Carlos Alberto Rodrigues T.
Awesome piece of equipment
Tobie H.
Richard H.
Dawn Pro by Moondrop
Luc B.
Round Vumeter Yellow Backlight dB Ø45mm (Pair) This round vumeter has a beautiful yellow backlight, ideal for use with an amplifier from 3W to 50W. A controller is already present at the rear, allowing simple wiring.
Vumètre parfait
Bon fonctionnement bien rétroéclairé
Erik J.
Amazing dac, highly recommend
A different kind of presentation compared to smsl m400 or topping, Sabaj a20d.
With tube amp it sounds awesome the other chips like sabre or akm haven't been this good in my system.
Hope they will develop an even better 2 chip design I will buy it emidtaly.
Harry P.
What a Journey
Having had the Asus Essence One DAC for a long time I thought its getting time to try something new.
First I tried Topping´s E50 and yes there was a wow-factor, in comparison the resolution and overall presentation was much better. Later on, I got to hear SMSL M500mk2 and the D300. As E50 and M500mk2 (both ESS Sabre) had been a clear stepup to the Essence One and everything sounded a bit clearer and more open the D300 did something very special, the instruments and voices sound so natural in comparison that its a real joy to listen to music.
What I noticed after using D300 for around a month now is that I listen to music longer or that I listen through whole albums again.
Good job SMSL/Rohm.
Claudio c.
SHANLING M3X Digital Audio Player DAP 2x ES9219C Bluetooth MQA 32bit 384kHz DSD256 The Shanling M3X is a high quality portable music player with a well thought-out and optimized design. It is based on a powerful Qualcomm Snapdragon 430 processor, an Open...
Tres bon lecteur
Coupler à un campfire audio dorado 2020, juste un commentaire, excellent. Pour ce prix rien à redire.
Claudio c.
KBEAR Headphone Cable Jack 4.4mm to CIEM 0.78mm Balanced Silver Plated OFC Copper 1.2m This cable allows the connection of a balanced headphone. With a length of 1.2m, it is composed of two 0.78mm CIEM connectors and a 4.4mm jack connector. Taking advantage of a...
excellent produit et bon prix
Très bon câble à un très bon prix.
Ioannis P.
Well built
Used to power a Melco server. Solid performance.
hubert b.
efficace, mais un rien agressif
J'ai acheté cet ampli pour remplacer un vieux machin hifi que j'avais acheté en brocante et qui m'a laché.
J'écoute souvent de la musique, je ne pense pas pouvoir me qualifier d'"audiophile", mais je suis mélomane, musicien, et j'écoute tres souvent de la musique, avec un esprit critique tout de même. au niveau du matériel, je n'ai simplement pas encore investi dans des articles de luxe.
J'écoute donc ma musique sur des anceintes colonne de bonne facture (un hasard des brocantes aussi), mais j'ai jusqu'à présent été frustré de la dynamique, particulièrement dans le registre grave, en les testant avec les 3 différents ampli -hifi que j'avais à la maison (genre 300€ neuf, amplis de grandes marques habituelles). Avec le FX50, aucun doute, ça envoie, il va fort, et même à volume contenu on sent les coups de grosse caisse, c'est tout ce qui me manquait ! Si j'ai bien compris la classe D donne ces résultats en général. Sans pour autant devenir oppressant, c'est assez aéré, et j'ai entendu plus de détails qu'avec mes autres amplis. Donc c'est plutot bien.
Par contre c'est agressif aussi sur le reste du spectre. avec la musique que j'écoute ( un peu de tout mais particulièrement du rock et du métal progressif), ça devient vite fatiguant. Je n'ai pas eu cette impression sur d'autres enceintes bibliotheque, certainement de moins bonne qualité, avec lesquelles le rendu est très sympa.
Je vais très probablement garder le FX50 pour amplifier les graves de mes colonnes, et utiliser un autre ampli plus "doux" pour les médiums et aigues (les colonnes sont bi-amplifiables). J'ai commandé le MOS 120 d'audiophonics. En classe A/B cette fois-ci, et qui reçoit de bonnes critiques... On verra, et je vais essayer de donner un retours après...
