Marcus L.
Michael M.
Worth every penny!
mathieu l.
Renaud P.
AD18 SMSL
Produit de bonne qualité, réserve de puissance étonnante pour la taille. Le grave est profond quoi qu'un peu surreprésenté à mon goût. Je constate également une certaine brillance dans les aïgues.
Produit que je conseille néanmoins car la rapport qualité/prix reste imbattable. Il donne de bons résultats avec des focal Electra 1007. Cdt.
Boris Z.
Simply wonderful!!!
Purchased one couple of months ago.
As was originally suggested, loaded Rune Audio onto micro SD card, booted the unit, and it came up - with the screen upside down. At first I thought some one messed up and mounted the screen upside down. Turns out it was a software issue, common to many players.
I contacted Audiophonics, and after few email discussions, loaded the latest Volumio player. Everything was great - except I had no sound. After numerous email exchanges, I had Audiophonics email me assembly instructions.
I took the player completely apart, and reassembled it again. In the process I discovered that one of the GPIO pins was bent and had no contact with DAC connector - most probably the reason for sound issues.
Once again I started the unit, this time using PiCore Player and Logitech Music Server. I connected the streamer to the Emotiva USP-1 preamp, mated to Emotiva UPA-200 stereo amp and Magnepan MG 3.7 speakers and HSU Research ULS-15 Subwoofer.
Few hi-res recordings from Primophonics instantly convinced me that this player was well worth all the aggravation:
the sound was simply wonderful.
I can't wait to convert some of my organ music LPs to HiRes WAV or FLAC or maybe DSD files and play them on my RaspTouch!!! It will be glorious!
Référence dans sa gamme de prix
Suite à mes 2 avis concernant l'ampli FX252A, j'ai poussé mes investigations d'écoute en le comparant chez un ami à du lourd. "préampli et ampli Mark Levinson de 200watt d'une ancienne génération, mais d'une valeur de 7000€ en occasion. Les enceintes étaient des Dynaudio 52 se. A l'écoute de l'ensemble Mark Levinson la sonorité était chaleureuse, mais manquait de réalisme et d'impact au niveau instrumental. ( cymbale, batterie, cuivre et voix ). Le secteur grave quant à lui était profond mais un peut envahissant. Ce style d'écoute est celle de mon ami, de mon côté je n'était vraiment pas emballé. D'un commun accord nous sommes passés à l'écoute du FX252A. Même câblage et même source. Ce fut encore la claque, ce petit bijou s'est mis à jouer sa partition, maitrisant parfaitement le secteur grave sans trainage. Quant au secteur médium aigu tout s'harmonisait avec réalisme. Mon ami n'en revenait pas et regardait ses Mark Levinson avec pointe déception. En conclusion il m'a demandé de lui commander le FX Audio 1002A. Bravo au concepteur FX audio.
meilleur rapport qualité prix du marché
Acheté pour remplacer un V-Dav Musical Fidelity tombé ne fonctionnant plus et ne voulant pas mettre trop cher car je vais l'utiliser en Guadeloupe ou electroniques s'oxydent vite.
Très bons résultats sonores sur tout le spectre, meilleur que le Dac intégré de l'ampli casque Matrix M-Stage.
ne pas hesiter , à ce prix la c'est donné
Hugues L.
SERVICE PARFAIT
Prestation s'etant parfaitement déroulée et le produit est conforme à mon attente.
Merci beaucoup, je reviendrai sur votre site
Hugues Laurencin
Michel C.
Whouaaa !
comme disent les ricains... simply amazing...
Sur usb c'est du vrai lossless en 16bits/44k qualité CD réel, reconnu directement sans pbs sur win et android, foobar et flac sont idéaux...
sur bluetooth, honnêtement c'est excellent et très bien défini malgré que ce ne soit pas normé aptx (mais il faut rappeler que l'engin ne coûte que 40€!)
pour moi un peut trop de basses, dut peut être à mes Infinity Outriggers de bibliothèque, testé aussi très bon sur mes triangles colonnes ...
Malgré le prix et le ridicule look de l'engin, le son produit est indéniablement de qualité Hifi... le son est aussi correct que sur mon SMSL Q5 pro...
