marc g.
Dominique R.
Hautement recommandé
Paulo D.
Karol U.
FX-AUDIO TUBE-P1 Valves Amplifier with Phono MM Input 6J1 + 6P1 Stereo Silver The FX-Audio Tube-P1 is a tube amplifier with phono preamplifier input, based on 2 tubes 6J1 and two tubes 6P1. It is therefore ideal for those who want both a tube amplifier...
UK
Surprising:
-price = final sound = great!
Construction:
- solid metal and decently heavy for its dimensions. The connector from the power supply could have been solved better - it moves after insertion. The backlight of the electronics could have been omitted by the manufacturer. In the forums, they criticized the volume control, that it clicks and the like, nothing like that happens. The volume is controlled smoothly and goes smoothly into performance.
Connected options:
-Rca and Phono, solid speaker terminals
Sound:
-tried and listened to for several tens of hours until the electrons burn out (100h). I replaced the original supplied tubes with Russian 6P1P (6П1П) = 6P1 (China)
and 6Ž1P-EV (6Ж1П-EB) VOSKHOD = 6j1 (China). The result? I definitely recommend! Why? The sound device shows the purity, space, depth of the music scene (tested on Tannoy M2, Triangel BR2 .. + device Marantz Se63, Yamaha dvd796, Akai gx32, Tesla NC470, Dynavox RCA + Repro cabling (I recommend both from Audiophonics)). It's surprising to listen to a device that doesn't get tired even after a few hours. You're just devouring music of various genres, whether it's Soul, Jazz, Rock, Classic, Pop .. the device can handle and offers what is expected of an electronic device - the warmth of serving in the form of music.
You can say okay, but what about the power 2x2.5W? I also thought it would be such a "weaker coffee". The space of 30-50 m2 will completely cover with music.
Remi B.
Moyennement satisfait
Ce DAC a été associé aux amplis Atoll IN 30 et TAGA HTR-1000CD et aux enceintes Triangle Zerius 202.
J'ai acheté ce DAC par rapport aux avis et à sa distinction Quobuzissime: je m'attendais à mieux. Je l'ai comparé à un AUDIO GD NFB 15 de 2014 qui a également reçu la distinction de Quobuz. Certe, ce dernier était vendu 300 euros à l'époque, mais ces deux DACS ayant reçu la même distinction, je pensais qu'ils étaient assez proches en terme de résultat.
Il faut d'abord régler le son au maximum de mon lecteur ONKYO HF player pour avoir du son (volume du DAC au maximum), le son est beaucoup moins détaillé et naturel que sur mon AUDIO-GD.
En conclusion, j'en ai pour mon argent mais sans plus.
Olaf S.
Das Foto wurde geändert und entspricht jetzt den abgegebenen Maßen.
Nuno Miguel J.
realy good LPSU
After trying Nirvana and Shanti, I``ve never tought that this would made a BIG improvement in SQ. Clear and transparent midle and highs, dynamic, creamy and tight bass e bigger sound stage. Super analogic and non fatigue sound. The best LPSU for your Revolution and Signature combo from Allow
Hasni Z.
Conforme et bon produit
J’ai tout de même enroulé l’extérieur du tube pour éviter les résonances en augmentant légèrement l’epaisseur
Hasni Z.
Élimination définitive des vibrations
Acheté en 5mm d’épaisseur et posé à l’aide d’un sèche cheveux sur les 5 faces internes d’enceinte DIY. Une fois refroidi, ça ne bouge plus! Pour parfaire l’adhésion, j’ai passé plusieurs couches de lasure « 1er prix » sur le bois avant la pose.
Très bon produit!
Hasni Z.
Excellent qualité/prix
Conforme à la description et de très bonne qualité contenu du prix de vente.
Je confirme également l’utilisation d’une rondelle plastique face interne ;)
Petit kit assez qualitatif. Alimenté par un transfo en 2x20v, aucun soucis de réglage de la tension et du courant de repos, mais qui nécessite à minima 2 appareils de mesure pour être vraiment précis, car tension et intensité varient beaucoup lors du réglage.
Au fait, il est dit de prendre réglage de la tension à VDD/2 au condensateur 4700µF, qui en fait fait 6800uF sur les modules reçus. Une petite amélioration : Une borne sur le dessus pour prendre cette tension, et un porte fusible en série avec un fusible de 1,2A seraient un bon point. Merci Audiophonics, maintenant il ne me reste plus qu'à l'écouter.
Robert F.
