Pascal H.
Marc C.
M. B.
Excelent
VERY precise amplifier. Excelent. Noise is zero.
The blue leds (2) on the preamp board are so bright they make bars of blue on my ceiling thru the ventilation slits. Could do with a little less. I'll modify their resistors.
Trigger option on the outside would be nice.
Thanx for this fantastic amplifier !
M. B.
Ok. Has drawbacks.
+ Audio quality.
+ Quality built.
+ Swappable opamps.
- Device gets rather hot (after a while), on the outside, no ventilation openings, inside temperature probably very high. Should be taken in account when stacking devices.
- Remote volume(-) is sometimes interpreted as volume(+) on the edge of its range (~5m).
- Remote control "Next" of my Onkyo C-S5VL SACD is also interpreted as "Next audio channel" by the device. No other matching codes.
- Volume control motor makes a lot of noise. A full rotation to zero is performed at startup, even when it is at zero already. (Nnngggjjj...)
- Volume is reset at absolute zero at startup. Requires getting used to.
- Volume knob has no visible position-indication.
- Documentation ?
jean-françois v.
IAN CANADA RECLOCKPI Double I2S / DSD Reclocker Low Noise / Low Jitter Ian Canada's ReClockPi is a high quality, low noise, low jitter dual reclocker module. It is designed to work with the FifoPi or any other digital audio device in synchronous...
Excellent reclock avec FIFO PI Q3
Très bon upgrade que ce recloker en plus du FIFO PI Q3 de Ian canada. Pour ma part c'est ma dernière modif après avoir installé le FIFO PI Q3 ainsi que des horloges acusillicon et des AOP de chez Sparkos Labs en sortie de mon filtre actif Najda, voir mes avis à ce sujet. Ce que je peux dire c'est que je ne pensais pas avoir un gain réel et bien si, il est certes plus faible que les modifs précédentes mais tout de même il y a un gap. Le plus frappant c'est la sensation de gagner en émotion comme si on retrouvais la chaleur de l'analogique. TOut est plus juste du grave à l'aigu mais surtout mes Altec 414 ont un grave très tendu parfaitement juste comme si j'avais des 416. A achetter lorsque l'on a déjà fait pas mal de modif et que l'on souhaite encore gagné un peu.
B B.
reçu en 48h, bravo Audiophonics et merci à David pour les conseils. Je l'ai acheté pour ma chambre avec des enceinte Dali Oberon on wall. Je l'ai aussi testé avec mes enceintes Iroise 500 et ampli Marantz PM17. il pilote bien les cabasse mais je préfère le son du marantz qui me semble plus naturel. Il est aussi dix fois plus cher... En revanche sur les Dali c'est très bien malgré leur faible rendement, on ne fait pas la différence avec le marantz et il vaut des ampli 2 ou 3 fois plus chers. Le son est très clair, bien détaillé, graves et aigus bien équilibrés. Avec le BT ça permet d'avoir un ampli tout intégré avec un excellent rapport qualité prix !
DAVID B.
M David B - Audiophile Scientifique
J'ai remplacé mon ampli ART SLA2 (en class AB) par HPA-S400ET pour alimenter mes enceintes Magnepan 3.7i.
L'échange avec le service technique très cordial, on sent clairement la maitrise technique et la très bonne connaissance du produit (c’est pas un service commercial délocalisé essayant de faire de la figuration).
Commande passée le vendredi 11 mars 2022 à 11h00, Livré le lundi 14 mars 2022.L'emballage - double semble être à toute épreuve !
La différence de qualité du rendu sonore est très nette. Les aigus sont bcp plus clair et les basses ne bavent pas ! La différence se perçoit même dans des pièces éloignées de la maison.
Les finitions de l'appareil sont impeccables et renforcent utilement l'aspect qualitatif !
Je tenterai sans doute plus tard de tester avec d'autres OP comme les OPA1612 pour voir…
Jean-Michel Q.
Une excellente affaire.
