Marius G.
Excellent quality cable
Marius G.
Satisfied
Stian L.
AUDIOPHONICS HPA-S450ET Power Amplifier Class D Stereo Purifi 1ET6525SA 2x450W 4 Ohm The Audiophonics HPA-S450ET power amplifier is based on a Class D architecture, using a pair of Purifi 1ET6525SA amplification modules, a Hypex SMPS1200A400 power supply and an...
A very good and powerful amp
Delivers clean and high gain without any colouration or distortion. It is what I wanted. Only negative is a slight power on pop noise and the screws are of low quality and it looks like they could start to rust just by breathing on them.
Paul C.
TRUTHEAR X CRINACLE ZERO:RED In-Ear Monitor IEM Ø10mm/Ø7.8mm 17.5 Ohm 117.5dB 20Hz-40500Hz With the Zero RED, Truthear has once again teamed up with Crinacle, renowned for its expertise in IEM, to offer a new version of the fruit of their previous collaboration. These...
D'une remarquable qualité
Excellents écouteurs, tant par leur qualité de construction que par leur son. Les embouts en mousse fournis avec isolent également bien.
Jean Louis d.
AIYIMA A70 2.1 Channel Amplifier TPA3255 2x185W 4 Ohm AIYIMA's A70 is a 2.1-channel Class D amplifier featuring quality components. In fact, it incorporates a TI TPA3255 amplifier chip combined with two NE5532 AOPs for an output...
ALIMENTATION
l'ampli est bon mais l'alimentation est une daube , celle si perturbe beaucoup le rendu , j'ai installer une autre alimentation est la ca marche très bien
A H.
OMG
I got: seat at the mixing desk
I paid: the bass
And I love this
Lennart H.
Eric H.
Expandable Braided Nylon Sleeve 6-12mm Gray This grey braided nylon sheath will effectively cover your cables and give them greater mechanical resistance. This has an adjustable diameter from 6mm to 12mm.
Bon rapport qualité prix : fait le job !
Eric H.
Très bon câble sur tout le spectre
Amène de la clarté et pleins de détails deviennent plus apparents.
Je recommande son achat
Tanel P.
Nicely flexible
It's thick and green like a garden hose, looks good :) Easy to work with and very flexible indeed.
AIYIMA A80 Integrated Amplifier Class D Bluetooth 5.1 TPA3255 2x120W 4 Ohm With its A80, Aiyima unveils a small integrated amplifier packed with audiophile features and components. It's primarily based on an ESS9038Q2M DAC chip and a TPA3255D2...
Complet
Après un mois d'usage, je dirais : "Conforme au descriptif" : formule passe-partout pour confirmer qu'il s'agit d'un produit de qualité " à composants audiophiles", sans point faible significatif, surtout pour le prix, et pilotant efficacement, excusez du peu, des DYNAUDIO emit 50 (raisonnablement, hein, sans chercher à faire trembler les murs non plus ! ) avec l'alimentation d'origine, et ce dans mon salon de 25 m2 ; je n'ai donc pas besoin de prendre l'adaptateur secteur doublant la puissance. Merci Audiophonics pour l'info et surtout pour ne pas pousser inutilement à la consommation...
Cet ampli est aussi efficace en vinyle sur entrée analogique qu'avec le lecteur réseau sur l'entrée optique...
Je recommande donc aussi bien cet ampli Aiyima 80 qu'Audiophonics...
benjamin b.
SUPER
Je viens de m'ennuyer de repartir du compteur électrique, de retirer l'ancien 1,5mm2 standard et de dédier la ligne uniquement à l'audio (il n'y a avait toutefois que quelques luminaires en plus de la hifi sur cette ligne) Avant installation, le câble avait "tourné" quelques dizaine d'heures. Verdict :
C'EST LE JOUR ET LA NUIT :-) :-) :-)
si vous installez plusieurs prises murales : ne coupez pas le fil sans isolant. Celui-ci sert à faire la continuité avec la feuille isolante / de blindage.
Je l'ai soudé et gainé au fil de terre côté compteur électrique
très satisfait !
Giovanni B.
Purchase
Dear Sir, my package will arrive as soon as everything is available, or will you ship what is already in stock first? Let me know, thanks.
Juha K.
