jevgenijs S.
Simply great!
My speakers never sounded this good! A very clear and open sound without being fatigue! The tone controls are very effective!
Reinhardt S.
VIABLUE EPC-4 Silver Balanced Interconnect Cable Ø3.9mm
sehr gute Qualität,sehr empfehlenswert
Reinhardt S.
NEUTRIK NC4MX-B 4 Gold Plated
Customers reviews - There are 20865 reviews.
Constantin T.
Onest power cable
Very onest power cable, sound good at first ear, we will see after burn, for the price is excelente
Dennis H.
SMSL DO400 DAC ES9039MSPRO Headphone Amplifier XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 MQA-CD Black SMSL unveils the DO400, a powerful, high-quality DAC/headphone amplifier. It incorporates quality components such as the latest ESS...
SMSL DO400
This amp/dac sounds very clean with the ES9039SPRO chip and it is also a very powerfull headphone amp. 6W at 16 ohm and 3W at 32 ohm can drive every headphone. The newer XMOS XU-316 is very good , PCM support up to 32bit/768kHz, DSD support to DSD512. Do not forget to install the windows drivers and update the firmware before listening.
GEORGIOS C.
Excellent sounding amplifier with serious power and driving capabilities
Being a long-time audiophile and part-time audio reviewer I have owned or tested numerous power amplifiers of any kind and cost. I own the (unfortunately discontinued) Audiophonics AP300-S2503E that uses this particular power module, fed by a Mornsun LOF550-20B48 Power Supply Module. To cut the long story short, I prefer this one to my 3.500€ solid state, zero feedback, single ended, pure class A marvel PORFYRA AUDIO that I used to cherish. I also prefer it to my 2.676€ "gentle giant" Audiophonics HPA-DM750ET. Its sound is wide and full, smooth, fluid, very detailed, spacious and three dimensional, with beautiful textures and finesse but, at the same time, it is fast, dynamic and controlled that it never gets boring. You just can't find any real drawback. Have no doubts and don't be fooled by its moderate price, this is a serious power amp regardless of the price. And the best TI TPA3255 implementation that I have come across. Just partner it with the best power supply you can afford, like the aforementioned Mornsun LOF550-20B48 or the even more powerful SMPS800RS (both are sold by Audiophonics), to maximize its driving capability (it is stable at 2Ω loads, can give more than 400W peaks per channel if the power supply supports it). Also use serious hook-up wiring for the power and speaker connections, like the ELECAUDIO FC125TC or better. I also highly recommend the EIZZ EZ-303 speaker terminals (tellurium copper is by far the best sounding metal after solid silver).
Andrzej J.
TOPPING B200 Power Amplifier Mono Discrete 200W 4 Ohm Black The Topping B200 power amplifier is a mono amplifier based on a discrete-component NFCA amplifier circuit. This enables it to achieve a considerable power level while...
A great power amplifier at a very good price.
Distortion and noise are inaudible. A spacious soundstage, thanks to exceptional time and phase coherence across the entire frequency range. Very good dynamics and resolution. I recommend B200.
Andrzej J.
DAYTON AUDIO DATS LA Speaker Testing System The Dayton Audio DATS LA (Digital Audio Test System Loudspeaker Analyzer) revolutionises loudspeaker measurement with its accuracy and price. This compact, computer-controlled...
Fast and accurate measurement
Good user manual. Easy measurement process. Software controls the entire process. Measurement results are available in a file, allowing for further processing in other programs. The device itself is well-made. The only minor issue is the power cable with an American plug. But since it's a standard PC cable, you're sure to find one at home.
Pierre J.
Barrette multiprise de très bonne qualité et de superbe finition.
J'ai même démonté le boitier pour vérifier les branchements, rien à redire tout est correct.
Associé à un câble Secteur Hifi Jjmooer noir 1,5m blindé avec anneau de ferrite en remplacement du cordon livré qui me semblait un peu trop light.
En résulte une scène sonore un plus propre, plus nette avec un peu plus d'envergure.
Très franchement, je ne pense pas qu'il soit nécessaire de dépenser plus pour avoir un résultat déjà grandement satisfaisant.
