Rémi D.
N'hésitez pas
Antony C.
Best rapport Qualité/Prix !
Laurent C.
Une référence
SMSL SU-X DAC 2x ES9039MSPRO XMOS XU316 Bluetooth 5.1 aptX LDAC 32bit 768kHz DSD512 MQA-CD SMSL unveils a state-of-the-art DAC with its SU-X model. The SU-X adopts not only two ESS Technology ES9039MSPRO DAC chips, but also an XMOS XU316 USB interface, enabling it to...
Bon dac,un peut cher..
En remplacement d'un Do100 pro,il y a effectivement du mieux : on perçois plus de détails dans la musique,image stéréo plus précise,un sentiment de son plus propre.
La ou je reste plus critique : il y a multiples réglages possibles de filtres dsp,oversampling qui a mon sens colire le son de façon artificiel.Je préfère le mode sans filtre.
En sortie rca,j'ai constaté qu'il faut abaisser le niveau de 3 db sinon niveau de sortie trop élevé et fait saturer mon ampli
Rafael G.
Just great
I had been using a Schiit Saga 2 preamp before purchasing the Audiophonics AP310. The latter is in my opinion way better insofar as it is silent (no pops, no noise at all when turning it on/off), it has a 12v trigger that works fine and a stand by mode you can set from the remote. It also has an xlr input and no issues at all when symmetrizing a single ended incoming signal. Build quality looks really good and the price is lower that other preamps (e.g. the above mentioned shit costs approximately 400€).
EMMANOUIL B.
The Best Copper Wire in Earth For Hi-Fi
Don't be fooled by the the title "Wiring Cable" !! Use this wire in power and speakers cables. For power cable just enclose it to a hard hose not to bent and use pure copper plugs. Don't use any kind of shield!! For speakers cable twist it 7 twists per meter and use it without plugs or with good quality ones. This is the best audio cable, it beats cables costing many thousands. Companies just don't use it because of it's easy to bent character.
I have made many power and speakers cable using this wire for me and my friends. I have also build interconnect cables using SOCT 18 wire in pseudo-balanced configuration. In direct comparison with many expensive cables those cables have completely no sound character, no coloring, no hi-frequency harsh, excellent tonal unity and the best bass control. Don't use those cables to "tune" problematic sounding systems, these are completely neutral and transparent cables let you to hear your Hi-Fi/Hi-End gear.
patrick a.
Relié en optique au drive et en coaxial au steamer,
ce joli petit dac offre un son chaud et musical, sans aucune agressivité.
Francois g.
ATAUDIO SILVER Male USB-C to Male USB-B Cable Pure OCC Silver 0.75m The ATAudio Silver USB cable offers exceptional build quality for optimal transmission performance. It features eight pure silver conductors that are insulated and braided...
Un très bon cable
Cable Utilisé pour relier un IPad avec Quobuz à mon dac : Cette solution simpliste fonctionne tres qualitativement et me permet de Streamer vers mon dac pour trois fois rien en comparaison de solution a pas de prix. La restitution est tres bonne, et je suis agréablement surpris par la qualité générale malgré le manque de blindage.
Le son quant à lui est tres bon, la réponse en fréquence est tres bonne, un poil éthéré peut être ou bien est-ce la connexion usb de mon dac que je découvre? C’est tout aussi bien que mon lecteur CD avec mon dac. En tout cas, le plaisir d’écoute est la, et c’est ce qui m’importe.
Serge l.
AUDIOPHONICS HPA-S450ET Power Amplifier Class D Stereo Purifi 1ET6525SA 2x450W 4 Ohm The Audiophonics HPA-S450ET power amplifier is based on a Class D architecture, using a pair of Purifi 1ET6525SA amplification modules, a Hypex SMPS1200A400 power supply and an...
Quel ampli !
Utilsation hifi, home cinema, mastering !
Ultra precis sans etre froid, maitrise absolue de mes enceintes dont le HP de grave est un 12 pouces, reserve de puissance infinie !
Fait prendre conscience immédiatement des limites du signal qu on lui envoie et necessite donc un preampli digne de ce nom.
Un interrupteur general aurait ete le bienvenue, a l arret l alimentation émet un leger sifflement.
Les event de ventilation situés sur le dessus de l' appareil emettent une lumiere bleue gênante qd l ampli est installé devant un ecran de projection.
