Thierry C.
Thierry b.
Toute la...
remy l.
Oliver S.
Just brilliant... :)
This amp replaced an Audiophonics MPA-S250NC which already was a steal for its price. The LPA-S400ET is better in every aspect, it´s even quieter, more resolving & liquid, greatly enhanced authority and control in the bass region. I bypassed the gain stage, the source is a DAC with 200 Ohm output resistance, driving the amps´ symmetrical inputs. Since I am using horn speakers, the too low output voltage of the DAC is no problem. BTW, volume control is done in the digital domain (MiniDSP), something I would have never expected to be a good sounding alternative, yet it is. All in all I am very happy, thanks a lot Audiophonics for this really great offering - these are wonderful and affordable times for open-minded listeners not only looking at brand names but end results... ;)
Christoffer H.
Just perfect!
It replaced a broken Schiit lyr 2 and I'm amazed how much better the Little Dot is.
Dominique V.
J'ai commandé 2 câbles pour un magnéto à bandes Akai des années 70, et à peine installés, que la différence , par rapport aux câbles traditionnels, se fait immédiatement, de part la qualité du son qu'il en sort et de la fabrication. Je les recommande sans hésiter.
De plus, commandés le Lundi reçus le lendemain, si ça c'est pas le top...
Merci Audiophonics.
Andrea T.
Bought to power the Sotm 200 streamer, it increases its performance in all fields...
Robust construction and excellent materials.
Recommended
Laurent M.
Doux
J'en ai essayé des câbles anglais, français.
Parfois très chers .
Celui ci n'a pas de verdeur dans l'aigu , pas de medium qui crie .
L'écoute est d'un naturel, d'un confort .
Superbe.
Martin A.
DD MFI09S Male USB-C to Male Lightning Cable Silver / OFC Copper 10cm The USB-C to Lightning DD MFi09S cable benefits from a perfectly mastered design, using very high quality components in order to offer excellent conductivity and...
Bad quality
I'm writing this, because this is the second DDHIFI item that quit working after some months of use. The lightning part will come loose from its socket, very disappointed of DDHIFI build quality, the sound was great though.
Martin A.
DD TC28I Male Lightning to Female USB-C Adapter OTG This TC28i Lightning male to USB-C female adapter will allow you to convert the Lighnting connection of an Apple device to standard USB-C. You will be able to use, for example,...
Bad quality
This product quit working after a couple of months, not recommended!
Sebastien S.
AUDIO BASTION SPIKE X PLUS Spike Stainless Steel M10 (Set x4) These Audio Bastion Spike X PLUS spikes effectively dampen the vibrations generated by your audio system. They are made of 304 stainless steel, both robust and durable....
Test à faire - conseil de montage
MONTAGE SUR ENCEINTE COLONNE DALI DE 37 KG avec pointes
Intérêt :
Remplacement des pointes d'origine en mauvaise état
Conseil d'installation :
J'ai déplacé une enceinte et une pointe s'est tordu légèrement.
Ce produit est à installer sans aucun léger déplacement !
Dommage qu'il n' y a aucune mise à garde à respecter.
La pointe n’est pas logé dans un trou et il y a un léger déplacement de celle-ci dans le galet de la contre pointe AUDIO BASTION X-PAD PLUS II
Suite au montage j’ai une image sonore précise et une importante stabilité des enceintes exclusivement avec des contrepointes perforées au centre.
Résultat moins stéréophonique pour des enceintes avec les AUDIO BASTION X-PAD PLUS II Contrepointes Aluminium Acier Inoxydable.
Elles seront placés sous une platine Vinyle, test à suivre
Simple et efficace, dommage juste qu'elle ne soit pas pré-étamée. Pour que ça "pompe" bien, ne pas hésiter à mettre le fer à 350°, et tremper la tresse dans du flux décapant. Pour les vieilles soudures, il vaut mieux les "recharger" avant avec de l'étain neuf. Et vous verrez, ça marche très bien !
