Pavel V.
Good and tight plugs
Good and tight plugs, but despite my impression from the pictures, there is actually no grooving to put on a coloured rubber...
Pavel V.
Excellent amplifier with a power-on issue
Excellent amplifier. The only serious issue: it can frequently trip sensitive circuit breakers on start-up. The NC252MP...
Pavel V.
Excellent amplifier
- the power supply produces a very slight high-piched noise (~4kHz)...
Customers reviews - There are 19144 reviews.
Szilard M.
Must have
Used it already in my previous OTL tube amp build, now again. Not sure if it affects sound that much or is it just the circuit itself, but microdetails are at a previously unimaginable levels to me. This solder isn't that shiny and polished like standard ones, but look is not important inside I think.. when cooled down, it's just some grey and matte material, no fancyness. However, 10% silver content is a good promise. Only thing you have to bear in mind is a slightly higher soldering tip temperature needed to melt this solder + clean the tip more often than usual for a nice, clean job - there's no resin whatsoever mixed to the solder. The amp I bulilt with that solder sounds freakin' amazing.
Szilard M.
I've never ever thought Neutrik connectors are of such high quality. Stunning, and contacts, solder points all silver plated.. the latching mechanism work like a charm.. a whole different world compated to cheaper XLR inputs.
Szilard M.
Robust, quality material
Great binding posts used for my OTL amplifier. Easy to work with and on top of functionality and high quality, aesthetics is also cool.
Szilard M.
So fat the greatest RCA inlets I've ever used, easy to work with and it's of very high quality. I was surprised to be honest. I'll stick to these next time too. Highly recommended, you won't regret. ;)
Charles C.
Complément
Un complément d'information suite à utilisation de l'entrée AUX avec un lecteur de CD Technics; câble RCA Monster 400; ampli en high; très bon son qui confirme pour moi la grande qualité de cet ampli.
André C.
André .C
Depuis de très nombreuses années, j'utilisais du câble QED Bi anniversary en bi amplification passive sur un système composé d'enceintes NIL et de blocs de puissance ADVANCE.
J'ai voulu essayer le SOMMERCABLE SPM 440 au prix on ne peut plus abordable.
Quelle ne fut ma surprise en obtenant une plus grande spatialisation, ainsi qu'une plus grande finesse de son.
Des basses plus fermes, un registre médium / aigu beaucoup moins agressif.
J'ai monté ces câbles avec de la gaine nylon et des splitters, ce qui donne un effet pro.
Que dire du service AUDIOPHONICS, toujours au top sur toutes mes commandes. Commandé le jour J, reçu le jour J+1...attention au choix du transporteur !
André C.
André .C
Excellent produit, permettant d'obtenir des câbles HP à la finition irréprochable.
Laurent V.
Service parfait pour excellents tubes.
J’ai commandé ces tubes pour un ampli JADIS DA88s, en remplacement des classiques KT88 Gold Lion. À l’écoute on ressent immédiatement que l’énergie disponible est montée d’un cran. L’exploration des premières octaves est très belle, timbrée, charnue et maîtrisée cependant que les hautes fréquences voient disparaître une petite trace de brillance, ce qui profite au naturel et au confort de l’écoute.
Un bel équipement gagnant sur toute la ligne.
Service impeccable et très rapide d’ Audiophonics: du travail de pros !
Serge r.
Aune X1s Pro Dac
Bonjour...
Sortant du Topping D10 ,Le Aune X1s Pro est beaucoup , beaucoup plus large niveau sonore, plus "aérer" il défini un son (wav ou flac) très clair , très propre , dynamique , en tout cas sur mon système son ( Bose companion 50) , la prise casque ne coupe pas automatiquement le son des enceintes , cette même prise alimente mon casque M&D MH30 divinement bien ,pour ma part Win 10 ne va pas au delà de 32 bits , 384000Hz avec ou sans pilotes fourni (est-ce indispensable plus loin...???) vraiment un achat superbe jusqu'au packaging prise ,câbles usb, raccord jack 6.35 , de qualité , facile à mettre en fonction sur Pc.Un rapport qualité prix qui fait du bien .Je recommande sans hésitationssss.
Théodore E.
Excellent produit !
Utilisé pour fournir 2x150W à un AIYIMA A07, cet adaptateur rempli parfaitement son rôle. L'alimentation est parfaitement stable, et même à pleine puissance il ne chauffe que modestement. Le boitier en aluminium est à la fois solide et élégant, et la finition très soignée. La connectique (G12) est d'excellente qualité.
