Marc C.
Que dire ?
Bertrand j.
neutrik
Ramiro F.
Jean-Michel P.
Un + vraiment appréciable
En remplacement de l'alimentation fournie en standard avec mon 3D LAB Nano Transport Sonata V5...
Le gain se situe au niveau l'attaque des sons. Encore plus nette et plus propre !
(sinon, comme Arnaud, je trouve que la LED éclaire un peu trop :) )
Aikaterini A.
Nothing special
I bought rhis dac because of Amirm' review. By using it I found it nothing more than a typical modern Chinese dac you can find at much smaller price. I wonder why, while they knew that their choice of this volume /source control was a joke , they dodnt give us the chance to bypass it. At least....
Vraiment decu
Andre T.
Recommendation
This little amplifier was an audiophile surprise for me. To say it in advance: it can definitely compete with amplifiers from the 1000€ league.
The first thing I noticed about the sound was the authority of the bass. It seemed as if my speakers were now supported by a very controlled subwoofer. Effortlessly and without strain, the MOS-120 controls the cones. This indicates a good damping factor. This sovereignty continues into the midband, which is wonderfully detailed and wide. The result is a spaciousness that I have never experienced with my speakers before. The high frequency range is accentuated and airy, giving the treble that typical audiophile melting. You can hear that this amplifier has a superior audio bandwidth.
The MOS-120 is a very good example of what makes a good analogue amplifier. It is puristic, but focuses on exactly what an amplifier must be able to do. I am considering ordering a second MOS-120 to use them channel separated. Unfortunately, my loudspeakers don't have a bi-wiring option and the MOS-120 can't be bridged, but this setup might give me even better channel separation.
Je l'utilise avec un Audio-GD R7-HE21. Tout est parfait de l'extrème grave à l'aigu, pas de dureté. Cable franchement excellent.
Olivier D.
Exceptionnel
Je n'ai pas l'habitude d'écrire un avis suite à mes achats, mais là je fais exception à la règle. Je fais tourner cet ampli avec des atlantis lab AT31 : une claque monumentale, je ne décolle plus de mon canapé. J'ai également un ensemble jolida à près de 9k€, un isem elixis millenium à 2k€. A mon sens et après comparaison sur ces enceintes, il est au dessus tout ça : une écoute ultra détaillée jamais agressive, des basses profondes qui me manquaient avec l'elixis, une écoute cristalline à souhait qui me manquait avec le jolida et une superbe ouverture sans perdre en crédibilité.
Si j'avais su j'aurais économisé 10k€ et je me serais limité à cette petite boite dont la taille est inversement proportionnelle aux performances qu'elle délivre.
J'aime les écoutes analytiques tout en restant réalistes et là je suis comblé.
Les produits chinois n'ont vraiment plus à rougir de leurs concurrents du vieux continent ou d'outre atlantique, c'est une évidence pour moi. Et niveau fiabilité c'est également un constat que 'on peut faire aujourd'hui à mon avis.
Cet avis que je dépose ici n'engage que moi, donc pas la peine de me dire que je ne sais pas de quoi je parle. Je suis extrêmement exigeant au niveau du son, qu'on se le dise.
Franck B.
A utiliser avec un filtre
J'ai utilisé ce large bande pour rénover une vielle radio.
Je suis assez déçu du produit. Le médium est plus que présent. Vie haut parleur nécessite un filtre
J'ai du le remplacer.
Si une bonne âme peut me conseiller sur les valeur a utiliser pour créer un filtre je suis preneur.
Le résultat médiocre peut être lié à la source et à l'amplification utilisée.
Dans l'absolu un large bande d'entrée de gamme ne peut donner (même bien traité) un résultat hifi.
Franck B.
J'ai utilisé cet ampli mono pour rénover une vielle radio.
Parfait très petit (attention chauffe un peu) mais une belle puissance développée pour la taille. A voir si il vieillit bien.
