Pack Topping PA7 Amplifier + E70 DAC + TCX1 XLR Cables 25cm Black
This Topping pack, composed of the PA7 Class D amplifier, the E70 DAC and the TCX1 XLR cables, represents an excellent set, very efficient and coherent both from a technical and aesthetic point of view. It will allow you to have a complete, powerful and efficient audio system, capable of a precise and rich sound restitution, to which it will be enough to add speakers (sold separately) to enjoy your music in ideal conditions.
By buying this product you get 79 loyalty points
Reference : 17702
799,00 €tax incl.
665,83 € tax excl.
Pack content
Pack Topping PA7 + E70 + TCX1
Amplifier + DAC + XLR Cables Black
Pack Topping Amplificateur PA7 + DAC E70 + Câbles XLR TCX1 25cm Noir
Topping PA7 amplifier
The Topping PA7 is a powerful amplifier, based on a Class D architecture and benefiting from an intelligent and particularly careful design. It is thus able to develop an important power while maintaining a very low level of distortion. The technologies used ensure a clear, precise and deep sound reproduction. In addition, the balanced structure of the PA7 provides effective transmission noise reduction.
Key features:
  • Class D amplifier
  • Output power: 2x200W @ 4 Ohm, THD+N <1%
  • SNR: 126dB
  • XLR, Jack 6.35mm TRS and RCA inputs
  • Balanced conception
  • 12V trigger
  • Two gain levels
View more informations on Topping PA7
Topping E70 DAC
Topping offers with its E70 a powerful DAC with an accurate design. A model capable of offering a rich and precise sound reproduction, combined with intelligent and practical features, such as Bluetooth, a 12V trigger or an adaptable output level.
Key features:
  • ESS ES9028Pro DAC
  • Hi-Res Audio and Hi-Res Audio Wireless certifications
  • Bluetooth 5.1 receiver with aptX, aptX LL, aptX HD, aptX Adaptive and LDAC codecs support
  • Sample rates support up to PCM 32bit 768kHz and DSD512
  • XMOS XU316 USB interface
  • THD+N: 0.00006%
  • Balanced and single-ended outputs
  • New I/V conversion circuit
  • Ultra low noise preamplifier
  • IR remote control
View more informations on Topping E70
Topping TCX1 XLR cables
Topping's high quality TCX1 XLR cables feature 6N copper and silver-plated 6N copper conductors, ensuring perfect signal transmission. Each conductor has a cross section of 0.533mm² (19AWG). The contacts of the connectors are gold plated to maintain excellent conductivity while ensuring high resistance to oxidation. Each cable is covered with a beautiful and robust black and red braided nylon sheath.
Key features:
  • Length: 25cm
  • 6N copper and silver plated 6N copper conductors
  • Gold plated connectors
View more informations on Topping TCX1
Topping PA7 specifications
Product typeAmplifier
Inputs1* Balanced XLR/Jack 6.35mm TRS combo
1* Single-ended stereo RCA
OutputSpeaker terminals
Amplification typeClass D
Dimensions200*155*41mm
Topping E70 specifications
Product typeDAC
InputsBluetooth 5.1
1* USB-B
1* Coaxial
1* Optical Toslink
Outputs1* Single-ended stereo RCA
1* Balanced stereo XLR
DAC chipESS ES9028Pro
USB interfaceXMOS XU316
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD, aptX Adaptive, LDAC
Supported sample ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Dimensions200*138*44mm
Topping TCX1 cables specifications
Product typeMale/female XLR cables
Length25cm
Conductors material6N copper
Silver plated 6N copper
Conductors section0.533mm² (19AWG)
Outer cable diameterØ8mm
Connectors contacts platingGold
Outer sheathBraided nylon
Cable colorBlack and red
This Topping pack, composed of the PA7 Class D amplifier, the E70 DAC and the TCX1 XLR cables, represents an excellent set, very efficient and...
