ASCILAB C6B Bookshelf Speakers Metallic Gray (Pair)
The AsciLab C6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a 1“ alumina-ceramic dome tweeter with custom waveguide and phase tapping, combined with a 6” woofer with alumina-ceramic cone, all housed in an enclosure with passive radiator.
By buying this product you get 159 loyalty points
Reference : 20946
1 590,00 €tax incl.
1 325,00 € tax excl.
AsciLab C6BBookshelf Speakers 250W 4 Ohm 85dB Metallic Gray (Pair)
Photo of Ascilab C6B
The AsciLab C6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a 1“ alumina-ceramic dome tweeter with custom waveguide and phase tapping, combined with a 6” woofer with alumina-ceramic cone, all housed in an enclosure with passive radiator. The 5x8" passive radiator provides a considerable boost at low frequencies. Their design allows for lower crossover points and reduced distortion, for an extremely clear sound reproduction. The C6Bs feature a fourth-order crossover at 1.1kHz, optimized via Klippel NFS, and support up to 250W of amplification. They are ideal for demanding audiophile or professional studio use.
For other colors, please contact us via our contact form.
C6B models
AsciLab C6B: Optimized tweeters for controlled sound dispersion
AsciLab C6B tweeters feature a waveguide and internal phase plug designed to precisely manage sound dispersion. These elements avoid phase interference, reduce internal resonance and improve off-axis dispersion. The advantages of this type of configuration translate into a more linear frequency response, reduced distortion and better spatialization of sound, offering a more coherent soundstage.
Zoom in on the C6B tweeter
Zoom in on the C6B woofer
AsciLab C6B: 6" woofer in alumina ceramic
Despite their compact size, the 6" woofers in AsciLab C6B loudspeakers are capable of delivering powerful, well-defined bass in spaces of up to 25m². Alumina ceramics provide exceptional rigidity for faithful, distortion-free reproduction, even at high volume, thanks to a strong limitation of cone deformation at high sound pressure. High-performance and dynamic, these woofers also come with an aesthetically pleasing protective grille, combining performance and design.
AsciLab C6B: A 5x8" passive radiator
AsciLab C6B speakers feature a passive radiator at the rear. This limits unwanted resonance while optimizing low-frequency reproduction. This solution also helps reduce distortion at high volumes, unlike a bass-reflex port, which can generate turbulence. AsciLab has also chosen to integrate a passive radiator in order to maintain a relatively compact speaker design.
C6B passive radiator
Product typePassive speakers
Design2 way
Tweeter1" alumina ceramic dome tweeter
Woofer6" alumina-ceramic woofer with aluminum chassis
DesignWith passive radiator
FinishMate
Crossover frequency1.1kHz
Sensitivity85dB @ 2.83V / 1M
SPL Max. (Full-bandwidth)99dB SPL
SPL Max. (>100Hz)105dB SPL
Frequency response-3dB @ 50Hz / -6dB @ 41Hz
ImpedanceNominal 4 ohm (min 200Hz / 2.6 ohm)
Recommanded amplification50W - 250W
Connection to speaker terminalsBanana 4mm
Bare wires
Forks
Dimensions40 x 20.3 x 26.5cm
Weight8.4kg/speaker
ColorMetallic Gray
Package1x Pair of AsciLab C6B speakers
(Please note that woofer grilles are optional and are not supplied with C6B speakers)
ColorGray
Impedance (Ω)4
Efficiency / Sensitivity (dB)85.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
Power (W)250.0
Number of ways2
Number of loudspeakers3
Speaker typePassive
Speaker form factorBookshelf speaker
Dingue juste dingue
Je suis totalement novice dans le monde de la hi-fi, mais pour mes 20 ans je voulais vraiment me faire plaisir avec un premier système sérieux. Du coup je me suis énormément renseigné, j’ai regardé des tests, comparé les mesures et accumulé un maximum de data avant de choisir.
Évidemment, c’est mon premier hi-fi system, donc je n’ai pas de vraie référence haut de gamme — seulement le son de ma TV et de mon téléphone. Mais justement… la différence est à des années-lumière. La meilleure analogie que je peux donner : c’est littéralement comme passer de la 360p à la 4K. Le changement est phénoménal.
Et honnêtement… je ne m’attendais pas à ça. À ce prix, le rapport performance / qualité est tout simplement du jamais vu. D’après tout ce que j’ai compris des mesures et des reviewers, ces enceintes jouent clairement dans une catégorie bien au-dessus de leur tarif.
À l’écoute, ça se confirme immédiatement : c’est clean, détaillé, naturel et addictif.
Pour un premier système hi-fi, je ne pouvais pas espérer mieux. Je suis plus que satisfait — pour moi ce sont tout simplement les meilleures enceintes du monde dans cette gamme de prix It’s just amazing.
This review has been posted for ASCILAB C6B Bookshelf Speakers 250W 4 Ohm 85dB Metallic Gray (Pair)
The AsciLab C6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a...
