Patrick K.
Sonic Master
This cable is sooooo good that i was shocked. I did not expect this level of warm neutral detailed rich, open and airy sound...
Pierre-Marin L.
Je confirme tous les commentaires élogieux sur ce câble...
Patricio C.
Dale una oportunidad de escucha en tu sistema... y juzgalo tu mismo.
Más vale tener potencia bajo el pedal y no necesitarla que al revés.... y vaya si se nota ir sobrado de potencia. Antes usaba...
Customers reviews - There are 19092 reviews.
Robert v.
How good are they?
The quad of Psvane EL34PH replaced my old Philips. The Philips replaced the nos brown base Tesla's when 2 broke down. The Tesla's were my reference.
It is getting harder to find and more expensive to buy those nos tubes and you can never be certain of their condition. This is why I bought the Psvane, as they are a recreation of the original Philips EL34. I found them for a reasonable price here @ Audiophonics and placed the order. Within a week I received them in perfect condition.
It took me some time to get the speaker setup right and that gave the tubes some burn in time. Now after some 15 hours they are starting to come alive. The sound image is opening up. Rich and well defined bass, the mids are getting more fluid and so are the highs.
When listening you won't experience the sound being loud.. until you want to start a conversation. Needless to say these tubes are incredibly dynamic. It may not make sense, but a second sounds like there are 2 seconds, because of the detailed information I get, at least in my set.
I am pleased with these, so I just ordered a matched pair of 12AU7S to replace the Sovtec.
DAYTON AUDIO UM15-22 Ultimax DVC Speaker Driver Subwoofer 800W 2x2 Ohm 87dB 15Hz - 1000Hz Ø38cm The Ultimax range of double coil subwoofers from Dayton Audio is the guarantee of powerful bass. Designed using the latest subwoofer technology, the Ultimax is the ultimate low...
Machine de guerre
Monte en clos de 90l avec un atohm s500 et un dspeaker c est démoniaque infernal. C est lourd pesant et massif sans etre traînant superbe en home cinéma et bénéfique meme en hifi
Frederic F.
simple et efficace
Utilisé avec dac Musical Fidelity M1 et casques SENNHEISER Momentum, FOSTEX TH7, AKG K271 ou AKG K240.
Les timbres sont variés, les réverbérations, nuances et instruments bien détachés.
Le grave est tendu mais sans plus.
Ne s’effondre pas avec mon casque le plus gourmand (AKG K240 studio).
Équilibre tonal bon et douceur (pas de dureté, aucune fatigue)
Un petit bémol: à bas volume avec mon casque le plus sensible (FOSTEX), le potentiomètre de volume étant en début de plage, petit déséquilibre du niveau entre les 2 voies.
très satisfait
J'ai eu beaucoup d'amplis casques. Je trouve le TA-20 vraiment très bon à l'écoute. La qualité principale est une grande douceur, mais pas au détriment de la définition ou de la sensation de puissance. Je le situe parmi mes amplis avec le meilleur niveau de détail, et la spatialisation est large.
Il semble mieux rendre en XLR symétrique, liaison au dac et sortie casque aussi, utilisant à mon avis la double triode de chaque tube 12au7 de préampli, et il y a un peu plus de puissance ressentie qu'en asymétrique contrairement aux chiffres sur le papier (?). J'ai un Hifiman HE-6 réputé gourmand qui fonctionne très bien avec. Ceux qui veulent des niveaux sonores très élevés sur ce casque devront rechercher des modèles d'amplis très puissants, mais à des niveaux bien confortables je ne ressens pas de manque avec le HE-6 (entre 65 et 75 sur 95 de volume). En particulier le grave est bien ferme et descend aux infras sans souci.
Les tubes d'origine ne sont pas ridicules, avec une spatialisation bien large. J'ai mis des PSVane qui sont plus fins dans le médium aigu, avec une spatialisation un peu moins impressionnante. Malgré le fait que ce soit un hybride, le changement de tubes s'entend.
J'ai bien aimé le très sympathique TA-10 toutefois un peu inférieur à mes meilleurs amplis. Le TA-20 est nettement supérieur, surtout en puissance, pour sa finesse, le niveau élevé de détail restitué.
Henrique S.
Really a Pro cable for the price!
Amazingly well constructed, fantastic shielding and despite the robustness of the cable, it is still flexible and easy to connect to my audio equipment.
Henrique S.
Excellent schuko plugs
Lots of space to connect the wires with no problems, superb screws that allow for the correct pressure over the wires, and the cable rests correctly attached to the plug. Shinning golden contacts and screws.
Henrique S.
A fine IEC plug
Bought five of these IEC plugs and really love it. Nice price, and excellent plugs: lost of space and good screws, it's easy to connect the wires and the cable rest really secure to the plug.
Henrique S.
Good Buy!