Bref, que du bon a part ces 2 details non rédhibitoires.
A voir dans le temps pour la fiabilité.
A acheter sans hesiter !
Jean-Pierre f.
XDUOO MT-605 Tube Amplifier 12AU7 TPA3116 2x30W 4 Ohm The MT-605 from xDuoo is a small and affordable amplifier, combining the performance of a Class D with the musicality of a tube system. Its amplifier stage is indeed based on a...
grand régal musical pour ce petit ampli
Déçu par l'Ayima T9, je récidive pour un autre petit ampli à tube, et là, bonne pioche ! Les avis précédents sur ce MT605 m'ont convaincu car j'avais envie de varier les plaisirs d'avec le SMSL ao300 que j'apprécie toujours autant. Une puissance inattendue pour mes enceintes colonnes, le bouton de volume est à peine tourné pour emplir mon studio.
Aération et respect du grain propre aux instruments acoustiques et même électr-on-iques. Halo sonore étagé, riche en nuances et modulations typiques du tube (que j'ai changé pou un Tung Sol vendu sur ce site, le chinois d'origine étant un peu dur et fermé par rapport à ce tube russe).
Un peu de souffle dans les enceintes en y collant les oreilles, un "ploc" surtout audible en éteignant, chauffe un peu, bouton de volume bon marché. Mais le plaisir plus palpable de l'analogue est bien là, comparé au numérique. Bref, une jolie petite surprise vous attend !
Jean-Pierre f.
TUNG-SOL 12AU7 / ECC82 Tubes (Unit) The Tung-Sol 12AU7, manufactured in Russia, ensures very low noise. It has been designed to mimic the performance of American NOS 6189 tubes. This one proposes an open...
gain appréciable
Acheté pour changer le tube chinois de l'ampli Xduoo mt 605, belle et appréciable différence : aération, clarté, douceur des aigus, de la musique, quoi !
Jean-Pierre B.
Excellent en cablage Tweeters
Utilisé en cablage interne HP pour la section Aigus, ce 'petit' cable est vraiment excellent ! Détails, finesse des timbres, aération, le tout sans crispation/rajout. Et en plus le 'Rodage' m'a paru assez rapide...
Il mérite d'être testé -en 3 fils torsadés- pour réaliser des cables HP pour le grave (en bi-cablage et multi-amplification) ou simplement large bande. Merci AUDIOPHONICS pour ces trouvailles magiques et économiques
Cebrail K.
Enfin le son que je cherchais !
Je viens d’installer une paire d’amplificateurs mono de puissance en classe D sur mes Focal Electra 1028 Be. Pour être honnête, j’étais plutôt réservé au départ… La classe D traîne encore pas mal d’idées reçues. Mais dès les premières écoutes, tout a été balayé.
Le rendu est d’une grande musicalité : c’est naturel, précis, avec une belle transparence et une scène sonore profonde. Les timbres sont justes, les détails ressortent sans agressivité, et le tout reste toujours fluide et cohérent. Les enceintes sont parfaitement tenues, même à bas volume, avec un grave propre et bien maîtrisé.
Chaque session d’écoute me surprend par le niveau de qualité et l’émotion que ce système arrive à transmettre. Pour moi, c’est une vraie révélation, presque une finalité : je ne ressens plus le besoin de chercher mieux.
Un grand merci à David Aubert pour son accompagnement, ses conseils précieux et la documentation autour de ces amplis.
MARC S.
7HZ X CRINACLE ZERO II In-Ear Monitors Dynamic IEM Ø10mm 3.5mm Jack Silver The 7HZ x Crinacle ZERO II in-ear monitors are dynamic IEMs that are affordable but no less powerful. An evolution of the 7Hz Salnotes Zero, they feature a number of...
Excellents pour la balade
La technologie, ce n'est pas mon fort, mais je possède une collection d'écouteurs pas trop chers que l'on ne craint pas d'emporter partout, de perdre, d'abîmer. Ceux-ci sont formidables ! J'ai modifié quelques réglages, d'amateur, sur l'EQ de l'app FIIO et ces "ZERO II" chantent sacrément bien (avec des embouts en mousse à mémoire de forme, quand-même, achetés aussi chez Audiophonics). Ils ne sont pas trop lourds, se placent vite et bien. Je suis un vieil amateur de musique et c'est une chance extraordinaire de pouvoir disposer de matériel de cette qualité pour un prix honnête.