La qualité du son est très très correcte.
Nils B.
Après un an.
Voila je donne mon avis après un an d'utilisation.
J'ai acheté ce câble pour le mettre sur un AKG 712 Pro relier à un SMSL M6 DAC USB. La qualité du son est d'une très grande justesse. Mais à ce prix c'est bien normal.
Le Cable est assez souple au passage. Mais j'enlevé une étoile car le tressage comme bien souvent commence à se détresser assez vite. Au milieu du câble et vers l'embout Jack.
Pourtant j'en prend grand soin.
Lorenzo C.
Little, just by name!
Even though everyone advised against purchasing it citing noise, hissing with low impedance headphones, buzzes and hums and so on, I still wanted to buy this iconic little headphone amp rather than one of its more modern siblings and cousins.
I ran the Little Dot for about 40 hours both with headphones and as a preamp on my tubes and solid-state amps, and I have to say, I did very well!
From the very first moment of listening you can perceive a really unexpected transparency, and obviously we're talking about stock tubes that, it has to be said, behave very well:
Great extension on the high octaves, nice dry and controlled bass, great airiness and an overall pleasant dynamic, all mixed together to obtain a sound that doesn't give any listening fatigue and is much more pleasant at high, but especially at low levels of evening and night listening of my jazz and classic favourites.
A special thanks to Audiophonics for the great attention and professionalism in handling my order!
See you again soon!
Jürg E.
What a fantasic cable!
I am very impressed about the sound quality of this cable. I did not expect such an improvement in sound quality. The soundstage is very precise, very wide and deep, the bass ist much more controlled, has a huge authority, goes much deeper than before. It does sound very corherent and natural. It is very detailed in the threble, but never too pronounced. I call this organic and natural. The midrange is very smooth an realistic, voices are very three dimensional. A must have cable for your Power Amp and your connector strip. Be aware: the cable is very thick and stiff and will not fit many power-plugs like Oyaide. I did combine it with the Viborg 502 Copper plugs. They fit perfectly and the sound is stunning!. Highly, highly recommended!
Jean P.
FURUTECH LAN-8 NCF Ethernet RJ45 Cat8 Cable S/FTP 1.2m Furutech LAN-8 NCF is a beautifully designed Category 8 RJ45 Ethernet cable with S/FTP shielding for high-speed signal transfer.
cable furutech rj45
très bon câble qui améliore de façon importante la qualité audio sur lecture réseau : transparence , voix naturelles , des graves et des aigus plus marqués et très bon rapport qualité prix
François G.
Ampli pour infragrave
Je recherchais un amplificateur pour driver un infragrave et ce petit amplificateur m'a surpris par la tenue de la membrane, sa précision, définition, le moteur de mon HP a une bobine mobile de 100mm. Je l'ai essayé sur une enceinte large bande aussi (appareil mono), même constat.
Sa sensibilité d'entrée n'est pas très élevée, mais n'enlève rien a ses qualités.
Ce petit ampli tiens vraiment ses promesses et je le conseille.
Eric L.
Impressionnant
Installes sur un Fostex Hp 8 Ac Mk1. Impressionnant : plus de largeur, de dynamique sur l’écoute au casque . En revanche pas de changement sur la sortie ligne ( mais c’est logique, les Aop ne sont pas sur ce trajet).
Attention à bien prendre les prolongateurs en plus . Ça évite de mettre les autres composants en tension.
Vincent B.
Pas de répère L/R
je ne jugerai pas de la qualité des câbles en soi qui parait OK, sans plus, mais le fait que les connectiques XLR n'aient pas de repère gauche/droite (L/R), alors que les connectiques RCA en ont, est pour le moins agaçant.
Neil L.