Admirable et excellent ratio qualite/prix
J'aime la musique mais je cherche aussi le meilleur rapport qualité-prix.
Suite à des conseils de passionnes je me suis tourné vers cet ampli en complément d'un Dac et vraiment je suis totalement satisfait de la qualité de sortie.
Mon focal n'a jamais chanté comme cela.
Un grand merci au SAV Audiophonics pour leur aide sur un problème avec mon installation.
Gérard P.
Impressionnant ce petit produit
Comme les autres je suis bluffé !
le système que ce DAC abreuve de musique c'est un Cambridge One V2 et de vielles JBL monitor studio 4301 deux voies de 1978 - Tout D'occase qui plus est ( suspensions des boomers changées en 2014) - Bref on peut avec pas trop de moyen se faire bien plaisir !
Il vient remplacer le DAC Sabre Audiphonics de 2014 qui partira au garage continuer son service avec du matériel encore plus improbable .
Il me semble à l'écoute que cette dernière version est bien meilleure et apporte une amélioration.
Vincent H.
HIDIZS S8 Portable Amplifier DAC CS43131 32bit 384kHz DSD256 The Hidizs S8 is an extremely compact and lightweight portable amplifier and DAC combo, to take with you wherever you go or to use with your computer to enjoy excellent...
Acheté pour mon IPhone, fourni avec tous les câbles pour ios/Android/Windows, très pratique.
Excellent son avec une dynamique sans faille, son peut être légèrement descendant mais très très propre compte tenu de la taille et du prix.
Service Audiophonics toujours au TOP !
RQP exeptionnel
J ai changé ts mes prise en Viborg rhodium. Son très bien défini, dynamique, équilibré, elle apporte en plus une image stereo très bien étagée même en profondeur. Les timbres sont bien respectés et son vivant et les silence et extinction de notes sont simplement unique dans ses prix. À égalité de marque prestigieuse pour des système assez avancé. Privilégier les câbles en cuivre up occ ou OFC avec un bon plaquage argent.
Dirk d.
que dire...
Pas de notice , une vulgaire caisse en carton .
déchirée de l intérieur. Bref je me pose des questions .
nouveau nouveau ou déjà exposé...
le produit en lui même semble neuf .
C est sur que j achète tout les mois ce genre de produit.
en principe je suis très méticuleux ,et c est pour moi
un honneur lorsque je revends un accessoire ou appareil dans un état showroom.
Pour ce qui est du reste , tout fonctionne parfaitement .
Nous sommes navré de cette déconvenue.
Notez que la marque ne délivre aucune notice d'aucune sorte avec ses appareils.
Jean Pierre b.
MUSICIAN MONOCEROS Preamplifier Balanced Class A Silver The Musician Monoceros is a beautiful, high-end balanced preamplifier with a high performance Class A architecture and a completely discrete line input stage. Its volume control...
Je recommande à 100%
Après 1 semaine d'écoute, Je dépose un long commentaire, car très peu de retour sur cet appareil.
Je n'ai trouvé que 2 essais sur le net.
Je souhaitais simplifier mon installation HI FI et c'est raté.
Je possède un convertisseur à sortie variable (M2Tech vaughn) relié en symétrique
à 1 Chord mezzo 140.
(câble XLR O2A Q Sublim)
Je me suis vite aperçu que la sortie variable sur le DAC ce n'était pas ça du tout!
A niveau modéré je n'avais plus rien , plus d'image stéréo , plus de grave, plus de BP etc...
Un ami a mis le doigt sur ce que je soupçonnais et ce que je pensais des réglages de volume numérique
intégré au DAC.
J'étais obligé d'écouter à un niveau sonore important pour retrouver de la Hauteur
et du détail .
Je me suis mis en quette de trouver un vrai Préampli avec un vrai atténuateur de volume.
En dessous de 2000€ c'est très compliqué de trouver.
Tout de suite, j'ai pensé à un atténuateur à résistance comme il en existe souvent
sur un préampli passif et préampli HDG.
Puis je suis tombé sur le Monocéros.
Techniquement, rien à dire, le tableau est même idyllique au vue du prix de l'appareil.
Le plus important c'est quand même comment il sonne .
Déjà, pour rester logique, il a fallu racheter un 2ème cable XLR Quintessence Sublim.
Bonjour pour la simplification de la chaine HI FI...
Inutile de dire aussi que je n'emmenait pas large d'intercaler 1 préampli à 1300€ entre 2 appareils à 5000€.
Mes doutes ce sont vite envolé dés les premières écoutes!
