yoan R.
Passé d'un ampli cambridge de 20 ans, qui chauffait, à lui, qui chauffe aussi. Mais la séparation des basses, m'a...
yoan R.
Premier ampli R2R, et je voulais pas casser mon PEL pour gouter a cette techno. Ca fait plus de 6 mois que je l'ai, et...
Xavier B.
Objectivement excellent rapport qualité prix, Très bon résultat "out of the box" chez moi avec un ampli de puissance...
Customers reviews - There are 21016 reviews.
Jean-Michel P.
Pratique et économique
Cet adaptateur me permet d'utiliser une entrée BNC de mon DAC avec un câble S/PDIF.
Il est très facile à installer.
La qualité semble au rendez-vous.
Janez R.
Poor higher tones
Unfortunatelly, I can only confirm some previous comments. I bought 12 of them, 4 were used with Mogami 2549, 4 with Canare 4e6s, on both very poor results in higher tones. 4 will remain unused. Cables were made by devoted audiophile who owns workshop which is also authorised repair service for Bang and Olufsen, Bose, ... My worst 'audiophile' purchase so far. Sorry to write this I was really looking forward to them.
Higher tones are supressed, no joy in listening music through these connectors. I should have gone for Neutrik or Klei. Money lost. I will probably buy Klei.
Peter W.
Excellent amp,even not regarding the price.
I used a nuforce Ref 8.5 V3 and wyred4sound SX1000 monos before,
this one will stay.
Very clear sound,many details,not harsh at all,dead quiet and enough horse power for loud sessions.
Bass control is on par with the rest.
And.... after finding the 3 silicon rings in the package,and fixing them
on the plastic feet,it stays in the rack,when switching on,which I pretty much appreciate!
Not absolutely sure if it is getting better and smoothens even more,after a few hundred hours,but I have the slight impression.
Recommendation from my side
Peter O.
Upgrade
Ik heb 5 van deze versterkers gekocht om een actieve home cinema set op te zetten door middel diy luidsprekers. Hoewel ik zeer tevreden ben over de geluidskwaliteit heb ik een tweak uitgevoerd door alle elektrolytische condensatoren te overbruggen met een kleine film condensator van Panasonic omdat ik die hier toch op voorraad had. En ik heb ook de ingang condensators vervangen. Ik dacht dat dit nauwelijks iets zou opleveren maar toen ik naar een vergelijkende test luisterde viel mijn mond open van verbazing. Vooral in het midden en hoog is er net een grote waas verdwenen. Stemmen hebben veel meer detail en het hoog is volledig opgehelderd. Ik heb dit getest met mijn achtergrond luidsprekers die bestaan uit een full range luidspreker zonder filter en in omnidirectionele opstelling. Het resultaat is gewoon geweldig! Ik heb nu een 150 van die condensator bijbesteld. Per versterker is de kost voor 9 stuks van 1uF en 2 stuks van 2,2 uF ongeveer 10 Euro. Echt aan te bevelen!
Christian V.
ampli sub
Petit mais costaud ! Bon renfort de basses nettes et pas ”boursouflées” . Super rapport qualité prix
Preamplifier Volume Control OPA2604 This preamplifier is both simple and efficient, and benefits from a robust and high-performance design that provides high-quality, transparent and accurate audio reproduction.
À ce prix, difficile de trouver meilleur preampli en hi-fi
Envoi très bien emballé et reçu comme prévu.
Merci Audiophonic
Gérard H.
séparation de circuit audio
Utilisé pour supprimer la ronflette 50hz pour la liaison symétrique de 50m entre préampli et ampli. Installé en sortie de de préampli.
entrée 1-2-3, sortie 6-7-8. tout est OK.
Yvon C.
produit rare !
Audiophile depuis de nombreuses années, j'ai essayé de très nombreux câbles de toutes marques et tous prix. Certains, très chers, m'ont laissé dubitatifs ou carrément frustré. D'autres m'ont
apporté une progression qualitative évidente. L'intérêt final se situant dans le juste rapport qualité prix.. Avec ce produit RAMM AUDIO, le rapport qualité prix est prodigieux (je pèse mes mots), car il fait mieux que beaucoup, coûtant le triple !
Une véritable bonne affaire à connaître et faire connaître.
Cédric B.