This amplifier could be described as very versatile for different music genres. Purifi has never disappointed my own ears. This does everything without adding or removing anything from the sound, however, being a little on the warm side. The treble is not dry as is typical for class D, it has nice details and brightness. The bass is also not a little dry as is typical for class D, it has nice thickness and meat, but still perfectly controlled. Overall, the sound has a nice "loudness". Physically very sturdy and high-quality housing. The adjustable gain is a big plus. The only small minus in my opinion is that the connectors on the back (speaker and RCA) are quite close to each other. If you use spades, there may even be a small risk of short circuit! However, there is no danger if you use balanced XLR connectors. This does not affect the number of stars. One of the best power amplifiers in its price range.
Eric H.
NEOTECH DG-202 RCA Connectors Plug OFC Copper Gold Plated Ø9mm (Set x4) These Neotech DG-202 RCA connectors, sold in packs of 4, benefit from rigorous design and high-quality materials. They are made of OFC copper plated with a thick layer of gold,...
Fiches RCA de qualités
Très bonnes prises RCA de très bonnes qualités.
Le seul bémol c’est la soudure de la masse sur le corps qui n’est pas évidente: ils auraient pu faire une « encoche » comme sur leurs autres prises RCA plus chers .
Eric H.
MUNDORF MLYTIC AG Capacitor 25V 22000μF These capacitors have been specially developed for small power amplifiers or preamplifiers. This new product replaces the M-Lytic SI series. The "Glue-On" output pins made of...
Excellents condensateurs
3ème commande, pour mes amplis: super sonorité
Pierre-Jean T.
Tung
Un son plus détaillé et limpide. Content.
André G.
Tweeter Dayton en complément du tweeter en facade
Ce tweeter qui est léger et ne paie pas de mine s avère etre clair non agressif et propre, il s intègre bien dans ma configuration en bi actif et rehausse l aigu en fusionnant avec le médium aigu. Pour 36€ c’est une aubaine
Stéphane K.
ELECAUDIO LI-07GB IEC C7 Connector Gold Plated 24k 3x5mm² Ø15mm This IEC C7 Elecaudio LI-07GB connector is ideal for making quality power supply cables. It uses 24k gold plated copper alloy contacts of 5mm², allowing to obtain a very...
Piètre qualité.
Un produit vraiment basse qualité. Btr cassée au premier démontage. direction la poubelle
Jean-francois L.
3E AUDIO A7 MONO Class D Mono Amplifier PBTL 1xTPA3255 1x260W 4 Ohm 3E Audio, a recognized player in the DIY world, now offers a Class D mono amplifier incorporating audiophile Hi-Fi components. The A7 Mono amplifier is based on one TI TPA3255...
A7 mono
Superbe ampli, je les préfères à mes anciens fosi v3 mono. Livraison rapide au Canada. Avec le support de 3e audio j’ai réussi à régler le problème du auto-standby trop sensible. Maintenant c’est parfait.
Jerome C.
RAMM AUDIO SA-15 Speaker Cable OFHC Copper Shielded 2x 1.65mm² The Ramm Audio SA-15 is a speaker cable offering quality design at an affordable price. It consists of two OFHC copper conductors with a cross section of 1.65mm² (15AWG),...
Utilisé en câble secteur bipolaire
Utilisé en câble secteur bipolaire, deux mètres de longueur avec un connecteur secteur schucko basique (ici Sommercable ) et un connecteur C7 que j'avais en stock.
C'est un réel bonus pour mon Lecteur DVD hdg (sur DAC externe) pour la partie audio à l'écoute de CD , son plus charnel un petit bonus en présence et séparation Stéréo.
Une optimisation "budget" très appréciable.
Le câble se "réalisera" (rodage) en une vingtaine d'heure
David C.
HIDIZS MERMAID MM2 In-Ear Monitors IEM Dual Drivers Magneto-Static / Dynamic PEK Black The Hidizs MM2 are in-ear headphones offering very good audio performance for an immersive and convincing listening experience. A sound quality associated with a resolutely...
Extra!!
Certes je poste mon avis avec 2 ans de retard! Ces petits écouteurs intra sont d'une qualité exceptionnel par rapport à leur prix de vente. La possibilité de pouvoir changer les filtre en fonction de ses goût et vraiment génial, de plus leur rendu acoustique dépasse mes attentes pour type de casque. Bref une petite pépite qui n'est malheureusement plus proposée à la vente au moment ou je me décide enfin à donner mon avis....
Nicolas P.
Ampli purifi
Cela fait seulement 2 jours que j ai reçu mon ampli purifi et donc tjrs en rodage.
La claque, il exploser en tout point mon ancien ampli pourtant 3 fois plus cher...
Je n' ose Imaginer dans quelques heures ce que cela va me donner...
