Jerome L.
Rémi D.
N'hésitez pas
Antony C.
Best rapport Qualité/Prix !
Hervé T.
Super Ampli
Très bon matériel, à la fois puissant et précis. Son clair et détaillé, graves percutants et vifs. Utilisé en gain moyen en XLR. Écoute addictive!
Joel G.
Feels and looks good
The product looks solid and well built. Since it’s arrival has been used for a new position of my amp and speakers and that involved new (longer and different brand of) speaker cables so the whole sound in the room is currently different. I can’t therefore say if my equipment sound better with this power distributor, but I like the built
Pascal P.
Super rapport qualité prix.
Je viens de relier en ampli classe A/B 90 watts et une paire d'enceintes Q-Acoustics 3020 éloignés de 10 mètres. J'ai donc utilisé 2X10 mètres de ce câble et ça marche très bien pour le prix. Je l'ai conseillé à un ami audiophile qui en a utilisé pour brancher des voix du théâtre. Il est satisfait aussi. Rien à dire, ce câble est plus que correct.
Johan v.
Good stuff
Not much to say about it it damps metal sheet very well so it will work on you Thorens TD1..sub chassis as damping material just have a look at the 160S innards and see what the factory did for ideas.
Large un-damped metal CD player parts are also a good candidate just be careful not to block the laser unit in any way.
Johan v.
The beauty and the tuff one
This is are very stiff cable but making a interconnect with it is certainly worth it.
The conductors are double insulated so after the first layer there is a ptfe layer so be aware of that.
The outer sleeve is also made of two layers of witch one can be peeled of if you are careful not to cut too deep this makes smaller cable entrance diameter RCA plugs possible to fit.
Compared to a expensive silver cable it loses some fine nuances but gains in solidity and warmth it is not a"warm" cable but very neutral and resolving.
Milan D.
FX-AUDIO TUBE-06 MKII Tube Preamplifier 2x 6N3 DAC ES9018K2M CM6642 Subwoofer 24bit 192kHz Silver The FX-Audio TUBE-06 MKII is an affordable and efficient tube preamplifier. Its preamplifier stage is based on the use of a pair of 6N3 tubes. It is associated with a...
Livraison rapide.
Johan v.
Exellent
My favourite RCA plugs very well made nicely packaged like jewellery!
Good sound no artificial colouration that I can hear.
Johan v.
Good quality item
Chosen for the small mass of this connector and yes the amount of metal in the signal path makes a audible difference.
Used by many manufacturers of equipment even very expensive ones not necessary this brand but this model.
Johan v.
Good quality item
Johan v.
Replaced a Pr.Ject phono cable
This cable replaced the cheapest Pr.Ject din to RCA cable with good results, more extension on both frequency ends and more detail.
If you have one of these Pr.Ject cables on your record player replace it if you want to hear what your cartridge is capable of, so recommended.
Merci Beaucoup Audiophonics for having all these goodies is house and so quickly delivered!
Maximiliano L.
Good
Very useful and convenient.
Maximiliano L.
Good
Nice looking knob
Jam M.
bon taraud pour les métaux tendres
Un seul taraud pour remplacer les traditionels triples tarauds, cela permet de gagner du temps. Mais attention à bien démarrer le taraudage afin qu'il soit perpendiculaire à la pièce.
Jam M.
Super précision et maintien des NE5532 et autres
Permet d'éviter de souder les circuits directement sur le circuit imprimé.
Jam M.
Insulation Spacer Transistor Components TO-220 / TOP-3 (Unit) This isolation spacer has dimensions that allow it to be adapted to certain electronic components, in particular transistors in TO-220 or TOP-3 packages. It will allow you to...
Conforme
Permet de fixer des TDA7294 sur un dissipateur.
Jam M.
Précis et propre
Elle me permet de réaliser des trous dans l'alliage d'aluminium.
Jam M.
Bien pratique
Elle me permet de réaliser des trous dans l'alliage d'aluminium. Travail précis.
