AUDIO-GD R29 Discrete DAC R2R / Preamplifier / Headphone Amplifier Black
With the R-29, Audio-GD offers a new R2R DAC and headphone amplifier based on the design of the R-28 MK3 model, sacrificing the balanced architecture to offer a device with similar qualities but at a much lower cost. Like its predecessor, the R-29 uses an FPGA-controlled and corrected resistor network for digital-to-analogue conversion and transistor signal amplification for its headphone outputs, delivering a typically analogue sound to your favourite tracks.
By buying this product you get 57 loyalty points
Reference : 21295
579,00 €tax incl.
482,50 € tax excl.
Audio-GD R-29 Discrete DAC R2R / Preamplifier / Headphone Amplifier 32bit 384kHz DSD512 Black
Audio-GD R-29 : Front view
Audio-GD R-29: R2R DAC
The R-29's digital-to-analogue conversion is handled by a network of ultra-low tolerance resistors, corrected by a high-speed FPGA logic circuit. This type of design is unique in that it does not rely solely on the analogue precision of the electronic components for conversion and reconstruction, but takes this same variability into account in the conversion process. This allows for sound reproduction with all the ‘density’ of R2R sound in its most subtle details, while maintaining excellent output signal stability.
Audio-GD R-29 : R2R network
Audio-GD R-29 : Xilinx chip
Audio-GD R-29: A high-quality digital circuit
The R29's digital circuitry uses high-quality components, specially selected and assembled to optimise the interpretation and decoding of the audio stream. These include a TCXO clock, an Altera FPGA logic circuit and a proprietary Xilinx FIFO on-chip input circuit for all digital inputs.
In this configuration, the FPGA can perform precise re-locking of the clock signal via the FIFO circuit, based on the internal clock rate, which further facilitates clock noise rejection and corrects digital imperfections accumulated from the audio source.
This digital circuit not only provides high-quality digital filtering, but also incorporates an oversampling function (x2 / x4 / x8) and two NOS modes (true NOS with 6dB analogue filtering). The entire system can be configured by the user to suit their listening preferences and the specific characteristics of their audio installation.
Audio-GD R-29: Transistor amplification
The analogue output stage of the R-29 is entirely discrete. Two pairs of 15W transistors ensure excellent signal amplification capability, with an output power of up to 3800mW at 25Ω.
Audio-GD R-29 : Transistors
Audio-GD R-29: Extended connectivity
The R-29 offers a wide range of connectivity options, making it easy to integrate into all types of sound systems. It features HDMI I2S, USB-B and coaxial inputs, ensuring broad compatibility with source devices. In terms of outputs, in addition to a stereo RCA output, the front panel has two 6.35mm headphone outputs.
Audio-GD R-29 : Pinout I2S
Product typeR2R DAC
Headphone amplifier
Preamplifier
Inputs1x USB-B
1x HDMI I2S
1x Coaxial
Outputs1x Stereo RCA
2x Jack 6.35mm
Signal-to-noise ratio (SNR)> 115dB
Total harmonic distortion more noise (THD+N)< 0.015%
GainL : +12DB
H : +22DB
Channel balancing< 0.05dB
Frequency response20Hz - 20KHz (< -0.5dB)
Output LevelHeadphone output : 10V RMS
Variable preamp output : 10V RMS
Fixed DAC output : 2.5V RMS
Headphone output power3800mW @ 25Ω
2400mW @ 40Ω
950mW @ 100Ω
330mW @ 300Ω
165mW @ 600Ω
Output impedanceHeadphone : 1Ω
DAC / Preamp : 5Ω
Input sensitivity0.5Vp-p (75 Ohms, Coaxial)
Supported sampling ratesUSB / I2S : PCM 32bit 384kHz / DSD512
Coaxial : PCM 192kHz
Power supply220-240V AC50/60Hz
Power consumption10W
Weight3.3kg
Dimensions240 x 230 x 85mm
Package1x Audio-GD R-29
1x Remote control
1x USB cable
1x Power cable
InputI2S via HDMI
OutputJack 6.35mm
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD512
Max sampling rate384kHz
ClassClass A / AB
Remote ControlYes
AUDIO-GD R29 Discrete DAC R2R / Preamplifier / Headphone Amplifier 32bit 384kHz DSD512 Black
With the R-29, Audio-GD offers a new R2R DAC and headphone amplifier based on the design of the R-28 MK3 model, sacrificing the balanced...