EIZZ EZ-505 Banana Plugs 24K Gold Plated Copper Ø7mm (Pair) These high quality Eizz EZ-505 banana plugs are made of 24k gold plated copper contacts. They provide excellent conductivity and durability. The assembly is done simply by means...
Excellente
Ces bananes sont ce que l’ on attend de bon connecteurs, solide, bien pensé, mécaniquement irréprochable, transparentes et jolies.
Top !
VIBORG VF518R IEC C7 Connector Silver / Rhodium Plated Pure Copper Ø20mm The Viborg VF518R IEC C7 power supply connector is of high quality construction, ensuring extremely reliable transmission of the electrical signal. It features pure copper...
super produit rien à dire cuivre pur plaqué argent rhodium
sans regret prenez la même coté male hyper top 2025 merci
Eric C.
Pas un gadget
J'avais des adaptateurs de base achetés dans un magasin d'électronique pour brancher mes câbles RCA sur mon préampli Naim depuis une platine Project de bonne qualité. Cherchant une petite optimisation j'ai acheté ces adaptateurs. Bon, voilà un petit investissement qui vaut le coup. Des aigus plus affûtés, une scène sonore plus aérée, des basses plus tendues. Ces petits trucs valent vraiment le coup. Pour 32 euros sur mon système, le gain est très sensible. Donc ce n'est pas du tout un gadget. Comme si j'avais retiré deux bouchons pour laisser passer le son et faire la mise au point.
Bon appareil
Bon appareil mais dans mon cas il faut choisir la sortie avant de mettre en route le système sinon il y a une déflagration dans les enceintes.
Victor V.
FIIO WARMER R2R DAC R2R Tube Buffer E88CC 32bit 384kHz DSD256 Black The FiiO Warmer R2R is a DAC combining discrete R2R conversion, a JJ E88CC tube stage and a linear power supply, all housed in a retro-style chassis equipped with a mechanical...
GG FIIO
I'm not a fan of China but......the audio industry should get a wake-up call from this DAC.
at 380 eur? I don't think I've heard anything that beats it :))))
natural, open, dynamic, depth and classic tube voices/midrange, 2 bass bowls, 1/channel.
loses the competition a little on treble and separation, but, in my opinion, for this money, very hard to find a similar package in terms of sound and build quality.
congrats FIIO for the design (another proof that "old" technologies are "the sh*t") :)
p.s.: I had it in trial from a friend that decided to keep it. I compared it vs a NewOnTech DAC07SE so....yeah:)
Alain S.
SMSL D1 DAC ROHM BD34352EKV XMOS XU316 32bit 768kHz DSD512 The SMSL D1 is a budget DAC based on high-quality components. Digital-to-analog conversion is performed by a USB XMOS XU-316 interface combined with a Rhom BD34352EKV chip,...
Bon et pas Cher
Trois entrées , DSD sur USB mais pas de télécommande. Le son est doux et plutot precis, je le prefere à mon DAC actuel 3 fois plus cher mais de conception plus ancienne qui est plus neutre et peut parfois avoir quelques duretés sur certains enregistrements. Pour le prix si vous pouvez vous passer de télécommande c'est un bon choix.
Jean-Michel S.
surprenant!
Une petite boîte toute simple... branché à mon Micro Seiki BL91, bras SME3009 SE et un petit Denon DL110.
Directement relié à mon Ampli BGW 750G par un câble de 5m.
Première surprise: pas de souffle, pas de hum.. rien.
Premier disque: deuxième surprise. Je m'attendais pas à ça. Proche du CD. Sauf moins de grave et le haut un peux voilé. Un disque quoi.
Par contre, très dynamique. Avec mes enceintes Vulkan Mk3 ça martèle. La plage stereo... restreinte, du vinyl quoi...
Après deux semaine je gratte un 2134 du fond du tiroir et remplace le 5532.
Et ben, ça n'a pas raté ! Tout est revenus: les graves, les hauts et la plage stereo. Plus de voile. Sublime! Et pratiquement pas de différence aux CD mise à part les restrictions du vinyl.
Après 5 minutes je ne ressent plus la différence si c'est un disque ou un fichier...