THOMAS R.
LINDY CROMO LINE Digital Cable Coaxial SPDIF Copper Gold Plated 0.5m The Lindy Cromo Line SPDIF Coaxial cable benefits from a beautiful design quality. Its conductors are made of Copper for a very good conductivity and its connectors are plated...
Câble trop fin
Belle qualité de fabrication mais j'ai été très surpris par la finesse et surtout la souplesse "caoutchouc" du câble qui laisse imaginer qu'il n'y a pas beaucoup de métal dedans et donne une impression de fragilité. Il fonctionne bien et je ne doute pas de la qualité audio mais je m'attendais à autre chose sur un site spécialisé.
THOMAS R.
SMSL Remote control for amplifier FDA AD18 / Q5 Pro This infrared remote control is dedicated to the exclusive use of the main functions of the FDA SMSL AD18 amplifier and Q5 Pro. It is ideal as a replacement for the original...
Mieux que la télécommande d'origine
Fonctionne parfaitement avec l'ampli/DAC SMSL Q5 pro, en remplacement de la télécommande d'origine peu fiable.
Elle mesure 15 cm, et on y retrouve toutes les fonctions, y compris la sélection des modes Equalizer qui ne peut se faire que par télécommande (touche FN ici).
Alexandre p.
En utilisation désormais régulière sur un "linux". Alsamixer propose 4 niveaux PCM. Je me sers de pipewire pour exposer toutes les interfaces proposée par l'appareil. Je peux donc laisser le cran à 0 pour le gain. Fortement suggéré. Ensuite pour la granularité du volume on peut effectivement binder n'importe quel recepteur.
Concernant l'écoute et la perception musicale, je peux juste conclure que l'habituation psychoacoustique demande encore une période de rodage. Pour le moment le rendu semble en faveur d'un son extrêmement dynamique mais froid. Selon le positionnement dans la pièce d'écoute on s'aperçoit que la structure du son rentre en faveur de certaines gammes de monitors et pas d'autres.. En ce qui me concerne le son manque un peu de chaleur sur des monitors Adam (classe D), mais les outils de masterisation sous linux me permettent de corriger la pièce selon les positionnements. mid field / near field. Bravo à l'équipe pour la conception. (Je ne me suis pas servi de l'alimentation proposé en 5volt optionnelle)
Lionel B.
A recommander sur des systemes à bonne resolution
Produit tres efficace (comme tous ceux de la gamme Furutech). Attention cependant au placement. En premiere approche je l'avais plaqué sur la prise murale avec des effets difficiles a cerner.
Je l'ai ensuite installé à l'entrée du mon filtre secteur Gigawatt et là, superbe! Vient accentuer les effets du NCF Clear Line.
Lionel B.
Produit tres efficient a utiliser sur des systemes à forte resolution.
Affaisse le niveau de bruit. Les micros details de la musique sortent de l'ombre pour apporter de l'air, de l'ampleur, de la dynamique aux enregistrements.
La video y gagne bien sur aussi.
Akkrawat W.
Audio extractor HDMI / MHL to I2S
This brings my old stuff Pioneer bdp-150 to life
olivier P.
b&w cdm1 améliorer
Remplacement des condensateurs électrolytiques 5,3 µF 70V b&w dont un avec un gonflement de son enveloppe, et l'autre avec une fuite d’un liquide surement toxique.
Remplacement également des selfs à noyau ferrite pour des sels à air Jantzen .
C'est la première fois que je faisais un remplacement et par la même occasion une mise à niveau le changement est radicalement positif ! je me suis satisfait . de toute façon les condensateurs d'origine de 20 années étaient morts. je pense qu'avec des condensateurs électrolytiques bipolaires j'aurai également eu une amélioration de cette ampleur ça je n'ai pas la réponse .
A voir si dans quelques mois je serais pas tenté par des condensateurs supérieurs afin de juger sur le rôle de la qualité d'écoute.
