Laurent B.
Bonne upgrade
Hans B.
Patrice L.
Un produit bien conçu.
Customers reviews - There are 19358 reviews.
laurent C.
excellente qualité
Finition et qualité du produit
laurent C.
OYAIDE NRF-005T Noise Suppressor Adhesive Tape Pulshut 4m Oyaide NRF-005T is a noise suppression tape using PULSHUT® (high performance non-woven textile) material developed by Asahi Kasei Corporation. This is a revolutionary...
utile ou pas ?
Personnellement, je n'ai pas noté d'amélioration concrète ou audible avec ce produit
Claus O.
The best purchase I've made in many years
I have heard many more expensive power cables and there has been an improvement in the sound, but this cable is to date the one that has given me the biggest improvement for the least money, in comparison to the Swedish SUPRA power cable which I have paid significantly more money for does not have the improvement in the sound at all, I immediately experienced an improvement in the bass, midrange and upper treble and 3D was fantastic, the only negative thing I can say is that it had a little emphasis in the upper treble, I could not hear that before... I do not hesitate to recommend this cable to others who may be skeptical about whether there is really anything to gain from power cables mounted cable with Oyaide plug P-046E & C-079. they were so fantastic that I compared it with the Power cable from LessLoss which costs 10 times the price, here LessLoss was a little better, but the tonal character was similar
regards Claus Olsen
Marc M.
SHANLING M1 PLUS DAP High Fidelity Digital Music Player DAC ES9069Q Bluetooth 5.2 LDAC 32bit 768kHz DSD512 Silver Shanling's M1 Plus is a technical and aesthetic evolution of the M1S high-fidelity digital music player. This Plus version benefits from an improved digital/analogue conversion...
Excellent DAP
Excellent DAP : neutre, belle image stéréo, tonailté parfaitement équilibrée, aucun bruit de fond, en bref, le nirvana tel que je l'imagine.. Je l'utilise avec un Moondrop Starfield et l'ensemble est magique . Egalement une fonctionnalité intéressante : arrêt programmable : idéal pour les utilisteurs qui, comme moi, s'endorment avec de la musique !!
Les bémols : autonomie un peu limitée (7 heures environ avec prise 3.5 mm), et prise casque semblant un peu "loose" : A voir dans le temps.
Marc M.
bien pour un DAP d'appoint
Ce DAP est parfait sauf sur un point : aigus assez prononcés et difficilement régalbles avec l'EQ. Fonctionne bien avec un casque Truthhear x crinacle Zero, ce casque ayant des aigus assez doux d'où un équilibre tonal correct. Donc attention au casque utilisé.
Je'utilise donc ce combo en ballades avec l'immpression de ne rien avoir en poche du fait de la taille de ce DAP.
olivier r.
Rendu très flatteur mais coloré
Monté par sertissage sur fiches Viablue, écouté pendant trois jours.
Système à moyen rendement enceintes 94db et amplification à triodes EC33C en SE. Source CD et streaming.
Premières écoutes un déconcertantes car rendu très flatteur dans l'aigu, avec beaucoup de présence, de détails et de relief dans le grave et le médium. C'est en passant plusieurs oeuvres de sonates pour violon et piano (CD labels Calliope, Paladino, Deutsche G et streaming) que je comprends que ce rendu fleuri dans l'aigu rend toutes les oeuvres semblables avec une sonorité des violons systématique et un peu "électronique". J'appelle cela une coloration, même si dans ce cas précis, plutôt discrète car on ne ressent pas de voile sur le médium, qui s'en retrouve pourtant un peu freiné, matifié. Plusieurs allers retours de cables sur l e long confirment mes impressions initiales, l'écoute me fatigue et m'agace. Cela pourra convenir à certains, mais pas à moi, je retire donc ce cable de mon système pour revenir à un rendu certe un chouilla plus cru, mais plus naturel et vivant.
super génial
Après avoir commander le cable hp Ludic carbon franchement c'est top que du bonheur allez y les yeux fermer sans regret année 2025 merci
Olivier B.