Comme j'ai pus constater, il s'agit de deux 1612 en entré: un pour amplifier, un après le filtre RIAA et un 5532 en sortie. Je suppose un filtre passif.
Je conseille fortement.
Enrico B.
FIIO K11 R2R DAC Headphone Amplifier 24bit 384kHz DSD256 Black The FiiO K11 R2R, the R2R version of its cousin the K11, is a small, versatile and high-performance DAC headphone amplifier. It is based on a resistor network and audiophile...
Filo k11 r2r
Ho preso questo DAC incuriosito dalla tecnologia R2R e devo dire che sono piacevolmente sorpreso.inserito nella mia catena per ascolto in alta fedeltà, Arcam A15, Marantz cd60, B&W 607 S3, ho subito notato una buona apertura della scena musicale con una buona estensione sia verso l' alto che verso il basso. Rappresentazione organica e colorata della musica di qualsiasi genere, che favorisce l' ascolto ed il piacere musicale. Acquisto e spedizione veloci e precisi
Alain V.
Essayés sous le lecteur CD apportent de l'aération de la musicalité. Instruments plus lisibles. Pour ce prix vous ne risquez que du mieux!
M. M.
LHY AUDIO LPS25VA Linear Regulated Low Noise Power Supply 220V to 18V 1A 25VA This LHY Audio LPS25VA regulated linear power supply is ideal for any high-quality audiophile project. All the necessary technical refinements are incorporated in this power...
Wonderful sound and service
I was looking for a power supply for my Pro-Ject Phono Box. This 18V unit’s specs were perfect. It got delivered in the Netherlands in 4 days, which is really fast given the distance. Unpacking was fun, beautifully made. I let it sit for a few hours to acclimatize since it was quite cold from delivery. Connecting it was easy and then the sound! I bought it primarily to avoid the electrical scatter from the cheap switching power adapter, but the sound improvement was significant. Music played with more authority, it was cleaner, and therefore you could hear more details. Thanks for the great experience and service.
Jean-François G.
IFI HDMI ISILENCER HDMI Female to HDMI Male EMI Noise Suppressor iFi Audio's HDMI iSilencer is an HDMI filter designed to reduce noise and jitter in your signal and protect your equipment from surges that can be caused by electrostatic...
Très efficace.
J’utilise 2 HDMI Silencer chacun placé à chaque extrémité de mon câble HDMI qui relie mon streamer à mon DAC via une liaison I2S. Après en avoir acheté un, l’apport était tellement notable que j’en ai acheté un second et l’ensemble va encore plus loin. Plus de détails et surtout une spatialisation accrue. Un seul c’est déjà très satisfaisant, mais deux c’est encore mieux!
Alain R.
Joli bouton
Ce bouton en alu massif est parfaitement fini, légèrement satiné.
Il est très joli et s'adapte parfaitement sur les axes de 6mm avec un serrage par vis BTR cachée.
Alain R.
Module Amplificateur Mono TDA7293 1x100W / 4 Ohm This Mono Amplifier module is based on the use of a high power TDA7293 transistors developed by the Swiss firm ST MicroElectronics. It is capable of delivering a continuous...
Ampli efficace et vraiment bon marché
J'ai ajouté à cet ampli un dissipateur de 100x50x40 ref: 9260. je n'avais pas trop de place. Si vous voulez faire des écoutes à fort volume, il faudra mettre un peu plus grand, comme la réf 9261 de 100x75x40. Bien sur, il faut mettre un isolant entre la puce et le dissipateur.
Il est alimenté par un transfo de 2x24V 100VA que j'avais en stock.
Il est très compact puisque la carte contient le pont de diode et les capas de filtrage de l'alimentation.
Le rendu est déjà très correct, dynamique, équilibré.
Il y a un peu de souffle que j'ai pu totalement corriger en faisant deux tweaks:
- jai remplacé les deux condensateurs de 100nF qui sont en parallèle des deux zener de 15V, par deux condensateurs de 10µF chimique.
- j'ai remplacé l'ampli NE5532 par un support DIL8 et j'ai testé un OPA1612. Parfait
Plus aucun souffle.
Une dernière modification qui agit positivement sur les basses et un peu sur le bruit.
