BURSON AUDIO CONDUCTOR VOYAGER VERSION STANDARD DAC Headphone Amplifier Preamplifier
With the Conductor Voyager, Burson Audio offers a high-end DAC, headphone amplifier and preamplifier. It features an ESS9039PRO DAC capable of processing PCM streams up to 32bit 768kHz and native DSD512, supported by an XMOS USB interface and a discrete dual-mono analogue section. Its Class A amplification delivers up to 10 W thanks to Onsemi MJE15032 transistors, ensuring compatibility with even the most demanding headphones. Its connectivity includes Bluetooth 5.0 compatible with LDAC and aptX HD, as well as a dedicated subwoofer output for versatile integration.
By buying this product you get 379 loyalty points
Reference : 21300
3 790,00 €tax incl.
3 158,33 € tax excl.
Burson Audio Conductor Voyager Version Standard DAC ESS9039PRO Headphone Amplifier Preamplifier 10W 32bit 768kHz DSD512
Burson Audio Conductor Voyager : Front view
Burson Audio Conductor Voyager: ESS9039PRO DAC
The Conductor Voyager is based on an ESS9039PRO DAC chip, a high-performance converter that Burson uses in a particularly sophisticated configuration. The analogue section of the DAC benefits from I/V conversion and low-pass filtering in a dual mono architecture, with each channel processed separately to optimise separation and limit interference. This part is handled by Burson V6 operational amplifiers, chosen for their linearity and low noise level.
The digital interface is based on an XMOS USB controller, whose integration ensures stable and accurate management of high-resolution streams. The combination of the ESS DAC, discrete analogue stage and USB module allows the Conductor Voyager to support PCM signals up to 32bit 768 kHz as well as native DSD512, meeting the most demanding formats.
Burson Audio Conductor Voyager : ESS DAC
Burson Audio Conductor Voyager : Transistors
Burson Audio Conductor Voyager: Class A amplification
The amplification section of the Conductor Voyager follows Burson's traditional philosophy: power, stability and pure class A. Each channel is built around four Onsemi MJE15032 transistors, operating under high bias to maintain full class A operation. This topology provides significant current headroom and a highly responsive response.
The available power reaches 10W, allowing the Voyager to drive a wide variety of headphones without constraint, including planar models or low-sensitivity dynamic designs. The whole unit is designed to offer controlled sound reproduction, even with difficult loads.
Burson Audio Conductor Voyager: Extended connectivity
The Voyager's connectivity has been designed to cover both traditional wired uses and modern wireless transmission needs. Its Bluetooth 5.0 module is compatible with LDAC, aptX HD and AAC.
This wireless connection complements traditional wired inputs, including USB-C, coaxial and Toslink, creating a versatile package suitable for any digital source. What's more, on the analogue side, it's no slouch either, offering RCA and XLR stereo inputs.
Burson Audio Conductor Voyager : View of the open device
Burson Audio Conductor Voyager : Comparison between different regulators
Burson Audio Conductor Voyager: Silent power supply
Power supply is a key element in the architecture of the Conductor Voyager. It incorporates seven Silent Power 1 modules, discrete regulators designed to ensure a particularly clean power supply. Their role is to drastically reduce the background noise generated by the regulation, allowing the analogue and digital stages to operate under optimal conditions. The result is a quieter power supply than that obtained with conventional modules, contributing to the stability and transparency of the audio signal.
Burson Audio Conductor Voyager: Subwoofer output
The Conductor Voyager finally offers a dedicated subwoofer output, allowing you to connect a subwoofer to your headphones using Head + Sub mode. This feature provides useful support for content requiring extended sub-bass, while maintaining the precision of headphone listening.
Product typeDAC
Headphone amplifier
Preamplifier
Inputs2x Single-ended stereo RCA
2x Balanced stereo XLR
1x USB-C
1x Optical Toslink
1x Coaxial
Output2x Balanced stereo XLR
1x Single-ended stereo RCA
1x RCA subwoofer
1x Single-ended 3.5mm jack headphone output
1x Single-ended 6.35mm jack headphone output
1x Balanced 4-pin XLR headphone output
Input impedance40kΩ
Frequency response0Hz-58kHz (±1kHz)
Total harmonic distortion (THD)< 0.0015%
Output impedanceSortie casque : 0.45Ω
Pre out / DAC : 1Ω
DACESS9039PRO
USB interfaceXMOS
Supported sampling ratesPCM up to 32bit 768kHz
Native DSD up to DSD512
DSD DoP512
Channel separation138dB
Balanced output power10W @ 16Ω
5.2W @ 32Ω
3.5W @ 100Ω
2.5W @ 150Ω
1W @ 300Ω
Single-ended output power5W @ 16Ω
2.8W @ 32Ω
2W @ 100Ω
1.5W @ 150Ω
0.5W @ 300Ω
Signal-to-noise ratio (SNR)96dB @ 16Ω
98dB @ 32Ω
95dB @ 100Ω
96dB @ 150Ω
96dB @ 300Ω
Dimensions265 x 270 x 85mm
Weight7kg
ColorSilver
Package1x Burson Audio Conductor Voyager
1x Remote control
1x Power cable
1x USB cable
InputXLR
OutputSubwoofer
OutputJack 3.5mm
OutputJack 6.35mm
DAC / ADC ChipES9039PRO
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
ClassClass A / AB
Remote ControlYes
BURSON AUDIO CONDUCTOR VOYAGER VERSION STANDARD DAC ESS9039PRO Headphone Amplifier Preamplifier 10W 32bit 768kHz DSD512
With the Conductor Voyager, Burson Audio offers a high-end DAC, headphone amplifier and preamplifier. It features an ESS9039PRO DAC capable of...