M'ayant envoyé une cloche de 22 mm, Audiophonics m'a expédié rapidement une cloche de 18 mm dès que j'ai signalé l'erreur.
1877PHONO FUSION PURE RCA MKII Modulation Cable PC-OCC RCA-RCA (Pair) 1.5m The Fusion cable series is the perfect integration with pure silver strands and Japanese monobrin PC-OCC copper. Designed with rigour and great precision, this Fusion series has...
Tres bon cable
Belle construction.
Cable pas trop lourd et assez flexible qui ne fatiguera pas vos connecteurs.
Tres equilibre.
Belle extension avec des details fouilles mais pas mis en avant.
Dynamique mais capable de plenitude.
Image construite et assez precise.
Tres bon rapport qualite prix
gilles A.
IBASSO AMP14 Korg Nutube Amplifier Module for DX320 / DX300 DAP Blue This iBasso AMP14 amplifier module is specifically designed to accompany the brand's DX320 and DX300 DAPs. Each module is hand tested and calibrated at the factory to provide...
ampli au son trés équilibré et la douceur du "tube"
cet ampli NUTUBE a un rendu sonore superbe ! complémentaire aux amp 12 (plus technique) et amp13(son plus analogique avec une légère mise en avant des basses). beaucoup moins de parasites avec le wifi activé que l'amp13
Erwin S.
Initially good, but sensitive and now broken
RCA inlet looks like a high quality, but the plug itself is made out of a thin folded sheet. When pushing an RCA plug in it under an angle, first the plastic insert breaks and then also the ring ruptures open. Had to take them out again, completely broken. So it is very important to push the RCA plug completely straight into the RCA inlet.
MANSOUR S.
This DAC module is a giant killer
Installed one of these R2R DACs today, coupled with Linear PSU and I2S direct from Raspberry PI 4.
After 4-5 hours playing, it is actually comparable with Denafrips Pontus 2, only diff is as thread starter mentions Pontus 2 is cleaner, probably because of all that power filtering. In the future I will add more capacitance to the PSU and see if that makes a different. Else it is a bargain. Make your own and pay 10 times less.
This replaced a Denafrips Ares 2 and no regrets.
More air, details, natural tone and off course no Delta Sigma harsness.
Quick delivery and quick response on tech questions from Audiophonics. Cheers
Thierry S.
Très bon rapport qualité-prix
Pour faire cours: très détaillé et très aéré, mais attention dans certaines configurations on peut être très proche du clinique.
Thierry S.
ARYLIC S50 PRO+ Network audio player DAC ES9023 ADC WiFi AirPlay Bluetooth 5.0 aptX HD Arylic proposes with its S50 Pro+ a connected stereo preamplifier, having the particularity to take advantage of a complete connectivity with WiFi and Bluetooth 5.0 reception....
La taille mais pas le son d'un gadget
Tout fonctionne correctement.
Le dlna ne pose aucun soucis et est télécommandable par toutes les applications que j'ai essayé.
Le wifi, je ne l'utilise pas, juste pour les maj, là un peu compliqué par contre.
La sortie analogique n'est pas ridicule.
Mais quel dommage que la sortie numérique soit limitée à du 16 / 44.1!!!
Pour du Bitperfect haute résolution regardez du coté des WIIM, Olio ou Octavio
Thierry S.
Tout d'un (très) haut de gamme
Je ne vais pas contredire les avis précédents, tout y est.
Reproduction tendance neutre ( pas typée)
En fonction des enregistrements: grande transparence, image large et profonde, excellente macro et micro dynamique, grande fidélité des timbres, etc.
Par contre, ne pardonnera rien.
L'appareil chauffe et les aérations sont dessous, donc n'hésitez pas à rajouter des pieds plus hauts et ne rien poser dessus.
Sensible au cordon et à la phase secteur.
Thierry S.
Très Très bon rapport qualité-prix
Apporte beaucoup de détourage, caractéristique de l'OCC et une très bonne profondeur.
Si votre casque est un peu décharné, par contre, passez votre chemin.
