FRANCOIS D.
Félicitations !
FRANCOIS D.
Bravo AUDIOPHONICS
Bravo à vous pour la conception de ce produit de très belle qualité !
Fabrice C.
Customers reviews - There are 19139 reviews.
Joscha O.
MONACOR SPH-200KE Speaker Driver Midbass 80W 8 Ohm 90dB This SPH-200KE speaker from MONACOR is a low-midrange driver with a Kevlar fiber cone. Its nominal impedance is 8 ohms and its power handling rating is 80W.
Perfect chassis
I bought them a couple of weeks ago and now inserted them into my speakers. They do a fantastic job!
Jean-Paul C.
cable
Cable au look sympa , dommage que usb-a flotte un peu sur le port micro . Livraison et traitement commande au top .
Franklin N.
Very good cable, soft move, thick, perfect for what I needed.
Franklin N.
Perfect top
Top all good, good material and works perfect. Was with some issues what to do and this product solve my problem. Many thanks. Very quick shipping!
Patrick d.
Great little Headphone Amp
I'm using this Amp with my 'PSB M4U 1 32 Ohm' and it sounds fantastic, never harsh but always a very good wel placed and smooth sound. The build is very sturdy and good parts where used. For the price this is a very good amp and even compared to more expensive amps I've heard ... well it's just a very good Headphone Amp d(-_-)b
Jean-Claude E.
Le branchement des deux cosses Ph & N n'est pas très génial et empêche de remettre la prise la plus proche. J'ai préféré souder ces deux fils au milieu de chaque barrette. Une fois cette modif faite, bon produit.
Jean-Benoit K.
Excellent petit Dac
En plus il est autoalimenté, pas besoin de transfo !
Philippe A.
l'écoute est plus sereine, plus naturelle.
je pense en prendre un autre pour mon zappiti one 4K hdr.
je recommande,
Attila S.
Antonio M.
Domanda
Deve essere collegato nel seguente modo ?
Spina RCA all'estremità del preamplificatore: schermo + conduttori blu a terra RCA. Conduttori rossi al segnale RCA.
Spina RCA all'estremità dell'amplificatore: conduttori blu - messa a terra RCA (schermo tagliato corto, non collegato). Conduttori rossi al segnale RCA
Pedro Antonio C.
Useful
Good balance between price and quality. Delivery really fast, customer service very good.
Pedro Antonio C.
Working with Piano 2.1 the sound is really good. I recommend it
Pedro Antonio C.
Delivery and the customer service were really good. Working with Kali Reclocker is a really gamechanger.
Pedro Antonio C.
I bought it by mistake because I have a Raspberry Pi 3 but it was easy to adapt it.
The delivery was really fast
Albert R.
Produit non complet
Je tiens à félicité l'équipe d'audiophonics pour leur réactivité. J'ai reçu le produit non complet et ils me l'ont renvoyés rapidement. Merci encore.
Laurent A.
fait très bien le job mais pas pour qui veut du clef en main
Peut faire penser à du gadget ou du chinois car très léger et l'alimentation mériterait d'être beaucoup mieux, mais c'est de la qualité. Galère pour le mise en oeuvre si on ne sait pas utiliser de logiciel de formatage de carte mémoire, je n'ai pas choisi l'option d'avoir une carte pré-installée par l'équipe d'audiophonics. Une fois installé, il faut bien paramétré le logiciel interne pour ses besoins, ça peut lire du DSD à la qualité maximale sans aucun problème (testé avec des fichiers officiels trouvés sur une plateforme officielle, qualité mp3 jusqu'au DSD maximal dispo sur le marché). Pris pour faire de la lecture streaming Spotify. J'utilise le plugin de streaming, pas l'application Spotify que l'on peut installer sur le DAC (il me semble que ça nécessite obligatoirement un compte payant Spotify, et je vous le recommande ne serait-ce que pour arrêter les pubs qui au final vous force la main à l'achat ou vous force à quitter l'expérience Spotify tellement c'est chiant et sans contrôle du volume sonore de la pub), je parle bien du plugin de streaming qui récupère la lecture de votre ordi/tablette/téléphone via le site ou l'application officielle Spotify. Ca fonctionne bien mais à la longue ça devient chiant de toujours devoir piloter l'appareil via les boutons volume de l'ordi/tablette/téléphone. Et c'est peut-être son point faible. Tout se fait par l'interface web ou par application mobile. De la configuration de l'appareil à la navigation musicale. Il n'y a pas de bouton physique autre que le power. Du coup, il n'y a pas ce petit plaisir de tourner le bouton de volume quand une musique favorite arrive, c'est con comme feeling mais ça fait toujours son effet. A refaire, j'irai directement vers du matériel clef en main, c'est plus cher mais c'est du plug and play ! Ne pas oublier de mettre à jour le logiciel interne et surtout de toujours le faire avec les sources de audiophonics. Je mets 2 étoiles parce que j'ai eu beaucoup de galères pour installer le logiciel, beaucoup de galère avec la fonction auto-power off, peut-être que le dac peut être plus performant mais pas envi de retourner dans la config au petits oignons. Je rajoute 1 étoile pour le service et les conseils de l'équipe audiophonics, ils répondent vite et à toutes vos questions. Au final je suis déçu de cet équipement, très difficile à vendre d'occasion, il est là, il est enfin configuré à minima, donc il restera pendant un certain jusqu'à son remplaçant.
