Pascal H.
Marc C.
Customers reviews - There are 19409 reviews.
Richard B.
JANTZEN AUDIO SILVER Z-CAP Capacitor 1200V 0.1µF Jantzen Audio Silver Z-Cap capacitors maintain perfect sound neutrality and a very nice tonal balance. They are particularly suitable for use with a tweeter or midrange in...
Utilisés en remplacement de condensateurs de couplage (Vima) dans ampli single-ended de 845 ils apportent une réelle amélioration. Belle présentation, plus de profondeur, scène sonore élargie. A recommander
Luis V.
Preamplifier Board Volume Attenuator with Tone Control 2x NE5532 This module combines the functions of both preamplifier and volume attenuator with tone control. The latter function allows independent control of the treble, midrange and bass...
Disapointed with sound Imaging
i hooked up this very well built preamp and i was not happy with the sound quality, i felt it was clearly a downgrade in terms of preamplfification and sound imaging. Not suited for my system anyway.
Oleg K.
Oleg
Nice, accurate measurement microphone. One of the best for its price / quality. Easy to install. You can get the callibration file:
www.minidsp.com/products/acoustic-measurement/umik-1
jean-Luc R.
C'est bien, mais pour piloter un hp de 40 cm il lui faut une source conséquente !!
ce que je n'ai pas en sortie de mon equalizeur berhinger
Teddy T.
Pour un cable de 5M il transmet parfaitement le signal vraiment rien a dire !
De plus le cable est très bien fait et la livraison à été rapide et soigner.
Roger F.
Switchcraft 3502AAU Connecteur RCA
Un must
Roger F.
ELECAUDIO BA-30G Fiche Banane
Bon produit, accepte des gros cable, contact fiable
Peter H.
Be careful, dangerous
Protection Earth is only on the Backplate...perhaps. You can measure it on your own. Only a drilled cable behind the cinchconnection. That is not the European standard. I have changed this. I drilled a hole, set a screw and a cable lug under the board, right under the power connector. Had to filing a little bit into the board...
I know...no more warranty...ok..but safe. EMV-Safe ? dont know...
The Sound is great...
Petit bijoux de technologie
Cet appareil est incroyable de possibilités, convertisseur analogique, ampli casque, pré-ampli, DSP, avec des filtres pouvant adapter les écoutes à vos préférences. L'épaisseur de la notice en dit long sur la foultitude de possibilités, de paramétrages, et autres. Même la petite télécommande est sympa, et programmable pour des fonctions au choix. Je pense que les limites de cet appareil vont bien au delà de celles de la majorité de ses futurs aficionados. Des points faibles, je n'en ai vu que quelques unes, il manque une entrée I2S, il chauffe pas mal, et du fait de son très faible poids, l'appui sur n'importe quelle de ses touches, déplacent l'appareil.
Rien de bien important, ses qualités surpassent de loin ces petits détails.
A ce tarif, il n'existe aucune concurrence.
Bravo et Merci RME !
Benjamin H.
Absolute beast!
Awesome headamp that drives my AKG K701 without any issues whatsoever. Solidly built. Can only recommend :-)
Peter M.
MPA-S250NC
This is a great amplifier, the case is solid and professional and the sound is excellent. I was disappointed that Audiophonics sent me a European power cable that is not compatible in North America even though I noted on my order that I am in Canada and require North American power compatibility. I was lucky I had an old computer power cable that seems to work alright. Also Canadians be aware that the courier will require HST on delivery and factor that in to your budget. Overall I am very happy too bad the cable was wrong that costs 1 star!
Kévin R.
Lever de rideau
Je confirme les avis précédents, mis en place sur un amplificateur S.M.S.L A8 relié à deux JVC SX-911, c'est surtout au niveau des tweeters (SEAS 27TAC/GB) que c'est flagrant, ça ajoute des détails et une profondeur que je n'ai jamais entendu jusqu'à présent, c'est hyper agréable. Les basses sont également beaucoup plus profondes et les médiums bien détaillés. Très bon câble robuste à la fabrication sérieuse.