Patrick W.
Code Bluetooth 0000
Si le code pour l'appairage Bluetooth n'est pas 0123 alors essayez : 0000
Christian H.
Amazing DAC!
This DAC replaces my out dated Topping D30 (not Pro). Price/ Performance wise I didn't expect too much, just a nice looking upgrade.
But: what an improvement in clarity and space! Air around instruments is visible. That's actually the wow I expected from my other more expensive and highly praised DAC in my "big" system.
The tiny and so good looking SU-6 is so enjoyable in every aspect.
I use all Inputs. They All work perfect even in the most critical DPLL setting (1) where the Topping D30Pro (which I also tried but returned) simply sucked. The D30Pro had obviously serious clock/jitter issues.
BT on the SU-6 is more than usable as well!
I just can recommend the SMSL SU-6 by heart!! 6 Stars.
Yannick r.
Un gain évident en transparence
Ce iPurifier vient s'ajouter au iSilencer 3 au sein de mon système (liaison entre un Zen Stream et un DAC Topping D70s).
Après quelques heures d'écoute, il m'apparaît que cet appareil finit d'exhumer les quelques détails supplémentaires que mon système est capable de reproduire.
Un peu plus de résolution, oui, mais surtout, ce qui est le plus net pour moi, c'est l'amélioration des timbres des cuivres, sur toutes les oeuvres que je connais déjà très bien.
Je dirais sans être formel que le iPurifier est allé chercher quelques harmoniques dans les hautes fréquences.
J'ai également des attaques et extinctions de notes plus perceptibles, notamment sur les violons et les pianos, la musique devenant plus riche et plus expressive.
Le bas médium/haut grave paraît également plus propre, plus dégraissé, certaines voix semblent de ce fait plus faciles à détacher des instruments jouant en simultané.
Encore autre chose, un peu plus d'aération entre les instruments et plus de douceur globale
En somme, ce petit gadget ne me déçoit pas et parvient avec succès poursuivre l'optimisation d'un système déjà tout à fait superbe...sachant que j'écoute au casque et que le gain est sûrement plus net encore aux enceintes
Oskar Kemal G.
High Quality
This is better than Furutech's original power distributors. I'd recommend to all of you. Good job!
Egon B.
Great
Between DAC/Preamp and Triangle bookshelves. Noticeable improvement in base, soundstage, clarity and detail over similarly priced class A/B integrated amplifier.
Incroyable
Très très bonne surprise, ce petit préampli Riaa, est bluffant de qualité, très bon gain, bonne bande passante, et, absolument silencieux, pas le moindre souffle, ou ronflette !!!
Je le recommande, à ce prix là, i n'a aucun concurrent !!!
A eviter
Vu son prix , on ne peut attendre à des miracles.
Accentuation des aigus devenant agressif dans mon système.
Vite remis le mogami 3103 et tout est rentré dans l'ordre.
Câble pouvant convenir a un système de début et encore....
Je ne recommande pas ce câble dans un système évolué.
Merci audiophonics pour la rapidité de cette livraison.
Louis F.
très bon son mais ...
Le préamplificateur a été livré très rapidement un grand merci a audiophonics ! je l'emploi pour pré-amplifier un amplificateur classe d de 100 w ,le résultat est très bon en analogique puissance et intelligibilité du signal on peut augmenter les graves et les aigus ce qui n'est pas forcement une hérésie audiophile ...Cependant le dac n'est pas reconnu par les ordinateurs Mac et je n'ai pas trouver de pilote ( pas de notice explicite à ce sujet d'ailleurs le mode d'emploi et quasiment inexistant et en chinois !) sur pc ça fonctionne sans driver mais pas vraiment tester pour me faire une idée précise ..
les lampes incluse 6n3 son vraiment de piètre qualité ( 1 étais poreuse et a rendu l’âme) j'avais des 6h3n d’Ukraine qui on remplacé avantageusement les tubes d'origine,le son et vraiment meilleur maintenant . En conclusion un bon pré ampli pour le prix avec les inconvénients que j'ai cité plus haut mais je suis content de mon achat .
Importance du gain ! (et modification avis précédent)
Je suis l'auteur de l'avis modéré sur cet ampli en raison principalement du rendu des graves...
En lisant, relisant les avis sur ce site et globalement sur le net, pour trouver une solution (alimentation, etc...), je me suis rendu compte que j'utilisais l'ampli en mode Low Gain.