J'ai retiré les deux condensateurs de 1µF qui sont à l'entrée de l'ampli et j'ai mis un condensateur bipolaire Muse de 10µF.
J'ai maintenant un ampli très bon et pour un cout dérisoire.
Alain R.
Selector 4x3 Positions Stereo Round Axis This 4x3 position selector has a smooth 15mm long round shaft (thread included).
Sélecteur de qualité
Je fais passer le signal audio par ce sélecteur.
Il n'y a aucun bruit de commutation, pas de "schisssss" non plus.
Le crantage est doux comme je l'aime.
Parfait pour moi.
Alain R.
Embase esthétique et transparente.
J'aime bien le look de ces embases, d'autant plus, que pour un prix encore raisonnable, elles sont parfaitement transparentes pour la musique.
Alain R.
AUDIOPHONICS MS2W Speaker Cable OFC Copper 2x2.5mm² The Audiophonics MS2W is a flexible cable which offers good electrical properties. It is made of 125 x OFC copper strands. This material is ideal for a cable enjoying good...
Joli cable
Ce câble est de section bien suffisante pour passer les 150W de mon ampli.
Sa couleur blanche fait qu'il se confond bien dans mon mobilier, il reste très discret.
Et il remplit parfaitement sa fonction.
Henry K.
TOPPING D90 III DISCRETE Balanced Discrete DAC Bluetooth 5.1 32bit 768kHz DSD512 Silver The D90 III Discrete balanced DAC from Topping is the parallel to the D90III using a 100% discrete digital/analogue conversion module. Here, conversion is performed by a PSRM...
Best DAC i have found
I have tried the LAIV uDAC, a china TDA1543x16 and a holo cyan 2, but this one is the best sounding DAC. It is very airy, very fast and dynamic. It is on par with the holo cyan 2, but has more power on the lower end. And it was the only DAC which can drive a DarTZeel NHB-108 power amplifier without a pre amp.
Sylvain M.
TOPPING DX5 II DAC 2xES9039Q2M Headphone Amplifier X-Hybrid Bluetooth 32bit 768kHz DSD512 Silver With the DX5 II, Topping presents the direct heir to its famous DX5 DAC and headphone amplifier. This new version features a host of changes, improving on its predecessor in...
Etonnant !
Acheté comme ampli casque connecté à mon PC (et ravi du resultat), j'ai eu la super idée de le tester au salon.... Il est bien plusd détaillé que l'ampli de mon Denon AV et du Wiim Pro+. Je ne suis pas du tout un expert du domaine, mais je comprends désormais le terme "aéré" utilisé par certains pour décrire. Ici c'est le cas ! Ravi de mon achat, je réfléchis donc à en prendre un deuxième pour le salon :D
Jean-Michel P.
Adaptateur de qualité
Cet adaptateur me permet d'utiliser mon casque câblé en symétrique 4,4mm sur la sortie jack 6,5mm de mon ampli et directement (sans l'adaptateur) sur la sortie 4,4mm de mon DAP
Jean-Michel P.
Headphone Balanced Cable Jack 4.4mm to 2x Jack 3.5mm OCC Copper Silver Plated 1.5m This headphone cable features one balanced 4.4mm stereo jack connector and two balanced 3.5mm jack connectors. The cable uses two OCC copper conductors and two...
Câble de qualité pour bénéficier de l'entrée symétrique
Câble utilisé en remplacement du câble d'origine de mon Meze 105 AER, ce qui me permet de bénéficier des avantages de l'entrée symétrique de mon Fiio M21 - principalement plus de puissance, donc réglage du volume plus "bas".
Le tout avec un câble visuellement plus sympa :)
Daniel M.
SILKLINE VIMI I Integrated Amplifier Class AB 2SC5198 / 2A1941 2x50W 4 Ohm Black With its VIMI I, Silkline unveils a discrete integrated amplifier ideal for small to medium-sized rooms, being able to deliver 2x50W of power at 4Ω. This Class AB...
Bluffant!
Associé à des Davis Ariane 1 accrochées au mur, dans une pièce de 12 m2, une pure merveille!
Jan W.
