Peter B.
Recomendded!
Edwin P.
Zywno H.
Perfect!
Fast delivery, wonderful DAP.
I strongly recommend!
Customers reviews - There are 19156 reviews.
Helmut F.
Excellent VALUE (SOUND) for the money (Topping E70V)
I bought this DAC in Dezember 2024 at AUDIOPHONIC.
PROS:
Excellent packaging and fast delivery.
Unboxing:
Due to low outside temperature, I waited for the unboxing 24 h after delivery (problem is condensation of cold equipment in warm rooms: ) Then everthing was all right as reported in the packing list.
Installation:
I use a DAPHILE SW with(old WIN7 labtop PC with I7 processor and 12 GB RAM and new installed SD-harddisc since 2021.
I use the DAPHILE upsampling process 44/16 to 192/24 with internal volume control. So i am able to control the SW via a LENOVO tablet (2 applications have to run at the same time on the tablet (DAPHILE in Browser to select playlist and PLAY-FROM-RAM-Mode and SQUEEZER for volume control.
Easy Plug-and-Play with DAPHILE. No driver needed.
I use chinch output of the DAC , which have to be selected with remote control (RC).
The delivered USB-cable is a little bit stiff, but sounds better then old USB-cable of Pro-Ject DAC DS even in 192/24 mode. I was suprised.
Filter options (PCM-mode) after testing i fixed F-4 as best.
SOUND impressions: (after one week of intensive checks)
I'm using electrostatic loudspeakers ES300 and DIY dipol bass in my special symmetic layouted listening room:
- strong low bass - very controlled much better then before
- upper bass - more controlled
- mids - charming voices, focused in the center.
- soundstage - very deep and wide impression,
- hights - awesome bells and pecussions, very airy.
Never heared DOORS-Raiders on the Storm with such emotions.
Others:
Bluetooth is working with my smartphone, but not important for me.
Both Digital Inputs have'nt been tested - no use.
CONTS:
No battery for the remote control supplied. (2x AAA)
Conclusion:
May be there is a better DAC available, but for me the measured specifications and the sound are excellent.
Before I read a lot of reviews in the internet.
Now I have choosen the best choice with the TOPPING DAC E70Velvet.
I recommend this DAC for AUDIOPHILES,
Jérémie P.
Source selector Audio / Video RCA 4 to 1 reversible This switch is an inexpensive solution for connecting up to 4 audio / video devices to a television set, projector or sound system. A digital marking corresponding to the RCA...
Simple et efficace
Simple à brancher, fait des clics satisfaisant lorsqu'on bascule d'une source à une autre. Rien à redire, c'est exactement ce que je voulais.
Jérémie P.
fonctionne comme prévu
Utilisé pour relier ma box internet/télé sur un ampli. Déballé, branché, ça fonctionne, on l'oublie, c'est ça les bons outils :-)
Ron L.
Amazing !!
After reading reviews and hearing experiences from friends, I switched to this amplifier.
After connecting I was pleasantly surprised.Amazing!! Lots of power, dynamics and soundsstage. My Audiovector QR7 SE came to life. No more classe A or A/B for me!
Thomas V.
OYAIDE P-029E Schuko Type E/F Power Connector Ø17mm This Oyaide P-029e male Schuko power connector offers a beautiful design quality and accepts large diameter cables, allowing for the design of high end finished power cables....
underrated !
Aucun avis sur cette prise! Sans doute la mal aimée de la gamme parce que la moins chère, mais elle est vraiment excellente.
C'est une "petite" 004. Elle a le même profil de neutralité et de transparence que sa grande soeur à 360 euros, simplement un cran en dessous sur l'extension en haut et en bas et les nuances de timbres.
