Martin S.
Lacking Some Detail and Control.
The aim was to replace my Musical Fidelity KW500 with something physically smaller.
I paired the MPA-S125NC power amp with a...
Jacques B.
Remarquable câble !!
Une superbe fabrication, un montage délicat car câble assez rigide à prendre en compte si l'espace est limité derrière les...
Andre K.
replacement
I used the Exicon transistor as a replacement for the discontinued SK1058 transistor. No need for any circuit modifications.
VIBORG VB406G Banana Plugs Pure Copper Silver / Gold Plated Ø6mm (Set x4) - reviews - There is 1 review.
Luigi P.
Wrong
Unfortunately the description misleaded me. These plugs are NOT standard . I was looking for plugs accepting cable size max diam 6mm but the plug itself is not standard one . I would have clearly reported the diameter for the connector anfor the plug rispectively! Bad luck Shipment timing and comunicationg during order preparation excellent on the other side.
These Viborg VB406G banana plugs feature pure copper contacts for excellent conductivity. They are also triple-plated with OFC copper / silver /...