En résumé génial
véritable +
Je valide ce qui est dit dans le descriptif du produit
Nikolaos R.
Very reliable for its price. The sound is clear and I was impressed with the channel separation. Of course, no comparison should be made with expensive amplifiers.
Nikolaos R.
Excellent quality.
Nikolaos R.
Excellent quality.
Nikolaos R.
Nikolaos R.
Excellent quality.
Nikolaos R.
AMP case
Excellent quality. It's small but the end result, if you choose things that fit inside, is incredible!
Michał W.
Very good opamp
I have changed my original dual OPA2604 to OPA 627 in my DAC and I am quite impressed. Sound improved significantly. Scene has more depth, bass is stronger, and overall sound is richer
Jean-François A.
Gaine thermo en assortiment
Excellente Gaines Thermo Rétractables, en assortiment de multiples tailles, très utiles. Recommandé
Jean-François A.
Filtrage enceinte
Condensateur Mundorf Mcap 630V 0,10 uf placé en lieu et place d'un Chimique NP sur la section aigu d'une enceinte JVC de 1990.Excellent résultat avec clarté et punch retrouvé ! Recommandé
Il remplace un lecteur RaspDIGI Digipi+ V2 qui n'est d'ailleurs plus dispo chez Audiophoncs, la différence est audible, finesse et détail sans pour autant provoquer de fatigue auditive. Le faible Jitter est sans doute le facteur déterminant. De fait, après comparaison, j'ai abandonné (définitivement ?) l'amplification classe D à précision chirurgicale pour revenir à du plus classique (Classe A/B de bonne facture et DAC à puces AKM) sans perdre de détail et avec la scène sonore de l'enregistrement . Ce n'est que du plaisir, mes fichiers numériques sont tous une redécouverte. Audiophonics propose toujours d'excellents produits qui ne sont pas nécessairement couteux. Ce n'est pas parce qu'il faut suivre la "révolution numérique" qu'il faut partir dans du matériel à 4 000 € et plus, proposés par certains vendeurs...
Christian R.
Excellente à tous points de vue
Excellente dès qu'elle est reliée à mon Node 2i,, utilisé comme transport, elle révèle toutes ses qualités après une bonne période de rodage (chez moi 30 heures) : douceur, précision, silence. Je pourrais regretter les câbles de liaison solidaires de l'appareil, mais tant pis, je me suis consolé avec un câble secteur de marque. Cette alimentation vaut largement son prix. Encore merci à Audiophonics qui me l'a conseillée !
Mike F.
Un casque compétent !
Les + : Un son clair et détaillé, confortable, un bon rendement et facile à alimenter.
Les - : Qualité du similicuir des coussinets.
Le son de ce casque se rapproche de la neutralité des casques de studio, mais avec un plus de chaleur dans le bas du spectre, et des aigus moins agressifs.
Appairé avec un Fiio BTR3, je modifie l’équaliseur pour lui apporter un peu plus de kick dans le bas du spectre, les basses sont alors tendues et rapides, un régal !
Dans les films, cette configuration apporte un plus dans les explosions qui deviennent plus percutantes.
En mode bureau, je le l’utilise avec un le zen dac (ifi) et la sortie symétrique 4.4 pentaconn.
Ici la scène sonore s’ouvre un peu plus. De temps en temps j’active l’option truebass du dac qui enrichi les basses sans excès.
J’habite en région tropicale et le similicuir des coussinets a commencé à se désagréger au bout d’un an est demi, je les ai changé par une paire de (très bon) coussinets trouvé chez DEKONI audio
Derrick S.
Excellent amp for the price
You get what you pay for. They are succeeding my old mono's from '97 and do all things for music better! I like the tiny case. All feels solid and is playing for week now and no issues and the sound is great! My fear was that things could get lean but non of that. Highly recommended!
Très bonne qualité, supporte même les soudures, le plastique ne fond pas facilement, et les contacts sont de très bonne facture.
Excellent produit !
La qualité est au rendez-vous, très pratique pour souder les minuscules composants !