Wonderful
Bought to use with Denon 3700h avr as pre-out driver for front speakers. At first I experienced a ground loop between this and my htpc which was solved by using a cheap Amazon EU/UK power strip and a 2 pin EU power cable..then all good. I found the Denon to be very bright especially with music, this little beauty changed all that. A wonderful addition to the Denon AVR setup which drastically improved music but also (rather surprisingly to me) movie performance. The additional warmth and detail for both music and movies was very surprising. Anybody thinking of buying this kit, I highly recommend it especially if you are looking to use with a brighter home cinema amp like the Denon. This is my first adventure with pre-amping and I blindly took the leap of faith after reading the positive reviews here...hence my adding to them. Cheers.
exelente.. et a upgrader
bonne alimentation pour un zen lecteur réseaux et la box upc en 12v.. sais un excellent resultat même en qualité video tv.. oublier pas le must. changer la prise iec pour une furutech or ou rhodium.. et les fusible.. la sa fait une grande différence en plus.. le fusible sur l entrée secteur un sr black yc les deux autre fusible a l intérieur.. la il se passe bc de chose.. douceur sérénité et dynamique transitoire nature ..tous monte d un bon cran.. si vous avez moins de 200fr a mettre..3 fusible sr black pas trop cher et une prise furutech or 7 rhodium.. faite le.. la ont a a faire a une alimentation excellentissime.. les câbles fournis sont excellent.. mais la aussi pour pousser plus loin . changer les fils de câblages par des argent mono ou multi brins.. et une prise 5,572.5 elecaudio cuivre tellure or 24k.. mon pote a cette installation.. sa vaut le détour.. pour bricoleurs méticuleux..
Jonathan P.
Pratique et audiophile
Après avoir cherché des jours entiers sur le net, je peux affirmer que ce petit appareil n'a aucun équivalent sur le marché à moins de 300€.
Certes, il ne fait que lire les fichiers numériques à partir d'une carte SD ou d'une clé USB. Mais il le fait bien et cela s'entend immédiatement.
Il est capable de restituer la musique avec une très grande rigueur, sans colorer les timbres, et toujours avec naturel. Son DAC est de bonne qualité, et sa fabrication en alu massif usiné respire la solidité.
Seul bémol, la portée de la télécommande qui est un peu juste (3m environ).
Je viens d'investir dans l'alimentation séparée du même fabricant, et j'ai encore fait un bond en avant en terme de dynamique et d'aération.
Facile à souder et d’une qualité sonore très intéressante. Belle finition et d’un prix plutôt dans la moyenne basse.
Associée au câble Canare L4E 6S star quad plus soudure argent mundorff 10% et vous obtenez une vraie pépite.
Pour 20€ vous allez taquiner le très haut de gamme. C’est bluffant d’équilibre.
J’aime bien et je vais en recommander de suite avant la rupture.
Etienne B.
Format sympa, son détaillé et doux
Très bon DAC pour accompagner un ordinateur, pour une écoute au casque. Le son est très précis, et reste doux. On entend les nuances et les timbres. Comparé à d'autres DAC qui paraissaient très dynamiques, avec des basses plus percutantes, mais au final mettant moins en valeur les timbres et la variété des instruments (shanling up, geek out 1000).
Marche très bien avec un seul cable USB branché à l'ordi pour données + alim (bien qu'il existe une deuxième entrée pour une alim dédiée).
Etienne B.
Très bon DAC
DAC que j'utilise entre un raspberry et un ampli classe D (Allô Volt+D). Rempli parfaitement son office. Le son résultant (qui dépend bien sûr aussi de l'ampli et des enceintes Davis Acoustics Olympia One Master) est détaillé, précis. Les attaques (piano, clavecin ou percussions) sont très réalistes. Les timbres sont respectés et me paraissent très justes.
Les 3 entrées sont bien pratiques : le raspberry sur port USB, une télé sur port optique, un lecteur DVD sur port coaxial.
Seule la télécommande laisse à désirer : même en étant bien en face, ça ne marche pas à tous les coups... ce qui réduit le confort d'usage pour un rôle de réglage de volume du système.
eric l.