Excellent and solid construction, the contacts make good pressure over the plugs terminals. Excellent relation price / quality
Toshiki K.
Rather good, but needs modification
The positive binding post of R Ch is unfavorably connected to GND due to the phase inversion at R Ch for reducing bus pumping. This is because negative output of 1ET400A is connected to GND internally.
Sound quality is not good enough for me, though is better than that of Hypex NC400 with SMPS600N400. I replaced the interface card with Purifi FE02 front-end board, in which OPA1612AID OPamps and low noise discrete regulators are incorporated. They seem to have higher performance than LM4562NA OPamps and conventional 3-terminal 7815 and 7915 regulators used in the interface card. I also changed cables connecting output Faston-tabs and binding posts to Cardas CROSSLINK 1S speaker cables that have star-quad configuration. The sound quality has come to be worth 5 stars.
I hear that FE02 is not permitted to be incorporated in commercial products by Purifi. Sound quality would be better if discrete 3-terminal regulators were used instead of the IC regulators in the interface card, because some sound degradation probably originates from noise and inadequate transient response of the regulators. The reason for reduction of 2 stars here is that modification is necessary for excellent sound.
Apart from the product, I felt kindness and faithfulness in customer service personnel.
Nicola G.
Ottimo
Ottimo servizio e prezzo. Montato su B&W CDM 7SE fantastico
Michel V.
Pas de regrets !
Les avis déjà laissés sur le site m'ont permis d'avoir une bonne idée du produit avant de l'acheter. Car il n'y en a quasi. pas sur le Net.
Il prend peu de place, semble solide, et est agréable à regarder. Passé le délai de garantie, je changerai le câble d'alimentation.
Déjà avec les 2 tubes d'origine, il est convaincant, bien spatial, dynamique, et tient mieux le bas du spectre que je ne l'aurais pensé.
La puissance est bien suffisante; même avec les excellents Alpair 11MS que j'ai monté en bass-reflex, mais qui ne constituent cependant pas un système à "haut rendement".
Ecoute avec le Bluetooth : qualité basique avec mon Natel, puis j'ai essayé avec ma Surface Pro; et là, la qualité (meilleure stéréo et spatialité) est montée d'un cran (proche de l'écoute d'un CD).
Je n'ai pas encore essayé l'entrée USB.
J'ai commandé les fameux tubes 6N3P-DR; je laisserai un autre avis, une fois écoutés.
Cet ampli. est donc à recommander !
Martin F.
Commandé mais pas monté car mon boîtier et trop petit. Par contre il est de très bonne qualité. Avec un touché très agréable.je j'utiliserai pour autre chose.
Martin F.
Fonctionne très bien. Installation sur pi 3 et volumio hyper simple. L'accessoire indispensable avec une carte pi. Un seul petit bémol: les barettes de connections ne sont pas très adaptés pour y souder des fils. Peut être vaudrait-il mieux ne rien souder et les mettre dans le sachet?
Jean-Denis B.
JDB
Très bon produit. Excellent rapport qualité/prix.
Luis P.
VIBORG LP528B Stabilizer for Vinyl Turntable with bubble 50Hz 280g This LP658B Viborg vinyl stabilizer significantly reduces vibration and stabilizes the rotation speed of the tray. A bubble level ensures that the latter is perfectly...
Ce stabilisateur aide beaucoup a limiter les vibrations de la rotation du plat.
Luis P.
Con Produit
Mis sur an ancien Toshiba, améliore la qualité d'ecoute.
Luis P.
Brosse de très bonne qualité e moins cher que les autres d'autres fabricants.
Matthias H.
Masterstroke!
I was quite happy with the default AMP6 output stage on my iBasso DX150 (which is brilliant in and of itself), but got interested in a different flavour. I ordered the AMP9 and have been listening for a few hours now. The tube based output stage provides a very different lense onto the music, and the implementation of it I find simply delicious and done with taste and great integrity. I will spare you detailed descriptions of its sound characteristics, and of course appreciation may depend on individual taste (and set of headphones), but I find that this amp module is absolutely worth the invest if you're more of a pleasure seeker than a truth seeker when listening to music on your DAP. Splendid product!
Joel G.
je suis très satisfait de ce produit.
finition soignée, pas de ronflements.
je l'utilise pour sélectionner diverses sources vers mon ampli hifi.
je recommande ce produit. Son prix me semble justifié.
Ian S.
Definite improvement, great value
My current amp is based on the Hypex UCD180 but I had the urge to try an Ncore. This one seemed very reasonably priced. Using the same pre amp I plugged the Ncore in and the improvement was immediately obvious. More powerful, expected, but also better all round, delicate when required, better imaging,width and depth, and clear as a bell without ever being harsh. Turn the volume way up and it just gets louder without distortion.
A real powerhouse but with finesse.
François L.
colis envoyé très rapidement et conforme à la commande
bravo, à retenir
RENE R.