Étonnants !
Ils ont remplacé avec bonheur les aop d'origine dans mes blocs mono Fosi Audio V3 et dans mon DAC Topping D10s.
Grosse évolution de la qualité sonore dans les 2 cas, désormais je ne me pose plus de questions sur d'éventuels upgrades de ma chaîne hifi, j'écoute la Musique.
Olivier B.
Très étonnants !
Pour faire au plus simple, ils remplacent sans discussion mes blocs mono MC30 Mcintosh. Je redécouvre toute ma discothèque.
Karim M.
Excellent câble pour HP
Le câble Mogami 3082, que j'utilise pour mes câbles de modulation comme pour les HP, étant en rupture de stock temporaire sur notre site préféré, je me suis laissé tenter par le Neotech NES-5009 pour essayer ce cuivre breveté monocristallin qui m'intriguait. J'ai recâblé avec des Celestion Ditton 9 SE de 1995, recapées, puis l'ai comparé au câble français ELBAC HP225C (1.8e/m). La différence de prix (4 fois plus cher) est complètement justifiée.
Ce câble japonais est excellent et musical, équilibré, précis dans la séparation des instruments et leur timbre, très dynamique mais doux et offre une énorme image sonore qui efface les enceintes au profit d'une présence acoustique et une transparence enthousiasmantes.
Je partage donc ce coup de cœur avec d'éventuels audiophiles aventureux, curieux de découvrir ce brevet japonais de cuivre ultra pur qui ne me semble pas du tout marketing, pour le coup, et vais en recommander, avec du Mogami 3082, pour comparaison.
Il faut préciser qu'il est difficile à dénuder car très solidement fabriqué - et joli en bleu. Un coup de briquet sur la partie de gaine à enlever fera gagner du temps sans abîmer les micro-fils.
En bref, excellent câble pour câbler en interne et en externe des enceintes qui le méritent. Les Ditton 9 SE se sont réveillées de leur long coma et donnent tout, joyeusement, grâce à ce câble de première qualité.
Commandés mercredi, reçus vendredi en montagne. Merci à Audiophonics.
PS : pour les intéressés, détails de l'installation et du morceau test :
Lecteur CD Denon DCD685
câble de modulation en Mogami 3082 (20cms*2), âme centrale plus, tresse moins et fiche RCA or)
ampli vintage Luxman L215
câble HP Neotech NES-5009 en deux fois un mètre, sans fiches bananes
Frank Zappa and the Mothers of Invention - album One size fits all. Morceau Inca Road. Blues baroque survolté.
Appareils et câbles japonais, enceintes anglaises, musique américaine et auditeur français : la musique ne connaît aucune frontière!
Karim M.
Câble correct pour son prix
Acheté pour essai (prix : 1.80e/m, retours et marque française) ce câble, très facile à dénuder, est tout à fait correct pour son prix. Montés en un mètre de longueur derrière un lecteur CD Denon DCD685, un ampli vintage rénové Luxman L250, précis et puissant, et sur des enceintes Celestion Ditton 9 special edition, recapées et recâblées, ils m'ont semblé déséquilibrés au profit des basses fréquences, un peu grasses et trop peu définies à mon goût. L'image stéréo est cependant très bonne, ouverte et présente et les autres fréquences mieux rendues, avec un léger voile et un léger manque de précision. Pour le prix, ça sonne tout de même bien. Mais j'ai aussi acheté 2 mètres du câble Neotech NES-5009 (même section de 2.5mm, à 7.9e/m) pour comparer : la différence de prix est largement justifiée : le câble japonais, utilisant un cuivre monocristallin breveté qui m'intriguait, enterre le précédent de manière très sensible. Avec exactement le même montage et le même morceau très chargé et dynamique (Zappa and The Mothers of invention, inca road de l'album One size fits all), la dynamique est supérieure, l'image sonore homogène et très définie, les instruments parfaitement détourés (et ils sont nombreux) et les étagements sonores très précis, au profit d'une image stéréo ample et vivante, avec des basses tendues et chantantes, des médiums moins en avant et des aigus plus soyeux et plus du tout métalliques (tweeter à dôme en titane). C'est avec ce câble neotech que j'ai recâblé les Celestion Ditton 9 et j'ai bien fait car il est tout simplement beaucoup plus musical et agréable à écouter.