EXCELLENT
Son clair et bien detaille,les aigus son cristallins,les graves present mais pa imposant,medium parfait.Trés bon casque
Andoni G.
AUDIOPHONICS JF20 Spade Jumpers Gold Plated OCC Copper 20cm (Set x4) These Audiophonics JF20 jumper cables allow for quick, easy and clean wiring in a bi-wiring audio installation or for series speaker setup. Each jumper is 20cm long and features...
Solid and big quality build. They are perfect.
Dominique G.
Commandé le jeudi reçu la samedi :)
Ce petit boitier fait parfaitement le job, je l'ai connecté sur l'entrée spdif du lecteur Audia CD1M, la restitution est excellente au regard de l'investissement ! Mon installation B&W 805d2 DB2d - Fls9 - Cd1M
Associé ce Canare a des prises rca rc-602, et après une vingtaine d’heures de rodage c’est absolument divin. J’ai suivi le montage préconisé à savoir,
2 fils blanc sur le chaud et les 2 fils bleu sur le froid avec la tresse de masse côté source uniquement. Le tout soudé avec mundorff 10% argent.
Je monte des câbles depuis très longtemps et j’affirme que ce Canare associé à des prises de bonne qualité est imbattable dans sa catégorie voire au delà.
Pour un un coût dérisoire de 25€ en 2x1 mètres il enterre des câbles 10/15 fois plus coûteux.
J’arrive à la conclusion que finalement le prix dans le monde du câble hi-fi n’est pas le seul révélateur de qualité.
N’hésitez plus car le rendu musical de ce Canare est EXCEPTIONNEL
Hervé B.
SHANLING ME700 In-Ear Monitor IEM Hi Res 106dB 18 Ohm Ultra light in-ear-monitor equiped with 5 transducers with custom Armature drivers. Removable cable with MMCX connecteurs and balanced / single-ended output.
Info complémentaire
La forme des intrus est au top! Enfin pour mon oreille, on dirait qu'is l'ont moulée à mon conduit auditif!
Mathias L.
Gustard DAC-A22 Balanced DAC 2x AK4499 32Bit / 784kHz / DSD512 XMOS Bluetooth 5.0 MQA Silver Gustard Audio DAC A22 makes use of two AL4499EQ DAC chip. This reference component is among today's best digital to analog conversion solution.
Gustard Dac A-22 TOP
Top, Super Dac, the finest technology, very fine resolution,
I've already had a few dacs, but it's the best, thanks to Gustard for this miracle of sound
Highly Recommended
Jens H.
The best RCA plugs
I have tried many different brands of RCA plugs, for my DIY interconnects. These are the best. Easy to work with, easy to solder, beautiful, very well made. Sound quality will not make you dissapointed if your aim is high end homemade interconnects.
I can't praise these enough.
Jens H.
Not my favourite
I don't like these at all. Difficult to solder, no place to attach ground cable, had to drill a hole. Difficult to solder (Tellurium, yes I know..). Fit of outer ring is a bit too tight.
Will not buy again. Instead, will buy the 1877Phono which are absolutely fantastic plugs, easy to work with, beautiful quality.
eric m.
Dans les premières heures d'écoutes, ce Tube est très terne (un peu normal pour un Tube neuf.....) mais après une bonne cinquantaine d'heures, ca va beaucoup mieux. on découvre une scène sonore très impressionnantes, surtout sur des enregistrements "Live". Un Tube qui correspond tout à fait à mon Préampli. SRPP. Tube faible bruit et microphonique un son bien équilibré. C'est un bon choix.
Etienne B.
Excellent ampli
J'ai acheté cet ampli chez audiophonics (service client très bien avec conseils avant et après achat) il y a un an. Il fonctionne avec un raspberry pi comme source numérique, un DAC SMSL Sanskrit, et derrière des enceintes Davis Acoustis Olympia One Master. Le résultat est très bon.