Tres bon mais encore des problèmes avec Deezer
Tres pratique, facile à mettre en place et polyvalent tant qu’on n’a pas l’utiliser de streamer du chromecast. Il an encore des problèmes à se connecter avec Deezer, il semble “oublier” le login après quelques pistes et revient en MP3 128 malgré mon abonnement wifi. Mais avec Spotify connect, tout est transparent. J’en ai déjà acheté 2, pour le salon et mon bureau. Pas trop d’utilité du multiroom mais ça marche !
Arto L.
Clear as crystal
I wanted to try this new Purifi-module amp to hear if it is as good as claimed.
It is. Hard to say if this is neutral sounding or not but it is very accurate. My Nuprime ST-10 class-D amp is good but has a bit more warmer sound that I like too.
If I want to dig deep in the recording nuances I would use Audiophonics. It is very relieving with details and may occasionally sound too harsh with some recordings. Power handling is more than I need.
The value of this product is exceptional.
Jam M.
WIMA MKS2 Polyester Capacitor 5mm 100V 2.2µF WIMA MKS2 capacitors have a very good capacitance to volume ratio and can be used for a wide variety of applications. They have an extended service life, even at high temperatures.
Conforme à la description.
Prévue comme capa de liaison peu encombrante.
Jam M.
Prévue pour un filtre HP. Il faudra la maintenir sur le CI avec des colliers en rilsan.
Jam M.
Jean-Claude F.
Sur une Rega 3
J'avais déjà acheté la même plaque bitumée. Les 2 m'ont servi pour amortir une vieille platine Rega 3. J'ai posé une plaque dessus et l'autre dessous en pratiquant des découpes là où il fallait. Cela n'empêche pas le fonctionnement de la platine. Une de mes meilleures améliorations de cette platine qui n'en finit pas de me surprendre!
Jean-Claude F.
Installé sur un préamli phono Vida Prima en remplacement d'un câble secteur ancien, bonne amélioration pour un simple câble secteur avec un excellent rapport Q/P. Satisfait
Michael Z.
Killer DAC
The DAC far exceeds my expectations. Use it with ROON and Hqplayer on Pure Audio Project Trio-15. The resolution and stage comes close to my R2R DAC, which cost four times as much. A clear recommendation from me.
Mike L.
wow
This opamp really opened up the soundstage.
Digital Interface USB Amanero / Bluetooth 5.0 to AES / SPDIF / I2S 32bit 192kHz DoP128 This small, high-performance digital interface takes a Bluetooth 5.0 or USB signal as input and then outputs it in I2S (via HDMI), AES, Toslink Optics or Coaxial. The Bluetooth...
Fait bien le taf
Destinée ajouter une interface Bluetooth à un DACvia entrée optique : interface facilement détectée, fait le boulot sans histoire et sans défaut audible. Une demi-étoile en moins pour le câble alim un poil court dans mon setup, et une autre pour le commutateur d'entrée qui revient par défaut sur USB lorsqu'on met la chose hors tension - il faut accéder au mini-bouton de sélection derrière le bidule à chaque mise sous tension, ce qui empêche de le caler au fond du rack et de l'oublier..
Maurizio L.
PSVANE EL84-S Pentode Tubes (Matched Quad) These EL84-S PSVane pentode tubes are improved versions of the EL84. They use longer plates, better materials and gold plated contacts, resulting in excellent sound performance....
Bad purchase
Excellent sound quality, but the tubes are completely unreliable. poor construction, especially the feet. after a few days a tube is even dead. simple sovteks seem indestructible by comparison. I asked for a refund which was given to me.
Jean-Marc H.
incontournable
Je l'utilise depuis un bout de temps pour mes câbles numériques.
Et n'en connais pas d'autre pour assurer une impédance à 75ohm grâce au montage sans soudure à sertir
Jean-Marc H.
En plus d'offrir d'excellente performance pour connecter vos enceintes il est aussi parfait pour le câblage ou recâblage d'enceinte
Jean-Marc H.
Parfait pour le câblage ou recâblage des enceintes.
Christiaan P.
Excellent connector, probably the best up to 10 euros
The connector makes an excellent grip with the female socket. Soundwise in line with anything up to 10 euros.
Christiaan P.
Much better than the cheap alternatives
Better fit on the socket and smoother sound. In comparison, the cheap variants add edge and sound forward.