RAMM AUDIO E7
SUPERBE CABLE AU RAPPORT QUALITE PRIX EXCEPTIONNEL, LARGEMENT EQUIVALENT A DES CABLES COUTANT 5 FOIS SON PRIX PAR CONTRE TRES REVELATEUR, RAPIDE, TRANSPARENT, AVEC DES BASSES TRES TENDUES. UN CABLE QUI RENTRE DANS LA MEME ESTHETIQUE SONORE QUE NORDOST. J'AURAIS MIS 5 ETOILES MAIS J'AIME PAS TROP LES PRISES.
MICHAEL A.
Livraison rapide, a peine arrivé et deja branché en moins de 2 minutes, mon caisson klipsch n avait pas de trigger ce produit remplace bien ce petit manque, ampi allumé sw allumé. Ampli éteint, sw eteint. Nikel.
jean pierre g.
R-CORE Transformer 30VA 24-0-24V Here is an R-CORE transformer, ideal for powering DAC or HiFi preamplifiers. The design and manufacturing quality of this transformer is impeccable, and will allow you to power...
super transfo
la tension est légèrement supérieure au 24v annoncé, mais c'est normal, tension mesurée à vide 27v1
ce type de transfo est de très bonne qualité, il est parfait pour des applications audio type préampli, il peux remplacer avantageusement des transfos toriques beaucoup plus cher
Extra
Pour avoir soudé deux paires de câbles HP dont une paire en étain classique et une paire avec celui-ci a 10 % d’argent.
La différence à l’écoute est impressionnante. Je n’utiliserai plus que cette étain a l’avenir
Essayez sans hésiter
RQP Imbattable
Facile à souder et bonne tenue mécanique.
C’est simple, efficace et abordable financièrement
Je recommande vivement
Bof
La qualité du corps de fiche est très correcte ainsi que la prise de soudure.
Par contre la tenue mécanique dans la prise femelle est trop faible et a tendance à se débrancher facilement et laissez supposer que la qualité musicale s’en trouve altérée. Je vais donc les remplacer car le Neotech 3004 mérite mieux
Dommage
Flavio M.
Perfetto
A spectacular dac....velvet sound is the right word.audiophonics a nice surprise
laurent v.
trop tot pour le dire peut etre mais je suis content de mon achat
livraison tres rapide seulement 2 jours
le son me parait tres bien j ai gagne en ampleur et en spatialisation en hc
par contre aucune amelioration notable en hifi mais ca me surpreends pas mon integre yamaha est assez puisant en stereo
Marc L.
conforme
Article reçu rapidement. Des papiers de protection pénibles à enlever. Pas de notice de montage mais des détrompeurs partout. Il n'est pas possible de se planter. Ma méthode a été de vouloir monter à l'envers donc allo boss vers le bas. Je note qu'il n'y avait que 3 vis au lieu de 4 mais qu'à cela ne tienne. Ce prix est imbattable et surtout, nous pouvons être sûrs que audiophonics a vérifié le produit avant de le proposer. 20/20
Didier L.
Based on favorable reviews; I decided to buy the Loxjie A30.
https://www.audiosciencereview.com/forum/index.php?threads/loxjie-a30-amplifier-review.17547/
Since I wanted to buy from a reseller inside of the EU; I placed
my order at Audiophonics. With this decision I was very satisfied.
Due to the december holidays and the COVID-19 pandemic; shipping from the manufacturer in China took more time. To my delight, this was clearly communicated by Audiophonics via e-mail. When the Loxjie A30 was available; I received a postal tracking code and less than a week later the Loxjie A30 itself. The Loxjie A30 was neatly packaged and functions as reviewed and advertised.
jean-yves c.
pieds aluminium
Livraison très rapide . Produit de très bonne qualité .supporte bien les appareils hifi
François K.
Pas encore testé mais une patte de fixation a été endommagée durant le transport. L'emballage de transport était très light !
Yves R.
Dual Linear Power Supply Module LT3045 LT3094 +/-15V This dual regulated linear power supply module provides a clean and stable DC electrical signal with a noise level close to 0 by using a positive LT3045 Ultrahigh PSRR linear...
Fonctionne mais...
Si on alimente en AC la sortie est variable en fonction de la tension d'entrée ??? c'est un down-step donc faut entrer plus de 15v ?pour du +-15v?. Dommage que les résistances de contrôle soient aussi petites: changement compliqué pour moi, j'aurai bien préféré des résistances réglables pour ajuster pile-poil.
Yves R.
moyen
N'est pas aussi ouvert que le NE5534p ou l'OPA 627 sur mon système. Mais bon ?
Yves R.
Bien reçu
Bon comportement sur mon système, mais il ne semble moins précis que le NE5534p (qui est évidement plus métallique), plus "rond".
Jean-Luc B.