A certains endroits vous avez besoin de neutralité, sur un câble barrette par exemple pour que les autres câbles puissent s'exprimer. Chez moi les 029 ont fait mieux que la 046 pourtant excellente sur le câble barrette. Les 046 essayaient d'imposer leur caractère et me masquaient, bouchaient complètement l'apport des deux câbles en 004 que j'avais sur l'ampli et le dac. Ca s'est remis à respirer quand je suis repassé sur la petite 029.
Tous les gens qui se font des "câbles magiques" avec des bonnes IEC 004 et des mauvaises schuko pas chères devraient essayer la 029.
La 004 est meilleure forcément, mais elle pardonne moins. Si votre système n'est pas parfaitement au point, elle en révélera aussi les faiblesses. La 029, un peu plus terne en comparaison, sera plus facile à associer.
Thomas V.
La barrette montée est vendue au prix des différents composants également dispo sur le site, sans supplément pour le montage donc. Bravo Audiophonics !
En gros, Audiophonics nous offre la barrette que Furutech aurait du nous proposer à prix raisonnable.
Je regrette quand même la section assez fine du câble. Ce serait possible de mettre du câble plus qualitatif sans faire exploser le budget, comme c'était le cas d'ailleurs sur une ancienne version de cette barrette qui n'est plus dispo.
Avec les embases schucko furutech or, on a un son plaisant, chaleureux avec des basses costaud, mais le tout est assez rond, pas ce qu'il y a de plus transparent et dynamique. J'ai finalement préféré la barrette whynot à 800/900 euros, plus neutre (mais là on perd en RQP). Sur pas mal de systèmes, je suis persuadé qu'on pourra préférer le modèle audiophonics.
Vu les prix pratiqués sur ce genre d'accessoire, y compris par les spécialistes Oyaide et Furutech, Audiophonics pourrait proposer une barrette vraiment haut de gamme pour moins de 1000 euros. En mettant deux ou trois embases oyaide swx par exemple. Une furu rhodium pour varier les plaisirs. Et le reste en furutech or qui font le job pour les appareils qui n'y sont pas trop sensibles.
Le très joli boitier audiophonics à 119 euros se retrouve sur des modèles complètement délirants à 5000 euros (Audiophonics devrait réclamer une commission! :) )
Thomas V.
FX-AUDIO TUBE-05 Preamplifier with ECC82 Tube / Headphone amplifier The Tube-05 is a compact device from FX-AUDIO. This desktop headphone amplifier/preamplifier is based on the use of an ECC82 tube. It features an innovative appearance and form...
plutôt décevant
Pour le prix c'est sans doute bien. Mais je l'ai utilisé avec une bonne alimentation 12 volts et un bon dac et j'en attendais plus.
Avec un sennheiser hd650 c'était assez mou, pas assez de grave et d'impact.
J'ai upgradé le tube (gold lion genalex) pour voir. C'était un peu mieux, mais toujours pas ça.
Thomas V.
Très bonnes bananes
Je préfère le câble nu directement dans le bornier. Je ne pensais pas réessayer des bananes, après des expériences peu concluantes avec des modèles autour de 30 euros qui faisaient bouchon.
Mais je me retrouve avec des enceintes avec bornier trop petit pour mon câble hp. J'ai donc investi dans ces wbt hors de prix et oui ça fait bien la différence. Mieux sur les timbres, l'ampleur, l'impact du grave. C'est nettement mieux.... que des mauvaises bananes, pas forcément mieux que le câble nu.
Ca reste extrêmement cher pour un petit adaptateur, à vous de voir si vous en avez vraiment besoin.
Très simple d'utilisation, système bien foutu. Par contre je comprends pas l'utilité du 2e pin en plastique, pour stabiliser par rapport au bornier?
Dans mon cas c'était gênant et j'ai dû le tordre pour pouvoir insérer la fiche.
Romain B.
ARYLIC S50 PRO+ Network audio player DAC ES9023 ADC WiFi AirPlay Bluetooth 5.0 aptX HD Arylic proposes with its S50 Pro+ a connected stereo preamplifier, having the particularity to take advantage of a complete connectivity with WiFi and Bluetooth 5.0 reception....
