Une révélation
Gionatan R.
Bello ma fragile
Mi piace molto questo eccitatore. Per le dimensioni che ha il suono è buono, però i due punti di connessione sono molto fragili...
François G.
Customers reviews - There are 19456 reviews.
Olivier P.
Très bonne liaison numérique 75 ohms entre Audiolab 6000cdt et hegel h190
Comparé à 2 autres câbles
C'est lui qui remporte le match. Il est neutre et évite de dépenser des fortunes.
Mention spéciale pour la fiche BNC qui verrouille idéalement le câble.
Vladimir S.
Buy and wait for ugly burn-in...you will be more than satisfied.
I mounted the cable to cheap plastic plugs (EU Power Plug 12 euros for 2) 2x1.5m
After 2 weeks of constant burn in I connected the 2 cables to 2 sbooster power supplies to my chord qutest and Auralic Aries
The sound is warmer with a good base foundation without losing resolution, more organic mid-range and the most important: !!! extremely musical and natural sound with a good size of the sound image.
I compared with transparent power cord 500 euros and up and I was not disappointed.
Frédérick M.
Gustard r26
Très bon produit beaucoup de détails une belle amélioration comparé à mon cxn v2 .et puis un grand merci a l équipe très professionnelle et très réactive de audiophonics.recu très rapidement
Grut S.
1MII B08S Amplifier 2.1 Class D Bluetooth 5.0 Receiver aptX HD QCC3034 2x50W / 4 Ohm The 1Mii B08s is a Bluetooth receiver with integrated amplifier that is both affordable and powerful. Incorporating a Qualcomm QCC3034 chip, it features Bluetooth 5.0 reception...
Petit ampli qui bouge très bien une paire de cabasse, bonne connexion et bonne puissance, le son est pas mal du tout...
Sorin P.
Quality for good price
Excellent build quality, works well, reasonable price. Thank you!
Alain C.
[GRADE S] HDMI 2.1 Cable 8K 60Hz 48Gbps HDR eARC ALLM Dolby 3m Refurbished product - Grade S This high performance HDMI 2.1 cable supports 8K 60Hz and 4K 120Hz video transmissions with a bandwidth of 48Gbps. Its conductors ensure an...
cable hdmi 2.1
Excellent cable 2.1 . La qualité de l'image est encore supérieur par apport à un cable 2.0. Très satisfait de mon achat
Alain C.
CABLE RJ 45 KAIBOER
Très bon cable rien à en redire
Bernardin A.
Top à condition d'être outillé.
Rien qu'au poids, vous sentez que ce n'est pas du cheap et les finitions sont nickel.
Pour chipoter, les visses de serrage en torx ou compatible étoile de petite taille, tout le monde n'a pas ça.
Personnellement, je recommande.
Bernardin A.
Presque top!
Beau produit, de qualité, pour chipoter une meilleure finition du bouton sélecteur, les arrêtes notamment.
J'ai testé 4 sources actives en même temps dont une phono, souvent problématique, et aucune interférence. En revanche, me concernant, un ploc dans les enceintes en cas de changement de sources actives.
Laurent P.
Acheté comme selecteur de sources , la fonction preampli est un plus avec les reglages basses /mediums/aigues et ou bypass .
Je trouve ce preampli très detaillé peut être un peu trop à mon goût avec mon ampli nc 250 ,enceintes magnat transpuls 1500 et ma source nvidia shield.
Je lui reproche un selecteur de sources et des potentiomètres sans graduations et 2 voyants rouge aveuglants.
Malgres cela , son prix vaut le détour et peu faire des heureux assurément!
Laurent P.
Très bon petit dac au look sympa avec un rendu precis sans être trop froid .
Il fonctionne aussi bien avec mon pc windows 10 et ma invidia shield .
" Pour les petits budgets qui veulent quand même de la qualité" c'est le bon choix !
Laurent P.
AUDIOPHONICS MPA-S250NC xlr
J'ai cet ampli depuis 2 ans maintenant et il me satisfait toujours autant !
Il fonctionne tous les jours de 15h à 22h30 et du matin jusqu au soir les week-ends.
Dès que vous changez de source, cela s'entend donc pour moi cet ampli est transparent .
Tres bonne dynamique avec de beaux medium et une spacialisation que j'apprecie !
Zero bruit de fonctionnement et de souffle dans mes enceintes de 95db (magnat transpuls 1500)
Si je devais changer aujourd'hui cela serai pour le nc 400 / 500 ou 600 pour etre sûr de ne rien perdre en voulant me faire plaisir et peut etre gagner encore ! la puissance apporte normalement plus de détails et de peps !
Merci audiophonics pour cette petite boîte qui embarque juste le principale pour faire de la musique.
Imre S.
Almost good..
Pretty good little amp, good sound. Treble and bass are good.
