Enrico N.
INCREDIBILE!
Amplificatore veramente potente e con un suono decisamente soilfisticato! Pilota anche i sassi! Se usato in mono è addirittura...
FRANCOIS D.
Félicitations !
FRANCOIS D.
Bravo AUDIOPHONICS
Bravo à vous pour la conception de ce produit de très belle qualité !
Customers reviews - There are 19139 reviews.
Harry H.
Switchlink cable for silent angel switch
Very good cable, I use it as a power supply cable between my silent angel bonn n8 ethernet switch and the 5v. linear power supply.
Way better than the standard cable
GILBERT C.
LPSU100
Bel objet bonne qualité mon intel nuc chante mieux avec cet alim juste cette led rouge trop brillante qui me gene mais ce n'est qu'un détail...
Huy T.
Excellent Amp for the price
Nice clean sound. It's transparent. More than enough power for a stereo system or for a receiver to boost secondary speakers. It never gets hot and only stays slightly warm.
The switch in the back turns the amp into standby mode and the button on the front turns it on. The light surrounding the button is white. It came with a EU power cord and no adapter for US buyers. It was packaged well and was delivered in 4 days to the US.
Tim C.
Excellent compact class D amp
Been using this for a number of weeks now. No issues - good build quality and a seemingly uncoloured amplification.
As usual with class D amps, I'd question the power ratings, but it is driving a pair of q acoustic 3020s well enough: 12 O'clock is about as high as you can comfortably go. Between 9 and 11 O'Clock offers up a comfortable volume level. Given this, it's probably similar to a Class AB amp rated at 50 to 60 watts. Powerful enough.
I have not noted ANY 'hiss' commented on by reviewers on other websites. Very clean amplification.
For the money, this is an absolute bargain and highly recommended.
jean noel B.
Qualité de fabrication et sonore.
Posées en remplacement d’ anciennes prises banane WBT, le gain musicale est très net.
Aigu plus détaillé, précis, plus clair, on gagne sur tout l’ensemble du spectre sonore, tout paraît plus défini . Ces prises sont d’une grande transparence et laissent semble-t-il passer l’intégralité du message sonore sans coloration ou altération.
Guy H.
Bon Matériel !
Matériel de bonne facture.
Qualités :
Bonne finition.
Bon poids par rapport aux prises connectées.
Bon espace disponible pour les différentes prises.
Interrupteurs en fasade efficaces et anti "Plop".
Défauts :
Je cherche pour l'instant et ne trouve pas...
Je recommande.
Guy H
Guy H.
Bon produit !
Ce cordon est de bonne facture.
La section du câble est bonne et il a une bonne souplesse.
Le rapport qualité prix est au rendez-vous.
Je recommande.
Guy H
Joao s.
Worst ever!
I forget this product is so bad that after I receive I m thinking not to buy from audiophonics anymore , because if the product is bad and have error , audiophonics must confirm before send.
Joao s.
The worst product ever!
This product is the worse thing I ever see, the machine work , is horrible , I receive 3 damaged, on the outside , and the only not damage , the conc work in the inside but the place that contact with , there’s no cnc, I don’t recommend this product ever .
Jean O.
OPA1612 Dual OPA DIP8 (Unit) The TI OPA1612 dual operational amplifier benefits from excellent technical characteristics, allowing very good electrical and audio performance. It ensures a very low noise...
Excellent ampli OP
Utilisés en remplacement des NE5532 dans le kit préamplificateur Velleman K 8084, ils donnent d'excellents résulttats : plus de transparence et moins de buit de fond. Très recommandé.
Jean-Marc H.
1877PHONO COVE-RA Cable RCA to 90° DIN High purity OFHC for turntable 1.2m This cable has been specially designed for analog applications and is intended to significantly improve the input signal of your board.
Utilisé pour remplacer le câble d'origine d'une Sanyo TP1000.
RAS, ça marche bien. Bonne qualité de cuivre et surtout excellente isolation du câble. Très important car les platines de cette époque son alimenté en direct par le câble secteur en 230v qui génère pas pas de fréquence parasite...et comme le câble de modulation n'est pas très loin.
Ce câble est la meilleurs option entre une platine vinyle et un ampli. Inutile de dépenser plus ça ne changera rien en de qualité
Par contre avant de commander, vérifier l'accès au bras de la platine. Sur la Sanyo TP1000 par exemple, le connecteur DIN coudé s'impose Un connecteur droit ne passe pas.