En bref, le câble Elbac HP225C est à réserver, d'après mon test, à une installation manquant de basses, par exemple de petites bibliothèques comme les Eva de Davis acoustics ou équivalentes et un ampli comme le Pioneer A-209R (assez sec) ou équivalent. Avec cet ensemble moins précis, ce câble est tout à fait satisfaisant et ses défauts corrigent ceux des autres éléments.
RICHARD L.
Le courant passe.
Prise très qualitative, c'est du sérieux et c'est aussi du lourd, ça pèse, la plaque frontale est très épaisse aidant probablement à une réduction des ondes électromagnétiques. L'arrière de la prise n'est pas plus profond qu'une prise Legrand standard. Les borniers sont assez grand pour accueillir chacun 2 fils de 2,5mm² (voir plus). Concernant le son, l'apport est indéniable, on perçoit une scène sonore plus profonde, la micro dynamique est améliorée, des micros informations apparaissent, les voix sont mieux incarnées. Il faut attendre quelques jours en laissant les appareils allumés pour que tout s'installe complètement. Je n'ai pas essayé les prises japonaises, mais le rapport qualité/prix de celle-ci est excellent. (Cable Furutech Empire, Furutech TP80ES NCF, Chrord Qutest, Primaluna Dialogue II, Cabasse Sampan 311/13.
Leandros B.
A real upgrade!
I use them at my triangle genese lyrr crossovers as an upgrade.
Simply excellent!
Leandros B.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 68µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
Excellent vfm
I use 4 of them at 68μf as an upgrade for my triangle genese lyrr crossovers at the woofer and midrange section. The sound now its more natural, full, clear and dynamic then before. Worth every penny
vincent r.
Marche très bien est stable, par contre mettre sur streamer une alimentation externe (iFi audio iPower2 (5V)) pour gagner en finesse de restitution.
Excellentes fiches bananes
Déjà acheté plusieurs fois et toujours satisfait de cet excellent produit
Patrice M.
SMSL DO400 DAC ES9039MSPRO Headphone Amplifier XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 MQA-CD Black SMSL unveils the DO400, a powerful, high-quality DAC/headphone amplifier. It incorporates quality components such as the latest ESS...
Acheté pour piloter une Beyerdynamic DT1990 Pro 250 ohms.
Cet ampli Dac le pilote sans aucun problème. Le son est clair et détaillé. La scène sonore est large et on distingue avec précision tous les instruments sur la scène. Combo à recommandé sans réserve.
bruno j.
câble pré ampli
très bon câbles ,donne plus de détails et de basses alors qu' il n ai pas encore rodé, je pense déjà en acheter un autre pour l'ampli de puissance
Jean-Pierre B.
JANTZEN AUDIO 000-1862 4N Copper Air Core Wire Coil 15AWG 0.91mH High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications.  The coil benefits from a modern design, self-supporting and with a low tolerance...
Utilisé en parallèle Filtrage HP Médium/Aigu c'est juste parfait ! Pas besoin de se ruiner avec d'autres Selfs beaucoup plus chères. De plus, permet facilement de dérouler pour mettre à la valeur voulue/désirée spécifique. Le Top = Noyée dans de la résine durcissante et c'est un MUST ! Qualité du fil = carrément excellente !
Merci AUDIOPHONICS;
Jean-Pierre B.