MARC S.
FIIO BTR15 Balanced Headphone Amplifier Portable DAC ES9219MQ Bluetooth LDAC 32bit 384kHz DSD256 MQA This FiiO BTR15 portable DAC headphone amplifier is a small, affordable device, but no less high-performance, since it integrates a number of market-renowned components: dual...
Un "compagnon" de balade idéal
Je cherchais un appareil qui améliore, en promenade, la qualité d'écoute de mes téléchargements Qobuz, à partir d'un smartphone, et ce BTR15 remplit sa mission. Exactement le même sentiment joyeux de "musique en liberté" que lors de l'apparition des petits lecteurs MP3. il y a 20 ans, la qualité en plus. J'utilise des écouteurs intra de qualité moyenne (je les casse, je les perds...), moins de 30€, avec des embouts en mousse. Grâce à l'EQ de l'app FIIO, facile à utiliser, mes intras me semblent bien meilleurs. J'écoute surtout du classique. Le BTR15 fait merveille avec la voix humaine. Celle des contre-ténors, en particulier, et ce n'est jamais facile. Aucune fatigue auditive après 3 heures d'utilisation (la batterie : impec) Le prix est très correct. Merci à Audiophonics : service impeccable et, dans d'autres circonstances, des conseils généreux, précis et précieux.
joli, pratique et facile a enfficher, le rendu sonore et neutre, le signal est bien transmis.
Aucune fragilité a deplorer.
pascal v.
Excellente je recommande
Prise venue en remplacement d'une Bals sur une multiprise Diy audiophonics MPC6 v2 avec cordon prisonnier. Cette Viborg est très bien fabriquée , les câbles sont solidement tenus, mais surtout c'est musicalement que la différence se fait avec la Bals , quelle précision cela respire entre les joueurs. Aigu qui monte plus haut mais sans fatigue , à l'opposé cela ne descend pas plus bas, mais une impression de meilleure tenue. Mon système (platine CD Carat, intégré Roksan Attessa streaming et mes Pel engy) semble comme libéré d'un voile.
Super.
Ne pas se priver de ces caches rca en silicone pour protéger les fiches femelles rca non-utilisées de la poussière.
Tout petit prix, livraison éclair avec le reste de ma commande.
Nico V.
Super powercable
Amazing cable for power supply. Maybe it's the graphene but it is an amazing sound.
MORNSUN LOF550-20B48 SMPS Switching Mode Power Supply Module 550W 48V 11A PFC This LOF550-20B48 switching-mode power supply module delivers 48V and 11A for 550W of power. The module features high-quality components and is...
en remplacemengt d' une alimentatiuon 48V 250W, ce module a considerablemnt augmenter les qualités de mon ampli 3 e audio. La scene sonore est incroyable, profondeur, largeur, precision ert détourage sont eblouissant. Vivement recommandé.
Julien R.
JANTZEN AUDIO ELECAP Electrolytic Capacitor 100V 120µF 5% Jantzen Audio EleCap electrolytic capacitors are non-polarized aluminum capacitors using etched or "raw" foil. With a tolerance of ±5%, they are more accurate than most...
Tolérance non respectée
Le prix est très bon mais la tolérance est plutôt à 10 % qu'a 5 %.
120 uf mesuré à 130 uf
56 uf mesuré à 63 uf
80 uf mesuré à 89 uf
@ audiophonics : Il sera intéressant de proposer (avec un surcout) des condensateurs sélectionnés et proches des valeurs annoncées.
Pascal j.
Viborg, toujours d'excellents produits....
je possède plusieurs paires de câbles HP haut de gamme, dont j'ai changé toutes les fiches bananes pour des Viborg VB401.
Résultats : dès les premières notes très nette amélioration !
Le rapport qualité prix est exceptionnel.
Je ne jure que par les matériaux nobles en HIFI ( Pur Red Copper, argent pur : exemple câbles Audiophonics OBSIDIAN ou cuivre Ohno OCC pour les câbles de modulation ou HP )
5 étoiles sans hésiter
Pascal, fidèle client depuis les débuts d'AUDIOPHONICS
Frederic F.
