Thierry S.
Beau produit, massif et bien fini.
Pour les connecteurs il y a mieux mais beaucoup plus cher. Ceux-ci font très bien le taf...
Thierry S.
Câble monté sur caissons graves en 38cm et comme attendu résultat propre sans exagération ni manque.
On suis très bien une...
joffrey J.
Bon matériel
Fiches en cuivre pas chères. Faciles à monter. r.a.s.
SMSL VMV A1 PRO Amplifier Stereo / Mono Infineon GaN 2x160W 4 Ohm / 1x400W 4 Ohm - reviews - There is 1 review.
Laszlo G.
Excellent as monoblocks
I bought 2 amps to use as monoblocks. I previously used an SMSL PA-X in stereo; it wasn't bad, but it wasn't good enough. That is why I immediately tried the monoblock configuration with these amps. It was promising the first time, but it needed about a 50-hour break-in period to show its true sound character. The amps were connected to my Sonus Faber Guarneri (the original version) loudspeakers. This configuration has excellent spatial resolution, well-defined instruments, and a deep, wide soundstage. You can hear the microdetails and the microdynamics of a good recording. The sound isn't warm, but it isn't tiring either. I could compare them to my VAC Avatar integrated amp, which is in another league. Of course, the VAC sounds considerably better, but they are not far apart. The VMV A1 Pro monoblocks have an even wider, deeper soundstage. And they don't heat my listening room in summer.
The SMSL VMV A1 Pro is an innovative amplifier that uses Gallium Nitride (GaN) transistors to deliver 2x160W of amplification at 4Ω. Its...