Ca change de la souplesse du câble d'origine en 3x 0.75. LOL.
Edouard C.
Formidable ampli
Construction de très bonne qualité dans un emballage parfait.
L'ampli est branché derrière un préampli Yamaha pour alimenter des Cabasse Egea 500.
Une dimension supplémentaire est atteinte dans la tenue des graves et la dynamique.
Pas encore eu le temps d'attendre un rodage suffisant ni de faire tous les tests nécessaires, mais le reste du spectre me parait très bien traité. Les bons enregistrements sont encore plus formidables et je profite chaque jour de ce bel ampli.
Olivier d.
Beau son
Simple a mettre en oeuvre et a manipulé.
Sur deux vielles dm 12 il marche mieux que mon Cambridge.
Happy
Vincent P.
1877PHONO THE ATLANTIC 5N OFC Copper Power Cable Shielded 3x2.08mm² 1.5m The cable The Atlantic from 1877Phono Zavfino benefits from a beautiful design with three 2.08mm² OFC copper conductors. This model shares the design methods of audiophile...
Super câble
Très beau câble, très solide. Aucune difficulté pour le brancher sur l'alimentation linéaire auquel il est rattaché et dans la barrette secteur.
Le câble est très bien fini, et plutôt esthétique.
Attention au rayon de courbure, il est très épais !
Vincent P.
Beau câble
Encore une fois, Audiophonics propose un beau câble. La construction est sérieuse, les fiches bien fixées et pas de jeu dans leurs branchements. Et en plus je le trouve esthétique (ça c'est purement personnel).
Est-ce que j'ai gagné en qualité par rapport à mon précédent câble, aucune idée, mais quoiqu'il en soit, la construction très sérieuse ne me fait pas regretter mon achat.
Vincent P.
Barrette secteur
Belle barrette, les impressions de solidité et de construction sérieuse sont là dès la prise en main. Les fiches s'enfoncent sans forcer et tiennent bien en place. 4 étoiles car la prise ne dispose pas de patins faisant en sorte de ne pas glisser (problème résolu en installant des pieds en polyuréthane 3M BUMPON que l'on trouve sur ce site :))
Vincent P.
Pieds qui font bien le taf. J'en ai installé sous le Rasptouch, sous son alimentation linéaire, sous la barrette secteur ; rien ne bouge. Facile à coller, et le pied adhère bien à l'élément auquel il est collé ainsi que sur le sol ou meuble où il repose. Bref, très efficace, et relativement discret.
Mick P.
Trop large pour les plaques vendues ici !
Le produit est super simple.
Premier défaut, aucune instruction de montage. J'ai fini par comprendre comment ça devait se faire, mais quand on ne l'a jamais fait, c'est loin d'être évident.
Second défaut, j'avais pris en même temps ici une plaque 8 emplacements, me disant naivement que puisque c'était vendu sur le même site, ça devait marcher ensemble. Que nenni mon brave ! Ce keystone est trop large pour en mettre deux côte à côte dans la plaque !
Bien évidemment, je m'en suis aperçu une fois tous les embouts montés. Qui c'est qui va devoir en commander d'autres ailleurs, recouper ses câbles et tout recommencer ? C'est bibi !
Guillaume L.
Après quelques recherches sur internet, je suis tombé sur ce DAC de conception récente. Notamment, le site suivant et les comparaisons proposées m'ont bien aidé :
https://www.audiosciencereview.com/forum/index.php?threads/topping-e30-dac-review.12119/
Je cherchais un remplacer un autre appareil de même type acheté il y a 4 ans. Et bien le E30 est un très bon choix. Je l'utilise comme source pour mon amplificateur Hifi. Il est raccordé en sortie (avec le branchement USB) d'un raspberry pi qui joue le rôle de lecteur réseau . Il est aussi raccordé en sortie de mon lecteur CD (branchement optique). Le E30 reçoit son courant d'une alimentation linéaire régulée de chez Audiophonics.