J’ai déjà deux casques hifiman (he400i et he1000v2) j’ai acheté cet édition XS en complément pour emporter en déplacement et je suis très favorablement impressionné. Une performance digne de ses grands frères et un prix qui écrase toute la concurrence. Aucune hésitation à avoir…
Matthias J.
Perfect unit - nothing more, nothing less
This is a totally boring device. Deadly quiet, lots of power, absolutely neutral, well built. It makes nothing wrong and you can hear exactly the sound of your source and your speakers. It easily controls even an Apogee Duetta Reference or a Cabasse Bora unconstrained and relaxed. And if your system sounds bad with the MPA-S250NC don’t blame this amplifier but look for the reason elsewhere. Highly recommended budget amp.
Yvon C.
J'ai commandé ce produit me basant juste sur sa bonne réputation. Les premiers résultats d'écoute (seulement 10 h 00 de rodage !) dépassent toutes me attentes. Extrêmement précis tout en étant naturel et très musical (fluidité et legato). Bref ! quoi de mieux à ce prix et bien au delà?
Francois g.
super mini Dac
Un très bon dac , la connectique est limitée mais l'écoute est superbe et c'est bluffant pour un petit truc au rqp imbattable. Voire les revues du Web pour les détails.
Francois g.
très bon straps
Remplacement de straps basique et le résultat se fait vraiment entendre, c'est plus équilibré , moins fatiguant , bref c'est mieux et la différence est sensible. Content de mon achat !
Francois g.
très bons straps
En remplacement de straps ohelbach basics, le remplacement est audible tout de suite et bien meilleur. Plus doux , mais surtout plus équilibrés. Mes enceintes
Francesco R.
le péché n'est pas identique
Ce ne sont pas les premiers que j'achète, mais les capuchons rouges sont toujours 2/3 mm plus courts que les blancs et de fabrication différente
Tres bon cables a prix contenu
Satisfait de ces câbles et surtout le système de verrouillage simple et rapide.
Enfin des câbles qui ne peuvent se différencier aux branchements.
À conseiller vivement...
Tres bon DAC
Je l'utilise essantellement entre un lecteur preampli ,un CD servant de transport et un ampli MPA-S250NC Audiophonic.
Le son est légèrement analogique et tout en finesse.
Je pense que le son va encore s'améliorer dans quelques jours.
Merci à David pour ses conseils.
Envoi rapide, mais ceci devient normal chez Audiophonics et très apprécié.
naturel avant tout
Une sensation de réalité de façon naturel . Plaira peut être plus aux mélomanes qu'aux "hifiste". Ma prise est connectée à une prise murale oyaide or /paladium , elle est le point de départ de tout mon système hifi. Elle remplace une fiche furutech rhodium qui peut paraitre plus dynamique mais à long terme n'affiche pas cette sensation d'équilibre naturel qui s'approche du concert . Le reste n'est qu'une affaire de goût.
Neutralité sans défaut
2 câbles connectés entre une alimentation séparée et un ampli double mono . Une neutralité et une rigueur de transcription parfaites. Une forme d'évidence sans artifice transparait . Un câble qui ne pardonnera pas les défauts de certains systèmes hifi . Prix légèrement élevé à mon goût d’où 4 étoiles . Reste cependant un très bon choix.
Dominique P.
Mais si !
Très sceptique sur l'influence des câbles et encore plus de ce genre de câble (numérique), mais intrigué par tous ces avis, je me suis fait ce petit cadeau. Pour voir...
Alors, je ne dirai pas comme beaucoup que les différences sont immédiates, énormes, sautant aux oreilles, avec ceci en plus et cela en moins, bref, les excès de langage audiophilesques.
En effet, je n'ai pas vraiment ressenti de différences dans l'immédiat. Mais je l'ai laissé car pour moi, c'est sur de longues écoutes sur plusieurs jours, sur divers enregistrements que je me prononce en général sur les différences entre matériels.