But it has its problems, unfortunately: When you turn it on, you hear a little electronic noise for a few seconds and then a soft crackling sound comes out of the speaker. Bluetooth connection is still fine, but there is some white noise.
Pascal F.
AUDIO-GD HE-1 MK2 Class-A Balanced Preamplifier ACSS XLR RCA Again Audio-GD strikes hard with its HE-1 MK2 of the series HE (evolution MASTER series) proposing a symmetrical Class A preamplifier of an exceptional quality. KEY POINTS:...
audioGD HE1 MK2
Une fois à température les transfo ronronne fort sinon très bon dans la reproduction des détails bon produit merci
Mickael c.
Utilisé en 5 et 6m sur des bw 801 alimentée par des mcintosh 601.tres bon, équilibré, dynamique et scène très correct. Je recommande
Jean-Claude P.
Mini mais costaud
Livré avec câble USB bas de gamme très court ... dans mon cas trop court ! commande d'un câble plus long chez Audiophonics et livré dans les temps.
La qualité est très étonnante pour un si petit DAC au prix raisonnable. Il prendra sa place dans une chaîne à plusieurs millier d'euros sans problème et si vous n'êtes pas satisfait du résultat vous devrez peut-être aller voir au niveau de votre ampli ou de vos enceintes ... mais là c'est une autre histoire ...
En conclusion: pas assez cher mon fils, pas assez cher...
Jean-Louis m.
Un bon ampli de Classe D
Je possède un D5pro et suis passé sur un AD-9 qui semble "marcher" tout aussi bien. Mes oreilles étant passé en Classe D je n'ai pas trouvé une grande différence. Pas de bruit de fond son bien spatialisé sur Mes colonnes triangle et mon sub-woofer Triangle.
A noter pas d'interrupteur physique, l'ampli se remet en On au retour du courant malgré l’Arrêt via la télécommande avant coupure de l'ensemble hifi (économies de veille oblige). Sinon RAS
VIBORG XM-202G Male XLR Connector 3 Poles Gold / Silver Plated Pure Copper Ø11mm Black (Unit) Viborg offers with its XM-202G a high-quality 3-pole XLR connector. Its contacts are indeed designed in pure Copper with triple plating Copper OFC, Silver and Gold, to ensure...
Bien aussi
J'avais déjà ces xlr en rodium et j'ai opté pour les 9r pour le câble AES/EBU. Je n'ai pas remarqué de grosse différence avec la version rodium. Montées sur un NEOTECH NEI-2001 ça marche d'enfer.
Bonnes prises
Ces xlr de Viborg sont de très bonne qualité, mâle et femelle. Montées sur un NEOTECH NEI-2001 le son est excellent, bien meilleur que du Qed au même prix.
Très bon câble monté sur des VIBORG XF-202R mâles et femelles pour du xlr. Le son est très propre, détaillé, transparent et avec de bons timbres. Le diamètre des fiches et du câble s'emboîte parfaitement sans avoir besoin de rajouter d'embout. Attention à la soudure, du flux de soudure est nécessaire. Je recommande.
Alexander D.
Kingsound M-03
I am really impressed with the power of the Kingsound M-03! Before I used the iFi IESL powered by the Topping LA90.
I am getting better results with the Kingsound M-03!
Thank you for the fast delivery!
Krasimir M.
Daiton audio os2hd
Producto de calidad cambio de sonidi los bajos mas controlados
Krasimir M.
AUNE XC1 Master Clock OCXO 10MHz Black The Aune XC1 is an external master clock, using a high quality OCXO and featuring four isolated outputs, capable of operating simultaneously. Its ability to provide an extremely...
Aune xc1
exselente envio, producto de gran calidad
Marek S.
Superbe ampli!
Détaillé, précis, bande passante très équilibrée, souffle quasi inexistant. Fonctionne très bien avec le Topping PRE90. Au vu de la puissance de sortie du Topping - il faut seulement dès le départ passer les cavaliers de gain en position by-pass.
Puissance largement confortable pour mes Tannoy D700 et ma pièce de 25m2. Je ne parle pas de musicalité - j'aime des appareils transparents, détaillés et neutres et je soupçonne que dès qu'on parle des appareils "très musicaux" il est plutôt question de distorsions agréables et pas forcément de la fidélité. Bref - pour moi il est très musical, les instruments et les voix sonnent authentiques, sont très palpables, bien à leur places, on est plongé dans l'espace qui les entoure, la scène sonore est tridimensionnelle .
La finition est impeccable, sobre, très agréable visuellement et au toucher.
Très bonne alternative comparé aux amplis beaucoup plus chers et n'oublions pas la faible consommation de la classe D - rien que ce fait place cet ampli bien au dessus des autres de classe A ou AB qui chauffent et/ou consomment bien d'avantage.