BEATECHNIK x LHY AUDIO LPS-A6 220V MK1 Linear Power Supply Module for EverSolo DMP-A6 Gen 1 The LPS-A6 linear power supply module has been specially designed to enhance the power supply stage of EverSolo DMP-A6 and DMP-A6 Master Edition network players by replacing the...
Upgrade à faire...
J'ai passé quelques jours avec mon DMP A6 MA avec l'alimentation d'origine et en passant sur ce module linéaire le changement a été radical : un son plus clair et détaillé pour faire simple. Je recommande sans hésitation l'achat de ce module, même si le tarif reste élevé : le résultat est au rendez-vous.
Jeffery F.
Great product!
Received it today after ordering only 3 days ago! Sound is awesome (A/B with a Node model prior to the current one with a Denafrips DAC.) For those in the States, its about $200 cheaper to buy from Audiophonics than from a US dealer (e.g. Amazon.) The only surprise is that the power cable is for European plug, the unit automatically selects the correct voltage but you need to have a 110v plug with the standard 3 way connection to the device. This was not an issue as I have 5 or more spare ones accumulated over the years. Powered on and worked with no issues. Very happy with Audiophonics!
Bastien S.
Bien mais pas fantastique.
J'ai acheté ce câble d'occasion sur LBC, mais vu l'emballage, il avait été acheté ici.
Avant lui j'avais 2 brins de Jantzen Audio cuivre plaqué argent 1.3 mm2 par polarité, donc 4 brins par enceinte.
Pour chaque polarité j'ai torsadé 2 brins enfilés dans une gaine coton.
C'est un bon câble isolé ptfe (vendu ici : ref 7133).
Le Ludic est effectivement bien équilibré, avec un son plein et généreux, et il me semble un petite bosse dans les bas médiums.
Je l'ai trouvé excellent sur les voix qui ont beaucoup de présence et de naturel, bien détachées, détourées de la masse instrumentale, mais sans désunion.
Il transmet des beaux timbres et une profondeur à la scène sonore.
Mais la différence avec le Jantzen n'est pas évidente en terme de détails et de nuances.
En comparaison du Ludic, le Jantzen est un peu plus montant, plus analytique, moins généreux, moins "profond".
Le Jantzen existe en 2.5 mm2, je ne l'ai pas essayé, mais avec sa plus grosse section (en général favorable au bas du spectre) il apporterait peut-être cette générosité qui manque un peu au 1.3 par rapport au Ludic.
Le Ludic Silenos est certes un bon câble, à la fois généreux et détaillé, naturel et agréable.
Mais il ne m'a pas laissé baba comme les autres acheteurs (au vu des commentaires précédents).
Olivier B.
Olivier B.
ELECAUDIO CS-331B Câble Secteur Double Blindage Cuivre OFC 3x3.5mm² Ø15mm
potion magique!
Bonsoir , j ai testé le Nano liquide or , sur ma tv et blu ray via hdmi et cables secteurs : résultat ,meilleur contratse, fluidité, luminosité, ,profondeur d image . Pour le son ,nano sur usb ,cable secteur, ipurifier ifi : résultat des basses plus rapides ,plus serrées, une meilleure transparence, des iagus plus doux, dynamique générale,plus de finesse. J ai amélioré mon dac et ma platine cd . Je recommande ce produit malgré un prix élevé!!!!!
MOONDROP X SINGER EDGE Dynamic Wireless Headphones Ø40mm Bluetooth 5.4 LDAC 20Hz-20kHz Black With the Edge, Moondrop offers us a wireless, LDAC-compatible Bluetooth headphone featuring a low-distortion 40mm driver with a titanium-plated composite cone for highly...
correct
Ce casque est orienté ambiophonique plus que hi-fi ; le confort et la douceur d'écoute sont privilégiés mais les détails sont audibles . Tout est fait pour ne pas agresser l'oreille . le volume maximum est limité mais ce n'est pas frustrant . Idéal pour la télévision et les films . En musique connectée en LDAC à mon smartphone la scène sonore est agréable . Un peu cher par rapport aux concurrents dans la même gamme de prix . Il existe plusieurs mode d'écoute sur l'application dédiée mais le mode standard m'a le plus convaincu .Le passage en LDAC s’effectue sur l'application . La scène sonore est le point fort au détriment de la dynamique un peu en retrait . Reste un bon produit mais il manque un petit quelque chose pour atteindre cinq étoiles . Content toutefois de cet achat . A noter un packaging qualitatif .
