Jam M.
6V6GT Electro Harmonics
Les tubes sont bien appairés. Les caractéristiques sont confromes.
Seul défaut: construction du tube non parfaite:...
Patrick V.
to much money for what you get
I received the case with one heatsink dented. So if this unit was intended for a client it was already useless. If you want a...
Please contact our customer service team via the forms on the website; the damaged part will be replaced.
Philippe T.
Excellent
Voilà il est arrivé .. il se rôde .. les premières impressions sont excellentes.. une très belle séparation des canaux .. un...
PANGEA PREMIER XL Phono RCA - RCA Cable + Ground Wire 1.25m - reviews - There is 1 review.
Arnoud H.
Well balanced phono cable
There is not a lot of information to find on internet for this cable. That triggered my curiosity.
On the manufacturers website I found that the cable are made with Cardas Grade One Copper conductors. Which I think is desirable.
The cable needs time to settle in the system. When settled, the cable gives a very good balance between timbre, spaciousness and clarity. It is difficult to describe. At first it does not appear that special of a cable. It does not have an overly holographic soundstage. It is not overly punchy but something much more natural. Like instruments are played in your room instead of an overly sharp projection where the instruments are outlined to accentuate their presence.
I do not think this cable is for everyone due to their size and stiffness. On an other turntable I have the VDH D-502 cable which is much easier to handle in tight spaces than this cable.
If you play a lot of music with acoustic instruments I think you will be pleasantly surprised with this cable. This cable will not add a aggresiveness to the music, which is sometimes needed for rock, punk, pop or electronic music.
Pangea Audio's RCA-RCA Premier XL phono cable is a top-of-the-range cable with multi-AWG conductors made of pure...