Le passage en mode High Gain (3 sec sur touche Direct) améliore énormément le résultat, et ceux sur l'ensemble du spectre :
Les aigus/mediums sont encore un peu plus précis, on gagne en détails, en subtilité...
Et les graves, qui sont très fades en mode L-Gain, gagne ENORMEMENT en densité, et en subtilité (distinction claire du haut grave et bas grave, belle tenue du grave, etc...) il en fait pas des tonnes, mais bien suffisamment et surtout proprement... on est pas encore au niveau d'un ampli classe A/B à 1000€... mais c'est tout à fait normal !
Désormais je suis ravi de cet ampli qui pour 250€ est un superbe rapport Q/P...
Je pense simplement que le constructeur ne devrait pas proposer le L-Gain sur son produit, et encore moins le programmer par défaut en sortie usine...
Bon je retourne à mon exploration musicale...
USB-C to USB-A Cable Silver / Gold plated Copper Shielded 1m This braided USB cable has a USB-C male connector and a USB-A male connector. Each connector is 24k gold plated. Each conductor of the cable is made of silver-plated copper,...
Un bon câble
outre sa fabrication qui est de très bonne qualité, ce câble s'avère parfaitement adapté à ma carte son MOTU M4. Le son est très équilibré sur l'ensemble du registre aigu médium et grave. La dynamique est au rendez-vous, bref c'est un bon achat.
Attention
Ces enceintes de bonne facture ne se marient pas avec tous les amplis vu leur rendement.
Il leur faut un amplificateur avec du jus pour pouvoir descendre en dessous de 4 ohms.
Dans mon cas un peu déçu, car c'était pour accompagner une TV a travers l'ampli.
Victor C.
Etonnante construction personnalisée avec Purifi
Je suis étonné par l'ensemble de l'équipement en lui-même. Le prix est vraiment compétitif par rapport à d'autres installations similaires basées sur la Purifi, mais c'est la bonne réputation qu'Audiopohics s'est construite qui m'a poussé à commander cet ampli... Et bon sang, je ne me suis même pas trompé d'un centime !
Puisque la perception du son est une question tellement subjective, je ne soulignerai que la propreté du son et la quantité incroyable de détails que je peux obtenir sur mon installation (KEF R3 + Audio Matrix Mini-i Pro 3). Chéry au sommet : où est passé le manque de basses percutantes des amplificateurs Class-D ? Est-ce une blague ? Je ne peux pas dire à quel point je suis satisfait de mon achat pour l'instant. Dois-je mentionner que la consommation électrique murale est de 20W ? Laisse-le jouer, bébé ! Et félicitations à Audiophonics pour votre merveilleuse construction : matériaux de premier choix, fabrication de premier ordre, spécifications de premier choix et plaisir musical de premier ordre!
Bon rapport qualité/prix - graves pas top
Premier pas dans le monde de l'amplification numérique.
C'est un bon rapport qualité prix au regard de toutes les connexions proposées et la taille très réduite de l'ampli.
Maintenant coté son, je suis plus mitigé :
Les aigus et mediums sont vraiment superbes : le côté analytique des amplis numériques donne une impression de précision et d'espace entre les notes, ça donne un coup de jeune à beaucoup d'enceinte de moyen de gamme...
En revanche les graves sont très médiocres : d'une part en retrait mais surtout brouillons, mal définis..
Pour un système audio d'appoint, ca fait le job mais pour moi niveau son ça ne tient pas la comparaison avec un ampli audio classique... (qui pour un prix légèrement supérieur sera 10 fois plus gros avec 2 fois moins de connectiques)
Noel R.
Erreur sur la notice du matériel.
La valeur de résistance annoncée n'est pas de 50Kohms mais de 100Kohms. Mais très bon matériel
Excellent Lecteur CD
Rien à ajouter et aucun besoin de DAC en analogique.
Merci a l'équipe Audiophonic pour cet excellent emballage.
Jerome D.
Excellent câble HP
Excellents résultats en utilisation câble HP pour caisson de basse REL, depuis l'ampli jusqu'au connecteur Speakon "haute intensité" (3 conducteurs pour les signaux droite et gauche + 1 neutre).
Remplace très avantageusement le cordon fourni par REL.