NEOTECH STDCT-14 Hook-Up Wiring Multi-Strands UP-OCC PTFE 2mm² The STDCT cable wire is a very high quality multi-core cable with 99.99998% pure UP-OCC copper conductor and PTFE insulation. Ideal for efficient internal wiring.
Toujours Excellent !
Ce câble est simplement un : 'assurance tout-risques' !
Utilisé en câblage Filtres HP Médium/Aigu dans du très haut rendement = c'est tout simplement excellent ! Sans parler du rapport qualité//prix, Irréprochable : c'est LE câble qui sonne sans artifice /rajout dès les premières minutes, cependant après une dizaine/vingtaine d'heures et c'est encore mieux !
Merci AUDIOPHONICS pour ce genre de genre de bon/excellent plan.
Jean-Pierre B.
MUNDORF L250 Air Core Coil 2.5mm 1.2mH Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this...
Un Must !
Belle 'bestiole' ! Vaut bien son pesant ! Résistance très faible
Y'a mieux, certes : la L340 ...mais l'écart de qualité vaut-il l'écart de prix ?!...
Jean-Pierre B.
Excellente fabrication/Qualité.
Très belle fabrication, du solide, ça respire la qualité.
Le diamètre des trous et le serrage des câbles est parfait !
Et la longueur permet de traverser un panneau de MDF de 25 mm sans problème.
Je recommande vivement, surtout vu le rapport qualité//prix !
Thomas V.
Extensible Braided Sheath Nylon (PET) 15-25mm Black This black braided sleeving made of PET (Polyethylene Terephtalate) single strand can be used for many applications.  Thanks to its expandability, the unique braiding of...
très bien, excellent RQP
Fait le job. Résultat très proche de la viablue à 8 euros la mètre.
Thomas V.
trop chère
Gaine très proche de celle vendue à 1 euro le mètre. Prix non justifié.
1 an d'utilisation
équipé d'une schuko furutech FI-E46 NCF (G) et d'une iec FI12 L , le budget a explosé mais ce câble est excellent. Pas la moindre coloration (contrairement aux câbles furutech). Il est très naturel et se fait oublier; fin et aéré, sans la moindre dureté (associé à un in400se Atoll) et un grave propre. Sur mon intégré précédent le résultat était tout aussi équilibré.
Vincent B.
Excellent câble avec une plus value après rodage
Ce câble est d'un excellent rapport qualité/prix. Au début quelque peu déçu par la sonorité un peu "plate" mais force est de constater qu'après plus de 20 heures d'utilisation entre le lecteur CD et le DAC: chaleur, détails, finesse des aigus sont bien présents. Je pense qu'il vaut des câbles bien plus chers. Encore merci à AUDIOPHONICS!
François R.
Super câble!
Très content de cet achat:ce câble remplace avec bonheur mon prédédent cable optique (il est vrai à 6 euro et en PMMA ) pour relier un lecteur de réseau avec un ampli avec DAC incorporé.Brillance , clarté , précision .A recommander
FRANK D.
Spade to Speaker Terminal Banana Adapter 24k Gold Plated (Pair) These speaker cable adapters transform a 4mm banana plug into a speaker terminal spade. This will enable you to easily adapt your banana...
Coup de genie?
Sans doute que oui si ce n'est que les fourchettes sont legerement hors norme.
Juste un poil pas plus mais suffisant pour que ca ne rentre pas sur des borniers de haute precision.
Sinon, ras.
Encore merci a toute l'equipe Audiosonics !
Panagiotis Z.
SHANLING EH2 DAC R2R Headphone Amplifier Transistors Bluetooth 5.2 32bit 768kHz DSD512 Black With the EH2, Shanling presents a desktop DAC and headphone amplifier that's intended to be the successor to the Shanling HE1. This evolution incorporates digital/analog...
Excellent (with one easily fixable caveat)
I am impressed with the EH2. I wanted a small, flexible all in one device for headphone listening on my desk. So that I do not have to fire up my more powerful class A dacs and amps for a spontaneous ad hoc listening session. I got exactly that and more.