J'ai été déçu par la qualité du produit.
J'avais un souffle présent dans mes enceintes.
Je déconseille si vous avez un ampli sans réglage du gain.
Peter S.
Superb cable
never thought a cable can make such a difference in particular at this price range, the sound has become more smooth an open as if there is less resistance. I would recommend this product, thank you
Maurizio G.
AUDIOPHONICS Trigger Cable Male USB-A to Mono Male Jack 3.5mm 1m Extremely practical, this USB-A to Jack 3.5mm mono trigger cable, assembled in France in our workshops, lets you control the automatic switching of your devices using the 5V...
works well
Works well with LG OLED TV B6 sending the trigger to TDAI-1120 amplifier, the 5V from the TV's USB port is sufficient and reliable to trigger waking up the amplifier
ERIC V.
DAYTON AUDIO DCS165-4 6-1/2" Classic Speaker Driver Subwoofer Kevlar 100W 4 Ohm 87dB 36Hz - 1100Hz Ø16.5cm This 16.5cm subwoofer speaker has a 36hz cutoff frequency. It allows the design of small subwoofers of quality and affordable. A simple amplifier in class D of 100W RMS RMS or 4...
En remplacement d’ un ancien HP de marque POWER concept
(qui fonctionne encore)
Un peu moins souple, mais très bonne réponse en puissance
(à réexaminer après rodage).
Ce HP Dayton semble à son maximum vers 100Hz dans ma configuration.
Goran R.
Good!
I was buy three of them and must say that this cable is top quality and is hard to find better power cables for the price.
Cable comes in nice corduroy bag wich tells us that is made with care.
It is on "the fat" side so take care of the place behind your equipment.
Didn't notice any sound difference, but at least i know that my equipment is well protected and i can sleep peacefully.
As always, great customer service at Audiophonics and fast shipping.
Will definetly buy again
Goran R.
Simply great cable
Ordered this cable for peace of mind for quality of my streaming data. Connected between my router and my switch. Cable was great manufactured and is pretty fat, wich is good. Better than most cables cost few times more.
Cannot say nothing about sound quality, but i am pretty sure it will be hundred times better than cheap stock cable wich come with router.
Great service staff at Audiophonics and fast shipping.
Will definetly buy again.
Slobodan P.
MULLARD KT88 Tetrode Tube (Unit) The Mullard KT88 is a top-quality tetrode tube. It's an exact copy of the tube made by Marconi-Osram for Marshall in the late '60s and '70s. This tube will give you a powerful,...
SDP
Perfect tube for Sonic Frontiers SFS-40. Excellent service. Thanx
Jürgen L.
XANGSANE XS-R13 RCA Connectors 24k Gold Plated Ø7mm (Set x4) These XS-R13 RCA connectors from Xangsane are high quality connectors. The contacts are made of copper alloy and are 24k gold-plated, for enhanced conductivity and optimum...
My Favorite!
RCA plug with a great price-quality ratio. Stable, easy to solder and well thought out. Best soldered plugged in. My recommendation and my favorite!
Josef Z.
IAN CANADA TRANSPORTPI DIGI II Ultra Low Jitter Digital Audio Interface Module With the TransportPi Digi II, Ian Canada has taken their high-performance all-in-one digital audio interface for the Raspberry Pi to the next level. This module delivers a...
Josef
This sound card from IAN CANADA is absolutely amazing, (reference) the presentation and detail a great sound improvement. Like all products from IAN Canada, who is serious about music through Raspberry.
Pascal N.
Excellent cordon qui a permis d'upgrader le son de mon casque AKG K240 Studio.
Par contre, durée de vie limitée : Moins de trois ans d'utilisation avant que le côté mini XLR ne commence à grésiller alors que le cordon originel (époque Made In Austria) avait duré quatorze ans avant de connaitre le même problème...
Boris K.