Les conducteurs multibrins de l'OYAIDE (4,5 mm²) rentrent bien pour serrage par vis et plaque dans un vrai Speakon de chez Neutrik (pas dans l'imitation made in China du connecteur de la fourniture REL).
Patrik M.
The best cooper cable ever
I've been thinking about neotech cabling for a long time, but in the end I opted for the NEI 3001 MKIII signal cable ... since I needed a longer version, I chose the 2x 1.5m RCA variant, which I fitted with aeco connectors ... The result after connecting from SACD is, in a word, amazing ... after the first tons it is very transparent, detailed, clean and with a magnificent space ... unbelievable. I will definitely try NEI 1001
François S.
Avis Suite
Finalement avec de petites rondelles sous les têtes de vis c'est parfait.
Georges C.
Excellent câble.
Ce câble se signale par son absence de signature propre.Sa transparence sauvegarde l'originalité de chaque enregistrement.On n'entend rien qui vienne de lui.Aucune coloration.
Mêmes éloges à propos de son cousin de la modulation...
Excellente
En remplacement de l’elecaudio or avec un câble Oyaide Tunami V2.
L’elecaudio détenait pour moi, la palme du meilleur RQP. Alors que la Viborg 501 pur cuivre ne m’avait pas emballée, avec cette Viborg 501 pur cuivre/plaquée or tout le registre musical gagne en définition. La présence du médium et la dynamique sur les fortes sont impressionnant.
Vraiment génial ce nouveau modèle avec un prix plus que raisonnable
Faites vous plaisir, car c’est de ça qu’on parle.
Rançon du succès ? car c’est déjà en rupture.
Elsa A.
XLR montage extra
Qualité Neutrik avec filetage facilitant le montage en façade, soudage OK sans fusion de l'isolant.
Elsa A.
Schuko viborg
Excellente construction mécanique, système de serrage optimum, montage facilité au maximum, corps métallique épais et massif.
Top qualité.
Arnaud D.
SHANLING MTW300 In-Ear Monitors IEM Bluetooth 5.2 QCC3040 aptX Grey The Shanling MTW300 Bluetooth in-ear earphones feature the ergonomic and comfortable design of the MTW100, in a version with enhanced performance. For example, the integrated...
Bluetooth Trop Capricieux
Trop pénible à appairer sur mon Samsung Galaxy S9...
Après de multiples tentatives, poubelle!
Szilard M.
Stong and heavy - quality stuff
For decent, heavy binding posts don't look elsewhere - this is it. An excellent back panel for DIY speakers.
Szilard M.
Very-very good quality, my DIY amplifier is happy now and the fading of the LED ring with an Arduino program is a cool extra in standby mode. :)
Szilard M.
Toroidal Transformer 60VA 5V 12A This high quality toroidal transformer delivers a power of 60VA 5V 12A and will be an ideal choice especially for the realization of your DIY projects requiring these voltages.
A quality transformer
.. but due to voltage drop it cannot feed the Raspberry Pi4 with my stabilizer module, I had to use a DC-DC step-up converter after rectification/stabilization. With that, everything is fine now. When looking for a Raspberry/DAC based transformer, choose a higher voltage one. Apart of this, quality is really top notch, the transformer is absolutely silent, quality work.
Szilard M.
TOPPING D30 PRO Balanced DAC 4x CS43198 32bit 384kHz DSD256 Silver Powerful and compact balanced DAC, the digital-to-analog conversion stage of the Topping D30 Pro is based on no less than four Cirrus Logic CS43198 chips. These enable it to...
A matter of taste
Great DAC, measures excellent and sounds very refined. From my experience it fits systems rather with relaxed highs because this kind of Cirrus-based DAC has it's own clarity. Mid region, mid tones and vocals aren't that emphasized like with an AKM DAC, bass is well-controlled. Top quality overall and the simultaneous use of XLR and RCA outs make this an amazing "preamp" too (in PRE-mode) for e.g. a 2.1/2.2 system (where you feed your sub/subs from the RCA outs while main system is fed from XLR). All-in-all, a neutral, precise sound without much emotion. It just doesn't has its own sound. Some people like this, some not. A matter of taste. For us it lifted a bit on the highs which came very handy so we give it 5 stars.
Szilard M.
Cleanness and transparent sound with power
This is the first time I ordered this Hypex module based amplifier of Audiophonics and I don't regret it. It arrived into to a luxurious home's audiophile system and the owner (a friend of mine) was blown away by the quality and cleanness of sound. Excellent product, thank you Hypex, thank you Audiophonics.