En gros, pour le FX50 : Super, pas cher, puissant, détaillé, dynamique, mais pas pour une écoute trop fine (je ne sais pas comment le dire, mais à mon avis avec des baffles de la même game de prix le résultat doit être vraiment bon)
Très recommandable
Sa fonction ampli pour casques électrostatiques a motivé mon achat.
Un ami m'avait conseillé ce M-03.
Je vais commencer par les défauts: la sortie casque classique sur jack 3,5 est à oublier. Souffle important, mauvaise progressivité du volume, rendu audio décevant.
La prise entrée ligne en façade n'est pas placée idéalement j'aurais préféré en face arrière. L'esthétique générale n'est pas incroyable, si l'on regarde l'ampli portable Stax.
Mais si l'on n'a pas le plumage avec le M-03, sur la sortie électrostatique on a bien le ramage! et avec une autonomie importante.
Donc sur e-stat aucun souffle, puissance très confortable. Un DAP utilisé en sortie ligne attaque avec un bon niveau l'entrée du Kingsound, aucune saturation audible. J'utilise un Stax L300, et un autre casque électrostatique DIY qui a moins de rendement, le M-03 les pilote parfaitement. Le rendu audio est excellent, comparé à mon ensemble sédentaire. Sur le L300 j'utilise la sortie variable du DAP pour avoir plus de progressivité sur le volume du Kingsound, et en début de course déséquilibre entre les canaux.
Olivier b.
1MII LAVAUDIO B03PRO Receiver Transmitter Bluetooth 5.0 aptX HD CSR8675 ADC DAC ES9018 The 1Mii B03Pro is an extremely versatile and high-performance Bluetooth transmitter and receiver at an affordable price. Its intelligent and careful design allows it to ensure...
Efficace et simple
Récepteur efficace et très facile à installer. Je l’utilise uniquement en récepteur Bluetooth, en entrée d’un DAC Benchmark. Le résultat est excellent, aucun souci de connection, très bon rapport qualité prix pour ce récepteur qui passe inaperçu grâce à son petit format.
Carlos M.
petite boite... grand son!!
J'ai du un peu attendre suite à la rupture de stock du PI4... Une fois le colis arrivé le montage est simple et sans difficulté la notice étant claire. Par contre c'est côté soft que j'ai eu des problèmes. Après de multiples essais infructueux je ne suis jamais arrivé à avoir la moindre image sur l'écran. Que ce soit Volumio ou Moode. Contacté le SAV m'a envoyé rapidement un lien pour télécharger une autre version de Volumio. Cette fois tout fonctionne! mais ce n'est pas fini... Impossible de monter mon lecteur NAS (SYNOLOGY DS416) dans la configuration Volumio. L'UPnP fonctionne mais je n'ai pas l'accès direct au NAS pour gérer l'audiothèque. Aucun des modes opératoires de Volumio ne fonctionnait. Alors si comme moi vous êtes bloqué , voici le lien vers le forum Volumio et la solution:
https://community.volumio.org/t/unable-to-mount-the-nas/52054
Après ces épreuves le résultat est là un très beau son, bonne assises des basses, aéré avec bon placement des instruments, dynamique et équilibré. Par rapport à ma chaine peut être un peu moins de rondeur dans les médiums...encore un peu sec, mais après quelques heures ce point s'est déjà amélioré. Assez bluffant au final par rapport à la dimension de l'engin. POur info ma config hifi Cyrus + enceintes Dynaudio. Avec le Raspdac j'ai pris une alimentation faible bruit 5v iPowerX . Cela doit avoir un impact mais je n'ai pas comparé sans elle.
Merci au SAV Audiophonics pour leur aide (rapide!) et bonne écoute à tous!!
marco g.
Game changer
Wow!
Bought this DSP board just for fun...and...it's really a game changer for any DIY project!
I'm using it swapping an Audiocontrol 6XS electronic crossover and driving one of my old DIY speakers (SBAcoustic SB17NRX-C35 + ScanSpeak D2010).
Results are astonishing, not only for the price...