Driving power
With sensitive iems it has no audible background noise.
I like to hear my music loud and this little dac-amp delivers. Full sized headphones are driven very well – both high impedance dynamic and low sensitivity planars. It can get my Verite Closed and my Arya Organic to very loud levels where I can feel the physical rumble on my ears without any distortion (knob range between 12 and 3 o clock). In comparison my FiiO K7BT can drive the Arya Organic, but if I push the volume any louder it’s protection circuit kicks in and shuts the device off (with red error LEDs). This did not happen with the EH2 (as to be expected: the EH2 has ~4000mW, double the value of the K7 with ~2000mW).
Tone controls
The tone controls are a nice addition. Fine adjustments in bass and treble are immediately noticeable. Turning the bass to the max would satisfy bass heads. The tone control knobs have a notch in the center that you can feel. In this position the tone alterations are completely off. It’s there if you need it, but you don’t have to use it.
How does it sound?
Nowadays the quality of dacs, even in the lower price segments, has vastly increased to the point that it is difficult to notice differences between dacs. Headphones are the most important factor in the chain. With that aside, yes the R2R dac of the EH2 sounds excellent. It is very clear, detailed, smooth and at the same time full sounding with a nice note weight. No harshness, noise or distortion whatsoever.
Notes
- It produces no pop noise when turning on or shutting off like some other amps.
- Even after many hours listening it does not get very hot, only hand warm.
- Plugging a headphone cable in the front shuts off the line/pre-outs in the back. So if you want to use it purely as a dac to other amps you have to detach any headphone cable in the front.
- The tone controls (bass, treble) also affect the pre-out in the back, but doesn’t alter the line-out (when the switch is set to line-out).
- The small blue LED above the power button is always on, even in standby mode.
- It is very small, about the size of an adult human hand.
Caveat: standby mode is useless
When the EH2 is turned on and not playing music (idle) it consumes about 5 Watt.
In standby mode it still consumes about 4 Watt doing nothing! This mode might as well not exist.
The FiiO K7BT consumes 0 Watt when turned off.
My solution:
As a workaround I plugged a simple power switch between the power supply and the EH2 power socket.
Now I do not use the standby button at all. I turn the EH2 on and off only with the power switch. When it receives power it automatically turns on, no need to additionally press the power/standby button again.
This is working great.
EH1 vs EH2
If you are on the fence about choosing the smaller EH1 or the EH2. Get the EH2. For the extra money you get a lot more: headphone driving power, a real R2R dac instead of delta sigma, more inputs (coax, opt, Bluetooth) and a balanced output. It can drive anything from iems to full sized headphones with no issue. Even if you plan to only listen to easy to drive iems, the EH2 is more future proof with its plus in power and flexibility.
This is a fantastic little powerhouse all in one. It fits many use cases. Headphone all in one, pure R2R dac, tone adjustments, BT receiver, TV Audio via optical input. Small enough for any desk space. Even if one owns bigger “normal size” dac and amp stacks this is still worth getting as a flexible desk device for the office or another room.
Price to performance is very high. I think Shanling priced this aggressively low, to get new customers to know the brand.
I’m glad that it exists. Highly recommended!
Panagiotis Z.
Driving power
Tone controls
How does it sound?
Notes
My solution:
EH1 vs EH2
Etonnant pour le prix
Ce câble n’enlève rien et ne rajoute rien
Aucune différence de son comparé a mes autres câbles
A essayer avant de dépenser de l'argent inutilement
De plus très bien construit agréable au toucher et facilite de mise en place car il se dénude facilement
Dominique G.
LHY AUDIO LPS160VA 12V Linear Regulated Low Noise Power Supply 230V to 12V 9A 160VA This LHY Audio LPS160VA regulated linear power supply provides great stability for any high-quality audiophile DIY project. All the necessary technical...