GUSTARD U18 USB Digital Interface XMOS XU216 I2S Accusilicon 32bit 768kHz DSD512 Silver This Gustard U18 USB digital interface offers a high quality design, ensuring excellent performance and accurate sound reproduction. The input point of the U18 is a second...
The Gustard U18 is an incredible device!
I recently bought a Gustard X18 DAC from Audiophonics and was blown away by its sound. It replaced my cheap but fantastic Khadas Tone Board DAC. I wrote my review of it on the Audiophonics website (https://www.audiophonics.fr/en/dac-with-volume/gustard-x18-dac-es9038pro-xmos-i2s-cpld-accusilicon-bluetooth-50-32bit-768khz-dsd512-mqa-black-p-15888.html). I regularly follow numerous audiophile forums and I noticed that many people praise the USB Digital Interface when their music source is a PC. Since my main music source is a PC, I decided to pull the trigger and order the Gustard U18. The choice seemed logical to me, since I already had a Gustard X18 DAC. To be honest, I didn't know what to expect from this device, nor whether I would hear any improvement in the already excellent sound of my system. After a few days, the device arrived in excellent packaging, as I have come to expect from Audiophonics. As soon as I connected it and played the first bars of classical music, I was completely taken aback. The sound image became much clearer, and the dynamic contrasts more natural. It reminded me of the moment when I first put on my prescription glasses. Yes, they were nuances in the sound, but very audible. The timbre of musical instruments became clearer, and in some performances of large orchestras I noticed violin vibrato for the first time. The resonance of the piano strings was now heard more clearly, giving the piano sound an incredible realism. The sound image was clearer and the arrangement of instruments within the sound stage more precise. The Gustard U18 has been in my system for two months now, and every time I turn on the system, I am amazed by the sound that comes from it. I recommend it unreservedly to anyone whose sound source is a PC. An incredible device!
My system: PC, Supra Excalibur USB cable, Gustard U18 USB Digital Interface, AudioQuest Cinnamon HDMI cable, Gustard X18 DAC, Van Den Hul 3T The River interconnect cables, Marantz PM8006 amplifier, Canare 4S11 speaker cables and Graham Chartwell LS6 speakers
Boris K.
Assaf A.
Great product!
“I recently purchased an amplifier from Audiophonics based on the Hypex NC502MP module, and I am thoroughly impressed. This powerhouse amplifier delivers incredible performance, effortlessly driving my demanding 87dB speakers with outstanding precision and control.
The sound quality is exceptional—rich, powerful, realistic, and truly moving. It brings music to life in a way that feels both natural and emotionally engaging.
I highly recommend this amplifier to anyone seeking high-end performance at an unbeatable value. In my opinion, it’s one of the best value-for-money amplifiers on the market today.
Charles B.
Très bonne qualité
J'ai acquis ce câble en complément d'un adaptateur AES/EBU BNC Neutrik NADIT BNC-M afin de pouvoir exploiter la sortie coaxiale de mon MiniDSP Flex Digital pour driver mes Genelec qui ont une entrée AES/EBU. J'ai choisi une petite longueur car mon câble XLR fait déjà 8 mètres.
Ici ce n'est pas du marketing, pas de placage or ni de gaine tressée : l'impédance du câble, des fiches RCA et BNC est de 75 Ohms ce qui garanti l'intégrité du transport des données numériques en SPDIF.
Hocine H.
Incroyable
Acheté à la base pour des câbles CS qui donnent entière satisfaction, je le'ai utilisé en câble H.P et quelle surprise. Câble très équilibré qui apporte beaucoup de douceur aux aigus sans les dénaturer, tout est en place place avec et associé à de bons connecteurs c'est un pur plaisir.
J'ai utilisé les Furutech FT 212 qui passe juste si vous habillé les terminaisons avec de la gaine, mais ça passe. Le hic, c'est la préparation, il faut beaucoup de patience pour dénuder les brins de cuivre, 4 par conducteur soit 48 par câble, 3 sont déjà à nu.
