IAN CANADA LIFEPO4 MINI PRO Battery Power Supply Module 3.3V
The Ian Canada LifePO4Mini Pro 3.3V is a well-designed, next-generation pure power supply module. It has many new features and is a major step forward from the current LifePO4 Mini series.
Reference : 21353
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 13-11-2026.
Ian Canada LifePO4MiniPro Battery Power Supply Module 3.3V
The LifePO4Mini Pro 3.3V uses four 18650 batteries in parallel to achieve a maximum capacity of 8000mAh with extremely low output ESR. Thanks to the USB-C PD (Power Delivery) protocol, 12V/9V fast charging mode is activated when a compatible USB AC adapter is connected. In addition, a Super-Pure mode (UPS mode) is introduced for the first time to enable it to function as an ultra-pure power supply without AC/DC input for noise-sensitive applications.
Furthermore, since this is a purely passive power supply, there is no feedback or active components involved. The sound quality of sensitive audio applications such as low-jitter clock oscillators, DACs, FIFOs, and many other circuits will benefit from this LifePO4Mini Pro power supply.
Thanks to this new state-of-the-art LifePO4Mini Pro 3.3V power supply, many high-end digital audio DIY projects can be carried out in a more professional manner.
18650 LifePO4 batteries are sold separately.
Be careful not to reverse the direction of the batteries.
Key features:
  • 8000mAh (4x 18650 LifePO4 batteries).
  • Current capacity of 12A continuous and 50A dynamic.
  • Actual output ESR measurement @ 1kHz: 6.1mOhm (fuse bypass) / 8.9mOhm (with default 12A fuse).
  • In “Pure-Mode,” the outputs are completely isolated from the input. There is no ground loop.
  • Can be powered by a 6-12V AC or USB-C DC power supply.
  • USB-C PD 9V/12V protocol for fast charging.
  • Super-Pure Mode (UPS): Can provide pure battery output even without mains power.
  • Rewritable fuse with very low ESR: no need to replace fuses.
  • Independent low ESR output connectors for positive and negative terminals.
  • Internal and external on/off switch.
  • Input (isolated) and output of the ON/OFF control chain.
  • SYNC IN/OUT charging (isolated).
  • Low-current (100mA) 5V AUX output to provide an additional 5V output.
  • 3.3V output.
  • Can be upgraded to a hybrid supercapacitor/battery power supply when used with a UcConditionerPro 3.3V or UcHybrid.
  • Has both switched and continuous outputs.
  • Protection mode to prevent battery depletion or low output voltage.
  • Four-layer printed circuit board design with two additional layers for low ESR and high current and additional shielding.
  • More compact design.
  • The mounting screw positions are compatible with Raspberry Pi-sized circuit boards (HAT).
  • Precision manufacturing.
Product typeBattery power supply module
Batteries4x 18650 2000mAh LifePO4 (sold separately)
Supply voltage6-12V AC or 5V DC via USB
Output voltage3.3V
Output current12A continuous
50A dynamic
ESR @ 1kHz6.1mOhm (fuse bypass)
8.9mOhm (with 12A fuse as standard)
Power input connectorUSB-C
USB protocolUSB-PD (Power Delivery)
Chargin syncIn / Out
ON/OFF control chainIn / Out
Auxiliary output5V 100mA
Dimensions130 x 67mm
Mounting holes spacing58 x 52mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)3.3
Output current (A)240.0
Input voltage (V)5.0
Input voltage (V)12.0
Input voltage (V)9.0
Power SupplyBattery
The Ian Canada LifePO4Mini Pro 3.3V is a well-designed, next-generation pure power supply module. It has many new features and is a major step...
