
Volume adjustment64 steps (1dB/step)
Dimensions263*288*85mm
Weight4.1kg
Package1* Hattor Audio preamplifier
1* Low noise Power supply (Power cable NOT included)
1* IR Remote control
InputXLR
ClassN/A
Remote ControlYes
excellent
J'ai possédé son petit frère il y a quelques années.
Ce modèle actuel est toujours aussi bien fabriqué. Il procure une transparence exceptionnelle, surtout si l'on ne met pas en oeuvre la partie active.
Je le recommande totalement.
This review has been posted for HATTOR AUDIO THE BIG Balanced Passive / Active Preamplifier Takman REX OPA2134 Black
This beautifully crafted Hattor Audio passive/active preamplifier features two high precision attenuators with Takman REX AMRT carbon film...