Je commence par ce qui m'a déplu, la finesse des timbres.
Ils sont pareil qu'avant rien de + rien de - et c'est peut-être sur ce point qu'un préampli
HDG fera la différence, mais je n'ai rien perdu sur ce critère donc c'est plutôt rassurant au final.
Car pour le reste.... c'est un sans faute.
C'est tellement mieux, que ça en est déroutant.
J'ai du comparer avant après pour comprendre ce qui ce passait réellement et ça après seulement 2h de chauffe.
Tout va plus loin.
BP élargie du grave à l'aigue, l'image stéréo plus stable avec de la hauteur proportionnel au niveau sonore.
Puis il y a cette sensation de pouvoir monter le volume sans rien déformer.
( A condition que les enceintes suivent)
Du détails en + qui devient tout à coup plus lisible qu'avant, mieux intégré aussi.
Il y a aussi un coté apaisé que je n'avais pas et que je n'ai jamais eu.
Cet appareil apporte beaucoup pour son prix , surtout si ses qualités et sa conception
perdure dans le temps, car c'est la grosse inconnu pour tout appareil hi fi.
mention spéciale pour le grave maitrisé et qui m'a bluffé.
Quand je pense qu'on peu encore travaillé l'optimisation avec 2 fusibles et un vrai câble secteur....
Stephane M.
STYROFLEX Capacitor 65V 0.001µF 2.5% Styroflex axial cylindrical capacitors can be integrated in many electronic assemblies. They have a tolerance of 2.5%.
preamp RIAA
Utilisés dans un filtre RIAA, leur tolérance serré convient bien.
Stephane M.
Agréable à manipuler. Prévoir une alim 12VDC pour la diode (ce que je n'avais pas compris). A toutes fins utiles, la diode consomme 10 mA et reste bien visible avec une tension de 9V; c'est même plus agréable à mon goût.
Andoni G.
Be careful
Don’t conect your Amps or active subs or high energy demand sistems
This power surge is for small devices like dvd, dac, router, light etc etc
Is only 10 a power my mcintosh for example I’d 25 a
Daniel G.
OEAUDIO OEOTG Lightning to USB-C OTG Cable 12cm The OEOTG from OEAudio is a USB OTG cable of excellent quality, benefiting from a careful design, using components to ensure very good performance.
Excellent câble d'une bonne rigidité. Le son est transmis de façon parfaite la prise lightning est bien maintenu sur mon mobile ce qui n'est pas le cas pour tous les câbles. La qualité est là. Le service client que j'ai eu l'occasion de tester (panne informatique de la poste) est compétent et rapide (moins de 8h pour la réponse . Très bonne enseigne, très bon produits je reviendrai. A+++
Michael D.
FX-AUDIO D502BT Amplifier FDA TAS5342A Subwoofer Output Bluetooth 5.0 2x60W 4 Ohm Silver The FX-Audio D502BT is, as its name suggests, the successor to the D502. The D502BT takes over its base and components, but this time it comes with a Bluetooth 5.0 receiver,...
Backup for my Advance Paris AMP
Due to some issues with my main AMP (right channel is not working), i just used the FX-AUDIO D502BT as a backup amp for my living room (TV, PC and BT connected).
And what should i say, it is surprisngly good. Not the punch of the Advance amp, but not way behind that.
Perfect and easy to setup for me with the Sub out as well.
Normally i just bypass sound settings or EQ, but in case with the FX-AUDIO D502BT is just set to EQ preset no. 4, this works best for my ears and listening style.
5 stars from my side for price efficient small amp.
Mathieu P.
Excellent câble, scène plus large, plus de détails, grave plus profond et net
Il faut compter une dizaine d heures avant d avoir un bon résultat.
Je ne regrette pas
Igor H.
Problème de connexion
Quand il n'y à pas de musique le dac se connecte et se déconnecte tout le temps ? Sinon très bon produit, bien fini, bon son
Nicolas J.
Petit ampli pauvre en fonctionnalités mais qui mesure vraiment très bien pour son prix.
Je n'ai pas fait de test ABX mais l'écoute est très plaisante. Mon autre ampli est un intégré bas de gamme Pioneer de même puissance de référence A209-R.
Le VOLT+D est très silencieux à faible volume (bon rapport signal/bruit, bien meilleur que le Pioneer).
Je l'utilise en écoute de proximité sur de petites biblio Monitor Audio Monitor 100, avec l'alimentation vendue séparément sur Audiophonics (19V 3.15A). Le réglage de gain de 20dB est largement suffisant dans ces conditions d'écoute (potard de volume à 8 positions du max).