Bref un très bon câble bien conçu sans se ruiner. Je conseille vivement, ils ont remplacé mes DUELUND.
Charles P.
COMPLY TW-200-C Set of 3 Pairs of Memory Foam Eartips (L) for Sony True Wireless These Comply TrueGrip Pro memory foam tips are designed to fit Sony True Wireless earphones perfectly. They feature a unique design that seamlessly seals the ear canal to block...
Très déçu
Mousses "L" vendues comme compatibles avec le Sony WF1000-XM4. C'est effectivement compatible mais la taille n'est pas du tout équivalent au L original. J'ai perdu 70% de réduction de bruit et les écouteurs ne tiennent pas dans les oreilles. 27€ de perdus !
2 étoiles car si les mousses vous conviennent elles ne sont pas si mal : mousse à mémoire de forme, pas trop agressif sur l'oreille, ont l'air plus résistantes que les mousses originales.
jean-françois v.
IAN CANADA FIFOPI Q7 II FIFO Reclocker Module I2S DSD DoP Syncrhonous The Ian Canada FifoPi Q7 is the new flagship in the FifoPi family of reclockers. It achieves the best performance in terms of jitter and noise by using a number of...
Upgrade FIFO PI Q7 vers FIFO PI Q7 II
Petit retour d'expérience sur ce nouveau Reclocker de chez Ian Canada. En effet, dans mes autres post sur le FiFO PI Q3 et Q7 dont j'ai été pendant de nombreux mois très satisfait (voir mes commentaires à ce sujet), J'ai décidé de tenter l'aventure avec ce nouveau Reclocker FIFO PI Q7 version II. Et bien, je doit dire que je nesuis pas déçu !! Même si l'apport en qualité n'est pas aussi flagrant, il y a tout de même un petit gap avec ce qui suit :
- Une amélioration de la scène sonore (plus d'espace)
- Une dynamique plus grande
- Une plus grande justesse des timbres sur toute la plage audible
- Des fins de notes plus silencieuses
A noter que j'ai en plus des Horloges Accusilicon et cela contribues aux résultats. Actuellement j'ai upgradé avec des horloges SC Pure et la c'est le top !!!
Seul petit bémol du FIFO PI Q7 version II, j'ai toujours des plocs au changement de plages audio mais cependant moins fréquentes.
Cordialement.
Jean-François.
Marc T.
TONEWINNER TY-1CD CD Player DAC ES9028 The Tonewinner TY-1CD CD player benefits from attractive aesthetics and quality components for superior CD playback performance. It features an ES9028 DAC chip as well as...
Platine CD Tonewinner TY-1CD, un must !!
Déjà processeur de l'amplificateur de puissance Tonewinner AD-1PA et du preampli AD-1PRE je me suis lancé dans l'achat de cette platine de la même gamme "TY". Et bien comme le reste de l'ensemble il s'agit d'une platine CD aux prestations musicales de très haute volée !! Tout y est: qualité des timbres, naturel des voix, profondeur et nuances du grave, scène sonore immense et grande échelle,...en bref un must qui fait aussi bien si ce n'est mieux que les plus grandes références concurrentes sur le marché à plusieurs milliers d'euros !! A acheter les yeux fermés, il est impossible de regretter cet achat sur le strict plan de la fidélité musical !! Je profite de l'occasion pour remercier Audiophonics qui a accepté à ma demande d'ajouter/proposer cette platine CD à leur catalogue, jusque là encore non disponible en France.
alric M.
genialissime !