J'ai comparé avec attention avec un SMSL AD18 (qui prend le signal numérique sans avoir besoin de DAC) : le AD18 est plus punchy sur les basses, très "direct" (ce qui est il faut bien dire très séduisant aussi). Mais le Volt+D est plus équilibré, avec des timbres plus riches et nuancés des basses aux aigus, et au final une scène plus réaliste, et c'est pour cela que je l'ai retenu. L e Volt+D reste étonnant sur la propreté des attaques et autres "transitoires" : les percussions sont très présentes, c'est presque troublant sur des cymbales. La fidélité et le respect de tout le spectre me paraît marquante, jusqu'aux aigus. Je n'ai pas comparé à des amplis chers et haut-de-gamme, je peux simplement dire que le son dans mon système modeste me paraît très bon et réaliste. J'entends très bien les différences entre des bons enregistrements, surtout en qualité CD, par rapport d'autres moins bons : la séparation des instruments, la présence dans la pièce des instruments, sont très agréables et réalistes, et en fermant les yeux, on y est... surtout sur des petits ensembles, jazz et vocal (mon petit système reste moins précis et réaliste sur des grands orchestres, mais je ne sais pas dire le rôle des enceintes, de la pièce, et de l'ampli).
Un son simplifié
Je rejoins l'avis de Patrick S. du 24/04/2021. Si ce Canare 4s11 présente un bon rapport Q/P, il offre une restitution trop simplifiée. Ses qualités sont cependant évidentes avec un son ouvert, fluide et aérien, une musicalité communicative et enjouée ainsi qu'une belle linéarité, mais les morceaux complexes et le jeu de certains musiciens sont fortement simplifiés et les styles musicaux ne sont pas toujours respectés.
Hervé P.
Parfait, fais le job ...
Dispositif mis en amont d'un Ampli Audiophonics Hypex 2x250W afin d'éviter tout risque d'exploser mes enceintes à l'allumage (Pas de réglage physique du gain, j'ai juste un "Bluesound Node" qui me sert de préampli donc absence de bouton "physique")
Fabrication super costaud avec Potentiomètre de qualité pour un prix très raisonnable.
Délai de livraison 2 jours ouvrés dans mon cas, bravo !
Hervé B.
Prestigieux!
Cette paire d’intras est à la hauteur des plus grands fabricants reconnus dans le monde de l’audio pour 3 fois moins chers!
Le son qui se dégage de ces écouteurs est un orgasme auditif, et pourtant je viens de les recevoir, et ils sont même pas rodés.
Bref, une grosse claque sonore sur mon Fiio M11. Des micros détails jamais perçus se révèlent majestueusement lors de l’écoute.
A titre de comparaison, je possède en sédentaire un RME adi2 dac couplé à un Focal Elear, et ces shanling les surpassent allègrement!
Les accessoires de très haute qualité et très nombreux viennent parfaire cette acquisition. Les paires d’embouts silicone sont dignes
De marque comme JVC spiral dots ou Sedna. Et les 2 adaptateurs 3.5mm et 4.4 viennent parfaire le tout.
Voila, vous êtes maintenant informés pour ne pas dépenser 1500 euros pour des marques prestigieuses. Et oui, la rétro-ingénierie Chinoise fait un knock-out aux ténors!
Je vous garantis que vous ne le regretterez point. Bien à vous.
Philippe L.
Excellent produit !
Très bon contact et parfait ajustage des matériaux pour un tarif acceptable; à noter une mention spéciale aux vis Tox qui permettent des démontages / remontages sans se coincer, ce qui n'est pas le cas de toutes les fiches bananes.
Sébastien S.
MA-LM02 Stereo Amplifier board LM3886T Class AB 2x 68W This Class AB Stereo Amplifier is renowned for its clarity, dynamics and excellent low frequency handling.
bon ampli, mauvaise presta de vente.
Ampli très correct pour le prix.