Gilles D.
Attention à la version du pilote !
DAC acheté en remplacement de mon précédent DAC mini-i Pro. Le DAC Gustard X16 est objectivement meilleur sur tous les critères, mais attention au pilote Windows : en effet, sur mon PC, le dernier pilote en date, la version 5.0.0 fait planter (figer) Windows 10 Pro 64 sitôt la lecture en ASIO engagée ... alors que la version précédente, la v4.86.0 fonction pafaitement, en ASIO et en WASAPI, quel que soit le logiciel de lecture utilisé : Roon, Jriver, Audirvana, Qobuz Player !
Renaldo V.
rapport qualité prix
Robert W.
Good quality power strip
Very nice power strip. Running Olflex 110cy 3x2.5mm,10,3mm cable. Just had to drill the hole a bit. Has small "pockets" on each end so you can attach it to a wall using screws. If your'e not familar working with electric appliences buy the ready made with the IEC socket on the end. Some skill needed to work on this one.
Robert W.
Works as speaker feet
With spikes under my speakers bass vibrations went down in the wood floor. These worked better. No more vibrations, but speakers gets a little wobbly and loses some dynamics.
Christophe G.
Adapter Male Jack 4.4mm to Neutrik Female XLR 4 Pins This adapter consists of a 4.4mm male jack and a 4-pin female XLR connector. It can be used to connect symmetrical high-end headphones to symmetrical amplifiers. The adapter...
Probleme de contrôle qualité
Tige centrale cassée du pentacon au bout d’un mois (nouvelle commande pour moi) sinon la fiche est de qualité
Antonio C.
Amazing interconnect
My review so far:
About the product itself AZ910:
✓ More distinctive layering of the music
✓ More ease, air, and energy
✓ Better clarity and transparency
✓ Slightly more neutral
✓ Much better separation
✓ nice bass (very well defined)
✓ More laid back
✓ Beautiful top-end sound
The sound is dynamic, musical, rhythmic, and unparalleled harmonic resolution providing music lovers with a new dimension in music enjoyment.
My setup is:
• Integrated amplifier - Rotel RA1592 (200w in 8Ω) +
• Technics SL-G700 Network/Super Audio CD player,
⁃ connected with Oehlbach BALANCED NF AUDIO XLR CABLE XXL SERIES (replaced with Oyaide).
⁃ Speakers Cabasse Altura Bahia(94db efficiency, frequency response 50-25000Hz), Impedance 8Ω with minimum 3,2Ω)- (very difficult to drive -can be very fast too bright)-
⁃ I’ve try with Audioquest cables impossible to hear with less good records), for the speakers and interconnects but they are not a good match.
⁃ currently connected by The Chord Company - Epic Speaker Cable.
There is fundamental differences which power cables used. Currently tried with the supplied standard cables (difference less significant that in my conclusion); kindly note that Technics a standard cable (with earth) with 3mm conductors (notorious), so matching power cable here is tricky. I thought to use the OYAIDE TUNAMI GPX-R V2 Power cable (does somebody have a good input how they mix with AZ910?). For the Rotel is even more tricky because standard power with 1mm conductors!. Amazing for such an amplifier to have such a cable!
The idea here is to go Viablue X-60 Silver AC power cable (very nice comments and reviews on this one, and mainly very neutral)
Giuseppe C.
