By buying this product you get 219 loyalty points
This Tonewinner pack includes the AT-300 audio/video processor and home theater preamplifier, plus two AD-5100PA+ power amplifiers. The result is an extremely powerful, high-performance home theater system. What's more, these devices feature a unique design for aesthetic integration into your audio system.
The package is completed by the Tonewinner ETM-2 measurement microphone, enabling easy acoustic correction to optimize sound reproduction according to the acoustics of your listening room.
The Tonewinner AT-300 is a 16-channel audio/video processor and preamplifier, ideal for home theater integration in 9.3.4 or 7.3.6 configurations. It supports all current audio formats, including Dolby Atmos, Dolby True HD, DTS:X and DTS Master. Similarly, the AT-300 accepts video streams up to 4K UHD 60Hz, and is compatible with HDR, HDR10 and Dolby Vision technologies. This means you can enjoy the latest and greatest formats available for the most immersive sound and visual experience possible.
FIND OUT MORE ABOUT THE TONEWINNER AT-300The Tonewinner AD-5100PA+ is a Class AB power amplifier with 5 channels capable of delivering 130W into 4Ω or 90W into 8Ω each. This makes it ideal for integration into a home theater system. It uses 5 pairs of Toshiba TTC5200 and TTA1943 transistors, ensuring rich, musical sound reproduction. The low-noise differential amplification circuit provides a clear improvement in SNR and dynamics.
This Tonewinner pack contains two Tonewinner AD-5100PA+ amplifiers.
The Tonewinner ETM-2 measuring microphone is designed to enable you, in conjunction with certain Tonewinner home theater systems, to automatically correct the acoustics of your system. It connects to the AT-2300, AT-2000, AT-300 and AD-7300HD models and applies optimal equalization to your loudspeakers for perfect immersion and sound coherence.
FIND OUT MORE ABOUT THE Tonewinner ETM-2Technical characteristics
Product type | A/V processor + 2x Power amplifiers + Measurement microphone |
Tonewinner AT-300 specifications | |
Product type | A/V processor Home theater preamplifier |
Channels | 16 channels |
Inputs | Bluetooth 6* HDMI 2.0 4* Stereo RCA 2* Coaxial 2* Optical Tolsink 1* Slot Micro SD 1* Mini USB (USB Audio) 1* USB-A (USB Host) |
Outputs | Bluetooth 2* HDMI 2.0 (with 1 eARC) RCA 9.3.4 channels XLR 9.1.4 |
Other connectors | 1* RS232 1* 5V trigger output |
Supported audio formats | Dolby Atmos Dolby True HD Dolby Digital Plus DTS/X DTS Master DTS Hi-Res DTS Upmix DTX Neural:X |
Supported video formats / resolutions | 4K UHD 3D Dolby Vision HDR10 / HDR10+ HLG |
HDCP version | 2.2 |
eARC support | On one output |
CEC support | On 5 inputs |
Automatic EQ calibration | |
Lip sync | Up to 1000ms |
DRC feature | |
Input impedance | 20kOhm |
Output impedance | 1kOhm |
Gain | >= 14dB |
THD | <= 0.02% (1kHz) |
SNR | >= 98dB (A-wt) |
Frequency response | 10Hz-50kHz (+1/-3dB) |
Channel separation | >= 80dB |
Crosstalk | >= 80dB |
Supply voltage | 100-240VAC 50/60Hz |
Dimensions | 431*326*100mm |
Weight | 4.4kg |
Color | Black |
Tonewinner AD-5100PA+ Specifications | |
Product type | Power amplifier |
Amplification type | Class AB |
Channels | 5 |
Inputs | 5* RCA |
Outputs | Speaker terminals |
Output power | 5x130W @ 4 Ohm 5x90W @ 8 Ohm |
Impedance | 8 Ohm |
Channel separation | >= 70dB |
THD | <= 0.1% |
SNR | >= 100dB (A-wt) |
Frequency response | 20Hz-30kHz (+1/-3dB) |
Supply voltage | 115-230VAC 50/60Hz |
Dimensions | 431*352*130mm |
Weight | 9.6kg |
Color | Black |
Tonewinner ETM-2 specifications | |
Product type | Measurement microphone |
Compatibility | Tonewinner AT-300 Tonewinner AT-2300 Tonewinner AT-2000 Tonewinner AD-7300HD |
Sensitivity | -40dB |
Directivity | Omnidirectional |
Microphone connector | XLR |
Cable connector | Jack 3.5mm |
Cable length | 5m |
Color | Black |
Input | Optical |
Input | Micro SD |
Input | USB |
Input | SPDIF |
Input | Bluetooth |
Input | HDMI |
Input | RCA |
Output | HDMI eARC |
Output | RCA |
Output | XLR |
Output | Bluetooth |
Output | Speaker terminal |
Output | HDMI |
Color | Black |
Channel | 5 |
Channel | 10 |
Class | Class A / AB |
Amplifier chip | Transistors |
Power (W) | 130.0 |
Remote Control | Yes |