Jaap B.
HYPEX SMPS1200A400 Switching Power Supply Module 1200W 2x64V The SMPS1200 switched-mode power supply is a very high efficiency model capable of developing a nominal power of 1200 Watts in an extremely small footprint. It has been...
Great
Works very well. No pops or clicks through speakers. Manual is not easy for an amateur. But all info is there.
Jaap B.
Beautiful case
Easy to assemble. Very sturdy. Good looks.
Francis L.
Francis L.
Sheath Natural cotton for cable Ø 5 - 8mm Red 100% natural cotton cable insulation for cable insulation.
Belle couleur, parfait à l'usage.
Francis L.
RAS
Souple et facile à travailler mais fragile mécaniquement, du plus bel effet une fois gainé coton.
Francis L.
Mitigé
Belle qualité de fabrication mais gros problèmes de faux contacts avec le port femelle... la fiche male nage trop là où une fiche standard marchait parfaitement.
Francis L.
Excellent pour class D
Couplé à un SA300, à une paire de Klipsch RP et un caisson, la différence dans le spectre des basses fréquences est flagrante, reste trop cher pour une alim mais l'effet wahou est bien réel.
Denis B.
passer votre chemin
je tiens le weller wsd 80 depuis 40 ans a 12.90 euros je n ai pris le bas de gamme non plus et la couronne de masse s est désolidarisée du corps de la prise, j ai pris une panne très peu épaisse genre aiguille et je soude a la mundorf supreme. alors vous voulez mon avis achetez vous un câble tout fait.ce n est pas les premières que j achète non plus et les autres étaient excellentes.aujourd’hui hui ce n est pas du tout la même qualité!!!!!.
Michael A.
Top quality at a very fair price !
Michael A.
Simple, such as excellent solution for the separation of signal and power supply.
Very Clean process tool, increases the flexibility when using between an SMPS or battery operation.
The length is sufficient for many combinations, but should be a little longer for a personal.
Top product !
Luis f.
MONOLITH LIQUID SPARK DAC AK4493 XMOS 32Bit 192kHz DSD128 The Monolith Liquid Spark DAC is a compact digital/analog converter developed by Alex Cavalli. It offers excellent audio quality and is especially designed to work in...
Smooth
Smooth sound with good soundstage, not sounding digital and analytical like others dacs at this price.
Recomended :)
dominique w.
Tres bon produit - livraison parfaite
Sebastien L.
idéal et parfait pour vos enceintes
Pointes Soundcare idéales et redoutables. Sous des enceintes Cabasse, l'ensemble est top et le son précis. Et quel confort et sécurité de se dire que l'on abimera plus son parquet.
Et Audiophonics assure toujours autant avec un délai de livraison plus court qu'annoncé. Service de qualité et communication parfaite. Un grand merci à toute l'équipe !
dominique w.
Parfait bon produit
tim c.
NEOTECH NES-3004 MK2 Speaker Cable UP-OCC Copper Silver plated 8x1.3mm² Ø 13mm This Neotech speaker cable features an 8-core StarQuad architecture with central insulation to lower the capacitive effect. The 1.3mm² conductors are equipped with strands...
Neotech
Very detailed, open clear sounding cable, excellent service from Audiophonics.fr
Jean-Michel D.
Bonne fabrication; difficile à trouver et une bonne alternative de qualité à ces mauvais produits en plastique. Le prix est justifié.
Jean-Michel D.
Pratique et efficace
Module pratique, pas cher, basé sur un schéma simple. Les LM1875T doivent être isolés du refroidisseur car portés à la tension d'alimentation négative.
Puissance suffisante pour la majorité des usages.
Jean-Michel D.
Fabrication impeccable. Ce produit n'est PAS une copie à bas coût.
Toujours satisfait des produits Neutrik.
Michel R.
Power Cable Jack DC 5.5 / 2.5mm to GX16 OFC 4N Copper 1.5m This quality power cable has a 5.5/2.5mm DC jack connector and a GX16 connector (or aviation connector) 2 female poles. The conductors of this cable are made of 4N OFC Copper to...
tres bon produit
Cable d'excellente facture,tres bien construit
Michel R.
excellent produit!!
j'alimente ma livebox 4 et mon nas buffallo et le resultat se fait sentir sur la qualite de mon reseau en ecoutant qobuz sur mon dac,surprenant!!