Eh bien, après quelques jours, je dois dire en effet que j'éprouve un plus. Plus de naturel ? Difficile à dire mais plus de plaisir en fait. Comme d'habitude et dans l'absolu, on ne change pas de chaîne bien sûr mais on apprécie, comme un raffinement supplémentaire. Surprenant !
J'ajoute que le câble est très bien fabriqué et "beau" (si ce qualificatif peut s'appliquer à un câble :-))
Dominique P.
ALLO FLEX Micro USB to USB-A Cable 90 Ohm for USBridge Signature / Revolution DAC 15cm This Allo Flex cable has been specially designed to connect the Allo USBridge to the Allo Revolution DAC. It has a controlled impedance from 90Ω, specific to these devices.
Très bon !
J'ai oublié de préciser que l'impédance de 90 ohms correspond à l'impédance théoriquement idéale non seulement pour les appareils annoncés mais pour tous les appareils (streamers / DACS) USB en fait. Impédance qui est rarement mentionnée par les constructeurs et qui pourtant fait la différence.
Dominique P.
Très bon si...
Vous cherchez un câble USB de qualité, le plus court possible et non blindé ? ...Et bon marché qui plus est ?
Celui-ci est fait pour vous si sa taille vous convient. ATTENTION, les 15 cm indiqués ne correspondent pas à la partie droite du câble (ce que je croyais) qui fait une petite dizaine de cms.
C'est ce qui me l'avait fait remiser car je ne pouvais pas l'utiliser entre mon ALLO USBridge signature et mon DAC Sanskrit 10th anniversary MKII.
Ayant changé la disposition des éléments de ma chaîne, je l'ai ressorti après plusieurs mois pour m'apercevoir qu'il... ne fonctionnait pas...!
Heureusement, Audiophonics a assuré comme toujours et après un petit échange de mails, j'ai reçu un nouveau câble, parfait celui-là. Bravo pour le SAV !
Chow s.
DSD 128
Hi, I'm using this converter too. However when connected to my Oppo 205 as a transport via I2S to my Pontus II it can obly play DSD 64 file. However when playing DSD 128 and above there is no sound. However my Pontus II led light show 1x and DSD while my Oppo 205 show DSD. Anyone facing this problem. Thanks
Richard M.
Turns on my amp perfectly
I use this to start my Rotel RB1080 from the 12v output from my Pioneer Elite LC-SX801. I was leaving my Rotel on all the time - even though it has a 12volt input, it made a funny noise and did not work. I had read on some hifi sights that this would work, so took the risk and ordered it from France. I am happy I did. It fits perfectly into my Rotel and the Rotel plug fits perfectly into it. I attached the 12v cord from my pioneer to this and Voila!!! Works perfectly and my Rotel is now shut off until the Pioneer turns on. Thank you. Worth every Euro!!
Henri F.
fantastique bloc de puissance
système d'écoute : PC windows optimisé avec fidelizer pro et process lasso, logiciel de lecture Audirvana Studio ou Hqplayer avec sortie asio avec protocole lecture réseau DIRETTA vers streamer Allo Usbridge tournant avec gentooplayer et le target DIRETTA vers dac AUDIO GD D77 en ACSS vers préampli AUDIO GD NFB1 AMP en XLR Vers le LPA - S400 ET vers colonnes TRIANGLE.
Tout d'abord oubliez tout les préjugés négatifs sur les amplis en classe D que l'ont peut lire sur différents forums francophones, sur leurs manques de musicalité, leur agressivité... Tout cela est totalement infondé, en tout cas avec les dernières générations. Ici le son est d'une transparence et précision extraordinaire. Il fait preuve d'une très grande musicalité, des basses hyper précises, bien tendues et propres, de très jolies médiums, des aigues bien présents et précis, tout cela sans aucune once d'agressivité. Il n'enlève et n'ajoute rien. il ne surjoue pas comme certains amplis de classes plus traditionnelles y compris à lampes. Non ici le son est restitué tel qu'il a été enregistré. il est d'une neutralité exemplaire. Et on ne s'ennui jamais à l'écoute contrairement à ce que l'on pourrait penser. Il permet de longues écoutes sans fatigue. Chez moi il tient la dragée haute et n'a pas à rougir face à un amplificateur intégré à lampes bien plus cher ! Autre grosse qualité est qu'il est évolutif et on peut très facilement changé d'AOP. vous avez compris que je prends énormément de plaisir avec et que pour moi j 'écarte totalement un retour sur des classes d'amplis plus traditionnels.