Alors j'étais ultra ultra ultra septique . Après avoir changer tous les câbles d'alimentation le xlr le câble USB mi des conditionneur des câbles d'enceinte de qualité j'avais un vulgaire câble catégorie 8 a 25euro . Je me suis dis bon au vue des avis je vais essayer . Encore une fois ultra septique et non mais alors vraiment non ça fais 2h que je l'écoute et vraiment il est top top top , la qualité et génial comme toujours avec les produits Audiophonics ( leur xlr et leur coaxiaux sont génial meilleur rqp su marcher ) pour ce câble que dire hormis la chose qui m'a directement sauter au oreille , un gain dans les silences . Le son est plus ouvert , légèrement plus détaillé , les basses plus sèche et net . C'est plus calme profond les notes sont franches avec de belles armoriques . Si on met de côtes l'esthétique superbe oui ce câble ajoute un réel plus , de plus a -100e cela reste un plaisir abordable . Je pense qu'il viens dans les dernières choses a faire quand le principal et fait ( pour en profiter ) câble enceinte , câble secteur , xlr , câble USB ( ou coaxial ) et câble ethernet en dernier c est la cerise sur le gâteau , un grand bravo à Audiophonics pour nous faire de jolies produits abordable et qualitatif . Je pense qu'il y a toujours mieux mais là on atteint un sacré niveau nulle doute qu'il faille débourser le double voir le triple pour avoir un gain . Je recommande les yeux fermés . ( Et encore une fois les xlr les coaxiaux les câbles fait par Audiophonics vous pouvez y aller les yeux fermer ! Content d'avoir un site français ! Avec un bon sav un service client réactif et encore une fois de formidables produit qualitatif a bon prix !)
David S.
très bon en liaison phono
Utilisé pour recâbler la sortie d'une platine technics 1510mk2, je confirme qu'il est très bon en liaison phono, aucun souffle ou perturbations. Compter une vingtaine d'heure de rodage avant une opinion définitive.
Il reste un peu épais, à prendre en considération.
David S.
Imbattable pour le prix
Très bons connecteurs au RQP impeccable. Facile à souder, très bonne connexion bien ferme sur les RCA femelles. Aucune coloration ou dégradation du signal à noter pour un signal phono en MC.
Remarque: ça passe tout juste avec un câble MOGAMI NEGLEX 2497 de D=8mm
Produit qualitatif
Envoi rapide et article bien protégé. L'alimentation est de tràs bonne finition et ses prestations sont excellentes. Les pavillons de mes Klipsch délivrent un aigu et un medium plus clairs, plus fins et ciselés, un voile s'est levé !
Les graves sont revenus dans leur juste proportion, ils ne sont plus baveux. La musique est plus aérée, c'est transparent et analytique. J4obtiens des prestations de très haut niveau sur un rasp 3B plus et une puce ess 9023 branchés sur un NAD C316.
Produit vivement recommandé!
Bravo audiophonics
Paulo A.
THINKYA R01 CD and USB Audio File Player Bluetooth 5.2 Bidirectional 16bit 48kHz The Thinkya R01 is a CD and audio file player with a retro look. It features a SILAN SC6137D processor and a precise laser head. In addition to allowing you to play your CD...
Fantastic CD player
This a great hifi budget !!! Small but with lots of outputs. The sound is very nice. Is fragile in some ways but with proper care it will last and you can have hours of audiophile sound, I connect mini with an small Fosi 331 amp and Roth speakers and it sounds so great.
Tjalling B.
Difficult DIY but worth it
Not the easiest to terminate properly, but well worth the effort.
Very neutral speaker cable with good soundstage and placement of instrument and voices.
I’m using it single wire; red + white and black + blue.
The shield of the individual wires (silverplated copper) is twisted together with the copper.
Well worth the money
luc f.
luc f.
daniel c.
chauchau
Depuis un an maintenant ce dac joue la musique de qobuz ou me donne le son de la télé. (qobuz en usb,la télé en optique). Bien que son prix ait augmenté, il reste d'un rqp formidable. Très musical, facile d'emploi, le top.
Hocine H.