Serkan A.
VIBORG VR106AG Male RCA Connectors Pure Silver PTFE Ø11mm (Set x4) Viborg's VR106AG are premium male RCA connectors, using pure silver contacts to provide maximum conductivity. They also feature PTFE insulation and a rugged aluminum body with...
Qualité exceptionnelle...
Prix qualité finition
C'est le meilleur....
Jean-Baptiste G.
Dac SMSL SU-X
L'équipe d Audiophonics est très réactive que ce soit pour des questions sur des futurs achats ou en sav.
Et je les en remercies.
Jean-Baptiste G.
SMSL SU-X
A peine écouté une heure et déjà un gain en tout sur mon installation.
Magnepan MG12 ampli SABAJ A30A cordon usb B usb A vers PC Deezer Hi-fi qualité 32 bit 384000 Hz.
Un cran au dessus du SABAJ seul que j'aime beaucoup déjà.
Plus de clarté de rapidité une basse plus profonde mais toujours aussi bien tenue.
Encore plus d'informations tout simplement ce qui moi me motive personnellement dans la recherche du son.
Je ne peux que recommander cet appareil qui sonne merveilleusement bien à mes oreilles.
Reste à voir la fiabilité dans le temps.
C'est toujours la même question avec ces fabrications chinoises car celui là est à 1000 euros quand même.
On en attend à ce prix une fiabilité pour quelques années.
Kris S.
TUNG-SOL KT170 Power Tubes Tetrode (Matched Quad) The Tung Sol KT170 is a high-end tetrode power tube. It has been designed to amplify low frequencies in the output stages of HiFi equipment.
Noticed immediately!
Running 4 quad matched in my Fezz Titania power amp. Swapped out the KT120s for these and noticed right away how much better it sounded! I use Kt88s for the mids and tweets and kt170s for bass. Very pleased!
GUSTARD X30 DAC 4x ES9039SPRO + ES9311Q XMOS XU216 Airplay 2 DLNA 32bit 768kHz DSD512 MQA Silver With its X30, Gustard unveils a DAC of exceptional performance and versatility. In fact, this DAC features no less than four ES9039SPRO DAC chips coupled with an ES9311Q linear...
Compliqué de faire mieux.
Après avoir écouté l'EVERSOLO DMP A10 qui est également un excellent DAC/STREAMER/PREAMPLI, j'ai finalement décidé de revenir sur un appareil moins étoffé en nombre de possibilité.
Malheureusement pas Roon Ready, il est toutefois reconnu mais on reste en ALSA au lieu de RAAT.
Qu'à cela ne tienne. Dès la première écoute, c'est doux, précis, dynamique avec une scène sonore large et très réaliste.
Les timbres sont magnifiques et tout est équilibré sur les bons enregistrements.
Pas de questions à se poser. Mon réglage préféré est Vivid et mode NOS.
Aucun regret d'autant que sa simplicité permet de se consacrer simplement à l'écoute.
Système autour : Roon Core, Le X30 relié en RCA sur Nagra JAZZ relié en XLR sur Nagra Classic AMP relié sur des Focal Sopra 2.
La prochaine étape pour aller peut-être encore plus loin, peut-être : RCA et XLR remplacé par du Néotech Némoi 1220 qui remplaceront du Sommer Câble épilogue.
Conquis...
Excellente petite machine.
J'ai commandé ce petit ampli sur la foi de différents avis indépendants, et aussi parce que j'avais remarqué la musicalité du ta2024.
Je n'ai pas été déçu...
En fait, j'ai ensuite commandé un deuxième ampli en secours, tant le résultat m'a plu.
Puis, tout bien réfléchi, j'ai installé un ampli par canal, afin de solliciter au minimum l'alimentation.
Donc j'utilise le canal droit de chaque ampli.
J'ai mis une résistance de 100 Ohms sur chaque canal gauche, au cas où il lui viendrait des envies d'oscillations, les amplis en classe D détestent les boucles ouvertes en sortie.
Le passage en deux blocs mono m'a fait gagner à l'écoute sur pratiquement tous les paramètres. Pour le prix de ces deux minuscules amplis, je ne sais ce que je pourrais leur opposer.