MAIS Audiophonics n'en a rien à faire de l'état de réception de nos commandes:
Emballages pitoyables, les circuits roulés dans un bout de carton avec systématiquement les CI écrabouillés sur leurs pattes. Condos bosselés, pattes rompues...
Beaucoup de clients ont déjà fait la remarque et rien ne change,
Conclusion : l'intérêt d'Audiophonics est ailleurs!
didier D.
Très bonne qualité, assez facile a connecter une fois que l'on a compris qu'il faut tout sortir. un mode d'emploi un peu plus détaillé ne serait pas du Luxe.
Monté avec un in wall 3x 3.5mm diam total 12 mm, a mon avis c'est la limite haute a ne pas dépasser car cela pourrait devenir difficile.
Excellent produit.
didier D.
un peu cher mais très bonne qualité
Très bon produit, facile a serrer avec une bonne tenue.
Un petit peu cher mais avantage de pouvoir les avoir a l'unité.
didier D.
bon produits mais caractéristiques affichées fausse
la qualité de ce produit est irréprochable, le rapport qualité prix est bon.
Cependant, il n'as pas convenu a mon besoin. Les caractéristique annonce diam 295mm et épaisseur 5 mm.
Il se trouve que le plateau de ma platine vintage est creusé et les 295 correspondait .
Hélas, quand je l'ai posé, cela ne rentrait pas, je donc du le retailler.
une fois posé surprise, pas assez haut, après mesure... épaisseur 3 mm. Je ne peux donc pas l'utiliser.
didier D.
connectique de mauvaise qualité
aprés avoir du reconnecter 3 fois les cables, le pas de vis de serrage de la terre a foiré.
22 € la prise shuko plaqué or, c'est pas cher, mais si c'est pour les mettre a la poubelle, ce n'est pas interressant.
Michel V.
Vraiment top , se connecte au Bluetooh de mon Iphone instantannément , je peux envoyer sur l'ampli de ma chaine hifi le son de l'application Deezer qui est sur mon Iphone, distance de réception super suffisante et aucune coupure.
Belle finition de ce petit récepteur et la livraison ultra rapide et bien emballé.
Merci à Audiophonics !
l evidence de la musique enfin!!!!!
iec fi c15 ncf sur ma platine cd , d une finition moyenne ,
pour cable pas trop epais,mais en sonorité c est vraiment excellent , dynamique generale ,basse tres tenue rapide,precise,medium ouvert ,propre ,douceur ,ça chante !!!! NCF je pense est le meilleur traitement pour les connecteurs
Christophe E.
Trés bon cable.
Essayé à la suite du 321b, celui-ci va plus loin sur tous les plans ! Il fait chanter mon Atoll DAC200.
Honnêtement je suis bluffé par la qualité de restitution de ce cable ! C'est un veritable up-grade de mon équipement.
Rapport qualité pour moi très bon. Je viens être convaincu par le bienfondé de l'apport qualitatif des cables d'alimentations.
Je pense que je vais équiper mes amplis avec .... à voir
Merci pour Audiophonics et son service super efficace !
Charles M.
IAN CANADA RECLOCKPI Double I2S / DSD Reclocker Low Noise / Low Jitter Ian Canada's ReClockPi is a high quality, low noise, low jitter dual reclocker module. It is designed to work with the FifoPi or any other digital audio device in synchronous...
Clearly makes a difference
Very nice improvement to the FifoPi MK3. Highly recommended.
fabrice v.
RQP imbattable
Bons câbles , neutres et transparents plus cristallin qu un câble bon marché et peut être même meilleur que certains beaucoup plus cher
Loic g.
Stereo Amplifier Class D TPA3251 2x140W 4 Ohm This affordable Class D amplifier is based on a TOPA3251D2 amplifier chip, ensuring a power of 2x140W under 4Ω and this with high efficiency. It will therefore have no...
Simple et efficace
Marche a la perfection, rapport prix / rendement au top.