Tout y est, à la bonne place, avec une précision extraordinaire.
Tout est sublimé.
Je suis super content de mon achat et certainement le dernier ampli que j achète.
Merci audiophonics pour donner la possibilité d avoir une amplification aussi bonne, à si peu cher en comparaison.
Markus W.
Speaker Terminals Rhodium Plated Ø19mm x 65mm (Pair) These speaker terminal blocks offer excellent design quality at an affordable price. Their contacts are made of rhodium-plated alloy copper, ensuring...
Good quality
These binding posts are very cost-effective. Build quality is massive contrary to most of the comparable products in this price range.
Patrick v.
TOPPING B200 Power Amplifier Mono Discrete 200W 4 Ohm Black The Topping B200 power amplifier is a mono amplifier based on a discrete-component NFCA amplifier circuit. This enables it to achieve a considerable power level while...
Magnifiques !
Les 200 sont d'une qualité de fabrication irréprochable, très beaux et élégants.
Vous trouverez une scène sonore vraiment très large et d'une clarté à couper les souffle, avec des détails jamais entendu avant. Ils sont extrêmement précis, donc aussi très révélateurs de la qualité d'enregistrement.
Absolument plus que satisfait de mon achat, finalement Internet avait raison!
Tom K.
Used the SU-6 to connect my Topping D90III Sabre over I2S rather than USB and to my ears this provides a real and very nice improvement in the sound. I did not have to fiddle with dipswitches to get the I2S connection to work. This was a pleasant surprise, both PCM and DSD work out of the box using a standard HDMI cable. Audiophnics delivered the device quickly as always.
Tommi J.
SMSL RAW-DAC1 DAC AK4191+AK4499EX Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512 MQA-CD The SMSL RAW-DAC1 is a high-performance, elegant DAC based on a combo of AKM AK4499EX+AK4191 chips and a USB XMOS XU-316 interface. These audiophile components enable it to...
Great connectivity, good functionality
Pleasant unit, good clear sound. If you are looking for a modern DAC with a little extra in the base and detailed sound that is a bit smoother than most Sabre DACs, this might be for you. in my case, I didn't like the sound signature and did not feel like an upgrade for me. In the end I went with Denafrips Enyo instead.
michel H.
DAYTON AUDIO MX15-22 Speaker Driver Subwoofer 800W 4 Ohm 90dB 18Hz-400Hz Ø38.1cm Designed to produce maximum output at an unbeatable price, this MX15-22 Max-X dual voice coil subwoofer from Dayton Audio has all the features you'd expect from a...
Retrofit de 2 caissons de basses Kliosch
Suite à l'achat de 2 caissons Klipsch hs ,j'ai procédé à leur rétrofit après adaptation de la caisse, par ces hp Dayton. Les 2 caissons sont passés en passif branchés sur un ampli Yamaha PX5. Très satisfais du résultat
SMSL SU-X DAC 2x ES9039MSPRO XMOS XU316 Bluetooth 5.1 aptX LDAC 32bit 768kHz DSD512 MQA-CD SMSL unveils a state-of-the-art DAC with its SU-X model. The SU-X adopts not only two ESS Technology ES9039MSPRO DAC chips, but also an XMOS XU316 USB interface, enabling it to...
Bon dac,un peut cher..
En remplacement d'un Do100 pro,il y a effectivement du mieux : on perçois plus de détails dans la musique,image stéréo plus précise,un sentiment de son plus propre.
La ou je reste plus critique : il y a multiples réglages possibles de filtres dsp,oversampling qui a mon sens colire le son de façon artificiel.Je préfère le mode sans filtre.
En sortie rca,j'ai constaté qu'il faut abaisser le niveau de 3 db sinon niveau de sortie trop élevé et fait saturer mon ampli
Rafael G.
Just great
I had been using a Schiit Saga 2 preamp before purchasing the Audiophonics AP310. The latter is in my opinion way better insofar as it is silent (no pops, no noise at all when turning it on/off), it has a 12v trigger that works fine and a stand by mode you can set from the remote. It also has an xlr input and no issues at all when symmetrizing a single ended incoming signal. Build quality looks really good and the price is lower that other preamps (e.g. the above mentioned shit costs approximately 400€).
EMMANOUIL B.
The Best Copper Wire in Earth For Hi-Fi
Don't be fooled by the the title "Wiring Cable" !! Use this wire in power and speakers cables. For power cable just enclose it to a hard hose not to bent and use pure copper plugs. Don't use any kind of shield!! For speakers cable twist it 7 twists per meter and use it without plugs or with good quality ones. This is the best audio cable, it beats cables costing many thousands. Companies just don't use it because of it's easy to bent character.