Excellent amplificateur abordable
Je l'ai acheté pour l'utiliser avec deux casques de grande qualité, comme le Hifiman Sundara et le Sennheiser HD700.
Avec les deux casques, cet amplificateur offre un son chaleureux et détaillé, avec une grande dynamique et spatialité. La possibilité de l'utiliser avec l'entrée symétrique est très utile. Avec l'entrée équilibrée, le son s'améliore et augmente la puissance et l'espace.
Honnêtement, je ne comprends pas qui se plaint de la qualité de cet objet: il est très difficile de s'améliorer dans la fourchette de prix allant jusqu'à 300-400 euros.
Jean-François A.
Cable "usb" pour alimentation séparée
Cable très pratique afin de pouvoir injecter un 5 volts séparé de celui de l'ordinateur, bien fabriqué par Audiophonics.Vraiment pratique pour un DAC externe. Très Recommandé.
Vraiment efficace !
Etant apprenti soudeur, j'ai progressé au fur et à mesure. Je me suis trompé de référence de soudure et j'arrivait pas à souder jusqu'à ce que je comprenne que la température était de 290° ; j'ai investi dans un fer WELLER électronique. Et là c'est du beurre !
J'ai soudé des XLR Neutrik avec un câble SommerCable ALBEDO et le résulté est parfait. Tout à fait conforme à ce que le constructeur annonce, ça file super haut et c'est très doux. Ouverture détails ; grave puissant et tendu. Soudure parfaite une porte grande ouverte sur tout les détails sonores.
LAURENT M.
GUSTARD A18
Evolution significative par rapport à mon Topping D50S avec alimentation 5volts Ifi.
Plus de matière , palette sonore plus riche , grave profond , pas d'agressivité, belle image.
Etonnant de musicalité notamment en entrée Bluetooth LDAC en streamant à partir d'un téléphone un simple abonnement DEEZER Hifi.
Je note une supériorité musicale (selon mes critères) des derniers DAC's AK4499 VS Sabre ES9038.
Je recommande chaudement ce DAC qui par ailleurs inspire confiance concernant la qualité de fabrication.
Daniel P.
Qualité-prix excellent
J'enrage, j'ai acheté du câble d'alimentation plaqué argent (qui n'est pas vendu ici) 5 fois plus cher, il n'y a rien qui va. Par dépit j'ai essayé d'autres câbles que j'avais en stock, pareil, et j'avais un bout de ce câble, je l'ai monté entre mon ampli Yamaha A-S2100 et la platine CD-S1000 et miracle, tout est meilleur, le placement des instruments, les graves propres et bien présents, les voix, tout est mieux pour un prix presque dérisoire, du coup je vais le monter sur tous mes lecteurs et l'essayer sur les deux amplis, hifi et HC.
franck J.
Réelle surprise et redecouverte de mes albums
Acheté sans l'avoir écouté juste sur des avis. Frustré de ne pas pouvoir monter le volume comme je souhaiterai sur les enceintes, j'ai voulu m'acheter un meilleur casque que ceux que je possède (focal spirit one C, listen, sennheiser hd570 etc). Je souhaitais un casque ouvert et confortable et je n'ai pas été déçu. La technologie utilisée que je ne connaissais pas crée un son délicat, précis et neutre même à bas volume. Je me suis surpris à me retourner pour voir si quelqu'un était derrière moi, c'était le son du siège du pianiste. Semble reproduire tous les petits son que je n'avais jamais entendu auparavant. Je n'en suis qu'à quelques heures d'utilisation et le son semble s'améliorer. J'utilise les fiio x1 et m7, le x1 est légèrement plus puissant mais les 2 restent insuffisant pour driver le casque. Je me suis équipé de l'amplificateur nomade topping nx1s pour avoir une écoute confortable sur le classique qui a souvent un niveau d'enregistrement plus faible.
J'utilise le casque aussi avec l'ampli smsl Thx aaa sp200 en sortie du dac smsl Su9 : gain de détail et de qualité de son !
Je ne pensais pas prendre autant de plaisir à réécouter ma discothèque.
AUDIO-GD R-7HE 2021 MK2 Balanced DAC R2R FPGA I2S HDMI Amanero 32bit 384kHz DSD Accusilicon Audio-GD is developing its HE range, composed of its most top-of-the-range products. They benefit from the longest design and testing period since the brand's inception. This...