Excellent produit !
La qualité est au rendez-vous, très pratique pour souder les minusvules composants !
Qualité très correcte, et pratique !
Eric R.
DAYTON AUDIO MA1260 12 Channels Multizones Amplifier 89W 4 Ohm The Dayton Audio MA1260 12 channel amplifier has been designed to provide a custom multi-room sound distribution. Its intelligent and versatile architecture easily integrates...
J'alimente 10 hauts parleurs de 20cm encastrés dans le plafond, démarrage et extinction automatique très pratique, une seule entrée alimente tous les canaux avec un super son.
Pavle J.
SMSL SU10
DAC is really excellent. Big and boldly soundstage. It is worth for the money. Recommended!
Radek P.
O.K.
I also have as a repro cable. Now I bought 2 pieces as power cable. Hard work, but now I listen and just smile. 50e for the cable and 50e for the connectors. As a colleague wrote a stellar buy. Detail, lightness, airiness, super deep bass. Great.
Damir D.
XDUOO TA-22 Tube Headphone Amplifier 2x 12AU7 DAC 2x ES9038Q2M Bluetooth 5.0 aptX HD LDAC 32bit 384kHz DSD256 MQA xDuoo unveils with its TA-22 a beautiful headphone amplifier and DAC combo with a neat design. This one embeds quality components in order to provide a sound restitution both...
Beautiful, well-finished device, numerous connection possibilities and top-notch features.
Getting started is very easy. I had a little problem with mine unit because voltage switch at the back was placed at 110V instead of 220V when arrived. I didn't pay attention and burned the fuse.
After week of listening impressions are great. Mine Audeze LCD-2 sounded like never before. I can only compare this amp with Unison Research SH sound wise, but Unison lacks power to drive LCD-2 properly.
With this device max volume I needed (on most quiet recordings) was 45 out of 100.
I am pretty sure reviews that will come out will point that this device does not have perfect measurements and I can tell you, I don't care. I didn't by this amp to read charts and numbers but to listen to music.
It sounds great with stock tubes. In a couple of months I will probably replace them with other tubes (something like PSVANE 12AU7-S which you can buy at Audiophonics) , which will probably sound even better.
I am more than satisfied with this purchase, which I can recommend.
Andrew B.
Changé le son mais pas une amélioration pour moi.
J'ai utilisé cet iFi iPower Elite avec mon DAC exaSound e38 et cela a changé le son par rapport à l'alimentation à découpage fournie. Malheureusement, le changement n'a pas été une amélioration sur mon système, il a rendu le son très légèrement plus dur et a donné un peu moins d'air autour des instruments.
Après quelques jours, j'ai décidé de retirer l'iFi de mon système et de rester avec l'alimentation fournie par exaSound.
D'autres personnes pourraient trouver le changement de son de l'iFi bénéfique dans leur système, mais cela a fait pencher l'équilibre sonore de mon système vers un son légèrement trop dur et brillant.
Xavier G.
TOPPING E70 DAC ES9028Pro XMOS XU316 Bluetooth 5.1 aptX Adaptive LDAC 32bit 768kHz DSD512 Black Topping offers with its E70 a powerful DAC with an accurate design. A model capable of offering a rich and precise sound reproduction, combined with smart and practical...
Le summum musical !