I have made many power and speakers cable using this wire for me and my friends. I have also build interconnect cables using SOCT 18 wire in pseudo-balanced configuration. In direct comparison with many expensive cables those cables have completely no sound character, no coloring, no hi-frequency harsh, excellent tonal unity and the best bass control. Don't use those cables to "tune" problematic sounding systems, these are completely neutral and transparent cables let you to hear your Hi-Fi/Hi-End gear.
patrick a.
Relié en optique au drive et en coaxial au steamer,
ce joli petit dac offre un son chaud et musical, sans aucune agressivité.
Francois g.
ATAUDIO SILVER Male USB-C to Male USB-B Cable Pure OCC Silver 0.75m The ATAudio Silver USB cable offers exceptional build quality for optimal transmission performance. It features eight pure silver conductors that are insulated and braided...
Un très bon cable
Cable Utilisé pour relier un IPad avec Quobuz à mon dac : Cette solution simpliste fonctionne tres qualitativement et me permet de Streamer vers mon dac pour trois fois rien en comparaison de solution a pas de prix. La restitution est tres bonne, et je suis agréablement surpris par la qualité générale malgré le manque de blindage.
Le son quant à lui est tres bon, la réponse en fréquence est tres bonne, un poil éthéré peut être ou bien est-ce la connexion usb de mon dac que je découvre? C’est tout aussi bien que mon lecteur CD avec mon dac. En tout cas, le plaisir d’écoute est la, et c’est ce qui m’importe.
Serge l.
Quel ampli !
Utilsation hifi, home cinema, mastering !
Ultra precis sans etre froid, maitrise absolue de mes enceintes dont le HP de grave est un 12 pouces, reserve de puissance infinie !
Fait prendre conscience immédiatement des limites du signal qu on lui envoie et necessite donc un preampli digne de ce nom.
Un interrupteur general aurait ete le bienvenue, a l arret l alimentation émet un leger sifflement.
Les event de ventilation situés sur le dessus de l' appareil emettent une lumiere bleue gênante qd l ampli est installé devant un ecran de projection.
Bref, que du bon a part ces 2 details non rédhibitoires.
A voir dans le temps pour la fiabilité.
A acheter sans hesiter !
Jean-Pierre f.
XDUOO MT-605 Tube Amplifier 12AU7 TPA3116 2x30W 4 Ohm The MT-605 from xDuoo is a small and affordable amplifier, combining the performance of a Class D with the musicality of a tube system. Its amplifier stage is indeed based on a...
grand régal musical pour ce petit ampli
Déçu par l'Ayima T9, je récidive pour un autre petit ampli à tube, et là, bonne pioche ! Les avis précédents sur ce MT605 m'ont convaincu car j'avais envie de varier les plaisirs d'avec le SMSL ao300 que j'apprécie toujours autant. Une puissance inattendue pour mes enceintes colonnes, le bouton de volume est à peine tourné pour emplir mon studio.
Aération et respect du grain propre aux instruments acoustiques et même électr-on-iques. Halo sonore étagé, riche en nuances et modulations typiques du tube (que j'ai changé pou un Tung Sol vendu sur ce site, le chinois d'origine étant un peu dur et fermé par rapport à ce tube russe).
Un peu de souffle dans les enceintes en y collant les oreilles, un "ploc" surtout audible en éteignant, chauffe un peu, bouton de volume bon marché. Mais le plaisir plus palpable de l'analogue est bien là, comparé au numérique. Bref, une jolie petite surprise vous attend !
Jean-Pierre f.
TUNG-SOL 12AU7 / ECC82 Tubes (Unit) The Tung-Sol 12AU7, manufactured in Russia, ensures very low noise. It has been designed to mimic the performance of American NOS 6189 tubes. This one proposes an open...
gain appréciable
Acheté pour changer le tube chinois de l'ampli Xduoo mt 605, belle et appréciable différence : aération, clarté, douceur des aigus, de la musique, quoi !
Jean-Pierre B.
Excellent en cablage Tweeters
Utilisé en cablage interne HP pour la section Aigus, ce 'petit' cable est vraiment excellent ! Détails, finesse des timbres, aération, le tout sans crispation/rajout. Et en plus le 'Rodage' m'a paru assez rapide...
Il mérite d'être testé -en 3 fils torsadés- pour réaliser des cables HP pour le grave (en bi-cablage et multi-amplification) ou simplement large bande. Merci AUDIOPHONICS pour ces trouvailles magiques et économiques
Cebrail K.
