Gerrit G.
Very good DAC , BUT .....!
The USB A to C cable that comes with it is only good for powering the davice , not for data transfer . If used for data ,...
Antonio C.
It’s a no brainer.
Tibor H.
Customers reviews - There are 19038 reviews.
Massimo G.
Great
Update asus sonar essence stx II with Burson v5i. Apart from a slight hiss with the volume at minimum which Burson claims is normal the sound with my Shure se 846 and Sennheiser hd 660 s is much improved. The distinction between bass is clearer, medium and high, even the soundstage is wider. A well ventilated case is suggested because the Bursons heat + the Muses. Recommended product, good service from Audiophonics
Martin D.
Excellent Housing
Very nice housing of good quality and reasonably priced
John M.
Fantastic
Really nice size. Excellent sound quality, used with Q Accoustics 2010 speakers. They drive those speakers no problem. No hum or noise.
Didier s.
mini inter
Trés bien et remplis sa fonction.
Didier s.
connecteur de pile 9 volts
Parfait et super tarif
Didier s.
Voltage Display Voltmeter with Blue LED 60-500VAC Ø22mm This voltmeter will allow you to monitor the voltage of a device. Its blue LED display is easy to read. The voltmeter accepts voltages from 60VAC to 500VAC. Its...
Parfait malgré un tarif plus que résonnable
Fil de câblage 0,5mm2
Retour d'expérience,
Ce câble de bonne qualité se travaille bien, de plus l'isolant résiste à la chaleur du fer à souder
Produit recommandé
Produit recommandé
Fil de Câblage Cuivre FEP 0.5mm² (Blanc)
Produit recommandé
W H W.
High quality power sockets
The title says it all; very good quality for the price.
W H W.
Alu Case for power sockets
Very solid and high quality aluminium case, consisting several panels which have to be mounted together (you need some patience to get the job done). Very good product.
Christian P.
Genial!
Ce petit module est tout simplement fantastique fonctionne a merveille, super simple a installer. Ce que je trouve super c'est que l'on peux faire quelque chose de très simple ou si on a la courage et un peu de savoir faire des choses plus complètes.
Seul petit défaut que j'ai trouvé c'est au niveau de l’application, il n'y a pas la possibilité de l'afficher au format paysage (tablette).
CLAUDIO R.
ELECAUDIO ADIACIUM GW Extensible PET braided sleeve Nylon 4-11mm Braided sleeve made in  PET (Polyethylene Terephthalate)  mono-strands which can be used in a wide variety of applications. Thanks to its expansibility, the unique...
Óptima funda con acabado elegante.
El material es excelente y da una buena sensación al tacto. Rápida de utilizar gracias a una buena expansibilidad. Utilizada para realizar dos cables de interconexión: acabándola con funda termo retractable el resultado es profesional. Muy satisfecho.
CLAUDIO R.
Óptimo producto.
Práctica selección de varios diámetros para distintos cables. Sella perfectamente y adhiere a todo tipo de superficie: fundas de PET, cordones de algodón, terminaciones audio, etc.
Fácil de trabajar, aunque sin una pistola de calor profesional.
CLAUDIO R.
Óptimo producto.
Utilizado para realizar un cable-filtro para mi REGA Apollo-R, con otros materiales en venta aquí, ha sido muy fácil de soldar y alojar en una caja metálica..
No es el primer filtro de la marca que compro: prácticamente cada regleta o aparato de mi sistema se beneficia de ellos.
Muy satisfecho!
CLAUDIO R.
Óptimo producto.
Robusto, bien hecho y con un cierre perfecto entre caja de montaje y cable. Relación calidad/precio excelente.
CLAUDIO R.
Óptimo producto.
He utilizado estas cajas en distintos cables-filtro, con otros materiales de Elecaudio y SCHAFFNER, y han sido muy simples de trabajar. Las piezas separadas permiten un montaje “fijo” hasta bajo tableros o baldas y los tornillo permiten varios ciclos de apertura y cierre sin perder su funcionalidad. Relación precio/rendimiento/estética excelente. Muy satisfecho!
CLAUDIO R.
Óptimo producto.
CLAUDIO R.
Buen conector a un precio honesto.
Fácil de soldar (con toques rápidos) y con un buen acabado.
Muy recomendable para cables de interconexión que necesiten el jack de 3,5mm.
CLAUDIO R.
Óptimo producto.
Utilizada en varios diámetros y distintos cables. Sella perfectamente y adhiere a todo tipo de superficie: fundas de PET, cordones de algodón, terminaciones audio, etc.