Merci à Audiophonics pour leurs précieux conseils et de nous proposer de tels produits à des prix défiants toutes concurrences.
Francois V.
Excellent, tout à fait en ligne avec la réputation du Gremlin
Alimenté par une meanwell 36V 300W, cet ampli est surprenant. Ne vous attendez pas à un gain important (le gain est plutôt dans cette configuration d'alimentation celui d'un 2x40W classique). En revanche il y a énormément de "headroom" et la dynamique est fantastique. Je recommande de casser la tirelire et passer sur la grosse alim 48V, ne lésinez pas. Il faut normalement bypasser les capa d'entrée et remplacer par des capa de bonne qualité, mais même sans ça le résultat est bluffant, même (et surtout) sur des enceintes difficiles comm mes VTLs Jordan.
Sébastien A.
Pratique
Plus pratique que des pointes avec coupelles, pas de risque de rayures lors des déplacements. La finition est propre. Avec la feutrine ça glisse sans problèmes. Pas de mesures effectuées pour -vérifier un éventuel gain pour l'instant du coup j'ai pas mis 5 étoiles. Livraison rapide.
Sébastien A.
Adapter Male USB-C to Female Jack 3.5mm / USB-C This adapter has a USB-C male on its side and a USB-C female and 3.5mm female jack on its ends. It is mainly designed to be used with smartphones that do not have a 3.5mm jack...
Pas pour S21
Pas pris en charge sur Samsung S21, achat inutile.
Bras c.
Un très très bon DAC
Voici maintenant 13 jours que le Pegasus s’est installé chez moi. Il totalise donc environ 300H de fonctionnement car je l’ai laissé allumé en permanence depuis son achat. Le moment est donc venu de faire le point sur son apport dans mon système (Atoll IN300, KEF LS50 + caisson REL T5i, switch ETheregen, streamer Emerson digital + important travail sur l'élimination des vibrations et sur le câblage). Pendant cette période, mes nombreuses écoutes m’ont confirmé (s’il en était besoin car j’en était déjà convaincu) que la restitution évolue considérablement entre la sortie du carton et le cap des 300H ….en bien, bien entendu !
Par rapport au DAC AK4490 de l’Atoll, le Musician se démarque tout d’abord sur la profondeur, la hauteur et la précision de la scène sonore. Par exemple, l’environnement qui entoure la voix d’Anna Reid de London Grammar sur le titre « If you wait » est bien plus vaste qu’avec l’Atoll. Dans le même sens, les effets 3D sont nettement plus marqués (les enceintes disparaissent vraiment cette fois-ci) et positionner les musiciens sur l’enregistrement d’un concert est un jeu d’enfant. La taille des instruments (notamment le piano) paraît bien plus réaliste. Toutes ces qualités supérieures font que la musique est beaucoup plus impliquante. A de nombreuses reprises, mes poils se sont dressés à l’écoute des titres de ma playlist de test que je connais pourtant par coeur.
Ensuite, il prend nettement le dessus sur les instruments à cordes, le piano et les percussions type cymbales... leur grain est palpable et très réaliste. D’une manière générale, les harmoniques sont bien plus riches avec le Pegasus et il vous permet véritablement d’accéder à l’oeuvre de l’artiste, c’est à dire qu’il la restitue avec toutes ses nuances, ses variations, ses arrières plans... Il ne favorise aucun registre. Ainsi, les medium ne sont pas particulièrement mis en avant mais les voix sont bcp plus présentes et agréables puisque mieux détourées et elles possèdent désormais un grain que le dac de l’Atoll est incapable de restituer. Les graves profitent également de toutes ces améliorations.