Quel rendu naturel
Ce DAC est étonnant de naturel.
On a l'impression d'être au concert. Précision des timbres, dynamique, scène sonore large et profonde, c'est formidable.
Je l'utilise en liaison USB avec Daphile.
Nécessite un cable particulièrement transparent pour en tirer le maximum.
On a plus l'impression d'entendre une source numérique.
Vincent D.
Très bon dac compact et à prix contenu
Utilisé pour contourner la sortie jack défaillante de mon LG G7 qui est doté d'un excellent dac (ES 9018 quad dac avec des mesures excellentes sur audio science review), je ne suis pas déçu! Distortion inaudible, clarté, rondeur, le son tient tout à fait la comparaison avec le dac natif du LG, avec un peu plus de pêche et de fermeté.
Il pousse très bien sur des écouteurs ou des casques faciles (AKG240, ...) ou en sortie ligne, par contre à ne pas utiliser avec un casque plus lourd à driver (pas terrible avec mon Beyerdynamic DT770, qui nécessite pour bien marcher un ampli casque).
Serge V.
SOVTEK 6H30PI / 6H30 / 6N30 / 6N30P Twin Triode Tube (Unit) This Russian-made, audiophile-quality 6H30PI power tube from Sovtek (sometimes also called 6H30, 6N30 or 6N30P), often used in pre-amplifiers, gives...
musicale et silencieuse: très satisfait
Pour remplacer une paire qui provoquait de la microphonie sur un ampli hi-fi à tubes, cette Sovtek est très musicale et silencieuse. Je suis donc très satisfait, d'autant que la livraison chez Audiophonics, que je pratique depuis 2015 sans jamais de soucis même en SAV, est toujours très rapide.
Je recommande et la 6H30PI Sovtek et Audiophonics.
Jean-Pierre B.
POWERGRIP YG-2 Power Distributor Conditioner Filtered 6 schuko surcharge overload protection For its second version, the PowerGrip YG-2 retains the same performance as its predecessor but adopts a more compact and more economical format. Like its big brother the YG1-V2,...
Une multiprise hors de prix ?
Sur un système « résolvant », (JMR Offrandes - 2 Pass Aleph 5 - Primare Pré 35 -Pré Pré Clearaudio Balance - Cellule Clearaudio Stadivardi) et en remplacement d’un Dynavox x6000 je n’entends aucune différence.
En revanche l’appareil est très joli, bien fabriqué, assez ergonomique avec un interrupteur en face avant.
Attention si vous comptez utiliser un câble secteur plus en rapport avec les prétentions et le prix du Powergrip, il vous faut une terminaison en IEC C19. Par chance J’avais un Shunyata de bonne qualité à ce format.
Mon installation étant entièrement symétrique j’envisage l’achat d’un deuxième Powergrip en remplacement d’un deuxième Dynavox. Je pense aussi monter deux câbles secteurs basés Viablue.
L’addition est très élevée. C’est mon seul reproche sur ce produit dont la valeur que je perçois est inférieure à 500 euros.
Alors une multiprise hors de prix : oui
simon c.
FX-AUDIO D802E FDA Amplifier STA326 Streamer WiFi DLNA Bluetooth 5.0 Multiroom 2x80W / 4 Ohm Silver The E version of FDA D802 amplifiers from FX Audio now includes WiFI (DLNA) connections to complement Bluetooth connectivity.
Livraison rapide , produit facile à configurer. Écran minuscule et télécommande surprenante dans l’organisation des fonctions ...mais le son est là suffisant pour sonorisé une télé avec deux enceintes bibliothèque . Les préréglages de sons très marqués permettent au moins de trouver un bon niveau de volume sur les voix pour certaines chaînes ou support médiocres. Voilà content de cet ampli qui en donne largement pour son prix .
Simon E.
the perfect upgrade for my x7 soundcard
Bought two of these and two ss3601 for my creative X7 soundcard.
They are a perfect upgrade, because
- they are small, you can´t close the hatch anymore because of the height of the ss3603, but you can still place the x7 on your desk normally
- you can HEAR the difference. I use it with a grado RS1, and the sound became more detailed
Awesome piece of hardware!
Simon E.
Bought two of these and two ss3602 for my creative X7 soundcard.
Gilles C.