SMSL AS400 Amplifier 2.1 Phono Preamplifier Bluetooth LDAC aptX HD MA5332MS 2x165W 4 Ohm Silver The SMSL AS400 is an extremely versatile integrated amplifier. It offers numerous advantages, such as a phono input, an HDMI ARC input, a preamplified output for active...
I have ordered this little gem out of curiosity, how it would perform next to my naim nait 5si.. well, to my surprise it outperformed the naim in EVERY aspect, exept its price (279, 1.999,- €). Soundstage, resolution, imaging, depth, punch, power and features is next level, frequency response is neutral but not analytical (perfect for my taste). Given the pricetag my old naim is beeing utterly destroyed by this alarmclock sized beast. My naim nait is ready for retirement, AS400 is the heart of my main system now.
Tip: for floorstanders use direct mode without EQ.
FURUTECH ASB-1 Antistatic Brush LP CD DVD BLU-RAY ASB-1 is an antistatic brush dedicated to audio & video media. It uses the Corebrid B technology based on a structure of conductive acrylic fibers. These fibers have a great...
Magic
Franck D.
Entière satisfaction !
Sur les conseils de Monsieur Aubert, j'ai commandé ce petit ampli, c'est une grande satisfaction le son est bon je me fais plaisir, le bluetooth est étonnamment bon et je ne perçois pas de différence avec la liaison directe par USB, j'écoute des fichiers FLAC non compressé en qualité CD minimum. Le son est neutre clair. Le bluetooth fonctionne très bien on a les boutons pour changer entre le bluetooth USB , l'optique, etc... La télécommande est un peu directive il faut être en face pour que ça fonctionne.
Pedro V.
Works as expected
Bought this selector to allow switching the DAC output between a headphone amp and an integrated amp.
The selector is well built and works as intended. Cannot notice any detrimental effect in the audio chain.
Very fast delivery by Audiophonics.
didier D.
Rapport qualité/ prix excellent
Montées sur un furutech alpha 22en remplacement de Ramm audio, la qualité est largement supérieure. La scène sonore est plus large et il y a plus de détails.
La qualité de fabrication est au rendez-vous et la mise en œuvre est simplisme.
Parfaites pour des petits câbles jusqu'à 9mm.
Didier
Francisco B.
Excelent service
Exactly as expected, which is exactly as anounced by Audiophonics.
Valuable supplier for audio and components.
Thank U!
Jérôme L.
WIIM ULTRA Streamer DAC ES9038Q2M Headphone Amplifier Bluetooth 5.3 WiFi 6E 32bit 384kHz The WiiM Ultra sets a new benchmark in the world of audio streamers, thanks to a design conceived to deliver an unrivalled audio experience. It lets you enjoy your music library...
Wiim ultra
Excellents conseils de M.Aubert. Ce wiim ultra fait merveille associé à un Nuprime Ida 8. Très bonne spatialisation sur des qacoustics concept 40. L'application roomfit est très utile également. Pour mémoire, dans mon cas il a été plus qualitatif de laisser le subwoofer branché sur l'ampli plutôt que sur le streamer.
Sylvain J.
Petit reclocker qui fait bien son job
Je voulais améliorer la qualité de mon transport cd Cambridge CXC. C’est chose faite.
Pierre S.
Passive Preamplifier converter RCA to XLR / XLR to RCA Silver This passive stereo 10kΩ volume controller allows you to switch from balanced XLR to unbalanced RCA inputs and vice versa, from unbalanced RCA to balanced XLR. The two...
Un parfait petit préamplificateur passif
Si nominalement bon et parfaitement silencieux que je viens d'en acquérir un troisième exemplaire, ceci à l'effet de pouvoir l'associer à une troisième configuration d'amplification, chacune opérant son dac et son amplification symétrique ou double mono.
Sylvain J.
OYAIDE NRF-005T Noise Suppressor Adhesive Tape Pulshut 4m Oyaide NRF-005T is a noise suppression tape using PULSHUT® (high performance non-woven textile) material developed by Asahi Kasei Corporation. This is a revolutionary...
Efficacité indéniable
Plus efficace que les ferrites de filtrage.
Jacques R.