Par ailleurs, je ne perçois aucune mollesse de sa part, défaut souvent attribué aux dac R2R. Sur le titre « the coil train » d’Hughes Masekela, les envolées de ce dernier sont retranscrites avec le même degré d’énergie que le dac de l’Atoll. Par contre, je ne le ressens pas exactement à l’identique. En effet, le Pegasus paraît plus à l’aise dans ce domaine, moins « rentre dedans » pour caricaturer, dans le sens où il ne donne jamais l’impression de « forcer » par rapport à l’Atoll : Cela paraît plus naturel, plus décontracté, plus fluide en somme.
Enfin, la synergie de toutes ces qualités conduit tout naturellement à un écart important en terme de musicalité entre les deux appareil...vous arriverez sûrement au même constat que le mien si vous partez d'un DAC "honorable" comme celui de l'Atoll et à la condition que votre système soit suffisamment abouti (vibrations parasites maitrisées, câblerie et électroniques/enceintes au même niveau cad aucune ne devant faire "bouchon").
Erne K.
Not recommended
This gadget is not worth 1€. One star in my rating is too much. I would give negative stars if possible.
Pierre Olivier C.
J’ai commandé de câble pour relier un drive cd à un Dac R7HE et pour remplacer un câble à 350€ qui….. ne marchait pas !
L’apport du canare est indéniable, séparation des instruments, aération, restitution du grave, définition etc, je ne peux pas savoir ce qu’aurait apporté mon ancien câble mais pour le rapport qualité prix ce canare me semble imbattable ! Ce n’est pas mon premier câble audiophonics, j’en ai plusieurs et tous m’apportent pleinement satisfaction. Pour moi pas besoin d’y mettre plus cher et pourtant je suis loin du rapport « 10% » du prix des appareils.
Par ailleurs je tiens à souligner même si cela a été fait maintes fois que le sav audiophonics est tout simplement remarquable.
Une équipe au top et toujours disponible, trop rare de nos jours !
Bravo à vous et merci encore
Le complément indispensable de l'EVO DAC
Vous voulez sublimer votre EVO DAC ?
N'hésitez plus !
Cette alimentation permet d'atteindre le nirvana, tout simplement :-)
Parfait ! Merci AUDIOPHONICS :-)
Un ensemble de grande classe, avec des fonctions à foison, et une sonorité digne de produits de "grandes marques".
Je l'utilise avec un ampli casque classe A, et un casque AUDEZE LCD2, le tout avec des fichiers en HIRES sur mon réseau local.
Le rendu est tout à fait excellent, le DAC est vraiment très bon.
De plus, ce système est ouvert à des plugins et de futures améliorations !
Pour terminer, je tient tout particulièrement à remercier et féliciter le SAV AUDIOPHONICS : réactivité, excellente communication, connaissance parfaite du système, permettant une mise en route en toute quiétude, que demander de plus ?
Cable d'une très grande finesse
Avec ces câbles en modulation XLR, la scène est précise, les aigus sont fin et l'espace semble aéré.
Bravo
VIBORG XM-202G Male XLR Connector 3 Poles Gold / Silver Plated Pure Copper Ø11mm Red (Unit) Viborg offers with its XM-202G a high-quality 3-pole XLR connector. Its contacts are indeed designed in pure Copper with triple plating Copper OFC, Silver and Gold, to ensure...
Excellent connecteur
Produit de grande qualité à tous points de vue.
VIBORG XF-202G Female XLR Connector 3 Poles Gold / Silver Plated Pure Copper Ø11mm Red (Unit) Viborg offers with its XF-202G a high-quality 3-pole XLR connector. Its contacts are indeed designed in pure Copper with triple plating Copper OFC, Silver and Gold, to ensure...
Excellent connecteur !