Le son de ce DAC est bien détaillé (bien plus que mon matériel précédent). L'image sonore est précise, la localisation des instruments ressort bien. Le son sait être enveloppant. Les basses sont propres. J'ai plaisir à l'écouter.
Anthony S.
DC plugs
Nice quality, efficient service and all round would deal with Audiophonics any time
Massimo G.
Great
Update asus sonar essence stx II with Burson v5i. Apart from a slight hiss with the volume at minimum which Burson claims is normal the sound with my Shure se 846 and Sennheiser hd 660 s is much improved. The distinction between bass is clearer, medium and high, even the soundstage is wider. A well ventilated case is suggested because the Bursons heat + the Muses. Recommended product, good service from Audiophonics
Martin D.
Excellent Housing
Very nice housing of good quality and reasonably priced
John M.
Fantastic
Really nice size. Excellent sound quality, used with Q Accoustics 2010 speakers. They drive those speakers no problem. No hum or noise.
Didier s.
mini inter
Trés bien et remplis sa fonction.
Didier s.
connecteur de pile 9 volts
Parfait et super tarif
Didier s.
Voltage Display Voltmeter with Blue LED 60-500VAC Ø22mm This voltmeter will allow you to monitor the voltage of a device. Its blue LED display is easy to read. The voltmeter accepts voltages from 60VAC to 500VAC. Its...
Parfait malgré un tarif plus que résonnable
Fil de câblage 0,5mm2
Retour d'expérience,
Ce câble de bonne qualité se travaille bien, de plus l'isolant résiste à la chaleur du fer à souder
Produit recommandé
Produit recommandé
Fil de Câblage Cuivre FEP 0.5mm² (Blanc)
Produit recommandé
W H W.
High quality power sockets
The title says it all; very good quality for the price.
W H W.
Alu Case for power sockets
Very solid and high quality aluminium case, consisting several panels which have to be mounted together (you need some patience to get the job done). Very good product.
Christian P.
Genial!
Ce petit module est tout simplement fantastique fonctionne a merveille, super simple a installer. Ce que je trouve super c'est que l'on peux faire quelque chose de très simple ou si on a la courage et un peu de savoir faire des choses plus complètes.
Seul petit défaut que j'ai trouvé c'est au niveau de l’application, il n'y a pas la possibilité de l'afficher au format paysage (tablette).
CLAUDIO R.
ELECAUDIO ADIACIUM GW Extensible PET braided sleeve Nylon 4-11mm Braided sleeve made in  PET (Polyethylene Terephthalate)  mono-strands which can be used in a wide variety of applications. Thanks to its expansibility, the unique...
Óptima funda con acabado elegante.
El material es excelente y da una buena sensación al tacto. Rápida de utilizar gracias a una buena expansibilidad. Utilizada para realizar dos cables de interconexión: acabándola con funda termo retractable el resultado es profesional. Muy satisfecho.
CLAUDIO R.
Óptimo producto.
Práctica selección de varios diámetros para distintos cables. Sella perfectamente y adhiere a todo tipo de superficie: fundas de PET, cordones de algodón, terminaciones audio, etc.
Fácil de trabajar, aunque sin una pistola de calor profesional.
CLAUDIO R.
Óptimo producto.
Utilizado para realizar un cable-filtro para mi REGA Apollo-R, con otros materiales en venta aquí, ha sido muy fácil de soldar y alojar en una caja metálica..
No es el primer filtro de la marca que compro: prácticamente cada regleta o aparato de mi sistema se beneficia de ellos.
Muy satisfecho!
CLAUDIO R.
Óptimo producto.
Robusto, bien hecho y con un cierre perfecto entre caja de montaje y cable. Relación calidad/precio excelente.
CLAUDIO R.
Óptimo producto.