Acheté suite au retour (suivant l'aimable conseil d'Audiophonics) du HPA-S400ET Sparkos Edition qui, bien qu'excellent lui-aussi, s'est avéré inutilement plus cher pour fonctionner avec mon Topping.
A mon avis - fortement conseillé!
Jose l.
trés efficace
c'est le troisiéme que j'àchéte brancher sur mes amplis plus box.
Peter S.
Better than others!
I had a similar mat with Cork & EVA (also with round recesses) but it was made less accurate - therefore it "dished" after just a few weeks and would not lie flat any more on the turntable.
This product is much more solid and thighter - also looks and feels much more sophisticated.
Mitigé
Cc et accessoire est indispensable pour contrôler l'allumage et l'extinction de plusieurs amplis en même temps, mais il est cher et mal foutu.
Déjà le câble Jack mono n'est pas inclus !
Une fois installé la prise jack se retrouve en haut et le câble en l'air et depasse de l'ampli.
J'ai du acheter une rallonge de câble d'alimentation pour mettre ce gros truc au sol. Coût total 45€ pour "juste" commander l'allumage d'un seul ampli.
Très cher pour ce que c'est.
Frederic F.
Une merveille
De tous les amplis casque que j'ai possédé (de 100 à 1500 e) , c'est mon préféré sans hésitation.
Utilisé la plupart du temps avec dac Micromega Mydac et casque Shure srh 840 (44 ohms).
Transparence totale,aucune distorsion, mais sans froideur.
Il ne rajoute rien, n’enlève rien, parfaitement fidèle à la source (qui a donc toute son importance).
Aucune dureté, c'est fluide,spontané, la musique vit.
Le grave, dégraissé et restitué avec de l'impact, descend bas, de manière ultra rapide et articulée.
Il est allumé tous les jours, c'est un signe qui ne trompe pas !
Thomas B.
An amazing piece of engineering
The built quality of this amplifier is top notch. I use it to power NS-10M‘s and it is exactly what I was looking for. Undetectable noise level, pristine audio quality and ample amounts of power.
What I love most about it is that there is absolutely zero mechanical (meaning: transmitted through the air) hum or buzz, what a revelation after years of having amps with humming transformers.
bon travail les gars, merci!
Thomas B.
Nikolaus N.
Spitzenklasse
Ich hatte zuvor den SMSL m400 und möchte einige Vergleiche ziehen.
Der EX spielt obenrum mit viel mehr Luft und Räumlichkeit und nach unten mit Kraft und Autorität!
Ich bin von dem Klangbild fasziniert. Der Hintergrund ist lose und schwarz, alles ist an seinem Platz, nichts drängelt sich hervor. Er wirkt richtig ruhig und entspannt - wenn es mehr wird, dann legt er los! Ingesammt sehr feinnervig/samtig.
Eric d.
[GRADE B] ARMATURE PHOBOS AB Integrated Amplifier 2x300W / 4 Ohm USB DAC Pre-out Refurbished product - Grade B The PHOBOS armature amplifier fits in with its time. Featuring a generous power stage with a high current capacity Phobos faces the most complex...
Excellent intégré, bon à tout faire.
On sent qu'il est capable d'alimenter n'importe quel type d'enceintes avec sa grosse réserve de courant.
Scène sonore extrêmement précise, sans doute pas le plus timbré de tout ce que j'ai pu écouter depuis 40 ans..
Utilisé en alternative à un PSE 300B class A ( inégalable), je me surprends à l'écouter pratiquement en ampli principal.
Grosse amélioration du DAC intégré depuis l'achat d'un câble RCA/BNC connecté au lecteur réseau.
michel m.
Ad18
Colis bien reçu et rapidement ...
Quelle ampleur et une certaine autorité dans les basses ...
FIP radio en streaming "Ça bouge"
Dans Foobar bien choisir "KS kernel streaming" pour shunter Wind...s
Vincent L.
Parfait!
Le XMOS U208 me sert d'interface entre mon PC et un DCX2496.
Fonctionnant dès le début sous Windows 11, je n'ai pas eu à installer les pilotes.
À l'écoute rien à signaler, très bon.
Par contre la LED rouge haute luminosité en façade se fait trop voyante.
Liviu S.
Second display for Moode
To use the second display with Moode Audiophonics provide the solution here: https://github.com/audiophonics/Evo_Sabre
Thanks for doing this
Excellante fiches bananes
Top des fiches bananes a ce jour pour ce prix.(Sur mon systeme)
Nicolas J.
Interface reconnue automatiquement par Windows 11, je n'ai pas eu besoin d'installer un driver. Je ne ressens pas de latence entre le flux audio et vidéo géré par le PC.
Gerard l.
AUDIOPHONICS RaspDAC I-Sabre ES9028Q2M - Streamer Raspberry Pi 3 & DAC The RaspDAC is a network player based on a Raspberry Pi 3 B+. With its display, it will allow you to enjoy simply your dematerialized music High Definition. It is proposed here...