Ils mettrait simplement cette électronique dans un gros boitier avec un afficheurs et quelques réglages manuels et beaucoup trouveraient génial de dépenser 200€ pour un tel produit simplement pour une histoire de look en plus...
En bref il ne paye vraiment pas de mine avec son look gadget (cependant bien fini avec de bons borniers)... mais abstraction faite c'est... Whaouuu
Pour ceux qui s'interrogent sur un bon petit ampli HiFi (non hiRes), il y a aussi deux fois plus cher... mais ce ne sera pas beaucoup mieux, sinon moins bien ! ... au delà visez directement le génial smsl ad18...
PS (une bonne alim 19/5A d'ordi portable lui fera gagner encore plus de pêche, mais utile surtout si vous désirez lui faire cracher des Db sans pousser en saturation)
Ma note : 10 étoiles sur 5 !
Raphaël H.
Très satisfait !
Reçu ce petit AD18 il y a 15jours déjà,je souhaitais prendre le temps de le juger sans précipitation aucune,et je ne regrette pas mon achat.Apres avoir fait un grand ménage dans mon installation (exit lecteur Jadis Jd3et Wadia X32,Nu-force ia7v3 en panne...)ne me reste qu un Rega planet 1 en lecture CD, branché à la fois sur l'entrée analogique aux. et aussi sur l entrée coaxial de l AD18.Bien évidemment juger le smsl via le planet en lecture CD m incline à la prudence (le lecteur Jadis ayant été vendu 2 jours avant réception de l ad18...).Mon autre source étant une Freebox reliée en toslink dont la qualité reste perfectible,j en suis conscient.Le reste de mon installation est de meilleure qualité :câble modulation et. HP supraflux et hotline de la marque Ensemble,Kimber D60 "illumination" en numérique,câble secteur Kimber Pk10 gold, barrette secteur AX son,boitier bi_cablage Fadel Art et pour finir des enceintes Équation 2B.Donc je me retrouve,pour le moment ,avec des sources qualitativement en deçà du reste de la chaîne...Et surprise malgré ces contraintes (provisoires) je prend beaucoup de plaisir à l écoute de ce tout-en-un lilliputien.Tout d abord je préciserai que me concernant l alim (de taille généreuse) ne chauffe ni ne vibre,idem pour l Ad18,dont la température oscille entre froide et tiède sans que cela paraisse lié au volume d écoute ou à la durée même de la mise sous tension ?! Je le laisse allumé en permanence sans soucis,pas de bourdonnements ou de souffle aux HP.
Question qualité sonore,j ai le sentiment d'une meilleure intégration des fréquences du spectre sonore,il manque parfois un peu de ceci ou de cela mais en même temps on entend des choses qui passaient quasi inaperçues avant.Tiens la basse est en retrait, manque de niveau oui (peut être...) mais l articulation est supérieur,les doigts tricotent sur la basse avec dextérité...L intégration semble homogène,surprend parfois par rapport à ses anciennes écoutes sur d autres produits haut de gamme.Je n aurai qu une réserve, peut être, concernant le relief et la profondeur de l image sonore.Malheureusement je ne peux décoller mes enceintes du mur autant que je le souhaite (actuellement 50cm) pour maximiser ce paramètre WAF oblige...
Au bilan,un super achat susceptible de faire décoller certains systèmes ou de remplacer sans frustration des produits de qualité.
En parlant de qualité,l ensemble alim+Ad18 est pour le prix vraiment irréprochable de surcroît.
Nicola P.
Stretchy Sheath Extensible Nylon (PET) 30-50mm Black This black braided sleeving made of PET (Polyethylene Terephtalate) single strand can be used for many applications.  Thanks to its expandability, the unique braiding of...
Gaine nylon
Très bonne qualité pour cette gaine en nylon, idéal pour vos câbles Hifi et autres. Merci
Christian S.
Grande satisfaction.
La qualité est au rendez-vous. Amélioration très sensible du son d'une chaine hifi. Très recommandable.
Ludovic H.