He utilizado estas cajas en distintos cables-filtro, con otros materiales de Elecaudio y SCHAFFNER, y han sido muy simples de trabajar. Las piezas separadas permiten un montaje “fijo” hasta bajo tableros o baldas y los tornillo permiten varios ciclos de apertura y cierre sin perder su funcionalidad. Relación precio/rendimiento/estética excelente. Muy satisfecho!
CLAUDIO R.
Óptimo producto.
CLAUDIO R.
Buen conector a un precio honesto.
Fácil de soldar (con toques rápidos) y con un buen acabado.
Muy recomendable para cables de interconexión que necesiten el jack de 3,5mm.
CLAUDIO R.
Óptimo producto.
Utilizada en varios diámetros y distintos cables. Sella perfectamente y adhiere a todo tipo de superficie: fundas de PET, cordones de algodón, terminaciones audio, etc.
CLAUDIO R.
Copper / Silver Wiring Cable 4mm² PTFE Sleeve Ø3.6mm Transparent This 3.6mm diameter cable has a single 4mm² conductor made of Silver plated OFC Copper. This provides excellent signal conductivity while providing the conductor with high...
Óptimo producto.
Utilizado para realizar un cable-filtro para mi REGA Apollo-R, con otros materiales de Elecaudio y filtro SCHAFFNER, ha sido muy fácil de soldar. El cable de alimentación, luego recubiertos por fundas de PET, se queda flexibles y permite una cómoda instalación. Muy satisfecho!
CLAUDIO R.
CLAUDIO R.
Óptimo producto.
Utilizada para realizar un cable-filtro con otros materiales de la misma marca y filtro SCHAFFNER, ha sido muy fácil de trabajar. Acepta diámetros de cable “importantes” y luce un aspecto de alta gama. Muy satisfecho!
CLAUDIO R.
Óptimo producto.
Utilizada para realizar algunos cables-filtro con otros materiales de la misma marca y filtros SCHAFFNER, ha sido muy fácil de trabajar. Los cables de alimentación, luego recubiertos por fundas de PET, se quedan flexibles y permiten una cómoda instalación detrás de los aparatos. Muy satisfecho!
CLAUDIO R.
Buena funda con un color alegre.
El material es excelente y da una buena sensación al tacto. Rápida de utilizar gracias a una buena expansibilidad. Con cable grandes, al limite de sus posibilidades, puede tender a deshacerse: un golpe de mechero en las puntas, antes de empezar la inserción y se soluciona el problema. Utilizada para realizar algunos cables-filtro: acabándola con funda termo retractable el resultado es profesional.
CLAUDIO R.
Excelente
Óptimo producto; hice un cable de alimentación nuevo para mi PSU MkII King Rex y el correspondiente amplificador T-Amp. Materiales de calidad y se puede soldar con facilidad.
CLAUDIO R.
Excelente.
Buen producto; hice un cable de alimentación corto para mi Elfidelity AXF-101 (Filtre alimentation USB Externe pour PC). Se puede soldar con facilidad.
Michel l.
une merveille
je remercie tous les collaborateurs de audiophonics de m avoir sollicite a prendre ce produit car j'avoue je n'en espérais pas tant car il est étonnamment surprenant après avoir patienté trois mois
c'est excellent ampli et branché sur un préamplificateur fx audio 3e de chez audiophonics platine cd Yamaha c700 rca cable cardas et wireworld equinox 7 j'ecoute principalement des hqcd le son et parfait l'impression d’être face au chanteur merci à toute l'équipe
claude N.
Voulant remplacer ma barrette Actinote Mezzo qui se couchait
suite au poids des câbles secteur..me suis acheté la Viborg VE80.
Incroyable déjà à l'arrivée emballage énorme et poids.Je ne pensais pas qu'elle était si imposante.
écoute phénoménale..tout s'améliore..Même après 2 semaines d'écoute..C'es magique..Pour un prix abordable ..n'hésitez pas!
Merci Audiophonics
Système THDG:Ampli Hybride Rogue Audio Pharaos
Enceintes Audiophysics Cardeas..Câble HP Tata-Labs Air 1....