ALIMENTATION LPS160VA 12V
Commande passée le 24 Février, enfin reçue le 20 Mars.
1 Mois, c'est franchement exagéré, surtout que l'argent est encaissé à la commande. Il pourrait faire un geste commercial sur une prochaine commande.
Heureusement pour Audiophonics, les produits sont de qualités et à part une personne qui m'a fait comprendre que si je n'étais pas content je pouvais annuler ma commande et l'acheter ailleurs, les autres personnes avec qui j'ai échangé techniquement ont toutes été sympathiques et professionnelles.
Dominique Guion.
Peter R.
AMPHENOL AC3MMDZ 3 Poles male XLR Socket Silver Plated This Amphenol AC3MMDZ 3-pin male XLR socket features silver-plated connectors for maximum conductivity. The nickel-plated body, meanwhile, provides unbeatable durability and...
A good and sturdy XLR connector.
Delivery was prompt.
Many thanks to Audiophonics. A reliable company.
Peter R.
EXICON ECX10P20 Transistor MOSFET (2SJ162) Exicon MOSFETS have been specifically designed for high power linear use. They offer high voltage capability, high slew rate and low distortion, making them the ideal choice for...
replacement type
I used the ECX10P20 transistor as a replacement for the discontinued SJ162 transistor to fix a problem with our power amplifier in the KS SAT MKII PA system. It works perfectly without any circuit modifications.
Replacement type
Peter R.
EXICON ECX10N20 Transistor MOSFET (2SK1058) Exicon MOSFETS have been specifically designed for high power linear use. They offer high voltage capability, high slew rate and low distortion, making them the ideal choice for...
replacement type
I used the ECX10N20 transistor as a replacement for the discontinued SK1058 transistor to fix a problem with our power amplifier in the KS SAT MKII PA system. It works perfectly without any circuit modifications.
Replacement type
Remus C.
FX-AUDIO DAC-A10 DAC ES9018K2M Tube Preamplifier 6N3 Bluetooth 5.1 aptX HD LDAC 24Bit 192kHz FX-Audio's DAC-A10 is a versatile, high-performance tube DAC/preamplifier with a relatively compact form factor. It is based on quality components such as an ESS ES9018K2M DAC...
Rapport qualité prix imbattable, la qualité d'écoute sera au rendez vous à seule condition de changer les tubes chinoises fournies par des tubes russes série militaire, la différence tant vraiment notable. Fabriqués selon des cahiers de charges plus exigeantes au niveau endurance, les tubes russes série militaire 6N3P-E (6Н3П-Е) chauffent moins. La puce de réception Bluetooth 5.1 QCC5125 de chez Qualcomm qui permet au DAC-A10 de supporter les codecs Bluetooth haute résolution : SBC, ACC, aptX, aptX LL, aptX HD et LDAC est un plus. Ecoute sur casques Sennheiser HD 650
Gabriel G.
LHY AUDIO LPS50VA Linear Regulated Low Noise Power Supply 230V to 5V 2.5A 50VA Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply...
Alimentation linéaire
Amélioration par rapport à ma précédente alimentation linéaire. Je l'utilise pour alimenter un rpi5 (6.5A 5V)
Mikael M.
HIDIZS MP145 In-Ear Monitor IEM Planar Magnetic 30 Ohm 104dB 20Hz-40Hz Titanium The HIDIZS MP145 in-ear monitors are IEMs with an ultra-wide 14.5mm planar magnetic driver. They feature an audiophile design with no less than 7+7 N52H magnets. In terms of...
Duo mp145 & Penon audio liqueur O
Ne sous-estimer pas ces écouteurs ! Une foi trouvez les bon emboue , le son est énorme !
J'ais essayé les Dunu S&S ... La bass n'est pas de trés bonne qualité ...
Penon liqueur B .... Boff
Penon liqueur O : Excellant !! Spécialisation , bass , sous bass ( infra ) pur ! Avec filtre gris ( équilibré ) , il est muni de filtre rouge pour encore plus de basse .