Super produits
Super produit répondant totalement à mes besoins. Expédition rapide
Musical
Après rodage d'une vingtaine d'heures, ce câble est équilibré avec une mise en valeur des voix (médium), un délié dans les aigus (sans ostentation) et une assise des basses fréquences réjouissante. La scène sonore est cohérente avec de l'aération autour des instruments. Ces commentaires n'ont évidemment de valeur que par rapport à mon système assez transparent (triodes 2x8w - DAC-19 AUDIO-GD). Je suis très satisfait de ce câble d'un prix modique au regard de ses prestations.
thierry h.
Gaine de qualité parfaite pour son usage
Simple et efficace.
thierry h.
Si pratique !
Impossible de trouver plus pratique pour un prix dérisoire.
thierry h.
Très bon produit futé
Très utile pour protéger les brins de cuivre d'un câble Hp très fins et ne pas les couper avec le serrage de fiche banane ou bourbier ampli.
thierry h.
Excellent produit parfait sur le plan technique et qualité de fabrication irréprochable. Seul reproche nécessite un embout torx 6 pour les vis et pas clef à 5 pans comme indiqué sur la description.
Ce petit ampli offre une connectique complète, on peut connecter sur l'entrée RCA, une source analogique en plus des classiques entrées numériques (usb, coaxiale, optique). Sa puissance est confortable pour alimenter mes enceintes au rendement relativement bas (86 dB) dans une pièce de taille moyenne. Ce qui est remarquable c'est la sonorité globale, elle est fluide sur tout le spectre. Un ampli à la sonorité un peu simplificatrice mais musicale, c'est l'essentiel. Cela change de la précision mais évite aussi les duretés dans le haut du spectre qui souvent l'accompagnent dans cette gamme d'ampli. Pour le prix, rien de négatif à noter, de plus son design est réussi.
Fabrice D.
Super carte ampli casque
Très bonne carte d'amplification casque fonctionne très bien avec mon Audeze LCDX. J'ai juste changer le potar contre un Alps et câblé en argent pure . Aucun bruits avec un transformateur Rcore. Je suis très surpris de la qualité au vue du prix proposé. Merci a l'équipe d'Audiophonics.
Julien F.
Correct
Peu cher, et tout de même efficace.
Leur capacité anti vibration est saisissante même si des produits plus chers doivent faire mieux. Elles ne relèvent pas beaucoup (1cm de hauteur) mais c'est toujours ça.
Très très pratique pour nettoyer les vibrations d'un pc ou d'un onduleur, d'un dac, voir d'un ampli.
Julien F.
Simple et efficace
Utilisé pour relier un onduleur double conversion (ça marche vraiment bien et ça protège votre matériel vintage prévu pour du 220v qui se prendrait du 239v dans ma ville assez souvent d'après les relevés d'entrée de l'onduleur - bien prendre double conversion uniquement pour la qualité sonore).
Il est solide, paraît un peu court car il est très tordu mais fournit le courant correctement. Dommage qu'il n'y ait pas de câbles hauts de gamme dans ce type mais ça serait des productions invendables.
Julien F.
Très belle construction
Ces jumpers ne risquent pas de lâcher ou de se défaire et sont compatibles avec toutes les tailles de borniers qu'ils vont rencontrer. Ils ne sont pas très flexibles mais c'est suffisant.
Ils sont assez épais pour des jumpers, j'ai noté qu'ils aidaient pour une fluidité du signal. Ce sont des produits prévus pour durer et une fois que vous les avez achetés, vous n'irez sans doute pas prendre d'autres jumpers.
Ils ont un prix d'entrée qui peut paraître un peu élevé mais le prix s'efface au fil du temps alors que la qualité va rester, ils sont vraiment très performants, autant payer un peu plus cher et dire non à la course aux prix tirés vers le bas, qui au final, n'ont fait que maximiser le prix des produits de qualité.
Julien F.
Des boas de l'audio
Ces très gros et lourds câbles sont vraiment à essayer tant ils restituent le son sans avoir de points faibles, hormis leur poids.
Il faut bien prendre en compte leur taille, on ne s'y fait pas avec la photo mais il sont bien costauds et peu flexibles, donc mieux avoir des bons borniers pour les fixer solidement.