Jean D.
Dongle Bluetooth 5.0 Audio Transmitter Receiver USB 2.0 Jack 3.5mm This Bluetooth USB dongle is ideal for providing a device with Bluetooth connectivity, allowing both remote reception and transmission of your audio files. The dongle is also...
Non fonctionnel avec certains périphériques
Pas un mauvais produit mais malheureusement ne fonctionne pas du tout avec des airpods. Par contre fonctionne avec une enceinte Bluetooth ue boom 2.
Bonne portée. Signal propre.
(Essais croisés sur pc et tv avec autres Bluetooth aux alentours éteint)
Patrick D.
Bon produit et RQP correct
Bon produit que j'utilise avec un DAC SMSL Sanscrit 10th acheté chez Audiophonics. Les effets sont audibles, plus de présence, de matière et de rapidité. Cette alimentation fait le Job et son prix est très correct en regard de la fabrication qui semble sérieuse. Seul regret, les prises usb de chaque côté. Ce type d'alimentation étant plutôt utilisée dans le cadre d'un ensemble hifi la prise avant n'est pas esthétique et serait mieux placée amha à l'arrière à cote de l'autre. Moins on voit de fils....
Sinon je constate encore une fois que l'expédition du produit n'a pas été effectuée dans les délais annoncés. Pas très grave mais un peu gênant à la longue.
Michel V.
Étonnant !
Acheté pour équiper mon bureau. A sa réception j’ai été agréablement surpris par son look et sa finition et par curiosité je l’ai connecté dans mon salon à mes Quad ESL 63. Résultat tout à fait impeccable et pas inférieur à celui de mon gros Yamaha habituellement connecté à ces enceintes . Un petit regret, l’absence de balance. Mais le rapport qualité prix est tout à fait exceptionnel.
loris c.
adaptateur
fait ce qu'il faut faire m'a permis de monter le bourson v6 vif dans un petit espace (sans lui je n'aurais pas pu le faire) juste faire attention quand il faut se pencher.pour le reste excellent
loris c.
parfait une très bonne qualité audio et le service de l'audiophonie excellent
Léo D.
DYNAVOX Banana Plugs Gold Plated Ø4.5mm (Set x4) These Dynavox banana plugs have been designed to provide an excellent connection to your speaker terminals. The expansion chuck at the rear of the plug allows the contact to be...
Erreur de conception
Technologie intéressante mais malheureusement une des quatre molettes de serrage ne fonctionne pas. La pointe contenue a l'intérieur ne vient pas écarter les pales de la fiche banane, qui ne tient donc pas dans le bornier. J'ai dû les écarter au couteau. De plus, l'intérieur de la pièce n'est pas couvert d'or, c'est le même matériau que le gris que l'on voit apparent. Niveau qualité j'ai préféré les Viborg VB 401 en cuivre.
Stephane S.
EIZZ XLR
le produit est de bonne qualité , l'avantage ,est la liaison vissée , donc pas de soudure . En prenant en compte le tarif , ce produit est bien positionné sur la grille
GERARD M.
Cable de liaison enceinte
Rien à voir avec les produits
à scoubidou que nous trouvons chez bricobuchmuch
Marjan v.
Big improvement
Well made.no Short on signals.
Marjan v.
Big improvement
The sparkos replaced the opa627 in tube preamp.
the natural sound with a lot of instrument sounds more open, the singer's breath differs from each other and the fingers on the guitar are heard as if they are playing in front of you.
a nice upgrade across the entire spectrum especially strong on the middle and high part.
worth your money.
Nicolas d.
Amplifier / Speaker Protection Module 220V 30A This protection module for amplifiers and loudspeakers includes 2 relays with a nominal voltage of 12V DC, a resistance of 155 Ohm, a power of 0.93W and a switching current of...
fait très bien le travail
Acheté pour résoudre un problème de ploc dans mes enceintes lors de l'extinction de mon ampli. Le colis contient des cosses pour le 220v et les vis de fixation. C'est agréable d'avoir tout de fourni avec. L'appareil en lui-même fait très bien ce pour quoi il a été conçu.