Répond bien au besoin
meme seul apporte un réel plus sur l'ampli de puissance
investissement très raisonnable au vu du résultat
Jacques R.
facile à utiliser et résultat audio perceptible, plus de transparence* et de cohérence sur haut médium et aigu et grave dégraissé*
bon investissement avec le cordon d'alimentation de l'ampli de puissance
Attention dans les racks la connection nécessite au moins 20 cm de place en hauteur pour connecter les appareils sur le dynavox
produit bien fabriqué
VIBORG VB404AG Banana Plugs Pure Silver Ø7.5mm (Set x4) The Viborg VS404AG are a high quality banana plugs for the design of high end speaker cables. They use a 99.98% pure silver conductor, ensuring maximum conductivity.
Super qualité de fabrication
Transparent rapide
Que demander de plus ?
Lory N.
MINIDSP UMIK-2 Low Noise Omnidirectional Measuring Microphone USB XMOS ASIO 32bit 192kHz The UMIK-2 is the second generation MiniDSP omnidirectional low-noise measuring microphone. It takes advantage of everything that made the first version, the UMIK-1, so...
Fonctionne très bien
Le microphone fonctionne très bien avec le logiciel REW et le fichier de calibration téléchargeable, ça donne des mesures très précises même dans les graves et à moins cher que les bidules de Big Sonomètre qui coûtent plus de 1000 voir 2000€ où en plus il faut payer encore des centaines d'€ pour avoir l'analyse avec des octaves plus précises, ici c'est moins de 300€ et toute la précision qu'on puisse vouloir raisonnablement et +
Il faut faire attention cependant car il est recommendable de l'utiliser sur un pc portable alimenté par batterie, sur un fixe on manque de portabilité et il peux y avoir des interférences
arnaud L.
ampli de puissance juste arfait
Bonjour, j'ai acheté cet ampli pour une voie centrale en home cinéma. En comparaison de l'étage d'amplification de mon ampli HC YAMAHA RX A 4A je dois dire que le son est plus clair, plus large, plus détaillé et plus dynamique. Cet achat transforme mes séances ciné, ainsi que l'écoute de musique où en HIFI l'ampli est très neutre. Il n'ajoute rien, mais surtout il ne retire rien. Je suis désormais un grand fan de la classe D et plus particulièrement celle de AUDIOPHONICS. A ce titre, je viens d'acheter deux autres amplis de puissance stéréo de cette marque pour remplacer et compléter mon système. Les modules HYPEX N CORE sont juste déments en restitution sonore. La différence avec les modules PURIFI doit être réelle je n'en doute pas mais avec l'HYPEX N CORE nous atteignons déjà du très haut niveau. Je mute donc de l'amplification de classe A à la classe D
Dominique L.
EVERSOLO T8 Streamer Digital Transport WiFi 6 DLNA UPnP Roon Ready Bluetooth 32bit 768kHz DSD512 The Eversolo T8 network transport allows you to connect your HiFi system to a network so you can enjoy high-resolution digital sources. Specially designed to deliver a digital...
Eversolo T8
En remplacement d'un streamer Dac intégré préampli Gold note j'ai commandé l'Eversolo T8 désirant séparé la partie streamer de la partie DAC pour améliorer les performances de mon système.
Je possède un dac intégré dans mon ampli préampli intégré et je voulais dans un premier temps pouvoir l'exploiter et évoluer si nécessaire vers un Dac indépendant.
L'Eversolo possède une interface très intuitive et facile à mettre en oeuvre. Cela m'a pris 10 mn pour le mettre en service.
Je l'ai connecté en RJ45 puis en wifi cette dernière liaison me permet d'isoler le streamer électriquement de la box.
J'ai testé la liaison coaxiale et USB pour l'instant je n'ai pas encore pu déterminer laquelle était la meilleure.
L'Eversolo T8 permet d'entendre toutes les micro-informations présentent sur l'enregistrement. Cela est dû déjà à un silence de fonctionnement total. La dynamique permet de vivre l'enregistrement. L'étalement des plans sonores en largeur et en profondeur est parfait.