Audio GD A 1
Dès les premières heures d'écoute cet ampli montre qu'il est taillé pour la musique !
Utilisé dans un système dématérialisé ; c'est une image très large avec plein de détails , une belle bande passante et de l'épaisseur dans le message !
Plutôt neutre et dynamique , il donne la place à chaque musicien , que du bonheur , fortement conseillé !
Didier P.
DAYTON AUDIO CE32A-4 Mini Speaker Driver Full Range 2W 4 Ohm 81dB 240Hz - 20kHz Ø3.2cm This Dayton Audio CE32A-4 mini speaker is designed to meet a variety of needs with a wide frequency response range. It is particularly suitable for small DIY designs
HP de remplacement
Petit HP pour réparer les 2 HP satellites HS d'un ensemble JBL CREATURE. Après avoir raboté les coins du hp il s'est parfaitement intégré au chassis de l'ancien HP. Depuis mon système JBL fonctionne parfaitement tout cela pour un prix plus que modique.
Très satisfait de mon achat reçu très rapidement
Andrejus V.
Excellent.
Tom O.
Mr.
Received in very quick time in Ireland and everything was perfect. You get full marks from me.
Tom
David b.
PANASONIC FC Low ESR Capacitor 25V 100μF Panasonic FC capacitors benefit from a high design quality and a low ESR. They will be suitable for most of your projects, whether for DIY creation or as a replacement for...
pour ne pas se tromper
je pose des muses pour toutes la partie signal et des panasonic fc sur la partie accessoire (moteur, affichage si il y en a ).
il y a le plaisir de travailler avec du bon matériel et ces condensateur en font partis. La surprise de découvrir un nouveau son surprenant quelque fois.
David b.
PANASONIC FC Low ESR Capacitor 100V 4.7µF Panasonic FC capacitors benefit from a high design quality and a low ESR. They will be suitable for most of your projects, whether for DIY creation or as a replacement for...
Juste pour le plaisir
J en ai même mis pour l'alimentation des accessoires de mon arcam alpha 9 comme les moteurs du sélecteur et volume. Aucun effet sur le son mais c'est beau..
David b.
euterpe est là
Le rodage c'est vrai, ils sont un peu chers, cela vaut le coup. un upgrade d'un deuxième arcam alpha 9 tout en muse et elna sur monteverdi me donne le frisson.
Comme toutes les muses, c'est cher et long à faire mais cela en vaut vraiment la peine.
David b.
NICHICON ES MUSE HiFi Audio Capacitor 35V 10μF Nichicon electrolytic capacitors of the ES Muse range are specially designed for HiFi use. They therefore offer excellent performance and are ideal for use in audiophile...
comme son grand frére de 100 micro farad
J 'en ai mis partout sur un arcam alpha 9 utilisé en ampli seul car le sélecteur de sources est très difficile à réparer.
En ces temps de confinement, l upgrade d'ampli "vintage" avec ces muses me font découvrir mes chaines. Vivement recommandé
David b.
NICHICON ES MUSE HiFi Audio Capacitor 35V 100µF Nichicon electrolytic capacitors of the ES Muse range are specially designed for HiFi use. They therefore offer excellent performance and are ideal for use in audiophile...
attention incroyable
sur un arcam alpha 9, ils ont remplacés deux rubicons qui avaient presque 20 ans. Comme l ampli a entièrement était reccapé, , c est l'effet cumulé mais au vu du prix dépensé , je suis très satisfait du résultat.
David b.
ideal pour recap un ampli agé
Utilisé une première fois sur un vieux Technics puis sur un arcam alpha 9 , les résultats sur la tenue dans le grave sont probants bien que les rubycon d 'origine aient peu dérivés.
Dans les deux cas ils ont du êtres placés à horizontale. le passage de 10000 à 15000 est parfaitement supporté par l'alimentation en effet le peak lcr me donne 12 000 micro farad au lieu de 15000. Correct
Mickaël D.
DAYTON AUDIO HDN-8 Speaker Driver Exciter Bodyshaker Full Range Weatherproof 50W 8 Ohm 40He - 15kHz Ø10.2cm A weatherproof electrodynamic exciter that can be placed virtually anywhere, Dayton Audio's HDN-8 literally makes any surface "ring". The product is...
Vraiment satisfait de mon achat. Les aigus et les basses sont bien retransmis.
Le SAV est très réactif.
stephane j.
BEAU LEU AZURE , LEDS FIABLES ;VENDEUR :SÉRIEUX , PROFESSIONNEL
TRÈS , SATISFAIT !! Conseiller a tous passionnés et collectionneurs .
Qualité
Très bon câble, très bien construit et bien fini, parfait pour des liaisons symétriques de bonne qualité.
Très bien, puissante et efficace, câble Jack un peu court, dommage qu'elle ne puisse se démonter pour le rallonger.