Un appareil qui semble petit par sa taille mais qui s’avère immense dans ses prestations sonores. Tout d’abord, la qualité de fabrication est exemplaire, tout en métal avec des connecteurs solides. Le potentiomètre rotatif à cran est des plus agréable à l’usage. Le design est donc une totale réussite, avec une touche de rouge tout-à-fait bienvenue. Une fois, allumé, l’écran s’avère magnifique et surtout bien lisible en blanc. La réglage du volume est au quotidien un régal de précision et s’avère très précis et sans aucun décalage de volume entre les canaux. Une fois relié en XLR à l’amplificateur pour casque Topping L70 qui au niveau du design s’accorde avec lui à la perfection, c’est la claque sonore totale ! Il s’agit tout simplement du meilleur combo que j’ai pu entendre et peu importe le prix. Avec plusieurs casques Focal et Sennheiser, le résultat est toujours au top. Tous les qualificatifs habituels pour décrire précisément un signal sont de rigueur tant la retransmission est transparente. Ensuite, la sortie RCA connectée à mon système d’écoute composé de l’amplificateur Marantz PM 6005 et des enceintes Focal Aria 906, produit également un niveau de qualité rarement atteint ! Sinon, en mode sans-fil, je regrette simplement l’absence d’AirPlay ce qui aurait évidemment imposé une puce Wifi en plus de celle Bluetooth qui hélas propose une liaison qui dégrade forcément la qualité sonore. C’est quand même pratique pour y connecter rapidement n’importe quel appareil nomade. Le fabricant propose enfin des mises à jour du firmware ce qui est un très bon point. Bref, je recommande donc chaudement cette marque et cet appareil exceptionnel pour toutes ces raisons. Il procure un plaisir d’écoute sans précédant ! Bravo aux concepteurs !
Sebastien S.
Excellent 5 étoiles
+++ Câble SOMMERCABLE ONYX 2025 +++
Donne de l’aération et une douceur dans les notes sur mes enceinte Bibliothèque - Esprit Ez Comète + Panasonic SC PMX80 + Pieds amortissants Coupuréthane.
DAMIANO S.
Excellent product. At first the couple of Shuko/IEC with my Acoustic Revive cable sounded very harsh but after 2/3 days it became very smooth and extended. Cost is very high but I really recommend AAA+++
DAMIANO S.
Not easy to use
I really do not like this shear. It's very difficult to insert your cable, furthermore you risk to damage the cotton. I like cotton more than nylon sheath for damping features however the finish of nylon is better and fit better on the cable.
DAMIANO S.
Good tool to crimp your cable in the right manner. Easy to use and crimping is very well done. I prefer use naked cable but if you need to crimp your cable, it's the best!
Il faut du 1,5
Pour visser
cyril p.
Bonne finition
Fini bien un câble
cyril p.
Bonne finition
Fini bien un câble
cyril p.
Bon câble
Bon câble facile d'utilisation
cyril p.
De bonne facture pour ce tarif
Jon Y.
Solution intéressante pour calmer une électronique à sonorité agressive
Le Furutech Alpha Line Plus vient remplacer un Audioquest Tower entre mon préamplificateur et ampli casque.
Mon retour en quelques mots :
- Les graves sont mieux détourés, il y a moins de rondeur, c'est moins gras et ils deviennent plus impactants.
Ledit impact, plus propre et expressif qu'auparavant.
- Les médiums gagnent en définition ainsi qu'en détails.
- Les aigus ne sont plus du tout agressifs, ils s'adoucissent. Ils deviennent un peu plus chaleureux.
Le test sur "Pendulum - Come Alive" est révélateur (morceau très chargé en aigus).
La scène gagne en naturel.
Pas de sibilantes entendues, pouvant être présentes avec le morceau "Tango in the Night (2017 Remaster)" de Fleetwood Mac.
La différence de dynamique est notable, l'impact de la batterie est saisissante (toujours avec Fleetwood Mac).
Idem sur des morceaux électro (Grandson, Daft Punk), rock (Lenny Kravitz) et metal (Metallica).
Le détourage des instruments et la lisibilité est meilleure (perçu notamment avec "Are You Gonna Go My Way" de M. Kravitz).
Ces changements sont des plus appréciables pour mon système qui avait une tendance à sonner mou et fatigant avec l'Audioquest Tower.
En résumé, ce câble assagit les systèmes montants et fatigants mais n'enlève pas les détails. Il permettra aux graves de s'exprimer pleinement et librement.
On appréciera une belle lisibilité de la scène sonore notamment grâce au détourage des instruments.
Je le recommande !