Un seul petit reproche : l'un des amplis a son bouton de volume collé ou trop serré, et si je voulais - après la garantie - améliorer l'alimentation, ou la rénover, je ne peux pas ouvrir l'appareil, de peur d'endommager le codeur optique.
Si quelqu'un a une solution, je suis preneur...
Sinon, mes enceintes ont un rendement pas trop mauvais, avec 91 dB. J'imagine que les 81 dB des Kef 101 d'autrefois seraient moins à l'aise...
Là, dans une pièce de 25 M2, un volume confortable est atteint et même dépassé sans problème.
Merci pour ces magnifiques petites trouvailles !
Židrūnas S.
NEOTECH NC-P312G MKII Schuko Type E/F Power Connector G-UPOCC Copper Graphene Silver and Gold Plated Cryo Ø24mm This Neotech NC-P312G MKII Schuko connector will enable you to design your own high-performance sector cables. It incorporates G-UPOCC composite contacts, a combination of OCC...
le son est doux comparé au furutech FI E35 r
Eric L.
DD TC05 M2 USB-C Cable OFC Copper Silver Plated OTG 50cm The DD TC05 M2 is a USB-C OTG cable with an OFC copper core shielded by silver plating to guarantee signal quality. It can be used to transmit information or simply to charge a...
Excellent cable, albeit extremely stiff.
High quality cable perfect for using with a portable dac, just a shame the cable is INCREDIBLY stiff.
But when it works, it works!
(Remember to use the right plug for the dac and one for the phone/source.
Serkan A.
Qualité exceptionnelle...pure argent
Pas chère....très rare...
pascal v.
Une prise indispensable...
Quelle amélioration par rapport à une prise schuko ordinaire, mon intégré Roksan chante bien mieux, aération sans commune mesure, un aigu plus fin , le grave est mieux tenu. Coté mécanique rien à redire c'est vraiment fait pour durer.
pascal v.
un boitier solide
Beau boitier une fois monté, comptez 2 heures de montage pour un bon résultat...mon boitier était plein de copeaux d'alu qui obstruaient les emplacements de vissage, pensez à vous munir de clés Allen coudées de différents diamètres. Coté musique grosse amélioration surement due aux prises schuko Furutech Rodium, j'ai réalisé un câblage en étoiles avec du câble cuivre de 2,5mm . Pas de connecteur IEC mais un passe-câble elecaudio pour amener un câble prisonnier de gros diamètre
Paul A.
Une révélation
Avec l’alimentation AUDIOPHONICS LPSU25 branchée sur mon streamer Wiim Pro Plus, le bond en qualité sonore est immédiat. La musique gagne en impact, en précision et en naturel — chaque note est plus vivante, plus juste, plus intense
Paul A.
Une révélation
Mes notes par critere
ETI schuko en dynamique vitesse 9.5 , punch impact 6.5 , neutralité 9.5 , matiere relief 7 , transparence 9.5 , timbre 9 , douceur 8, precision details 9, basse 9, finition 9.5 si ça peut aider quelqu un
Glen B.
Horrible app
The player itself is good. Feels premium, sounds good, although a little bright and sharp using Tidal. But the problem is that the software is run from a closed Android operating system, which doesn't allow any updates other than from Shanling themselves. And they stopped working on this model shortly after release. The remote app is absolute garbage. Extremely slow, and jolty. I won't ever buy anything from Shanling that requires operating systems or screens.
Decu
Je retire qu'une seule etoile car d' un système a un autre...
Mais j' ai monté ce câble de plusieurs manières et au une ne m' a donné une restitution meilleure que le wifi.
J' ai tente un blindage actif asymétrique, le son est plat, étriqué sans vie. En flottant sans blindage actif et non connecté ,bien meilleur, plus musical. Mais sans câble, c' est plus naturel et fluide... J' espérais obtenir un gap mais, pas cette fois ci.
Jean-louis L.
Sparkos SS3602 sur Fosi V3 Mono
" Enfin, comme toujours, nos instruments sont extrêmement précis, capables de creuser bien en dessous du seuil d'audition pour déceler les différences. Nos mesures ne sont donc pas aveugles aux différences. Elles ne le sont pas. Nous pouvons voir et évaluer les changements et confirmer avec certitude l'absence d'audibilité lors de tels échanges.