J'insiste sur ce point simplement pour éviter la surprise au déballage, du reste, le gros avantage du câble comparé à d'autres notamment un type 4 occ sans bananes est d'avoir une écoute plus élargies, pas simplement au niveau des détails qui passent tous dans les enceintes mais surtout au niveau du message musical : on a l'impression qu'il était auparavant écourté et que toute les notes ne sont plus découpés.
Les aigus, medium et graves sont vraiment très beaux à écouter, à noter que le son est plus réaliste, et j'ai noter une présence moins puissante des graves même après rodage. Simplement, vu la beauté des sons développés, très proche d'un vrai enregistrement, je pense que les anciens câbles étaient plus dopés dans le graves, nuisant à la fidélité.
Sincèrement, ces câbles sont en un sens un problème : une fois mis en place, en les laissant se roder, la course aux câbles de hauts parleurs prends fin. Ils sont cependant très méchant avec les systèmes qui n'ont pas un minimum de qualité, des Klipsch RB-81 mk II montraient très vite leurs limites alors qu'elles sont décemment placées dans les productions actuelles.
Ce sont des câbles pour utiliser la totalité de votre système et tirer le son qu'il peut reproduire du fin fond de ses entrailles électroniques vers vos oreilles.
Au passage : le service audiophonic est une perle rare.
Julien F.
Bien devant les câbles grand public
J'avais acheté ce câble usb, ce fut mon premier achat de câble usb pour DAC. Il prend un certain temps avant de se mettre en place mais il est redoutable. Les attaques et les timbres sont très accentués, c'est ce qui m'avait le plus marqué ainsi qu'une très bonne séparation des sons.
Son défaut était une faiblesse au niveau des sons d'arrières plans, beaucoup plus faible qu'avec d'autres câbles cependant plus chers (100 euros neuf pour son remplaçant, que j'avais put prendre moitié prix en occasion). A noter qu'il dépasse le câble audioquest usb cinnamon pour ceux qui veulent une comparaison.
Pour le prix, il n'y'a rien à dire honnêtement.
Philippe L.
Fonctionne en OTG Mais...
DAC acheté pour aller de concert avec un téléphone portable sans prise jack. Fonctionne très bien (MP3, FLAC, DSD) mais nécessite pour bien fonctionner une app payante (USB Audio Player PRO) . Parcontre KO avec Spotify (90% de mon usage) contrairement a ce qui est indiqué sur le site. Plutôt déçu de mon achat donc.
Vous pouvez utiliser Hiby Music parfaitement gratuit.
Aucune mention n'est faite à la compatibilité Spotify, Deezer, etc... (bien connus pour verrouiller leurs application !)
Claude L.
alimentation à découpage smsl 24v/6.6A
Utilisée pour alimenter ( en double mono ) des modules classe A Amp Camp Amp(N.Pass) ainsi qu'un buffer B1 Pass.
Très bonne alim,aucun bruit,bonne dynamique,avec un ampérage largement suffisant.Ces boitiers sont assez volumineux.Pas de surchauffe.
Dominique L.
Commande Tube ECC83S
Tube conforme à ma commande , délais de livraison rapide , communication par mail du suivi de la commande parfait .
A recommander sans modération .
D.Lebourgeois
Alain R.
Très bon produit acheté pour sa versatilité du fait de l'USB. Impeccable et même impressionnant sur un rasp pi. Par contre je l'ai connecté pour essayer à un NAS et à mon PC, et là il y a des interférences. Les enceintes sifflent plus ou moins fort, même en le tenant éloigné. Je pense que l'interférence passe par le cordon USB. En tenir compte pour cet usage. Par contre pour le RASP c'est nickel, je suis vraiment content, jai l'impression d'avoir un nouvel d'ampli pour 30 euros !
Alain R.
Borniers pour panneau bois de bonne qualité, bon serrage, rien à redire.
Gilles P.
Matériel livré rapidement et le fonctionnement est parfait pour une tension de sortie entre 5,5V et 35V
Raul S.
Audiophonics ES9028Q2M DAC
Very nice DAC, I use this with my old Arcam amplifier and I manage it through my smartphone using Volumio. Nice results and easy to configure.