Jean-Luc B.
VIABLUE THREAD ADAPTERS M6 / M4 Adapters for Spikes (Set x8) Viablue's high quality stainless steel adapters and threaded nuts are used to safely mount spikes and absorbers to your speakers and equipment.
Adaptateur M6 M4 VIABLUE
Très bon produit , très bien usiné , tip top , recommandé .!
Fabien A.
Cable étonnant !
J'ai commandé ce câble dans l'optique de faire du bi-cablage sur mes JMR qui avaient un excès de grave dans ma pièce d'écoute.
J'ai donc branché ce petit câble sur les bornier de grave et laissé mes autres câbles (JPS Labs) sur les borniers de médium/Aigus.
L'écoute s'est tout de suite améliorée ! j'ai conservé tout ce que j'avais auparavant avec mes câbles hp et le Jantzen à apporté un contrôle incroyable sur le grave.
A présent plus d'excès et aucun manque non plus, tout est à sa place, j'ai une écoute équilibrée, comme si j'avais appliqué un réglage d'EQ sur les fréquences en excès pour tout lisser.
J'ai testé d'enlever le Jantzen et ne conserver que le JPSLabs et le grave est tout de suite revenu en excès et le déséquilibre à l'écoute est revenu.
Nous sommes 2 à avoir appliqué ce principe avec succès sur nos installations (qui nécessite évidemment un double bornier sur les hp) et en sommes ravi !
Fabien
Albert L.
Restitution sonore nettement améliorée
Deux NJR MUSES 8620 Double J-FET DIP8, acquis pour remplacer les deux AOP d’origine d’un buffer symétriseur-désymétriseur. Une restitution sonore nettement améliorée dès la première écoute par l’effet stéréo plus élargie, et l’on apprécie également la meilleure perception de certains sons, jusque là un peu en retrait, avec les précédents AOP, et cela au même niveau sonore.
Ivan S.
SEVA
A LITTLE FLEXIBLE, BUT OK
Ivan S.
DYNAVOX DAC UM1 DAC Coaxial Optical 24bit 192kHz The Dynavox DAC UM1 is a small digital/analog converter that is particularly affordable but still efficient. It has a Coaxial and an Optical input. At the output you will find a...
SEVA
THE PRODUCT MEETS EXPECTATIONS, SUITABLE FOR CONNECTING THE TV OPTICAL OUT, THE REMOTE CONTROL IS EXCELLENT FOR VOLUME REGULATION.
Lecteur réseau
Petit lecteur réseau particulièrement intéressant sur plusieurs points.
Tout d'abord il bénéficié d'une très bonne finition.
Ensuite, extrêmement simple à mettre en service (rj45 pour moi).
Branché en optique sur mon Dac.
L'application est relativement bien faite et Qobuz fonctionne en Gapless en natif. Par contre j'ai utilisé M connect sur IOS et là, pas de Gapless.
En tous cas un rapport qualité/prix quasi imbattable.
ATAUDIO L-4E6S Male USB-A to Male USB-B Cable Gold Plated OFC Copper 1m This ATAUDIO USB cable offers both high quality and luxurious design. It consists of a four conductor structure made of braided OFC 6N copper with excellent conductivity,...
Très beau câble USB
J'ai acheté ce câble USB pour relier mon PC Dédié Daphile avec mon DAC Topping D70.
Très personellement, en ce qui concerne le son, je n'ai pas trouvé de différence.
Par contre, il est extrêmement bien fini, avec des connectiques de très bonne qualité. Une fois fois en place, ça ne bouge plus.
Des câbles comme je les aime.
Merci Audiophonics
Que du plaisir
Aération, précision et profondeur c'est ce que l'on gagne avec cet appareil. Les vinyles revivent avec un préampli phono Micromega.
Bonne complicité avec le Dac X16 de la même marque et la connexion XLR. Le volume peut être réglé très finement grâce à l'affichage.
Jacques O.
Parfait pour l'utilisation
J'ai utilisé un nombre de modèles différents, 1U, 2U, 4U avec et sans dissipateurs pour carrosser amplis et DACs . Difficile de trouver mieux: qualité irréprochable Made In Italy. Pas besoin d'aller voir en Asie!
Jacques O.
