Jam M.
6V6GT Electro Harmonics
Les tubes sont bien appairés. Les caractéristiques sont confromes.
Seul défaut: construction du tube non parfaite:...
Patrick V.
to much money for what you get
I received the case with one heatsink dented. So if this unit was intended for a client it was already useless. If you want a...
Please contact our customer service team via the forms on the website; the damaged part will be replaced.
Philippe T.
Excellent
Voilà il est arrivé .. il se rôde .. les premières impressions sont excellentes.. une très belle séparation des canaux .. un...
NEOTECH NC-06612 Gold Plated Brass 3 Way Male / Female XLR Connectors Or Ø12mm (Set x4) - reviews - There are 7 reviews.
Cedric J.
Bon rqp
Pas d' avis sur les qualités sonores, semblent relativement neutre, mais sont qualités tout a fait correct. Pour des câbles de fort diamètre, c'est intéressant.
Sandro R.
Very Good
Xlr Connectors, of construction quality and of the best connectivity I have seen and used until today
François G.
Câbles de 1mm de diamètre.
Belle qualité de finition et matériel de bonne facture, l'un des rares modèles qui s'adapte a mes câbles. Je conseille.
Damon A.
I love these beauties.
Thanks to Audiophonics for fast, trouble-free shipping to the United States.
Two sets of 4 connectors were purchased for use with NeoTech NEI-3004 cable. The connectors were very nicely packaged in a well padded tin, and are of excellent quality. Mounting the cable was trouble free with my ordinary soldering skills. The Audiophonics web site implies the maximum cable size these connectors will take is 10mm. It will actually take much larger which is a huge plus if you like big cables. I would have purchase the 10.5mm NEI-3001 cable if I knew it would fit. It wasn't until I got the connectors that I saw (in the description) it would take up to 13.5mm.
Gerard M.
Très "pro"
Pour un prix unitaire voisin, ces XLR s'ils sont moins beaux (en photo) que les Viablue achetés en même temps me semblent de meilleure qualité apparente. Ça pèse lourd c'est founi dans une boîte en alu sur un lit de mousse. Le design mécanique semble bien conçu et réalisé. Manque juste le côté bling bling type Viablue, Viborg,....
jean francois G.
adapté aux gros câbles
je ne jure que par neutrik , malheureusement la gaine de mon nouveau câble m oriente vers ce modèle beacoup plus coûteux . la qualité est là , le poids aussi . l emplacement réservé au câble a souder est spacieux et doré , le mien s en trouve d ailleur un peu perdu et oblige a consommer plus de soudure .
je ne sais pas si le ramage vaux le plumage . neutrik propose un package plus basic mais les mêmes qualités de contacte , de robustesse , de fiablité etc ... pour un tout autre tarif. c est se qui leur coutera la note ultime .
pour le reste a vous de voir .
anael R.
Excellente facture / rapport QP
Une belle surprise, pour le prix, on en a vraiment pour son argent !
Construction externe robuste, massive, et sans aucune faute de finition. En interne, c'est RAS. Au montage, aucune surprise. Les pin en cuivre OFC dorés se soudent parfaitement, pas trop massifs. Le lock est impeccable. Incroyable de simplicité, calqué sur les Neutrik mais en qualité bien supérieure. Ouverture 11,7, s'accommode bien des plus gros câbles audio.