Au besoin il y a 2 switches sur le dessous à changer de position pour passer à 26dB de gain, et il est possible d'utiliser des alimentations plus puissantes.
Guillaume F.
Fountek FR135EX
Monté dans une enceinte à ligne de transmission, ce haut-parleur émet un son très propre. Pour sa taille, c'est impressionnant de descendre aussi bas dans les graves.
Le seul point faible est l'aspect visuel, notamment avec la mousse visible au niveau du cache-noyau.
Je recommande ce petit large bande de bonne facture.
Stefano Z.
wonderful streamer
I really wanted to ear the difference from my PC to a real streamer, and I wanted that every euro I spent for a streamer was on the streamer performance (so no DAC attached, no bells and whistles). This IS it. I usually struggle to ear differences between DACs so I was so surprised when I played the first track through the digione sig. The staging, clarity, less fatiguing sound was a huge step forward. I am totally happy.
One CONS: the preinstalled volumio was not original, so not up-gradable, so I had to buy extra hardware to flash the drive again and the extra money spent for the volumio version was a waste. You are better off choosing the roopie version and flash whatever on your own. I bought it with Nirvana, for me the result is already super satisfying, I don't feel the need to go with shanti, but I don't even know what I may be still missing, only that I am fine like this.
Antoine G.
Il me sert à alimenter l'ampli AUDIOPHONICS TDA-S50 Class D 2x 70W 4 Ohm, et le résultat est bluffant. J'ai bien plus de puissance que je ne l'imaginais, et il n'y a aucun souffle.
Antoine G.
Appareil remarquable
Avec une alim de 36v 6A, j'ai bien plus de puissance que je ne l’imaginais. Finition impeccable, petit et discret. Irréprochable côté qualité sonore. Aucun souffle. Il me sert, avec des enceintes bibliothèque, à sonoriser la zone 2 de mon installation audio-vidéo. J'ai fait passer un câble HDMI, j'ai un moniteur d'ordi avec sortie casque, et j'ai branché l'ampli dessus.
jean luc L.
https://www.audiophonics.fr/index.php?id_product=4635&controller=product
livraison rapide , multiprise solide
Farzad E.
CL-400W Amplifier Board TDA7498E 2.0 / 2.1 / 4.0 Bluetooth I2S HDMI 4x120W 4 Ohm This complete and versatile CloudyX CL-400W amplifier module has the particularity of being able to operate in stereo mode (2.0), 2.1 or 4.0. It is capable of developing a power...
Très déçu de la qualité sonore en sortie avec beaucoup de bruit
Cyril V.
AUDIOPHONICS EVO-SABRE PACK DIY avec Roon Labs
Acheté début 2020, j’ai pris le temps de tester l’AUDIOPHONICS EVO-SABRE PACK DIY DAC Symétrique 2xES9038Q2M.
Avec l’entrée USB je suis déçu, le son est moins percutant. Je ne serai dire pour quelle raison, surement ma source USB (Serveur NAS ou Raspberry PI 4) ! De toute façon, je ne souhaitais pas utiliser cette entrée en l’achetant.
Le résultat est meilleur avec le Raspberry PI (interne au boitier utilisant les GPIO en I2S). Le son est dynamique, précis sans être analytique comme les autres DAC Audiophonics DIY utilisant également l’ESS SABRE 9038Q2M. Je pense que c’est lié au filtre a phase linéaire et ou la gestion du DPLL.
J’ai changé les AOP de sortie par des BURSON AUDIO SUPREME SOUND SS OPAMP V6 Classic AOP Simple (pour info, pas besoin d’adaptateur). A mon oreille cela n’a pas changé grand-chose (A l’époque où j’avais changé les AOP j’avais des enceintes et un ampli bas de gamme de 20 ans d’âge).
J’ai mis en place un dissipateur thermique sur le Raspberry Pi 4 qui s’intègre bien entre le PCB et le PI (Geekworm Raspberry Pi 4 11mm Embedded Heatsink (P165-B)). Ce qui m’a permis de gagner quelques degrés.