CLAUDIO R.
Copper / Silver Wiring Cable 4mm² PTFE Sleeve Ø3.6mm Transparent This 3.6mm diameter cable has a single 4mm² conductor made of Silver plated OFC Copper. This provides excellent signal conductivity while providing the conductor with high...
Óptimo producto.
Utilizado para realizar un cable-filtro para mi REGA Apollo-R, con otros materiales de Elecaudio y filtro SCHAFFNER, ha sido muy fácil de soldar. El cable de alimentación, luego recubiertos por fundas de PET, se queda flexibles y permite una cómoda instalación. Muy satisfecho!
CLAUDIO R.
CLAUDIO R.
Óptimo producto.
Utilizada para realizar un cable-filtro con otros materiales de la misma marca y filtro SCHAFFNER, ha sido muy fácil de trabajar. Acepta diámetros de cable “importantes” y luce un aspecto de alta gama. Muy satisfecho!
CLAUDIO R.
Óptimo producto.
Utilizada para realizar algunos cables-filtro con otros materiales de la misma marca y filtros SCHAFFNER, ha sido muy fácil de trabajar. Los cables de alimentación, luego recubiertos por fundas de PET, se quedan flexibles y permiten una cómoda instalación detrás de los aparatos. Muy satisfecho!
CLAUDIO R.
Buena funda con un color alegre.
El material es excelente y da una buena sensación al tacto. Rápida de utilizar gracias a una buena expansibilidad. Con cable grandes, al limite de sus posibilidades, puede tender a deshacerse: un golpe de mechero en las puntas, antes de empezar la inserción y se soluciona el problema. Utilizada para realizar algunos cables-filtro: acabándola con funda termo retractable el resultado es profesional.
CLAUDIO R.
Excelente
Óptimo producto; hice un cable de alimentación nuevo para mi PSU MkII King Rex y el correspondiente amplificador T-Amp. Materiales de calidad y se puede soldar con facilidad.
CLAUDIO R.
Excelente.
Buen producto; hice un cable de alimentación corto para mi Elfidelity AXF-101 (Filtre alimentation USB Externe pour PC). Se puede soldar con facilidad.
Michel l.
une merveille
je remercie tous les collaborateurs de audiophonics de m avoir sollicite a prendre ce produit car j'avoue je n'en espérais pas tant car il est étonnamment surprenant après avoir patienté trois mois
c'est excellent ampli et branché sur un préamplificateur fx audio 3e de chez audiophonics platine cd Yamaha c700 rca cable cardas et wireworld equinox 7 j'ecoute principalement des hqcd le son et parfait l'impression d’être face au chanteur merci à toute l'équipe
claude N.
Voulant remplacer ma barrette Actinote Mezzo qui se couchait
suite au poids des câbles secteur..me suis acheté la Viborg VE80.
Incroyable déjà à l'arrivée emballage énorme et poids.Je ne pensais pas qu'elle était si imposante.
écoute phénoménale..tout s'améliore..Même après 2 semaines d'écoute..C'es magique..Pour un prix abordable ..n'hésitez pas!
Merci Audiophonics
Système THDG:Ampli Hybride Rogue Audio Pharaos
Enceintes Audiophysics Cardeas..Câble HP Tata-Labs Air 1....
Tamás P.
percy
This is a very good cable. Good for interconnects or using it inside the equipments where shielding is required.
It has low capacity and a very well built cable.
Cyrille G.
POWERGRIP YG-1 V2 Power Filter Distributor 11 schuko surcharge overload protection The Powergrip YG-1, powerful distributor and mains filter with its 11 Schuko sockets is the essential element for all enthusiasts wishing to protect its Hifi Home Cinema.
Multiprise qui protège vos électroniques des surtensions ou sous tensions du secteur: coupure. Réarmement manuel qui permet de se rendre compte que ce genre de mésaventure n'est pas si rare! Filtrage efficace contre les appareils pollueurs. Pas donné mais c'est le prix de la qualité et de l'efficacité.
Mickaël P.
bonjour je l'ai reçu , j'avais pas pris l'adaptateur pour l'alim je recommande fortement de le prendre , car j'avais utilisé une alim qui était pas le bon du coup ça fonctionnement , et j'ai fais un retour client le SAV a été vraiment sympas il on testé et il fonctionnait très bien , du il me l'on renvoyer j'ai prit l'adaptateur de prise et ainsi que la clés USB BT tout fonctionne très bien j'ai pu faire la MAJ du DSP
je vais l'installé et voir comment celui-ci gére le 3 voies
jean-luc P.