Une révélation en HP
Ce câble mérite une écoute. Il suffit dès lors de se fier à son oreille.
Absolument redoutable !!!!
Je l'ai adopté et pourtant des câbles bien plus onéreux je possède.
Ce produit est d'une qualité irréprochable. A essayer de toute urgence.
Des qualités sans rapport avec son prix.
c'est une révélation et un produit absolument unique. A découvrir de toute urgence sans préjugés. Il vient remplacer des câbles beaucoup plus onéreux.
Joseph B.
Excellent câble audio
Je viens de remplacer le câble d'origine de mon casque Ultrasone edition eleven par ce modèle. La différence est immédiate. Le son ressort tout de suite comme étant plus clair, plus détaillé et plus aéré. Le résultat est vraiment probant. Je suis très content de cet achat. Merci Audiophonics de nous proposer de tels produits.
Grande qualité
Matériel de grande qualité et qui inspire confiance.
Il alimente un DAC SMSL Sanskrit 10th
Je ne sais pas encore s'il y a une amélioration du son, mais le duo fonctionne terriblement bien
Rien à voir avec le chargeur de batteries qui alimentait auparavant le DAC
Expédition parfaite et temps record de livraison.
Merci à l'équipe Audiophonics
Ahmet A.
perfect
quiet background calm presentation and previously unnoticed details
EXCELLENT TRANSPORT CD
Voici deux ans que je vis avec ce petit Shanling Tempo et je souhaite apporter des précisions supplémentaires par rapport à l'avis que j'avais posté jadis. En effet on est toujours un peu trop pressé à donner un avis, alors que c'est seulement sur le long terme qu'on apprécie un objet technologique. Musicalement, ce Tempo CD est honnête et même très honnête compte tenu de son prix modeste. Disons qu'il rivalise avec des produits de marques Grand Public deux fois plus coûteux. Toutefois ce petit lecteur n'est pas parfait avec des limitations qui sont celles des appareils de milieu de gamme, disons jusqu'à 500 ou 600 euros. La définition est très bonne dans l'aigu et le médium mais un peu insuffisante dans le grave, légèrement "cotonneux". Du coup, l'image stéréo manque un peu de présence en profondeur, cela est surtout sensible sur la musique symphonique qui exige une localisation des instruments plus nette. En changeant les AOP d'origine (des Texas Instruments 5532) par de bons TLE 2142 CP le miracle ne s'est pas produit, ce qui prouve que les limitations viennent davantage de la puce de conversion que du préampli interne. Rien de trop grave cependant pour un DAC Bur Brown 1796 qui n'est plus une puce de dernière génération. En outre, ce lecteur privilégie la douceur, chose louable, mais ici un peu trop systématque ce qui gomme légèrement les aspérités de la musique, pourtant nécessaires. Malgré ses limites, je recommande chaudement le TEMPO CD en tant que transport CD, on bénéficiera ainsi d'une excellente mécanique Sanyo, précise, silencieuse et fiable, généralement montée sur des systèmes beaucoup plus coûteux. Ce TEMPO CD, accompagné d'un bon DAC externe risque bien d'accomplir des miracles. Le mien, couplé à un DAC à puce Asahi Kasei 4493, a transiguré la restitution sonore. Ces puces Asahi Kasei sont peu coûteuses et vraiment étonnantes ! La défintion est devenue excellente sur tout le spectre avec une transparence de haut niveau qui ordonne l'image stéréo en trois vraies dimensions. Les instruments du fond de l'orchestre sont parfaitement localisables et les atmosphères des lieux d'enregistrement très crédibles. La dynamique, libre, fait vivre la musique comme au concert. Et n'hésitez pas à vous munir d'un bon cable numérique coax comme le CANARE vendu sur ce site.
Jens H.
Favourite RCA plugs
I really like these plugs, very good value for money. Used them to make interconnects with Neotech cables. Particularly like the way the inner part is constucted, where you solder the cable, it is easy to solder. Clever minimalist design. The amount of metal in the plug is very little, I see that as an advantage, it means they can use higher quality metal and keep the price down probably.