Quant au Sparkos SS3602, il fonctionne et n'endommage rien. Mais il n'améliore pas non plus votre amplificateur pour les raisons évoquées précédemment. "
audiosciencereview.com
Ludovic L.
Pourquoi dépenser plus?
Voici mon avis de cet ampli out of the box. Esthétiquement il est très simple et robuste. Au niveau audio c’est autre chose.
C’est doux, riche avec une image sonore profonde. J’ai gagné un peu en largeur avec des opamp Sparkos. Mais ceux d’origine sont vraiment très bons.
Je pense que je vais encore avoir de longues heures d’écoute devant moi pour découvrir les capacités de cette belle machine.
Les Sparkos apportent un peu plus de détails, non pas qu’ils soient absents avec les 1656 mais il y’a un peu plus de relief sans être chirurgical.
Ce qui est impressionnant c’est l’énergie et la rapidité, une main de fer dans un gant de velours.
Je remercie monsieur Aubert pour m’avoir mis sur la piste de ce modèle.
Très bien.
Splitters de qualité, mettre de la vaseline pour faciliter le passage des câbles.
Super gaines.
Effectivement ces gaines se collent et se moulent parfaitement.
Solides et suffisamment épaisses pour que l'on obtienne un excellent résultat.
Merci Audiophonics.
Toujours au top.
J'avais déjà acheté 4 fiches pour fixer sans soudure les câbles HP du côté de l'amplificateur.
J'ai acheté ensuite 4 autres fiches pour fixer les câbles HP du côté des enceintes.
La fixation est forte, le son est toujours au top.
Merci Audiophonics.
Heat-shrink tubing 3:1 Ø19.1mm Transparent (1m) Thermo-retractable sheath with a ratio of 3: 1, internally equipped with an adhesive layer ensuring better support on any type of surface (plastic, rubber, metal ...)
Fantastique !!
C'est la meilleure gaine thermo-rétractable que j'ai utilisée.
Mise sur mes câbles HP Straight Wire Rhapsody S en 15mm de diamètre, elle se rétracte parfaitement et se moule et se colle fortement aux câbles.
Par-dessus les gaines des câbles et par-dessus les splitters également, c'est transparent et surtout très épais, génial !!
Livraison éclair comme toujours, merci Audiophonics.
Massimo B.
FURUTECH E-TP80ES NCF Filtered Power Distributor 8 Sockets NCF Alpha Treatment GC-303 The Furutech E-TP80ES NCF is a sophisticated and extremely well-designed power supply, eliminating many common problems with audio and video devices caused by poor...
The service is fantastic: the item arrived in perfect condition and quickly; good job.
Produit intéressant mais conception à revoir
J'ai un avis mitigé sur ces fiches que j'aime bien par ailleurs, modèle ocomonoque, contacts très faciles a souder, un corps fin et procurant une très bonne prise en main, manchon souple évitant la gaine thermo. Auditivement c'est excellent, assez transparentes plus définies et précises que d'autres à ce prix. Mais au montage probleme, contrairement au modèle XLR qui fait quasiment l'unanimité dans le monde du studio et de la hifi, ce modèle de RCA ne s'adapte pas bien sur la plupart des câbles de 6 mm du marché à tel point que les professionnels finissent par le monter sans le serre câble sur du Mogami ou du Canare!!! A ma connaissance seul un modèle passe a peu près, c'est l'albedo, qui possède une gaine très tendre ce qui rend le montage possible et encore, il faudra terminer le vissage du corps avec une pince sur le méplat du contact. Donc revoir la mention 6 mm sur la documentation svp, ou la conception du serre câble. Finalement ces RCA ne vont bien que sur du 5,5 donc mariage avec le Goblin parfait. Après on peut faire sauter l'embout plastique pour des câbles plus gros jusqu'à 8 mm, ça passe mais faut parfois mettre de la gaine thermo, la finition n'est plus aussi pro je trouve. Enfin les contacts, ils sont mal fichus, le serrage n'est pas ferme et en plus dans le temps il se relâche, a cause de cette nouvelle conception avec seulement deux ailettes inclinées qui vont mordre sur l'embase elles sont trop fines et n'apportent aucun serrage franc. Pour finir a ce sujet Svp Audiophonics changez le photo qui montre l'ancien modèle de fiches ...