En comparaison avec les Focal Elegia , hifiman Arya , Dt 900 x rien ne m'a procurer du plaisir ,
le mP145 et Penon O est mieux pour moi .
Seul le EMU TEAK est aussi bon en basse fréquence ... Et apporte également une meilleur image et scene sonore ... En revanche , l'Emu est moin vif , moin dinamique ( plus doue ) .
Le planaire du hidizs lui donne certaine avantage .
Source qobuz + UAPP en mode Bit perfect + Aune Yuki + topping NX7 .
Ne compté pas en retiré le meilleur de cette écouteur avec un simple d'ongle . ( 30 ohms )
Samu T.
Difficult solder
Difficult solder coax cable ground to that wide tiny hole. Plug is not attractive to magnet and that is very good.
PIERRE R.
XANGSANE XS-5N Banana Speaker Cables OCC Copper Silver Plated 2m (Pair) Xangsane's XS-5N speaker cables are made up of 12 strands of silver-plated 5N single-crystal OCC copper to ensure electromagnetic impermeability and perfect conductivity. Each...
câble xangsane XS-5N
Excellent produit qui donne une reproduction remarquable du grave à l'aigu avec de la dynamique et de la précision . C'est mon meilleur à ce jour !
Kimmo A.
Great
Works great, good value for the price.
Jean-Pierre f.
AIYIMA T9 Amplifier TPA3250 Tubes 2x 6K4 Bluetooth 5.0 2x60W 4 Ohm The Aiyima T9 is a versatile and affordable integrated amplifier, ideal for setting up an audio system without breaking the bank and without multiplying the number of devices....
perplexité et mise en garde
Une seule étoile car j'y entends plus d'inconvénients que de plaisir, même à ce petit prix.
D'abord, le plus gênant, c'est ce volume sonore quasi incontrôlable à l'écoute de la plupart de mes CDs et flac, mes 2 principales sources de musique. Aiyima me dit qu'il n'y a pas de mise à jour possible sur le fait que l'avant-dernier cran du volume sonore reste trop élevé. Un cran de plus, et le son est coupé. La seule façon d'y remédier est de passer par l'ordinateur, où il faut y baisser le son interne pour pouvoir ensuite contrôler celui du T9, dommage. Ce "détournement" permet quand même de profiter des radios internet via l'ordi ou de Youtube par exemple.
Autre inconvénient, ce clic intermittent et récurrent dès qu'on laisse en veille le T9, qui signale sa mise en pause. Il est léger mais vraiment pas indispensable.
Enfin, il faut absolument changer les tubes et utiliser un DAC externe pour obtenir un son plus acceptable. Malgré cela, la stéréo reste simplement confinée dans les enceintes, sans réelle scène sonore.
Bref, je ne le recommande qu'à certaines conditions d'utilisation et d'exigence musicale.
Pascal G.
Hélas mitigé.
L'appareil en soi est très bon. Construction irréprochable, son à l'avenant, connectique complète.
Malheureusement, pour moi qui écoute beaucoup de SACD, cet appareil n'est pas adapté à cet usage car je n'utilise pas de préampli et donc le réglage du volume sur le DAC est primordial, ce que ce D2R n'est pas en mesure de faire.
En effet, malgré le paramètre PRE MODE sur variable, le volume avec un stream DSD est irrémédiablement réglé à 0.0db, c'est à dire sortie à fond sur mes blocs de puissance ce qui a failli faire sauter mes enceintes.
J'ai contacté SMSL Chine et j'ai reçu la réponse suivante, je vous la livre telle quelle (littéralement) :
"The DSD of D2R cannot control the volume. It is Normal, there is a chip issue". Sans plus de formes.