Pour l'instant j'ai utilisé le streamer seulement en streaming sur Qobuz. La lecture est parfaite sans aléa de lecture.
Je ne regrette aucunement mon achat Je peux qualifier ce streamer de très haut gamme. La technologie embarquée est de premier ordre avec une isolation de toute les interfaces qu'on ne retrouve que très peu sur d'autres appareils à ma connaissance.
Le RQP est excellent. Il n'y a pas de concurrence à ce prix.
Prochaine étape essayer le Dac Z10 pour savoir si il surpasse mon Dac intégré.
J'en profite pour remercier David Aubert qui répond toujours rapidement et sincèrement à mes questions
Dominique
Gavin F.
five stars possible but needs software update
Moode audio 10 is so much better than 8 but LCD and remote control not working. No update since 2022 this is too long. Come on Audiophonics please update the software.
Nikita M.
I can finally use my eyes instead of years when playing with my audio.
Nikita M.
Helps integrating multiple subs as one for my home cinema.
Marijan S.
IBASSO DC ELITE Portable DAC Headphone Amplifier BD34301EKV 32bit 768kHz DSD512 The Ibasso DC-Elite is the miniature version of the DX320 Max. In fact, the components and architecture of this portable DAC/headphone amplifier are inspired...
also quite ok
Compared to the IBasso DX 220, the sound is less detailed but more pleasant and analog. Sometimes you like one aspect, sometimes you dislike the other.
On a Samsung S10+, it sounds cleaner and more resolved than on the headphone output of the S10+.
The same applies to an old laptop compared to the headphone output.
With a pure silver USB cable between the laptop/S10+ and the dongle, it sounds even a bit better.
There is no headphone output on a Samsung S24 Ultra. My impression is, that it sounds slightly worse there than on the S10+.
Translated with DeepL.com (free version)
Marijan S.
IBASSO CB19 USB-C to USB-C / USB-A Silver Plated Copper Cable 10cm The DB19 from iBasso is a USB-C cable for a dongle (portable USB DAC or amplifier). It has a USB-A connector for power and a USB-C connector for data transfer. Its 10cm...
quite ok
The cable can be used to charge the dongle while listening to music. It would be even better if it could be used to charge the cell phone (the player) and thus extend the total playing time even further.
Silver-coated copper sounds quite acceptable. Pure silver at a higher price would be even better.
Jean-Pierre B.
POWERGRIP YG-2 Power Distributor Conditioner Filtered 6 schuko surcharge overload protection For its second version, the PowerGrip YG-2 retains the same performance as its predecessor but adopts a more compact and more economical format. Like its big brother the YG1-V2,...
Après plusieurs mois d'utilisation
Je complète mon avis après deux ou trois ans d'utilisation., J'ai maintenant deux Powergrip sur mon système principal, ce qui est parfait compte tenu de la multitude d'appareils à alimenter (TV, Lecteur BR, Pré-Pré vinyle, Platine TD, Pré-ampli stéréo, Pré-ampli AV, Caisson de basses, deux amplis de puissance entre autres).
Je vis dans un pays tropical ou l'alimentation en électricité est souvent perturbée. Ce système protège mes appareils en commutant lors des incidents les plus brutaux.
Le fonctionnement est sans problème après plusieurs mois, l'aspect reste très bon et le fait de pouvoir tout éteindre en appuyant sur deux boutons en façade est particulièrement pratique.
Tout cela pour dire : une étoile en plus.
István R.
DD TC07AC USB-A to USB-C cable Pure Silver / OFC Copper OTG 50cm This DD TC07AC USB cable is a high-quality USB-A to USB-C cable. Part of the Nyx version 2.0 series, it features silver shielding and double insulation in PE NUC and PVC for...
definitely better than AQ Carbon
I have never heard of this DD-hifi brand. I bought this USB A-C cable for testing purposes, to see if it would show something different, maybe better sound. I have not experienced any different or better sound between USB A-C cables between my media player and SSD drive till now. True, I have not tried a big high-end brands. In this case, this DD TC07AC cable sounds different at first listen, and in my opinion, with a better instrument representation than the AudioQuest Carbon A-C cable I have been using here so far. If burn-in also matters here, then maybe it will get better.
