VIBORG VF501R IEC C15 Connector
This Viborg VF501R IEC C15 connector is ideal for designing and upgrading high-performance, high-quality power cables.
Reference : 22002
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 25-11-2026.
Viborg VF501R IEC C15 Connector Pure Copper OFC Copper / Silver / Rhodium Plated Ø19mm Black
Viborg VF501R
This Viborg VF501R IEC C15 connector is ideal for designing and upgrading high-performance, high-quality power cables. Its pure copper contacts with OFC copper / silver / rodhium plating ensure very high conductivity and excellent resistance to oxidation. The insulation is made of nylon and fiberglass, robust and lightweight materials that are also electromagnetically neutral. Assembly is very simple thanks to a screw-lock system.
Technical Specifications
Product typeIEC C15 Connector
Contact materialPure Copper
Contact platingOFC Copper / Silver / Rhodium
InsulationNylon and fiberglass
AssemblyScrew-lock
Compatible cable diameterØ6-19mm
Maximum conductor diameter / cross-sectionØ8mm / 50mm²
Voltage / Current250VAC 10A / 125VAC 15A
DimensionsHeight: 49mm
Diameter: Ø33mm
Length: 72mm
Package1x VIBORG VF501R IEC C15 Connector
Max cable diameter (mm)19.0
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Contacts Plating (Connector)Copper
Rated current (A)16.0
VIBORG VF501R IEC C15 Connector Pure Copper OFC Copper / Silver / Rhodium Plated Ø19mm Black