SOMMERCABLE MERCATOR CAT8.1 Ethernet Cable OFC Copper 8x0.32mm² Ø8.2mm This Sommercable Mercator Cat 8.1 Ethernet cable has 8 conductors of 0.32mm² each (22AWG) with double tinned copper braid shielding. This cable, sold by the metre, will...
Pas terrible.
La ohoto est trompeuse, pas le même bleu et la tresse de masse est en realité quelques fils qui se battent dn duel. Le câle est très rigide et la gaine externe blanchit, voire se fissure si vous tentez de le plier. Son petit frère est beaucoup mieux. Et si vous voulez quand même l'acheter, il faut lui associer des Connecteurs cat 8 car les telegartner MPF8 T568B ne sont pas adaptés, opté pour MPF8 8.1 avec bouchon de serrage.
Kenneth m.
SMSL VMV A1 Amplifier Class A MOSFET PGA2311 2x15W 4 Ohm The SMSL A1 is a compact but very powerful Class A amplifier, offering an excellent sound reproduction, both round, musical and precise. This amplifier provides a beautiful...
WoW
A fantastic amplifier for lightly driven speakers. Was thinking of buying a musical fidelity a1, but have not regretted the vmv a1. Nice volume control. It makes my vintage Beovox 1100, Beovox 2200 play like never before. Likewise my Zu Audio Cube mk ii. Can't wait to get my Lowther Bicor 1000 assembled for Christmas so they will perform like never before. But it's only for really lightly driven speakers, but really makes them sound beyond great. Works great with my Rel t5x subwoofers.
Kenneth m.
WoW
Giorgio B.
Balanced Adapter Male 4 Pins XLR to Femelle Jack 4.4mm Gold Plated This balanced adapter features a 4-pin XLR male connector and a 4.4mm jack female connector. The conductors are made of monocrystalline...
Magnifique
C'est un magnifique pièce lourde et de bonne manufacture. Fais parfaitement son travail.
Giorgio B.
Fonctionne bien, a l'air un peu fragile
Mon titre a tout dis.
Le potentiomètre pour régler la température du fer a souder n'a pas l'air solide.
Sinon il fonctionne parfaitement
Giorgio B.
Facile a utiliser
Il fond assez rapidement, a un point de fusion de 217c° environ, plus facile que le 90% étain+10℅ argent qui fond a 290 environ.
Attention, il "crépite parfois et envois des petites projections d'étain fondu, donc garder votre visage a distance
MOGAMI w31003 4mm2
Avec le bon conseil de Mr David Auber , j'ai commandé ce câble pour faire jouer mes Focal Aria K2 liées à un Yamaha RN 2000 A (2X9 mètres) . Pas du tout déçu du résultat tout est là et dans tous les registres. Pour moi, c'est un bon mariage, je ne vois pas ce qu'un autre câble plus onéreux pourrait m'apporter de plus !
Merci Audiophonics.
Armin w.
Automatic Power Suplpy Switching Module This power supply switching module automatically switches an amplifier on and off when the module receives an audio signal with a level above 500mV.
Nice automatic, worth a try.
Increasing the power on time with bigger capacity (the 220 uF printed on the board, already comes with 470 uF). Go for higher values to expand the time before shut off.
Add a 4.7k resistor between pin 1 and 2 (the pins next to the point marker on the chip) to increase sensivity from -36 dB to more practical -56 dB for low listening levels.
Armin w.
RCA Sockets Rhodium Plated Pure Copper (Pair) These affordable yet high-quality RCA sockets are made from rhodium-plated pure copper for optimum conductivity and resistance to corrosion and oxidation.
Fair priced, good offer!
I really like the sockets, for sure a good deal.
What I don't like are the isolator plastic shims, they are just to flimsy and hard to fit (11 mm drill required). I got not a good feeling with them.
I went with rubber rings instead that are normally used for cable through case installation.
denis b.
Acheté par curiosité en remplacement d'un AUDIOPHONICS Câble secteur blindé OLFLEX 110CY 3x2.5mm² 1.15m en place depuis un moment, qui alimente un conditionneur Ludic Heimdall.