Ceci est non seulement extrêmement malpoli mais surtout totalement inacceptable d'autant moins que nulle part ce défaut n’est indiqué, ni dans le marketing ni dans la notice sous forme de mise en garde vu les implications potentielles léthales pour vos HP. Que le circuit intégré ne fasse pas le job est une chose, ne pas prévenir le futur acheteur de cette situation en est une autre.
Bref je suis mitigé et ça m’embête car le son en PCM (NAS, Qobuz, transport CD) est vraiment excellent, surtout à ce prix.
J’ai deux autres DAC SMSL, M400 et M500, au demeurant excellent eux aussi. Les deux convertisseurs ont toujours fonctionné sortis de leurs boites sans rechigner et avec tous les formats d’encodage disponibles. Là ce n’est pas le cas et j’en suis navré puisque forcé de le retourner.
5 * pour tout sauf pour la conception (1 *) clairement baclée et la mésinformation inexcusable et dangereuse pour l'équipement.
on a pas sur les mêmes finitions ou design que d'autres connecteurs plus chers mais le rendu sonore est au mois aussi bon voire plus naturel pour 3 fois moins cher...
Olivier L.
L'ampli idéal
J'ai eu pas mal d'ampli et souvent pas 100% satisfait mais là j'ai été convaincu dès les premières écoutes. Le son est fantastique tout simplement.
Autant j'ai été déçu par un ampli comme le topping LA90, qui a de bonnes mesures mais est pouratnt très mauvais à l'écoute.
Je n'ai pas encore le comparer à mon ampli de référence mais je suis super content. J'ai l'impression qu'il est diffcilie de trouver mieux à ce prix.
Marc F.
Super sauf l'alim
Excellent petit ampli, pratique et quasi. Mais l'alim à découpage fait du bruit, j'envisage de la changer pour une autre.
Catalin C.
Incredible
I was a cable skeptic, thinking that a decent cable is more than enough for my KSE1200. I bought NEMOI 1220 cable out of curiosity mainly, after seeing all the reviews here.
Oh Boy, I wasn't prepared for all the changes I've got: more details, fuller and lusher (!) sound with better soundstage. Nothing like what people say about silver cables.
It's true that my previous cable was way cheaper, made with DCA16GA, but still, it's just a cable...
I'm impressed, I wish I tried this cable before.
Thank you audiophonics and to all those who post their reviews.
Impressionnant !!
Dans le cadre d’une évolution progressive de mon système en 5.2 Je viens de m’équiper de 2 bloc mono LPA-M750ET (1ET9040BA) qui sont branchés sur les sorties Pre-Out d’un Yamaha RX3060 (qui a terme sera remplacé par un préampli multicanal plus performant). Mes enceintes principales un peu exigeante (Panneaux Magnepan 1.7i) étaient depuis quelques mois alimentées par un HPA-S500ET (1ET7040) qui déjà m’avait bluffé, mais là avec les 2 bloc mono (choisi pour des questions d’intégration plutôt que la version double mono qui doit avoir le même rendu sonore j’imagine). C’est une autre dimension, séparation des canaux, profondeur, très analytique, je redécouvre quasiment toutes les prises de son. Le réglage du gain est un plus incontournable pour pouvoir associer ces amplis avec les sorties pré out du Yamaha. Le HPA-S500ET est passé sur les enceintes arrière (JMLab Micron Titane) ça les a bien réveillés ! Prochaine étape un bloc mono pour la voie centrale (Dynaudio Gemini). Merci à Audiophonics pour les conseils et rapidité d’expédition.
Pavel Z.
AV
I will write one review for all ordered goods.
I appreciate a very good approach to the customer in an effort to help in every situation. Very good communication, responses to questions come almost immediately. Thumbs up. I believe that such an approach is standard.
Goods: I ordered the brand of goods on recommendation. I think it's OK.
Max Michel D.
EXCELLENTE QUALITE POUR AUDIO
Cette soudure est vraiment TOP pour faire vos cables audio.
Qualité d'écoute au rendez-vous sur vos cables.