Petit b mol pour le knob volume, manque de solidité a l'intégration mais rien de terrible.
Pd: Bornier HP de petite taille (2 mm) à tenir en compte pour l'achat de câble et/ou fiche banane.
Pierre-Yves C.
ALLO Acrylic Case for Raspberry Pi 4 + Allo DigiOne Signature Black This acrylic case designed by Allo is perfectly adapted to receive the Raspberry Pi 4 and Allo DigiOne Signature combo, while maintaining access to the different connectors of...
Would be better with all the screws...
Although people have the tendency to complain about the cheapness of this acrylic case, I think it looks quite nice for the price and has the advantage to let the Wi-Fi signal in and out nicely. Why 3 stars then? Glad you asked. Simply because none of the ALLO DIGIONE SIGNATURE parts (case or boards) comes with the small spacers you need to secure the pi board to the base of the case. I am not the only one to complain about it and yet, still happens. The other star is for cheaping out of providing assembly instructions for the signature version of the the Allo digione board although it is the one that drains the most money out of your wallet... Despite all of this, ALLO support was really effective and I managed to get my 4 little screws before I could even say "quidditch"! The quality of the equipment, I have no doubt that it is decent, but right now my amplifier is a modest Onkyo TX-NR646 and the combo with my B&W 703 S2 is absolutely terrible and I can't wait for my Atoll IN300 to be here...
Bottom line, good product, good support but bad logistics.
Jean-Baptiste M.
Remplace l'alimentation de l'AD18 V3
Indispensable si vous avez l'AD18 V3 avec l'alimentation 5ah, cette alimentation 6.75ah mène à merveille mes Magnat Monitor alors que l'alimentation d'origine était à la traine.
Extrêmement dommage que SMSL ait modifié cette dernière et qu'il faille rajouter 20€ pour un ensemble performant.
Jean-Baptiste M.
Parfait sauf l'alimentation
AD18 adossé à des enceintes Magnat Monitor Suprême 202, résultat très équilibré et polyvalent si et seulement si vous utilisez l'alimentation de l'AD18 V1 cad 6.75ah. L'alimentation livrée avec la V3 n'est pas à la hauteur et c'est bien dommage.
KONSTANTINOS L.
Good performance amp
Pleasant surprise the amplifier. It was difficult for me to decide to buy a class D because I always had class AB amplifiers. The vocals are a bit flat but I pass it with its good dynamics. The only problem is that the amplifier refuses to start from the remote control ! That's why 4 stars instead of 5.
Alain L.
Grande valeur musicale
Après plus d'une semaine de rodage et de tests avec mon gustard p26 modifié avec les aop sparkos,
je constate avec plaisir que le gain en plus est bien là.
Ces aop n'apportent pas de sonorité typée et sont aussi neutres que les LME, c'est excellent pour moi, ce préampli garde son côté "passif".
Sur le plan de la transparence, un voile se lève. Les voix ont un peu plus de grain, les reprises de souffle sont plus perceptibles.
il y a un plus en rapidité, en lisibilité des informations.
La bande passante s'élargit, légèrement dans l'aigu mais surtout dans le grave qui est mieux tenu sans masquer le médium, c'est propre.
D'un point de vue de la spatialisation, je n'ai pas constaté de différence en largeur de scène, par contre un grand plaisir est là de voir qu'il y a
plus de profondeur. Sur mes enregistrements de basses, le haut grave est mieux détouré dû à la notion d'espace.
Tout celà donne un diable de préampli qui peut se comparer à des modèles valant 2 foix son prix, celà donne envie d'investir dans des sources
plus hautes en gamme. Le revers de cette belle médaille reste que les mauvais enregistrements révéleront tous leurs défauts.
Enfin c'est un véritable plaisir pour moi de l'utiliser ainsi, ce préampli comme cœur de mon système me donnera du plaisir pendant très longtemps.