J’alimente le DAC avec l’alimentation proposé par Audiophonics (MEAN WELL Adaptateur Secteur Alimentation 100-240V AC vers 9V 4A DC ) avec un filtre ifi
J’ai remplacé l’écran de droite SPI par un écran DSI en couleur et tactile de 4,3 pouces (4.3inch DSI LCD Capacitive Touch Screen Display 800×480). J’ai dû le coller avec du double face en façade. Ce n’est pas des plus esthétique (ce n’est pas moche non plus) mais c’est fonctionnel. Je vois les jaquettes, je peux passer au morceau suivant, diminuer ou augmenter le son en appuyant sur l’écran.
Utilisateur de Roon, j’utilise la distribution Ropieee qui s’intègre parfaitement au DAC notamment la gestion du volume, l’écran tactile DSI (non SPI). J’ai testé d’autres distributions, Ropieee tien le haute du pavé avec Volumio en termes de restitution sonore.
Pour info, j’utilise ce DAC comme préamplificateur sur un amplificateur Audio-GD A1 et depuis 3 semaines sur des enceintes Triangle Magellan duetto. Le tout sonne très très bien.
Les plus :
- Rapport qualité prix
- Qualité de fabrication
- Pas mal d’entrées (GPIO(I2S), USB, TosLink, SPDIF, Bluetooth)
- En sortie XLR et RCA
- Module DAC symétrique Double ES9038Q2M
- Possibilité de choisir les AOP de sortie
Les moins :
- RPI I2S : 384kHz / DOP128. J’aurai préféré une liaison DSD Direct 512. Est-ce que c’est possible avec le Raspberry PI ? ou Est-ce lié au FGPA Altera Max ?
En conclusion
Très bon produit en therme de son. J’ai aimé le monter moi-même et le modifier pour mon utilisation (Roon Player). L’intérêt de ce produit est le prix, l’électronique de bon niveau, la flexibilité d’utilisation, mise à jour à moindre frais. Si Apple sort un nouveau protocole Airplay 3 (implémentation dans l’OS) ou un futur Bluetooth 6.0 (via clé USB ou changement du RasPI) vous pouvez mettre à jour après que la communauté est sortie la mise à jour.
Stéphane C.
J'ai commandé ces fiches bananes pour remplacer de très anciennes WBT , livraison rapide et sérieuse comme toujours.
les fiches sincèrement elles sont de très bonne qualité , d'un point de vue fabrication et résultat sonore. Je possède un bon système et la différence sonore est bien réelle .
Je recommande ces fiches sans hésitations.
Stéphane.
reginald B.
Fait le job!
Enfin testé ce weekend sur des b2 d&b, ça s'est très bien comporté, alimenté par 6 batteries 12v en série, un bonheur. On verra dans le temps mais c'est du sérieux.
Tomáš N.
PSVANE tubes
The first switch-on, a fuzzy, obscure, crooked, bad sound, but improving during burning, after 30 hours of listening accurate fast bass, beautiful clean mids and highs with perfect microdynamics, amazing holography 3D stage, very nice warm character, I think they are the best from EL34 line, (better than everything I've heard so far including gold lion kt88) the only small disadvantage for me (just when compare) is not such dynamics and such deep bass as on KT88. I am very very happy with this.
Produit correct
Boîtier tôle emboutie, avec façade de belle facture en aluminium, montage aisé et intuitif, prix décent. Un seul bémol négatif, faites hyper attention en manipulant le boîtier, les arêtes vives des radiateurs sont aussi coupantes qu'un scalpel... Je vous recommande fortement de ne le manipuler qu'avec des gants (pas en tissus ni en nitrile), sinon mettez les mains sur les façades antérieures, et postérieures.
Content de cet achat
Par rapport à la génération précédente, il est à présent possible de couper totalement l'alimentation à l'arrière du boîtier, les fiches HP sont plus qualitatives, le boitier est plus large er fait plus chic, belle évolution, il ne me reste plus qu'à l'écouter voir s'il y a amélioration, mais ça, j'en doute, le module interne semble identique, et comment améliorer le son de quelque chose d'aussi fidèle dans la reproduction sonore.
Merci Audiophonics, excellent rapport qualité prix.
Mikael I.
zimmerman
I give it 10 stars I love this cable can only recommend it to anyone how wants good
natural with large sound stage
Mikael I.
zimmerman
Nice for the price and good for tick cables
Mikael I.
zimmerman
noel s.
SHANLING UA1 Pro Adapter DAC USB-C ES9219C 32bit 384kHz DSD256 80mW 32 Ohm Black Whether you are using a latest generation smartphone that lacks an analog audio output (compatible directly with your headphones / headphones) or you simply want to improve the...
Géant !!!!!!!!!!!!