Szilard M.
Beautiful sound
Szilard M.
Great quality
Excellent button of great quality, I can only recommend.
Exelent steamer
Brancher avec alimentation Ifi élite 12v 4a et usb neotech neu argent sur interface digital di20 audio gd qui est branché via hdmi (pangy premier cardans pl argent 0,5m) sur dac r2r r28 audio gd. Et ami cayn st200. Superbe image superbe audio du grave profond à l aigus montant et lumineux. Ont sens la puissance la dynamique et la spacialite avec transparence naturel et ultra musical. Par apport à mon lecteur cd. Sais vivant et jubilatoire. Bon si il faut chipoter un chouilla l infra grave manque très peut d assise. Mais pour le prix d un cable secteur moyen de gamme. Le RQP et exceptionnel. A consommer sans aucune modération. Merci à audiophonics de proposer de vrais bijoux tj à pris contenu et réaliste.
Rémy D.
LINDY Ethernet RJ45 Cable Cat 8.1 S/FTP LSZH Gold Plated 1m The RJ45 Ethernet cable takes advantage of the latest Cat 8.1 standard to support bandwidth up to 2000MHz. The cable has an S/FTP structure, where the twisted pairs are shielded...
Gain en qualité et vitesse
Après avoir remplacé mes câbles cat 5e par ces câbles, j'ai gagné sur mon réseau interne presque 10Mbps grâce à la propreté du signal. Le câble est plus gros que du câble ordinaire, il est aussi plus rigide mais les connecteur rj45 sont de bonne qualité et ne bouge plus une fois enfichés. Je recommande (j'ai mis entre boitier fibre et ma box puis de ma box vers du cpl...)
Rémy D.
PANGEA PREMIER SE Ethernet Cable RJ45 Cat7 Silver Plated Cardas Copper Triple Shielding 1.5m If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver their full potential. With its...
Aération et silence
Dès la pose du câble, le son m'est apparu bien plus calme (moins de perturbation) se traduisant par de meilleurs silences, son moins agressif. Un très bon câble pour l'audio
markus s.
Perfect Bass
Very good bass, better than the TCS31. For me on the amplifier with Electra speakers. But the treble is too resolved and slightly harsh. Whether with gold or rhodium. With good recordings it's ok, with bad ones too many details, somehow slightly metallic. It now has 60 hours on it.
Grégory O.
Carte ok
Tout fonctionne correctement. Le schéma fourni en description par audiophonics est appréciable. Livraison toujours Ok après plusieurs commandes.
Prise coudée de très bonne qualité, avec une FI48or sur un SP1100 ça marche très bien sur un R7.
Magnifique
Câble de grande qualité monté sur des Furutech FI48R. C'est très propre, net, fin, et plus rapide oui.
Testées avec un Yarbo Sp1100 les FI48R apportent de la propreté, mais ce FP-P55N va plus loin et amène une exécution immédiate de la musique. C'est très impressionnant.
Diametre
J’apporte une petite précision sur le diamètre extérieur de ce câble
Il fait 6.5 mm et non 4.6 mm
Essayé avec une chute avec des prises rca rean en modulation c’est absolument bluffant et Il tient la comparaison avec des câbles à 3/400 €.
Je viens de le monter avec des rca Elec Tellurium, une gaine cuivre, soudure mundorff 10% et gaine de finition. Soit 40€ le tout en 1 mètre.
Seconde claque, qui renvoie le ultra haut de gamme très cher au rang d’imposteur.
Essayez par vous même, c’est une révélation.
Damien N.
Très complet, de bonne qualité et performant
Ce tout petit ampli fait bien ce qu'on attend de lui. En l'occurrence il remplace ma vieille chaîne compacte qui sonorisait mon PC. La finition est bonne, jusqu'à présent je n'ai pas eu de mauvaises surprises et je l'utilise principalement avec les entrées bluetooth et optiques.
J'apprécie les réglages disponibles pour ajuster les graves et les aigus, et c'est ce qui me l'avait fait choisir face à un Elipson Music Center BT équivalent. Alors ça ne donnera pas autant de contrôle que l'égaliseur à bandes de ma vieille Sony mais ça suffit largement.
Elsa A.
Bruit de fond
Bonne idée d'une alim non symétrique, mais le bruit de fond augmente dès qu'elle augmente mème au delà de 5V (tests avec une alim faible bruit : ça ne change rien)