Régis C.
Excellent dac, à recommander
Je cherchais un ensemble dac plus ampli casque de qualité en remplacement d'un ampli tubes que je trouvais mou.
Alors j'ai vu les mesures que l'on dit excellentes pour ce dac et je l'ai donc acheter en aveugle en me disant que je le renverrai si l'association ne convenait pas à mes petites oreilles, car les chiffres c'est bien beau mais l'important c'est le rendu sonore.
Et bien effet whaou garanti dès la première écoute.
J'ai testé toutes les entrées sauf USB...
Très bon en coaxial, il est excellent en AES.
J'ai testé en mode preamp sortie XLR sur un rotel RC1570+RB1582MKIi
Et bien en sortie XLR sur un ampli casque SMSL SP200.
Dans les cas c'est magnifique, à faible volume c'est détaillé, limpide avec des blancs incroyables.
Ce qui m'a le plus marqué c'est l'impression de dynamisme accrue lais pas du tout fatiguant avec des aiguës justes et basses tendues.
Toutes les musiques sont belles , je passe des heures au casque à écouter du rock/pop/classique.
Les casques essayés: Audio technica M7Rb, Beyer DT990 pro 250, Focal Spirit classic, intras Blon BL-03.
Les sources: Qobuz HiRes, CD.
Pour finir l'entrée bluetooth est excellente aussi, pas de coupures, même si je quitte la pièce avec le téléphone.
Voilà mon ressenti sur ce dac, mon premier dac Topping, vraiment excellent.
Pour finir je remercie Audiophonics pour la qualité du service, première expérience aussi...validée !
Henri B.
Adaptateur Dj44B
Ai acheté cet adaptateur récemment . Après plusieurs essais et écoutes il remplit parfaitement don rôle et sa missi. Vraiment très pratique. Je le recommande vivement.
Roland L.
Elirol
Bon produit ,conforme à la description ,envoi rapide et bien suivi.
thomas d.
bon tube de preamp
première commande sérieux et pro
envoie rapide et emballage pro
le produit correspond à la demande !
thomas d.
bon tube de preamp
premier achat très bon site sérieux et pro
le produit fait le job !
Alex B.
POWERGRIP YG-2 Power Distributor Conditioner Filtered 6 schuko surcharge overload protection For its second version, the PowerGrip YG-2 retains the same performance as its predecessor but adopts a more compact and more economical format. Like its big brother the YG1-V2,...
Bon investissement
Effet très net sur la clarté générale,les aigus et l’ouverture de la scène sonore et tout cela avec les câbles secteur « basiques ».Je ne regrette pas mon achat.
Jean-Yves F.
Transfigure mon DAC Fostex HPA8C
Complément de mes commentaires laissés sur l'AOP Burson Supreme sound orange.
Je souhaité remplacer les AOP des étages de sortie de mon DAC par des Burson mais la place manquait en hauteur pour les loger. J'ai alors exploré les autres solutions et je suis ravi d'avoir essayé ces Sparkos selon les conseils d'Audiophonics . Ils m'apparaissent extrêmement performants et dopent mon DAC désormais capable driver tout type de charge. Le son n'est plus seulement bon en sortie casque mais aussi sur mon ampli.
Attention, ces AOP sont plus longs et plus larges que les AOP d'origine. Il faut leur faire de la place. Je n'ai pas voulu utiliser de prolongateur, ceci a nécessité de souder les petits condensateurs aux dos de la carte et d'éloigner les gros condensateurs de quelques mm . Je pensais mon DAC de 2014 dépassé, avec ces deux transformations il sonne aussi bien que les DAC actuels du commerce à plus de 2000€.
Jean-Yves F.
J'ai remplacé les AOP de conversion d'origine de mon DAC par ces AOP Burson.
J'avais choisi de garder des connexions les plus courtes possibles, en plaçant les Burson en lieu et place des AOP d'origine. Cceci a nécessité pour un AOP de déplacer un condensateur de 3 mm. Je n'ai pas essayé les prolongateurs. La définition et justesse sonore ont énormément progressé. Au départ j'imaginais mon DAC de 2014 dépassé mais suite à cette évolution et au remplacement des AOP de l'étage de sortie par des AOP Sparkos je ne vois plus la différence avec les DAC modernes autour de 2000 €. Je recommande !