Les SMPS Connex sont toujours de grande qualité. J'ai utilisé différents modèles pour alimenter avec succès plusieurs amplis de classe AB en lieu et place de transformateurs/ponts redresseurs/condensateurs de filtrage.
Top !!
Avec Audiophonics c'est toujours une qualité de conseil et une rapidité dans le traitement et envoi des commandes au top !!
Top !!
Comme toujours avec Audiophonics, qualités de conseil et rapidité dans le traitement des commandes et envois. Ils sont top !!
Thomas L.
Great product, great service
Thanks for the smooth handling and delivery of the products.
Thomas L.
Jacques O.
Remplacement à l'identique d'un potentiomètre arraché dans un ampli vintage Hafler P3000.
Michel C.
Nice to work with
High quality cable, it feels very different with the hard teflon coating. A bit rigide because of this coating. I used in my amplifier to connect the speaker terminals.
Michel C.
XANGSANE XS-010R Splitter Aluminum 1x9mm to 2x6mm Black This black aluminum splitter has one 9mm diameter input and two 6mm diameter outputs. It will allow you to design perfectly finished cables, with an efficient guiding and holding.
Nice looking
If your cable is not to big they are very nice because the outer diameter is small.
They fit great with AudioQuest Slip 16/4 cable, perfect match.
Michel C.
Very nice
I like to work with these, they are quite soft and think so they crimp very easy. They are nog magnetic so I suppose pure copper. 4mm Fits exact my 4mm² cable.
Je rejoins les autres commentaires.Il ne manque rien, c'est ouvert tout en ayant un grave et un bas medium propre.Sans duretés, c'est vraiment top.Pas donné mais le rapport qualité prix est excellent.
Après avoir essayé audioquest, mogami, van den hul, canaré, et d'autres, j'ai enfin trouvé un équilibre sans fatigue.J'étais resté sur le stratos depuis un moment, pour son prix et sa douceur mais il est bien en dessous, moins précis, moins aéré.Associé au fiches rca EIZZ EZ-203.Elles sont top mais préférez des fiches avec un diamètre de 10 minimum.
Elles sont qualitatives, on peux pas dire le contraire.Le prix est un peu élevé mais sont supérieures (plus robustes et lourdes) aux viablue t6s, par exemple.
Elles sont associées au FURUTECH FA-αS22, c'est plutôt concluant d'un point de vue sonore.
La mise en œuvre est simple, il faut idéalement un câble de 8mm max si vous voulez coincer la tresse entre la gaine et le corps de la fiche.J'ai du faire autrement avec le furutech.
Mario J.
Good quality problem solver
Nice pots, low noise (depends on other gear). Cheaply solves the problem with modern digital DACS and PREs having only one audio input.
Pol T.
Pol
J'ai acheté cette alim pour une imprimante 3D Flsun SR. Fonctionne parfaitement. beaucoup plus silencieuse.
Baptiste R.
On sait à quoi s'attendre!
Dès que j'ai vu cet amplificateur en stock, je me suis jeté dessus. J'avais besoin d'un bon ampli intégré, pour ne pas avoir plusieurs appareils, donc plusieurs boitiers.
Reçu vendredi dernier, en test tout le week-end, et bien... répond à toutes mes attentes!
DAC ES9038, NC252MP, XMOS... la précision et les watts sont bien là, et pas qu'un peu! Je n'ai pas encore réussi à aller à fond tellement c'est puissant et propre.
Son design sobre et classe fait qu'il s'intègre très bien au banc TV à côté des enceintes.
Télécommande réactive, bluetooh vraiment bien (Apt-X HD ou LDAC au choix).
Je ne peux que sur-recommander cet amplificateur réalisé par Audiophonics! Très bon boulot!
Anodized Aluminium Foot Ø30x14mm Silver (Unit) This foot is ideal for stabilizing a device while disconnecting it from an assembly to limit vibrations. It is made of CNC machined anodized aluminum and a rubber ring prevents...
Finition Hifi
4 pieds à l'excellent rapport qualité/prix.
Belle finition. Donne une belle allure aux appareils (ampli, Dac, alimentation.....)
De plus, ayant un insert en caoutchouc, ça permet aux appareils de rester en place.
Merci Audiophonics.
Comme d'hab.
André G.
cable audio médiocre
Malgré une période de rodage de 3 jours, ce cable apparait trop doux, manquant de détails, de relief et de dynamique.