It's really like to play a game setting up serious things like:
All levels +
24dB Linkwitz-Riley Filters +
Baffle Step loss compensation (curve choice via potentiometer) +
Notch Filters +
Time Delay...
Sigma Studio works perfectly and is quite intuitive (from my personal point of view).
Well, for this price it's an incredible product giving Hi-Fi sound quality and...unique DIY freedom!
I hope that in future we can buy also an evolution of this concept with more powerful DSP, direct SPDIF input (+output), different DACs, 2x6...etc.
Great purchase, thanks!
Marco
David S.
MUSICIAN DRACO Balanced R2R DAC NOS I2S The Musician Draco is a fully balanced, high end R2R DAC with high quality components. Versatile thanks to its complete connectivity, it can also work in NOS (Non Over Sampling)...
Approuvé
Préférant le son vinyle, la technologie R2R me réconcilie enfin avec la musique numérique.
Sortie branchée en RCA sur mon ampli hybride, le son est précis, très équilibré, naturel et rempli l’espace de la pièce, contrairement à mon dac ESS Sabre précédent.
Je n’ai pas vraiment compris la différence avec le grand frère Pegasus, j’avais lu sur un comparatif anglophone qu’il est très difficile d’entendre les différences. Peut-être au niveau du DSD, Musician restant visiblement flou sur les spécifications DSD du Draco.
Je l’utilise principalement avec un transport CD Audio Note révisé par mes soins ou un Macbook avec Qobuz .
(Attention pas de télécommande, c’est un dac et rien d’autre!)
En tous cas, à ce prix, il est impossible de se tromper en vu de la qualité de fabrication et du son.
Merci Audiophonics !
Freddy D.
U-Sabre
Reconnu avec difficultés après bien des bidouillages par Windows10 , impossibilité de profiter des meilleures résolution sur Quobuz , reste sur 48K , un peu déçu par le produit ...
Aucun driver n'est nécessaire pour ce produit.
Ce type de problèmes n'existent qu'avec un câble USB trop long et / ou de mauvaise qualité.
Pour une lecture bitperfect il convient de régler le lecteur :
https://www.qobuz.com/fr-fr/info/qobuz-vous/les-modes-de-lecture-du-desktop179381
dans le cas contraire c'est le mélangeur de Windows qui détermine la résolution maximum.
JEAN-MICHEL E.
Exceptionnel
Ce DAC est une merveille ! Combiné à mon Meze 99 Classics Noyer Gold équipé d'un câble symétrique, j'obtiens une restitution sonore de mes fichiers Qobuz on ne peut meilleure. C'est la perfection absolue. Mais je voudrais surtout souligner l'accompagnement technique que m'a fourni Audiophonics pour m'aider dans mon choix (Salut David). Je n'ai jamais rencontré un service technique aussi avisé, consciencieux, patient, réactif et compétant ailleurs. De plus, sitôt commandé, aussitôt expédié. Livré en Belgique en un temps record. À défaut de pouvoir mettre mille étoiles, j'adresse mille mercis à Audiophonics.
Philippe f.
Une valeur sûre
Testé cette semaine sur mon système, ce câble est très musicale.Je recommande.
Jean-Claude G.
CONNEX SMPS300REh Power supply Module 300W +/-30V SMPS300RAh is a switching power module for audio amplifiers requiring high power for extended periods
Super SAV
Je rajoute une étoile à mon avis précédent !
Moins d'1 heure après la rédaction de mon avis où je signalais l'absence de fusible, j'ai reçu un mail du SAV me proposant l'envoi d'un fusible adéquoit.
SUper réactivité. Par ailleurs, les performances de l'alim sont très bonne. Le rapport qualité/prix est excellent
Martin M.
Bluetooth 5.0 Receiver Board QCC5125 LDAC aptX HD aptX Adaptive to I2S This Bluetooth 5.0 receiver module is equipped with the new Qualcomm QCC5125 chip, which supports the high-quality transmission codecs LDAC and aptX HD, as well as aptX...