Qualité
quelque soit sa dimension, ce câble donne toujours de bons résultats: son détaillé et pas d'agressivité dans l'aigu.
jean-luc P.
Pratique et pas cher
Je trouvais cet accessoire inutile avant mais pour un coût modique c'est drôlement pratique et le fer à souder reste disponible rapidement en toute sécurité.
jean-luc P.
Précision
Intéressant pour les soudures de précision: pointe fine et réglage de la température pour un travail propre.
jean-luc P.
Complémentarité
Ce connecteur IEC en cuivre argent or est complémentaire d'un câble d'alimentation en cuivre équipé d'une prise shuko Elecaudio également en cuivre argent or. J'avais un connecteur IEC Elecaudio mais en alliage de cuivre. Le montage est plus cohérent ainsi que le son.
jean-luc P.
MUNDORF MCONNECT Copper Foil Flat Wiring Cable 70x0.07mm 4.9mm² This flat wire Mundorf will appeal to amateurs chevronés wishing to design cables loudspeakers or for the shielding by sheets of transformers, condensers or simply of boxes.
Blindage coffret
J'ai fixé de l'amortisseur bitume à l'intérieur des capots des amplificateurs, préamplificateur et convertisseur puis j'ai fixé ces feuilles de cuivre comme un cadre de tableau sur le bitume. L'effet est intéressant: le blindage et le bitume apportent au son plus de netteté et de détourage.
Alain M.
Satisfaction de ma commande
Embase jack très précisément définie sur l'offre (dimensions, utilisation, ..) = aucune erreur possible d'acheter un produit ne correspondant pas au besoin. Livraison très rapide = BRAVO et merci, je recommande à tous ce professionnel.
Pierre H.
Excellent tubes
Utilisées sur un vieux Dac Métronome Technologie C20 et un ampli Pathos Classic One MKIII. J'ai acheté ces lampes en faisant confiance à l'avis précédent de Christophe et bien que je n'ai pas la même expérience que lui de différents modèles, mis à part des Sovtek et des Tesla, je le rejoint tout à fait dans son analyse très précise: aigu sans brillance ni saturation, grave avec beaucoup de corps et d'impact physique, médium et voix pleines de matière et beaucoup de présence, excellente image en 3D. Parfais équilibre entre le rendu des lampes et celui des transistors. Très bon rapport qualité/prix.
Jesus C.
Sorprendente Ampli.
Sorprendente amplificador por su pequeño tamaño pero sonido espectacular. Buena potencia. Sonido calido y cristalino. Ideal para empezar con la tecnología de amplificadores a valvulas.
Ivaylo K.
Ivo
Very Good quality. Thanks to the Audiophonics team for the neat packaging of my whole order.
Ivaylo K.
ivo
Ivaylo K.
Ivo
Good quality. Nice and thick.
Ivaylo K.
Mr. Kovachev
Very nice in real life, looks good and solid.
Ivaylo K.
Mr. Kovachev
Excellent cable. More dynamics, better bass response, the treble is fine as well - despite the solid core.
SMPS300RS Switching Power Supply Module 300W 36V The Connex SMPS300RS is a half-bridge resonant switched-mode power supply (SMPS) capable of delivering 300W continuous and up to 360W peak. It is configured for a 36V output...
SMPS 36V
Très bonne alimentation, stable, fiable, les mesures multimètre sont au RDV. Excellent ripple et clairement orienté pour les amplis Audiophiles. LLC + Softstart
XDUOO XQ-50 PRO
Très bon recepteur et supporte nativement le meilleur des codec sans fil : LDAC. Piloté depuis un Xiaomi, le son est très bon ! Il est couplé avec un TPA3255.
Un peu cheap de part le poids mais excellent rapport qualité / prix.
Alim 36V
Alime livrée sans cordon secteur contrairement à ce qui est annoncé ! Sinon, mesurée au Multimètre, elle fait son job.
Celle que j'ai reçu avait un plastique qui se baladait à l intérieur...
TPA3255
Rapport qualité prix correct et contrairement à ce qui est annoncé par Audiophonics, l'Anti Pop est bien présent sur cet ampli )
Sinon, pour optimiser le son prévoir :
-update OPA1656 ou 1612 pour gagner en holographie et définition
- une bonne alimentation SMPS type 36V / 40V @300W
Globalement super petit ampli, ça ne vaut pas du TPA325X de chez 360 Customs ou XRK mais pour le prix c'est très très bien.
Alain C.