Thanks to Audiophonics team for their help!
olivier r.
très bon rapport q/prix mais limité tout de même
Testé sur 4 systèmes (du plus simple au plus complexe) dans 4 pièces distinctes. Le constat est le même à chaque foi. Les plus: joli médium, grave légèrement en avant, assez naturel, dynamique juste mais pas excessive. Les contre: légèrement sombre (ne comptez pas sur lui pour mettre en avant les micro informations dans l'aigu), aigu un peu raide manquant de finesse et de différenciation, semble écourté. Au final, naturel mais un peu déséquilibré en faveur du bas du spectre. Fera des merveilles en compensation sur de la classe D ou T (Tripath) un peu sèche et trop portée vers le haut. A mon gout pas adapté à un système dont on attends un haut niveau de finesse (SE8454 ou 300B par exemple).
pascal l.
Gaetan g.
très bon compromis
acheter jour j et livre j + 2 en bon etat. Installation facile, bon appairage et qualité au rendez vous. Utilisation pour lecture avec tel port smartphone via site de musique et sortie sur chaîne hifi avec ampli rotel râ 12 et enceintes bw cm1. Que du n=bonheur
Gaetan g.
très bon rapport qualité prix , jai aussi acheter le même type de câble pour utiliser une source iPod vers ampli et cela donne un résultat bluffant
annie r.
baladeur shanling m3
baladeur conforme aux caractéristiques et tests énoncés sur le site.
je l'ai pour l'instant depuis quelques jour, la qualité est très bonne (le jour et la nuit par rapport à mon shuffle).
Mais meme si mon intra est de qualité moyenne, je vais obligatoirement monter en gamme sur les écouteurs.
Sinon un rapport qualité prix très intéressant.
jean francois G.
Rectifier une précédente evaluation
J'avais trouvé ce câble moins bon dans les médiums que Le Sommer câble éléphant mais en fait c'est une erreur il a le même rendu dans les médiums seulement il a plus de poids dans le grave ce qui fait toute la différence , et qui m'a induit en erreur . encore une fois attention au choix du câble , ils ne rendent pas pareils en fonction de l installation .
Câble Mogami et Canare
Melomane72 le 12/11/17.
Mon système hi-fi actuel est câblé en mogami ( modulation & hp ) que dire du résultat " exceptionnel " dans tous les secteurs. En guise d'essai j'ai essayé le canare L-4E6S. Le mariage est excellent avec même un surcroit de définition . Je l'ai comparé chez un ami à un câble US 10 fois plus cher, le canare était meilleur dans tous les registres L'autre paraissait terne manquant de vie.
Jean Louis F.
excellent pour un prix très abordable. Le plug in pour apple est instable au redémarrage.
Qu'appelez vous le plugin pour Apple ?
Nous n'en connaissons pas pour ce périphérique.
En cas de soucis, raccourcissez la liaison USB.
Olivier D.
Excellent !!!
Tres bon ampli avec un tres bon rapport qualité prix conseillé par Qobuz. installation et fonctionnement tres intuitif, même sans mode d,emploi. Je l’utilise avec un videoprojecteur Benq sur la sortie Aux ou directement sur la sortie optique avec un lecteur de DVD ou un Mac Book Pro. Enceintes JBL de bibliothèque. La puissance est largement suffisante et le réglage du volume tres fin. Très bonne qualité du son. Un très bon achat pour un petit ampli auxiliaire.
Service audiophonics parfait et rapide.
Gilbert K.
Très bien...
Circuit imprimé de qualité, résistances à couches métalliques 1% et en plus un 5532 en AOP ce qui donne un ensemble cohérent et de qualité.
Petit bémol, le gain est un peu faible par rapport aux autres entrées CD AUX et j'ai enlevé les picots pour les connexions entrées/sorties pour souder directement sur le circuit.
Vous pouvez aussi changer le 5532 pour un OPA627.
Rene R.
TEST
Très bon câble ,rapport qualité prix,aucune partie du spectre dominante,fluidité et respect des timbres
Enfin un câble sans cette foutue mode des câbles argent et cuivre argent
Sans vous perdre dans les méandres de l 'audioFolie, vous pouvez démarrer sans hésitation avec ce câble de modulation
jean francois G.