USB Communication
Search for SJR-BTM525, this is the name of the blue module and find module pinout
To enable USB communication you need to solder "USB_DP" and "USB_DM" to your preferred connector and you must solder/connect "VCHG" to your power voltage, without this the USB is disabled.
I connected "VCHG" to +5V currently working but not sure, maybe you should use +3.3V
PLEASE REFER TO CHIP DATASHEET (not module) TO AVOID ANY DAMAGE!!!
No-one takes responsibility for how you modded this module ;)
Leceur de qualité audiophile
Topping, j'adore et suis leurs produits depuis les débuts.
Look élégant, sobre et efficace.
Ecran certes petit mais pas déplaisant.
Je l'utilise en mode lecteur de fichiers sur clef usb par usb otg ou la microsd.
Il est gapless, mode à activer dans un menu. Il lit un album de façon continue. Lit mes flac avec superbe. Aucun plop.
Sortie puissante sans volume, à raccorder à un dac ou ampli fda ou ayant une entrée coaxial ou optique. Rapport signal/bruit élevé.
Autonome, discret, ne chauffe pas, alimentée par un jack usb vers 54v celà permet d'utiliser un chargeur usb ou une alim de son choix.
Facilement pilotable en bluetooth avec hibylink, c'est stable.
le wif ou mode dlna ne permet pas au lecteur de piloter directement vos fichiers du nas, il faut passer par un smarphone android sur le même réseau et monkey ou autre app dlna. C'est un peu dommage que la pub puisse faire croire autre chose. Courage pour entrer le passe wifi, tout le monde n'y arrivera pas.
On peut lui envoyer des fichiers par bluetooth, il peut envoyer la lecture vers tout dispositif bluetooth, casque, enceintes. Le choix du recepteur bluetooth est rapide par le menu.
Pas exploré le mode dac usb ni airplay.
Un très bon produit à prix contenu par rapport à la concurrence.
PANGEA PREMIER SE Ethernet Cable RJ45 Cat7 Silver Plated Cardas Copper Triple Shielding 3m If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver their full potential. With its...
RQP exelent
Essais fait entre se cable occ pl a 6% Ag pangy et le vialube ofc etamé argent et telegardner metal. Apres ecoute de trois semaine donc bien rodé ils en ressort qq difference. Pangy sais plus naturel et les instruments voix sont plus realiste. Il y a un peit plus du cpté analogique du son, par contre le grave descend un chouilla moins que sur le vialube et est moins aeré et aerien. Je vais essayer de monter des telegardner cat 7 sur les pangy car je pense que les prise du pangy sont bc moins performante dansble blindage se qui pourais etre la seul raison du grave et aeré. Bref en abaissant le bruit. Cela devrais supplenté ée vialube dans ses deux paramettre. Reste que sais une question de goût musical. Question prix ils sont tous les deux exelent. Chaque fr le vaut. J aime bien le vialube entre le modem et le filtre bonn n8. La co entre le bonn et mon streamer se fait avec un neotech neu up occ cuivre. La sais plus cher mais ont touche le ciel. Apres essai via etbpang. Il y a pas photo. Le neo depasse les deux en terme musicalité transparence naturel dynamique et aucun bruit. Extinction de note et un aigus d une douceur devtoute beauté. Le choix se faitbuniquement via le porte monnaie, quoi que pour un suppl de prix acceptable. Je pose pas la question
Changed mind!
I've had the powerstation for 6 months now and have gone back to running power through just a DC blocker. Ultimately, the sound is very refined with the powerstation, but at the expense of dynamics and agility
Jean-Claude G.
Bien mais serait encore meilleure avec un fusible !!
L'alimentation en elle même semble fonctionner parfaitement (je viens seulement de la recevoir) mais ce serait encore mieux si elle arrivait fonctionnelle, ce qui n'est pas le cas car il manquait le fusible secteur que l'on voit pourtant bien sur les photos... Ce serait encore mieux si la valeur du fusible était indiquée sur le PCB ou la description !
Heureusement j'avais de quoi me dépanner, j'ais mis un 3,5AT que j'avais sous la main mais je pense qu'un 2AT serait plus adéquoit. Cependant ce n'est pas très critique pour moi car j'ai des fusibles en amont.