Peu microphonique, mais vous pouvez lui rajouter une gaine textile sans trop la tendre.
Les fils ne sont pas repérés, vous aurez besoin d'un multimètre et d'un fer qui chauffe beaucoup.
Thierry S.
Female Balanced Jack 4.4mm Connector Gold Plated Ø8mm This female Jack 4.4mm connector of good quality benefits from gold plated contacts, ensuring a good transmission quality and an excellent resistance to oxidation. It accepts...
Les pinoches seraient deux fois plus grandes la soudure en serait grandement facilitée.
Thierry S.
Fonctionne Parfaitement
La prise Toslink a juste un peu trop de jeu.
Thierry S.
XDUOO XD05 BAL Portable Balanced Headphone Amplifier 2x ES9038Q2M XMOS Bluetooth 5.0 32bit 768kHz DSD512 Silver The xDuoo XD05 BAL is an enhanced version of the portable headphone amplifier XD05 PLUS. Its digital/analog conversion stage has been updated, its Bluetooth wireless...
Une alternative très sérieuse aux DAP
N'a pas a rougir face à des Kann alpha et autres N6 ii.
La possibilité de changer facilement les Aop n'est pas à négliger du tout.
Très bonne autonomie.
Gain et capacité en courant suffisante pour driver la majorité des casques.
Attention, avec les Intras très sensibles, vous devez vous fabriquer un atténuateur, ou en trouver un chez Ifi par exemple.
Bluetooth relativement anémique, 6 mètres de portée.
Sortie 4,4 très raide.
Thierry S.
SPARKOS ARIES FULL Discrete Preamplifier Headphone Amplifier Sparkos offers with the Aries a high-end preamplifier and headphone amplifier for audiophiles looking for the best sound quality. It is based on an architecture composed solely...
Un fil droit avec du gain ?
C'est en tout cas ce que revendique le concepteur et c'est ce que je ressent, un effacement total devant la musique.
Voilà tout est dit.
Quelques fonctions bien pensées, une balance qui ne dégrade pas le son, une sortie casque et une sortie préampli qui peuvent fonctionner simultanément et qui sont débraillables séparément.
L'appareil ne chauffe pas du tout.
Attention a la performance du cordon secteur.
Ne manque qu'une télécommande.
Bert D.
a very small big sounding dac
The dac sounds very good, neutral and balanced. Love to listen to music. I use it with my iPhone SE 2022. There are two problems: 1. the cable between iPhone and dac has to be a special one, you need carefully chose an otg cable. 2. I did buy that cable in the shop of E1DA but it's very vulnerable when you use it during traveling and having the phone in you pocket. It's not special related to this product but making your audio portable by Phone, bend cable and dac.
Derrick S.
XDUOO MU-602 SPDIF DAC PCM1793 24bit / 192kHz xDuoo proposes with the MU-602 a small pure SPDIF DAC, both compact and efficient. If it remains relatively simple thanks to its 3 buttons on the front panel, it nevertheless...
Good sounding DAC
I like the sound very much and the onboard EQ is very handy !!
IOANNIS A.
Πάρα πολύ καλό.
Το έχω συνδέσει σε παθητικό προενισχυτή με ενεργά ηχεία.
Του έχω βάλει γραμμικό τροφοδοτικό 7,5V 1Α.
Με διακοπτικό τροφοδοτικό 9V 2,77Α έπαιξε χειρότερα...
Επίσης οι δύο πυκνωτές 390pF της Evox αλλάχθηκαν με Wima FKP και έπαιξε ακόμα καλύτερα.
Έπαιξε καλύτερα από dac των 319,00 euro...
Οπότε είναι ένα δώρο σ' αυτή την τιμή.-
Freddy D.
Cable Isopod
Cable idéal pour le câblage interne , très facile d'utilisation !
Freddy D.
Boitier Ampli de Puissance
Livraison très rapide , article de bonne qualité , très belles finitions , c'est du lourd ! Prix de reviens inférieur a ceux pratiqués en Chine ! Bravo ...
Hendrik W.