Enfin le son que je cherchais !
Je viens d’installer une paire d’amplificateurs mono de puissance en classe D sur mes Focal Electra 1028 Be. Pour être honnête, j’étais plutôt réservé au départ… La classe D traîne encore pas mal d’idées reçues. Mais dès les premières écoutes, tout a été balayé.
Le rendu est d’une grande musicalité : c’est naturel, précis, avec une belle transparence et une scène sonore profonde. Les timbres sont justes, les détails ressortent sans agressivité, et le tout reste toujours fluide et cohérent. Les enceintes sont parfaitement tenues, même à bas volume, avec un grave propre et bien maîtrisé.
Chaque session d’écoute me surprend par le niveau de qualité et l’émotion que ce système arrive à transmettre. Pour moi, c’est une vraie révélation, presque une finalité : je ne ressens plus le besoin de chercher mieux.
Un grand merci à David Aubert pour son accompagnement, ses conseils précieux et la documentation autour de ces amplis.
MARC S.
7HZ X CRINACLE ZERO II In-Ear Monitors Dynamic IEM Ø10mm 3.5mm Jack Silver The 7HZ x Crinacle ZERO II in-ear monitors are dynamic IEMs that are affordable but no less powerful. An evolution of the 7Hz Salnotes Zero, they feature a number of...
Excellents pour la balade
La technologie, ce n'est pas mon fort, mais je possède une collection d'écouteurs pas trop chers que l'on ne craint pas d'emporter partout, de perdre, d'abîmer. Ceux-ci sont formidables ! J'ai modifié quelques réglages, d'amateur, sur l'EQ de l'app FIIO et ces "ZERO II" chantent sacrément bien (avec des embouts en mousse à mémoire de forme, quand-même, achetés aussi chez Audiophonics). Ils ne sont pas trop lourds, se placent vite et bien. Je suis un vieil amateur de musique et c'est une chance extraordinaire de pouvoir disposer de matériel de cette qualité pour un prix honnête.
MARC S.
FIIO BTR15 Balanced Headphone Amplifier Portable DAC ES9219MQ Bluetooth LDAC 32bit 384kHz DSD256 MQA This FiiO BTR15 portable DAC headphone amplifier is a small, affordable device, but no less high-performance, since it integrates a number of market-renowned components: dual...
Un "compagnon" de balade idéal
Je cherchais un appareil qui améliore, en promenade, la qualité d'écoute de mes téléchargements Qobuz, à partir d'un smartphone, et ce BTR15 remplit sa mission. Exactement le même sentiment joyeux de "musique en liberté" que lors de l'apparition des petits lecteurs MP3. il y a 20 ans, la qualité en plus. J'utilise des écouteurs intra de qualité moyenne (je les casse, je les perds...), moins de 30€, avec des embouts en mousse. Grâce à l'EQ de l'app FIIO, facile à utiliser, mes intras me semblent bien meilleurs. J'écoute surtout du classique. Le BTR15 fait merveille avec la voix humaine. Celle des contre-ténors, en particulier, et ce n'est jamais facile. Aucune fatigue auditive après 3 heures d'utilisation (la batterie : impec) Le prix est très correct. Merci à Audiophonics : service impeccable et, dans d'autres circonstances, des conseils généreux, précis et précieux.
joli, pratique et facile a enfficher, le rendu sonore et neutre, le signal est bien transmis.
Aucune fragilité a deplorer.
pascal v.
Excellente je recommande
Prise venue en remplacement d'une Bals sur une multiprise Diy audiophonics MPC6 v2 avec cordon prisonnier. Cette Viborg est très bien fabriquée , les câbles sont solidement tenus, mais surtout c'est musicalement que la différence se fait avec la Bals , quelle précision cela respire entre les joueurs. Aigu qui monte plus haut mais sans fatigue , à l'opposé cela ne descend pas plus bas, mais une impression de meilleure tenue. Mon système (platine CD Carat, intégré Roksan Attessa streaming et mes Pel engy) semble comme libéré d'un voile.
Super.
Ne pas se priver de ces caches rca en silicone pour protéger les fiches femelles rca non-utilisées de la poussière.
Tout petit prix, livraison éclair avec le reste de ma commande.
Nico V.
Super powercable
Amazing cable for power supply. Maybe it's the graphene but it is an amazing sound.