Pas de panique! en toute première écoute, effet loupe sur les basses (boursouflées), mediums proéminents et aigus agressifs avec accentuation des sifflantes. Aie!!
Mais tout de suite, amélioration de de la scène sonore toutes sources confondues : élargissement, projection vers l'avant, amélioration du centre disposé bien plus en avant du plan des enceintes. Amplification des micro détails déjà identifiés, apparition d'autres bien plus ténus. Bon..
Les basses rentrent dans le rang en premier: plus de profondeur, meilleur découpage et lisibilité, plus d'amplitude surtout à la lecture des vinyles.
Les médiums et aigus suivent, avec conservation du gain sur la scène et les micro détails. Le centre se stabilise dans une belle présence, vraiment agréable.
les aigus s'assagissent vraiment, soyeux, vifs et précis, mais sur mon système je note un léger tassement surtout à la lectures de CDs, et de certains vinyles, mais pas sur tous. Le dac est trés peu impacté.
Le câble respire la qualité, il est beau, de gros diamètre, assez raide mais pas trop gênant de ce point de vue. Les prises sont belles, et le grip très bon.
En conclusion un très bon câble ,excellent chez moi, au détail des aigus près (à voir la suite), plus de coffre, plus de basses, plus de scène sonore, qui fera beaucoup sur des systèmes remontants, après 50 bonnes heures de rodage minimum.
Bonnes écoutes!
Intégré push pull KT90, enceintes monitor audio Silver 500 6G, CD eera, Dac D50s, riaa Lehmann audio black cube SE2, cellule Mc Audio Technica, rca Harmonic technology, secteur sources Wireworld Aurora.
Jean-Michel S.
Pas mal, satisfaisant.
C'est mon premier DAC. Combiné à un ampli Studio old school BGW 750G et des baffle Vulkan Mk3 j'en suis ravis. Ce n’a pas été le grand changement vus que j'utilisais ma sortie PC qui inclus déjà une sortie piloté par un OPA 2134, une Gigabyte Gaming, mais les graves sont mieux maîtrisé, plus sec et l'ensemble est plus aéré, plus propre, les instruments sont mieux détachés.
Mes VU m'indiques aussi une dynamique accrue. Le branchement est fait avec des câbles Sommer XLR, qualité Studio.
A l'écoute de Poem of Chinese Drum je fus complémentent convaincu: les tambours sont comme des coups de foudre avec la vibrations des peaux... sublime. Et après My Bass, quelle profondeur... ou Bass Drops...
Un bon choix si on veut un DAC simple, performant et pas cher.
Voyons la durée de vie...
denis b.
USB Dongle Bluetooth 5.2 Transmitter aptX / aptX HD / aptX LL / aptX Adaptive This Bluetooth 5.2 USB transmitter dongle will allow you to broadcast audio streams wirelessly, from a computer for example, and in high quality, thanks to the use of a Qualcomm...
Dongle Émetteur Bluetooth 5.2
Acheté pour utilisation arec une tablette sous W10 dont le Bluetooth a rendu l'âme. Reconnu directement et facile à connecter après quelques clignotements sur un D50s. Le son est plus que correct avec un léger assombrissement facile à corriger dans Foobar2000 (equaliser).
Excellent RQP.
Antoine S.
Indispensation pour le streaming
Je m'attendais à une légère amélioration, mais au final dès sa mise sous tension, mes écoutes à partir de Qobuz sont transcendées.
Amélioration de la spatialisation, tout à plus de matière et plus de justesse, une meilleur dynamique, apparition de nombreux micros détails, etc ..
Je recommande vivement :-)
Paulius S.
MUNDORF MRESIST SUPREME MRES20-1.5 Resistor 20W 1.5 Ohm The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution, these resistances allow to obtain finer...
Best
I think it is the best resistor on the market.
Paulius S.
High quality, price friendly connector.