François-Régis B.
TINYSINE TSA5000 Bluetooth transmitter module 5.0 apt-X This ultra-compact and light-weight module has an analog input and a Bluetooth encoder / transmitter. This technology is particularly useful when you need to connect the audio...
"noise-gate" activée sur le microcontroleur Qualcomm
Le défaut de documentation est patent, l'option "noise-gate" a été activée sur le microcontrôleur Qualcomm chargé d'encoder le signal audio. Résultat : le son est coupé dans les parties légères ou faibles. Cela est très flagrant sur la musique de la renaissance ou des sons de la nature alors qu'un transmetteur bluetooth classique comme un smartphone ne présente pas ce problème rédibitoire.
Julien L.
Bien mais...
Manque cruellement de gain (volume sonore) dans ma configuration : gestion de multi-source en RCA vers une mini-chaîne.
Je ne comprends pas en quoi un pré-ampli diminue le gain ?
Sinon l'appareil est qualitatif et correspond à mes autres attentes (multicanal RCA / bluetooth)
Attention pas de câble d'alim ! c'est un peu chiche !
Manque une sortie casque
Recordcard ..
Au top!
Super cette interface et en plus abordable.
Autoalimenté par l'HDMi ce qui simplifie grandement son intégration.
Les flux DSD sont intégralement transmis sur l'I2S.
Coax, Optique et i2S pour 65 €, c'est cool.
Recordcard ..
Formidable!
Super satisfait de ce DAC. Profondeur, précision, détails tout est là avec ce gros plus "analogique" R2R.
Ultra compatible avec tous les formats numériques (DSD 1024x!) Oubliez les mauvaises rumeurs sur le R2R, ici c'est du 100% maitrisé avec des perfs en THD et SNR digne des meilleurs DeltaSigma. La qualité de fabrication n'est pas en reste, au top pour un tarif très très cool.
J'ai écouté bon nombre de DAC à plusieurs milliers d'€ qui étaient très loins de ce niveau (Mc.I ect..). Il abreuve mon gros système Accuphase et est très largement au niveau. Ils sont quand même sacrément forts et compétents ces chinois.
Retours apres longues ecoutes et plusieurs jours
Je reviens sur mon avis précédent , après avoir insisté à l'écoute sur plusieurs jours de ce DAC entre preampli classe A et le lecteur CD Chanling le son s'est vraiment amélioré, je ne saurais dire pourquoi, mais c'est un fait.
Très heureux finalement de cet achat.
Je voulais écouter la différence sur mon ampli Exposure avec le tcs31 que j'ai depuis un moment, plus chaleureux. Le s032n est plus naturel tout en restant feutré, et plus ouvert.L'aigu est plus défini mais pas fatigant.Excellent câble (comme le tcs31 d'ailleurs).
ALEKSANDRS P.
IBASSO DX240 Digital Audio Player DAP DAC ES9038Po Balanced Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA Green iBasso is back with a high-end DAP, mixing brilliantly pure sound performances and modern and ergonomic design. Its digital/analog conversion stage embeds an excellent ESS...
Excellent service
Player delivered within 4 days to Latvia.
Very good customer support service, replied after few minutes.
Additionally supplied with nice leather casing.
Recommend for everyone, shop is high standard service quality!
eric m.
Indéniable amélioration.
Ce tube redresseur Genalex-Gold Lion GZ 34 est venu remplacer mon GZ 34 SOVTEK qui déjà fonctionne très très bien sur mon Ampli.SE. Mais par curiosité et sachant que ces 2 tubes sont physiquement identiques, Je voulais entendre une différence...........
Pour le coup la je suis fixé.....ce Tube redresseur Genalex apporte une scène sonore beaucoup plus ample, avec des instruments qui sembles plus réels, vraiment une nette amélioration à l'écoute.
En conclusion; très satisfais de cet achat, et du service Audiophonics.