MORNSUN LOF550-20B48 SMPS Switching Mode Power Supply Module 550W 48V 11A PFC This LOF550-20B48 switching-mode power supply module delivers 48V and 11A for 550W of power. The module features high-quality components and is...
en remplacemengt d' une alimentatiuon 48V 250W, ce module a considerablemnt augmenter les qualités de mon ampli 3 e audio. La scene sonore est incroyable, profondeur, largeur, precision ert détourage sont eblouissant. Vivement recommandé.
Julien R.
JANTZEN AUDIO ELECAP Electrolytic Capacitor 100V 120µF 5% Jantzen Audio EleCap electrolytic capacitors are non-polarized aluminum capacitors using etched or "raw" foil. With a tolerance of ±5%, they are more accurate than most...
Tolérance non respectée
Le prix est très bon mais la tolérance est plutôt à 10 % qu'a 5 %.
120 uf mesuré à 130 uf
56 uf mesuré à 63 uf
80 uf mesuré à 89 uf
@ audiophonics : Il sera intéressant de proposer (avec un surcout) des condensateurs sélectionnés et proches des valeurs annoncées.
Pascal j.
Viborg, toujours d'excellents produits....
je possède plusieurs paires de câbles HP haut de gamme, dont j'ai changé toutes les fiches bananes pour des Viborg VB401.
Résultats : dès les premières notes très nette amélioration !
Le rapport qualité prix est exceptionnel.
Je ne jure que par les matériaux nobles en HIFI ( Pur Red Copper, argent pur : exemple câbles Audiophonics OBSIDIAN ou cuivre Ohno OCC pour les câbles de modulation ou HP )
5 étoiles sans hésiter
Pascal, fidèle client depuis les débuts d'AUDIOPHONICS
Frederic F.
BEATECHNIK x LHY AUDIO LPS-A6 220V MK1 Linear Power Supply Module for EverSolo DMP-A6 Gen 1 The LPS-A6 linear power supply module has been specially designed to enhance the power supply stage of EverSolo DMP-A6 and DMP-A6 Master Edition network players by replacing the...
Upgrade à faire...
J'ai passé quelques jours avec mon DMP A6 MA avec l'alimentation d'origine et en passant sur ce module linéaire le changement a été radical : un son plus clair et détaillé pour faire simple. Je recommande sans hésitation l'achat de ce module, même si le tarif reste élevé : le résultat est au rendez-vous.
Jeffery F.
Great product!
Received it today after ordering only 3 days ago! Sound is awesome (A/B with a Node model prior to the current one with a Denafrips DAC.) For those in the States, its about $200 cheaper to buy from Audiophonics than from a US dealer (e.g. Amazon.) The only surprise is that the power cable is for European plug, the unit automatically selects the correct voltage but you need to have a 110v plug with the standard 3 way connection to the device. This was not an issue as I have 5 or more spare ones accumulated over the years. Powered on and worked with no issues. Very happy with Audiophonics!
Bastien S.
Bien mais pas fantastique.
J'ai acheté ce câble d'occasion sur LBC, mais vu l'emballage, il avait été acheté ici.
Avant lui j'avais 2 brins de Jantzen Audio cuivre plaqué argent 1.3 mm2 par polarité, donc 4 brins par enceinte.
Pour chaque polarité j'ai torsadé 2 brins enfilés dans une gaine coton.
C'est un bon câble isolé ptfe (vendu ici : ref 7133).
Le Ludic est effectivement bien équilibré, avec un son plein et généreux, et il me semble un petite bosse dans les bas médiums.
Je l'ai trouvé excellent sur les voix qui ont beaucoup de présence et de naturel, bien détachées, détourées de la masse instrumentale, mais sans désunion.
Il transmet des beaux timbres et une profondeur à la scène sonore.
Mais la différence avec le Jantzen n'est pas évidente en terme de détails et de nuances.
En comparaison du Ludic, le Jantzen est un peu plus montant, plus analytique, moins généreux, moins "profond".
Le Jantzen existe en 2.5 mm2, je ne l'ai pas essayé, mais avec sa plus grosse section (en général favorable au bas du spectre) il apporterait peut-être cette générosité qui manque un peu au 1.3 par rapport au Ludic.
Le Ludic Silenos est certes un bon câble, à la fois généreux et détaillé, naturel et agréable.
Mais il ne m'a pas laissé baba comme les autres acheteurs (au vu des commentaires précédents).
Olivier B.
Olivier B.
ELECAUDIO CS-331B Câble Secteur Double Blindage Cuivre OFC 3x3.5mm² Ø15mm