NEOTECH SOST-30 Wiring Cable UP-OCC Solid Pure Silver PTFE 30AWG 0.0509mm² Neotech, leader in high-tech HiFi cable, continues its research in the field of sound reproduction and today produces the ultimate in cabling wires. The SOST Solid Core Silver...
Cable DC
Produit excellent. Triplé par pôle pour un câble DC pour un switch. Équilibré dynamique fluide et détaillé. Je recommande
parfait !
J ai acheté ces pangea pico pour stabilisé mon ampli phono ,j ai gagné en lisibilité ,et profondeur . franck
Adelmo T.
Génial
L'un des meilleurs câbles que j'ai jamais entendu, rapport qualité-prix inégalé.
TOP!
stephane j.
TRÈS SATISFAIT
Beau BLEU
BONNE QUALITÉ
MERCI
stephane j.
TRÈS SATISFAIT !!
BON MATERNEL
MERCI
Jef B.
Behuizing
Mooi afgewerkt, prijs waard.
Gian Enzo R.
the best matched EL34 quad you can possibly find
Suggested by a friend and quite many positive reviews I ordered and promptly received the Psvane EL34-PH matched quad from Audiophonics
I put them on my Audio Innovations 800mkIII valve poweramp: immediately greater and clearer sound! Bigger scene more detailed and musical. I am really happy and super impressed!
I believe I will keep these tubes on for a long while and will try Psvane again whenever I will need to change other tubes
PASCALINE S.
rien a dire tout est OK
PASCALINE S.
Insert to Screw for Wood M6x18x11mm (Unit) These inserts to screw are used to add a metal screw thread in wood or soft material. The dewclaws on the sides allow the insert to be held firmly in the material.
tout est OK comme a l'habitude
didier D.
suffisant pour le prix
Apporte un léger mieux qu'un câble de base.
Mais bon pour le prix on ne peux pas demander beaucoup mieux.
La tenue des fiches n'est pas au top.
La souplesse du câble et sont gainage est néanmoins appréciable.
Au final correct... mais sans plus
didier D.
bon produit - efficace
Bon produit, facile a mettre en place. Très efficace sur mon système moyenne gamme.
Un peu rigide pour un câble de cette taille.
Dans l'ensemble un bon produit.
Oyaide est bien une marque phare du câblage
Norman M.
Ravi de mon achat
Matériel immédiatement reconnu sur un viel Asus eeepc tournant sous Lubuntu. Gain de rendu flagrant, même sur des fichiers mp3 en 128 Kbit/s. Idem pour les radios web de qualité (Fip, France Musique etc.) Le son est plus limpide, comme si l’on avait retiré un voile, pas d’agressivité dans les aigus, des basses nettement plus franches mais sans lourdeurs. Bref, c’est le jour et la nuit par rapport à la sortie jack 3,5 du Pc. Merci pour cette belle réalisation au rapport qualité prix imbattable. J’ai quand même une question : À quoi sert cette sortie optique numérique ? Si quelqu’un pouvait m’expliquer l’intérêt ça serait sympa.
Olivier b.
Tres bon connecteur
Utilisé avec du câble Mix Stream MX6 de 6mm acheté ici même. Tres bonne compatibilité avec ce gros câble. Facile à installer, solide, bien pensé avec son système de serrage qui écarte la fiche banane en position. Un très bon produit a recommander, avec comme toujours une logistique sans faille de la part d’Audiophonics.
Aliaksandr S.
Simple solution that just works!
Works as expected! The assembly took some 30 min, the system is very straightforward and I got Spotify Connect working in just a few minutes. Scanning files from NAS took a bit longer but also simple. Overall, pretty happy! Good sound!
A couple of smaller issues:
1. Remote does not always work, still figuring out how to configure additional buttons. However, volume and source work fine and that's the most important.
2. TFT screen is not fully off when in screen saver mode. But not too bright to be a problem.
3. Spotify connect plugin can freeze if you switch tracks too often. You have to either restart the raspdac or open the UI and manually restart the plugin. Still figuring this one out.
Leonidas D.
Top product
In combination with my Bluesound node 2i the sound is more detailed , transparent, combined with quality cables , you have a cracking combo with an exceptional value for money ratio , if the same product did have the name Gustard but some other well known European brand name easily the asking price could be over a 1.000 € , fast delivery and secure packaging from Audiophonics bravo for providing such quality products