Sinon parfait pour l'expédition : commandé dimanche reçu mardi avec GLS
C'est anormal, contactez mes collaborateurs du SAV qui feront le nécessaire pour vous fournir la pièce manquante au plus vite.
Yi Z.
ROSE HIFI RS250 Lecteur Réseau Audio DAC ES9038Q2M 32bit 768kHz A true audiophile network player, the Rose Audio RS250 combines versatility with high performance, thanks to its high-end DAC and optimized power supply stage. A jewel of design...
Lecteur superbe
C'est un très bon lecteur réseau, son adorable, un joli écran. Une sortie hdmi nous permet de regarder des vidéos sur YouTube sans pub. J'ai mis 4 étoiles parce qu'il a un OS pas vraiment stable, on rencontre souvent des petits bugs, parfois faut le redémarrer. Et il a toujours pas tidal connect c'est nul quoi..... -.-
Radek P.
Great
Change from Atohm Zef Max. Ramm is tighter, more detailed, more dynamic, overall tighter sound. For me use better. The difference is instantly noticeable, it's not nuances. The sound is more dramatic. Some places the bass is a little more, some places a little less, but overall they go lower. Satisfaction. I recommend. Great bi-wi, bi-amp option.
mathieu l.
Philippe f.
En cours de test sur mon système face à un ancien Wireworld Starlight 7.
Il n'est pas aussi bon pour l'instant mais il est très proche de mon Wireworld qui coute 3x plus cher.
Au passage, bravo à toute l'équipe d'Audiophonics pour leur rapidité de traitement et la qualité de leur service.
Bonne continuation.
Marc M.
Super DAC
Très bon DAC. Rien à redire au niverau qualité du son. Seul bémol, une télécommande très "chinoise" : elle marche à conditon de ré-appuyer régulièrement sur le bouton "C". Etant donné le prix du produit, les 5 étoiles sont tout de même méritées.
Cameron C.
Clean power
I'm comparing this amp with two Schiit Aegir's used as mono blocks, fed by a Freya+.
Maybe my speakers need more than the Aegir's can provide (Tekton Electron SE & Tekton Mini-Lore Monitor), but there's just an ease and clarity in the Audiophonics amp that the Schiit doesn't really hit. At least at lower volumes. I'll have to do some more listening. Very very good quality and sound though. A+
Philippe K.
Une référence audiophile...
Très peu d'avis circulent sur ces Amadeus 7 MK II.
Je vais donc tenter de partager mon retour d'expérience sur ces câbles.
Ayant eut en prêt des Siltech LS-100 Classic bi-câblage pendant une année entière grâce à un ami, il était temps pour moi de les rendre et de me pencher sur ses remplaçants.
Mon système étant connecté en Transparent sur la grande majorité de la modulation, il me fallait trouver un câble neutre, s'associant parfaitement à elle.
Je me suis donc intéressé à la technologie présente dans les différents câbles.
Cherchant un modèle bi-câblage, les Amadeus 7 MK II ont retenues mon attention (section des conducteurs, blindage, type de cuivre...)
Une fois la commande reçu, je les aient monté avec des embouts en argent et des fiches bananes au rodhium.
Je les aient câblé en 4 conducteurs au lieu de 6 présents, comme sur les Siltech. Ramm Audio préconise de doubler les conducteurs pour le grave, mais sincèrement ce n'est pas nécessaire.
Il est à noté qu'il faut de la patience et être minutieux pour dénuder et monter l'ensemble.
A la première écoute, une scène ample et large viennent bousculer les Siltech LS-100. C'est impressionnant!
Mais l'expérience ne s'arrête pas là. L'ensemble joue plus dans le médium, ce qui flatte l'oreille, mais avec une douceur nettement supérieur aux Siltech.
Le grave est mieux tenue et bien mieux maîtrisé.
Le détachement des différents plans sonores, la profondeur de la scène sont accentués de manière significative.
Les timbres sont beaux et naturels donnant l'impression d'entendre les instruments plutôt que les enceintes, tout est transparent!