Extrêmement satisfait
Utilisant avec mon Mi 10 il change radicalement la qualité du son
Même avec mon autre dac plus cher je trouve celui ci nettement meilleur.
Christian T.
Comparé directement avec un câble secteur à 1500 €, le NEOTECH NEP-3001 est à égalité pour 10x moins cher.
Je suis très satisfait merci audiophonics.
Vincent B.
Une rolls
Cable de super facture, robuste et de qualité.
Une Rolls.
Vincent B.
CYK Stereo Cable XLR-3 Male / RCA Male Gold plated 24K OFC Copper 2m This affordable RCA male to XLR male CYK cable is ideal for ensuring good conductivity to your signal with its OFC copper conductor.
Fabrication OK mais aucun repérage G-D du coté XLR
Tout est dans le titre. On se demande comment on peut concevoir un câble audio sans repérage de voie gauche-droite d'un coté du cable (ici du coté XLR).
Vincent B.
SHANLING MTW100 V2 In-Ear Monitors IEM Bluetooth 5.0 White The Shanling MTW100 V2 headphones, particularly practical, allow a stable and efficient transmission of your music. Knowles loudspeakers and the intelligent design of these IEMs...
oreillettes très simples d'utilisation, discrètes, de bonne qualité audio, aucun problème de connectivité avec un PC, avec iPhone. Bref excellente expérience. Je recommande vivement pour qui ne veut pas se ruiner dans des oreillettes BT.
IMAGE STEREO SANS PROFONDEUR
Beaux timbres et transparence correcte. Points négatifs: le niveau de détail pourrait être meilleur avec des micro-informations qui passent à la trappe. Image stéréo manquant singulièrement de plans en profondeur ce qui rend la restitution d'un orchestre symphonique abstraite, irréaliste. Le Sabaj A4 qui embarque les même puces fait beaucoup mieux.
Bof
C’est un câble pas cher mais heureusement, car contrairement aux autres avis, il ne m’a pas emballé pour l’instant. Il a déjà tourné 20 heures et il reste fermé sauf dans les aigus ou il s’en sort. Il dégraisse trop en bas et il écourte trop les fins de notes.
Dans les mêmes prix, le Canare et surtout l’orbite 240 font bien mieux.
Ecouté sur deux ensembles différents avec le même constat.
Atoll in 100 et cd 100 en SE
Sur hp triangle Antal xs refiltrées et recablées.
Ampli et cd Roksan K2 sur focal chorus 826 v recablées
Câble et prises secteur Oyaide Tunami pour les deux ensembles
KRISTIJAN B.
Super konektor
i connetori sono perfeti!
Chi sa saldare non avra nessun problema.
Cosiglio aquistare!
Bengt N.
Superb DAC its outstanding control
I can agree on all positive reviews, plus the excellent control possibilities such as the optional volume control. I have not tested the I2C input yet, but it is tempting to try. This DAC is perfect for my 4 channel DSP crossover filter. Recommended!
Bengt N.
USB to I2S Interface XMOS XU208 32bit 384kHz DSD256 This USB to I2S digital interface includes an XMOS XU208 chip supporting high sampling rates up to 32bit PCM 384kHz and DSD256.
Works very well
No problems at all. The I2S input from this device gave an improvement on the sound quality from my DSP, compared to my previous SPDIF input. Recommended!
Jean Michel P.
Excellente fiche IEC
Cette fiche IEC est de très bonne fabrication et l'insertion dans mon ampli Denon est très franche . Le cuivre pur apporte réellement un plus à l'écoute par rapport aux plus basiques IEC Schurter ..
Définition ,douceur ,largeur de spectre et image tout semble magnifié. A marier avec un très bon câble secteur pas nécessairement cher
Bengt N.
Working well
This remote receiver is working well in the volume control/input selector PCB after a small modification. Instead of soldering it straight with pins 1-2-3, it should be mounted 1-3-2., two of the leads swapped. After this it is fine!
And you should know that it is not working without the display attached...
Petit transformateur pas cher, belle qualité, la tension est respectée, 0.1v près, très silencieux et facile à mettre en œuvre. Attention à ne pas tirer sur les câbles de sortie, j'en ai malencontreusement arraché un. Ce transfo est tellement bien fait, qu'il est facile de le démonter, et de ressouder le fil, ce que j'ai fait.
Une petite amélioration : Un schéma des bobinages interne serait un plus, afin de ponter en série ou parallèle entrées ou sorties, afin d'avoir le meilleur couplage possible.
Merci Audiophonics pour la qualité de ce composant.