Parfait mais
ce lecteur est parfait dans sa conception, je l'utilise maintenant depuis + de 5 ans avec ses evolutions sous volumio 2 & qobuz, mais la nouvelle version V3 ne fonctionne plus sur ecran et est instable le lien fourni sur le blog pour l'install n'est pas joignable
CHRISTOPHE B.
ELECTRO-HARMONIX 6H30PI Gold Pin Tube Twin Triode (Unit) The 6H30PI Gold Pin from Electro-Harmonix is a double triode tube. Its low plate resistance combined with excellent linearity and a dissipation of 4W per plate make it a prime...
Bien meilleures que des 6N6P que j'avais, bien bien dommage qu'elles ne soient plus livrées appairées !! Electro Harmonix ne les appaire plus: problème de mesures proches?donc à voir dans le temps..par contre Audiophonics toujours au top!!!
Ghislain B.
Bien et pas cher !
Pour le prix, ce DAC est très intéressant. Les graves sont très bien gérées et les aigus pas agressifs. Acheté en remplacement d'un petit DAC Tangent, le son n'a rien à voir. C'est vraiment bon ! Cette nouvbelle puce Sabre fait des miracles ! Si vous hésitez vous ne serez pas déçu. Il y a certainement mieux mais c'est (beaucoup !) plus cher.
exelent en i2s
branché entre une di 20 et un dac audio gd. belle équilibre et ma fois de bon resultat .musique naturel et bien imagée. pour la tv oui un peut de bruit. mais après qq améliorations au niveau secteur prises et câblages .tous est bon.. pour le prix dire qu' il est cher.. sais une gageur.
François R.
Dynavox Fiches bananes
Très pratiques ces fiches sans soudure. Câblées avec du câble cuivre Hi-Fi de 2,5 mm, elles font très bien le job. Très bon contact sur les connexions de mes enceintes CABASSE.
Je recommande. Très bon rapport qualité/prix.
François R.
Ampli SMSL AD18 V3.1
Acquis récemment chez Audiophonics, suite à lecture de différents essais dont celui de Qobuz, je suis très favorablement surpris par cet ampli.
Le prix est sans concurrence et les qualités audiophile très au dessus de la moyenne. Rendu sonore (music Hi-Res évidemment) magnifique, qualité et aspect du produit très convaincant.
Il a remplacé mon vieil ampli analogique JVC sans problème.
Connecté à un PC fixe de salon qui gère Music et Vidéo, et à une paire d'enceintes hautes Cabasse, le rendu est exceptionnel.
Je recommande et bravo à l'équipe Audiophonics pour la rapidité et la qualité de l'envoi, ainsi que le SAV conseils.
Pierre F.
SMSL SU-9n DAC ES9038Pro USB XMOS Bluetooth 5.0 32bit 768kHz DSD512 Little brother of the SMSL SU-9, the SU-9n is a modified version, with all the characteristics of its model, but this time without the support of MQA files, of the Bluetooth UAT...
SMSLSu9
Ce DAC est une merveille. Détails espace limpide raffiné il est nettement mieux pour moi que le DAC intégré de mon lecteur Luxman D05u. Belle référence
Pierre F.
SMSLSu10
Excellentissime DAC.
Frederic G.
Peut-être utile pour un système dur ou brillant…
Câble assez moyen, correct au niveau des timbres mais un peu mou…chez moi, selon mes goûts ;)
Je n’ai pas eu la patience de le laisser tourner plus de 10 heures. Retour à mon ancien câble multibrins bon marché, en 4 carré Inakustik exzellenz.
Un produit remarquable de très bonne facture ..la mise en œuvre très facile ..un rapport qualité prix incroyable.
mikael N.
tip top
exactement ce qu'il me fallait pour régler mes deux forcefield 3 aux petits oignons.
Attention avec les montres et objets connectés sur le même bluetooth, ça plante la connexion avec iwoofer sur android.
J'ai du éteindre ma montre et désactiver temporairement son appli.
Ne pas oublier de sauvegarder pour ne pas perdre les réglages.
Livraison ultra rapide. Jamais déçu par Audiophonics.
Sandy G.
Câbles RCA Cuivre OFC Plaqué Or Canare L-4E6S 1m (La paire)
Belle qualité du produit, et écoute agréable, avec une belle neutralité.
Sandy G.
TOPPING D90SE DAC Symétrique ES9038Pro 32bit 768kHz
Belle écoute très détaillée, , sans atteindre celle d'un NANOLAB sonata , mais très agréable, avec en plus des basses bien tendues, et étendues. Il manque juste de la "matière" dans les voix, notamment , par rapport a des DAC bien plus couteux...!
Bon rapport qualité prix.