On dit qu'un câble donne 70% de sont potentiel à la première écoute, les 30 autres viennent au fil du temps.
J'ai trouvé ici mon bonheur, qui rend hommage à mes électroniques et à toute l'optimisation réalisée derrière.
Un produit résolument High-End qu'il faut soigner lors du montage pour en tirer tous les bénéfices et que je recommande.
Un référence audiophile!
MICHEL B.
Qualité et écoute parfaites
J'ai acheté ce câble pour relier ma barrette 10 prises Schuko au secteur. La qualité de réalisation est superbe. Le courant est désormais fourni sans problème avec du câble 3,5 mm2. Le résultat est là : plénitude des instruments de musique, image sonore parfaite en 3 D et surtout aucune saturation sur les explosions orchestrales. Merci à Audiophonics d’avoir réalisé ce câble de très haute qualité à un prix abordable. De plus, comme d’habitude la livraison a été rapide.
Timo T.
Love them !!
A friend of mine makes his own cables and sometimes for me too . Neotech all the way , contacts and wires , what a great sound !!!! And thanks to Audiophonics , love your customer service !!!
pedro p.
burr brown remplace na5534
j ai mis ces burr brown sur mon little bear bx4 a la place des 5534 et apres 5 heures d ecoute tous s ameliore et c est pas fini,c est plus doux dans les 3 registres ,plus de puissance au niveau volume ,le little bear chauffe beaucoup moins,la scene sonore est plus ouverte, consomme moins. je suis tres content de mons achat.
Andre L.
TOPPING P50 Regulated Linear Power Supply Ultra Low Noise 2x 5V 1A + 15V 1A Silver This regular linear power supply Topping P50 offers excellent performance and allows a HiFi system to be powered properly and thus promotes the sound reproduction quality of the...
Very good power supply
I bought this power supply in combination with the Topping D50s DAC. The build of this PSU is superb. It is small, but very heavy!
Very happy with it sofar.
Andre L.
Good detailed DAC
I ordered this DAC together with the Topping P50 linear power supply. I have also a Toppin D90 (AKM chip) DAC in my living room and bought this for a smaller room.
Compared to my D90 it has a more analytical 'cooler' sound. I like the D90 a tad more, but that is a matter of personal talste. Also the D90 was much more expensive. This is still a very good DAC for the price though. Therefore I give it 4 stars.
Marco S.
Mai ottenuto così tanto da un cavo USB
Ho provato diversi cavi di varie brand e fattura, questo è l'unico che mi ha soddisfatto pienamente. Appena lo inserite il suono non è come te lo aspetteresti, anzi la mia prima impressione è stata che mi aspettavo di più poiché sono stato abituato ad ottenere risultati migliori dai conduttori in argento, ma ho aspettato e lasciato suonare per diverse ore e ad oggi dopo circa una settimana posso dire che non c'è cavo migliore che potevo acquistare, il suono si è aperto, i dettagli arrivano da tutte le parti, suona tutto così pulito ed organico senza alcun artificio.
Wayne M.
Jantzen Z-Caps
Very detailed and fantastic value, clear distinct audio
Wayne M.
Jantzen Z-Caps
Wayne M.
mundorf
clear n precise
Francois L.
TOPPING LA90 Amplifier Class AB 2x90W 4 Ohm / 1x180W 8 Ohm Black Topping offers with its LA90 a powerful and efficient amplifier, which can work both in stereo and mono mode. In the first case, it is capable of delivering a power of 2x90W...
Waouh
1 semaine que j'essaye d'opérer à des écoutes comparatives avec d'autres amplis. Rien a faire dès que je passe au LA90, j'écoute la musique.
Pour une fois, les mesures s'entendent. Une étoile en moins pour le bloc alim cheap en plastique ABS
Martin M.
Defaualt code is "0123"
lot of product here missing some useful description
ANTONIO M.
low quality built
sounds is ok if you like the shitty integrated volume, yes at leats is analog and passive but still, conectors quality are really bad. Also for being "class d2 is pretty ineficient, with 90db/w/m 8 ohm speakers it goes pretty hot the case!!! nad 216 is more efficient.