OPA1622 nice improvement
Decided to replace the JRC4556AD in my Denon AVP-A1 phone amp stage. What a good improvement this was (using Qobuz), vocals crystal clear, highs more sparkling and a bit more bass (but much more tight). I didn't use the pramp for headphone listening because it was dull, lifeless and floppy bass with 4556, now I enjoy it again.
While I was at it also replaced most resistors, capacitors and installed opamp socket for easy opamp rolling.
Emin U.
JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 2.2μF Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every...
fantastic
sound quality, scene creation, softness,detail, i loved the all. i liked it more than dayton mpts
Emin U.
fantastic
Dhafer D.
DAC unique dans son genre
Je l'ai acheté pour un systeme composé de hauts parleurs focal chorus 5 et d'un ampli marantz pm5005 afin de calmer
les twetter des focal. Et bien c'était pil poil ce qu'il fallait pour ça. Donc je confirme bien que c'est un dac qui
n'est pas brillant et qui n'est pas fatigant.
Mais en meme temps il y a beaucoup de justesse et de neutralité sur les autres plages de fréquence. Il est assez transparent je trouve car il n'amplifie aucune plage par rapport aux autres.
Tout fonctionne correctement, meme le DSD avec moode audio, du premier coup sans intervention de ma part.
La télécommande est meilleure que les anciens modele, il suffit de la pointer vers le dac et ça marche sans soucis
J'aime ce dac franchement.
Frederic G.
FERRUM HYPSOS Hybrid HiFi Power Supply 5V-30V Adjustable The Ferrum Hypsos is a high-end power supply, offering exceptional technology and performance to give your HiFi audio system an extremely clean power supply for optimal sound...
Cette alimentation est très bien construite et ne pose aucune difficulté à paramétrer mais il faut faire attention à ce que l’on fait. Il faut bien vérifier ses choix de tension et ne pas risquer d’inverser la polarité…Un large éventail d’appareils est déjà dans sa base de données. L’hypsos alimente mon Chord Mscaler de manière impeccable. Le son est plus neutre et plus musical qu’avec l’alimentation d’origine, plus posé, plus normal. Elle est « Meilleure » également que la Sbooster qu’elle remplace. La Farad super 3 que j’utilise sur un Emerson digital est très proche mais peut-être un poil moins neutre, moins « rapide ». Le gros avantage de cette alimentation est de ne plus avoir à la remplacer à chaque changement d’appareil! Je suis très satisfait de cet achat même si cela représente un certain investissement.
William G.
MUNDORF MCAP SUPREME EVO SILVERGOLD OIL Capacitor 1000V 1µF Since 2015, the MCap Supreme EVO SilverGold and MCap Supreme EVO SilverGold OIL capacitors have been the undisputed top-of-the-line products from Mundorf. It combines all of the...
Supreme capacitors
Used these to replace coupling capacitors in a Plinius M16 Preamp- simply stunning improvement - These provide detail balance / neutrality and depth with very realistic spatial imaging
Christian L.
ampli TDA7294
bien reçu, et installé, tout marche à merveille !! nickel !
R A S
Commandé dimanche, reçu mercredi. Et ben........................ rapport qualité/prix pour moi c'est parfait ! Ce câble est monté en liaison ampli, pré ampli marantz 140/ 3200 en remplacement des anciens : Analogue interconnect qui devaient avoir au moins 20 ans. Bien construit, la connexion se fait normalement, même dans les rca rapprochées. Je pense équipé toute mon install avec ce câble. Quand à l'écoute ? Difficile à dire, mais meilleur qu'avec les anciens .
Nikolaos R.
DAYTON AUDIO PC68-4 Full-range speaker 20W 4 Ohm 86dB 120Hz - 17kHz Ø6.3 cm A compact wideband loudspeaker with beautiful finishes. Ideal for building/repairing a small audio system.
The sound is clear, but it does not have any low frequencies due to its size. Good choice without much demands on its sound!
Nikolaos R.
Excellent quality. Extremely clear sound, but poor in low frequencies due to its size. Excellent choice!