Je suis restée sur ma faim .
Honnêtement vu le prix proposé je m'attendais à autre chose je viens de commander du Sommer câble éléphant spm 425 et franchement on entre dans une autre dimension surtout au niveau des médium , pour un prix défiant toute concurrence . 3.8 euros le mètre !
jean francois G.
A acheter sans réserve .
Au prix proposé ce petit câble ne paie pas de mine . J'ai relié les 4 câbles de 2.5 mm 2 par 2 pour n en faire que 2 de 5 mm carré . Ce montage permet d'annuler le champ magnétique . A l écoute stupeur ! Je connais bien Sommer câble j'utilise l'albédo régulièrement et encore une fois il son à la hauteur de leur réputation .
jean francois G.
Mon câble de 5 mm à trouvé sa place sans problème , la qualité de fabrication est au-dessus de tout soupçon , le contact des fiches est très franc , du très grand viablue a prix Contenu .
mélomane 72 le 11/11/17 Ampli surprenant
J'ai comparé le FX 252A à un intégré audiophile 10 fois plus cher. Je n'ai pas trouver de différence. le FX 252 A est bluffant. Bonne tenue du secteur grave, Excellente richesse harmonique. La musique est distillée avec chaleur et naturel. Cet intégré à sa place dans un petit système audiophile.
Bluffant
Ampli comparé à une grande marque française 6 fois le prix ! difficile de trouver une différence. le FX 252 A est tout simplement bluffant. Il a tout pour lui. Justesse des timbres , richesse harmonique très bonne tenue du secteur grave. Il entre aisément dans un petit système audiophile. A acheter sans hésitation .
Joshua Y.
PARFAIT !
Facile à assembler, un régal à souder car la soudure adhère très bien. Utilisé dans mon cas pour fabriquer un câble DIN-DIN pour platine cassette avec signaux de lecture et d'enregistrement gauches et droits.
Joshua Y.
PARFAIT !
Parfait pour fabriquer un câble DIN-DIN pour platine cassette avec signaux de lecture et enregistrement gauches et droits.
Joshua Y.
Eric J.
Intégration, dynamique et précision à format et prix mini
6 mois d'utilisation. Ce minuscule boitier (un petit autoradio!) à prix très modéré remplace avantageusement plusieurs appareils qui valent plusieurs fois son prix!
- L'ampli full digital permet de se passer d'un DAC en alimentant directement en USB (ordi, certains Android, pas iOS) coax ou optique. Beaucoup de dynamique, de précision, les basses descendent bien fermes, la scène sonore est transparente et profonde, tout ça le met dans des classes d'amplis classiques beaucoup plus chers. Point faible: le bornier HP et les fiches bananes c'est du léger.
- Côté casque le circuit est complètement différent puisqu'il comprend son DAC puis un ampli casque. De fait le résultat est différent, moins dynamique et analytique, plus chaud, mais quand même tout à fait honorable, plutôt mieux que beaucoup de sorties casques d'amplis classiques.
- Et aussi une entrée ligne analogique, qui est d'abord numérisée: je trouve que c'est plus du dépannage pour de l'écoute occasionnelle car la conversion AD crée des distorsions audibles.
En résumé, pour le prix l'Alientek D8 remplace plusieurs appareils traditionnellement beaucoup plus gros... et beaucoup plus chers pour obtenir la même qualité sonore! Privilégier les sources numériques.
Eric J.
Performant et polyvalent
Très polyvalent avec ses entrées USB (marche aussi avec iPhone et Android), coax, optique, ligne, et sorties casque et ligne, décode tous les fichiers Hi Res PCM, DXD, DSD...
Très bonne qualité d'écoute, notamment en HiRes, un plaisir - avec un bon casque car plutôt du côté analytique. Dynamique, grosse réserve de puissance, manier le potard avec modération!
Préférence pour le filtre PCM4 en CD et PCM1 en HiRes.
En résumé excellent pour le prix, couplé avec un smartphone et un bon casque c'est du haut niveau à encombrement minimal!