Sound quality, if using integrated volume is pretty good but i want a pure power amp with no volume or level control a nd unbalnced rca imput neutrik good quality a nd quality decent 4mm banana female shockets for speakers . Looking for next generation for Purifi class.d or topping Class-D amps. Not interested in La90 class ab, im really happy with my quad 606 and nad 216, just still looking for something like AUDIOPHONICS MPA-S125NC RCA (great built made in france quality) but with the "TPA3255 enhanced" that uses this topping pa5 and a integrated meanwell swithing mode PSU, that will be the perfect combination until Purifi makes smaller power modules
ANTONIO M.
better than hypex smps
thats is enough to say
ANTONIO M.
meanwell is meanwell
the smps brand choosen for nelson pass's pass aca class a diy amp.
Not casualty, the only one smps can make analog audio device sounds almost as good as with linear psu
ANTONIO M.
good detail, really good but compressed dynamics even with linear psu
good detail, really good resolution but compressed dynamics even with linear psu 5 volts
ANTONIO M.
Not better than UCD with linear PSU
Yes is more efficient than linear PSU amps but the treble is dull and not detailed at all. CI hope Purifi is much better than this. I ended selling it as i did with the NC500MP dual mono i purchased here too. Built construction is great, as all audiophonics house products but ncore is with smps is not good enough for hifi or high resolution monitoring. But Brunos's designs are advancing and the good thing is contruction is great, is durable, it really can handel 3 ohms loads, is dynamic .... but is low resolution highs... Looking for next generation of Purifi to see if they fix its high reslution weakness. Just ordered some pro class d amp for a popular brand of pro single driver passive studio monitor, Aurartone, still waiting for it. I use Focal, B&w and dynaudio only. Hope someday some class d amp can surpass my quad 606 or even my modest NAD 216thx regarding crisp highs and liquid mediums
Thibaut L.
J'ai commandé une 36 v pas une 24 v
Jean-Pierre V.
Documentation pas à jour
Attention la documentation téléchargeable sur le site audiophonics ne correspond pas au modèle livré (juin 2022) : en particulier contrairement à ce qui y est spécifié, Win7 n'est pas compatible... Savoir que l'achat d'un nouveau PC est indispensable, n'est pas complètement neutre.
En attendant, il ne m'est pas possible de tester l'appareil.
Le fabricant ne nous a malheureusement pas prévenu de ce changement, nous mettons la fiche produit à jour au plus vite.
A noter que vous n'avez pas à changer d'ordinateur pour mettre à jour Windows.
MATHIEU B.
DAYTON AUDIO BPP-SN Speaker Terminals (Pair) These terminal blocks offer great design quality at an affordable price. They provide a secure and efficient connection without the tendency to loosen. They also accept banana...
Beau de loin…
Massif et qualitatif, mais vu de près, les détails tels que la régularité approximative rainures évitant le glissement des doigts trahissent une fabrication inégale. Il y a sur le site des borniers mieux finis vendus moins cher. Mais bon, pour le look gris mat, il n’y a pas d’autre choix….
MATHIEU B.
Bonne qualité générale
Belle qualité générale, nombreuses mâchoires permettant le sertissage de presque tous les connecteurs. Je retire une étoile car la pochette ne contient pas d’illustration reprenant la correspondance mâchoire-connecteur, donc j’ai dû imprimer la photo du site pour obtenir et conserver cette info.
Joerg K.
Excellent Cable for reasonable price
Sound is excellent, very broad and deep soundstage.
Clear without irritating highs. Bass is also ver accurate.
To remove the insulation is very diificult and time consuming, also the termination with connectors is not that easy.
Still the sound quality was worth all the hassle.
Charles S.
VIBORG VF512R
Qualité des composants de haut niveau, excellente tenue de la fiche connectée supportant le poids de câbles lourds .
Sans oublier les soins apportés au traitements de surface argent/rhodium.
De la haute couture avec à la clef l'apport d'une musicalité au rendez vous .
je recommande ce produit sans réserve à ce prix sans concurrence !!!