Jose l.
XDUOO TA-22 Tube Headphone Amplifier 2x 12AU7 DAC 2x ES9038Q2M Bluetooth 5.0 aptX HD LDAC 32bit 384kHz DSD256 MQA xDuoo unveils with its TA-22 a beautiful headphone amplifier and DAC combo with a neat design. This one embeds quality components in order to provide a sound restitution both...
très bon son
j'avais oubliés les 5 etoiles .
Jose l.
très bon son
je l'ai acheter pour sa sortie tubes , car mon ampli rotel manquait de matière dans les medium sur les voix , problème résolu avec ce préampli très bien fini . Et comme toujours depuis plusieurs années un très bon service de la part de toute l'équipe audiophonics. Compter toujours un rodage plus ou moins 100heures , attention quand un appareil ne fonctionne pas pendant quelques jours il faut refaire un petit rodage de quelques heures surtout en hiver.
M A.
IAN CANADA FIFOPIMA V1.5 Reclocker Master Clock Mode for Raspberry Pi The Ian Canada FifoPiMa is an audiophile I2S/DSD/DoP reclocker for the Raspberry Pi running in Master Clock mode. Its functionality is equivalent to that of a FifoPiQ3 combined...
top product from ian canada
nice addition to the sound, works great with a raspebrry pi.
highly recommended.
Stephane B.
KHADAS TONE2 PRO DAC Headphone Amp ES9038Q2M 768kHz DSD512 MQA Full Decoder Black Meet the famous digital to analog conversion circuit (DAC) based on 32 bit ESS ES9038Q2M chip with PCM support up to 768 kHz and native DSD512 and even MQA. New headphone...
Fantastique DAC
Petit, mais inspirant confiance, je ne l'ai jamais fait tomber, mais il ne semble pas craindre les chutes qui peuvent arriver dans le quotidien.
Il répond parfaitement à mes besoins de "nomadisme" sédentaire, c'est-à-dire de pouvoir le déplacer facilement entre plusieurs lieux d'écoute, en le raccordant à divers matériels tels qu’ordi et smartphone en USB et ampli en RCA Balance.
Aucun souci avec un casque à 300 Ohm.
En utilisation intensive, il chauffe un peu, rien d'alarmant. Même si c'est une évidence, il faut simplement le disposer à un endroit qui n'entrave pas la dissipation de la chaleur
. Le son est une affaire personnelle, il sonne plutôt large à mon oreille, sans aller trop loin, réaliste et plutôt neutre.
Stephane B.
Optical Fiber HDMI 2.0 Cable HDCP 2.2 4K HDR ARC 10m This HDMI 2.0 cable integrates as conductors beams of Optical Fiber. These provide an excellent transmission rate up to 18Gbps, very good signal stability, extremely low...
Ce câble remplace avantageusement un ancien câble hdmi, certifié 1.4, qui ne permettait pas de faire passer correctement de la 4k, Dolby vision/HDR10+.
A présent c'est fluide et parfaitement reconnu par la TV, qui applique ces paramètres les plus poussés sans soucis, également dans le cas du Gaming à 60fps.
Ce câble HDMI 2.0 est 3 fois plus fin et souple que mon précédent câble 1.4
Commande passé un mercredi soir, livré le vendredi midi, dans un colis bien protégé.
Oliver S.
Just brilliant... :)
This amp replaced an Audiophonics MPA-S250NC which already was a steal for its price. The LPA-S400ET is better in every aspect, it´s even quieter, more resolving & liquid, greatly enhanced authority and control in the bass region. I bypassed the gain stage, the source is a DAC with 200 Ohm output resistance, driving the amps´ symmetrical inputs. Since I am using horn speakers, the too low output voltage of the DAC is no problem. BTW, volume control is done in the digital domain (MiniDSP), something I would have never expected to be a good sounding alternative, yet it is. All in all I am very happy, thanks a lot Audiophonics for this really great offering - these are wonderful and affordable times for open-minded listeners not only looking at brand names but end results... ;)
