jevgenijs S.
Simply great!
My speakers never sounded this good! A very clear and open sound without being fatigue! The tone controls are very effective!
Reinhardt S.
VIABLUE EPC-4 Silver Balanced Interconnect Cable Ø3.9mm
sehr gute Qualität,sehr empfehlenswert
Reinhardt S.
NEUTRIK NC4MX-B 4 Gold Plated
Customers reviews - There are 20865 reviews.
Aritra P.
TECTONIC TEBM65C20F-4 Full Range BMR Speaker 30W 4 Ohm 81dB 60Hz-20kHz Ø7.62cm Tectonic's BMR range consists of full-range speakers designed to cover a very wide part of the audible spectrum. For example, the TEBM65C20F-4 features...
Excellent Full range drivers
Set this up with manufacturer specified 1.6 L cabinets (non ported) made of PETG (3D Printed Boxes). The Clarity of the drivers are remarkable for such a small size. These drivers can be run by themselves eliminating the need for a crossover and tweeter setup.
Bass is a bit on the weaker side. Complementing it with a subwoofer driver is a necessity if you are looking for a rumble.
Overall highly recommended drivers as they are quiet the underdog in the DIY space. Hope more people buy this and enjoy these.
Aritra P.
DAYTON AUDIO LW150-4 Speaker Driver Woofer Low Profile 40W 4 Ohm 86dB 60Hz - 1600Hz Ø15.2cm The versatile Dayton Audio LW150-4 woofer has been designed for space-restricted applications thanks to its shallow depth. Its low-profile frame and unique venting allow the...
Nice Slim Drivers
Based on a preleminary testing, the drivers are of good quality. Bass response is good and the quality of manufacturing is good. Recommended drivers.
ERIC C.
Très bonne gaine
Gaine de très bonne facture, idéal pour habiller mes nouveaux câble de modulation.
leo h.
IAN CANADA CMCHOKER Common Mode Filter Module for Audio Power Supply The Ian Canada CmChoker is a two-stage, high-current, wide-voltage common mode filter that effectively suppresses common mode noise introduced by AC power transformers. The...
Choke
Works perfect
Charles S.
VISHAY ERO MKP1837 Polypropylene Capacitor 5mm 160V 0.1μF Vishay's ERO capacitors are polypropylene film MKP capacitors. They offer good performance in a compact size.
Amélioration générale du rendu sonore et de plages musicales "touchy".
Essayés sur un vieux lecteur cd Marantz CD-52 en parallèle aux condensateurs de sorties, les pattes coupées très courtes¨(5mms) + des résistances Vishay:
des passages difficiles dans les aigus des pianos, le toucher des accords se distinguent mieux, les clarinettes souvent compliquées à bien rendre et cordes passent enfin bien ainsi Stan Getz ! Comme moins de distorsions, plus de nuances, plus bel et plus profond espace sonore. Ceci sans avoir encore attendu les 10 heures que conseille le commentateur précédent.
J'avoue n'avoir, sur mon matériel, jamais apprécié la dureté de sonorité des Wimas; pour moi aucun rapport de musicalité avec ces Vishay. Je n'aurais jamais pensé qu'en tant que simple bricoleur arriver à avoir un rendu aussi propre et musical avec ce vieux lecteur cd. Là, je n'arrête plus d'écouter tant c'est enfin agréable.
Merci à Audiophonics d'avoir choisi de les distribuer !
Ferre l.
JANTZEN AUDIO 000-0826 4N Copper Air Core Wire Coil 29AWG 1mH The Jantzen Audio Air Core Wire Coil is made of high purity Copper wire, offering distortion-free inductance. This makes it suitable for all audio applications. The coil...
High resistance
Si vous achetez ceci, notez que la résistance de la bobine est de 3,9 ohms — cela peut vraiment affecter votre crossover.
Dag-Atle K.
Dag K.
Fantastic sound, similar to the sound of Nad's M23 power amplifier, i.e. very dissolved. But the AUDIOPHONICS LPA-M750ET is more dynamic. Great product for the price!.
Tibor M.
How many reclockers is too many?
Excellent. This has brought the improvements, I wished smsl po100 I bought earlier, would. It does what you guys said it would, clarity and precision is next level, I got better separation and layering out of the music. Voices are really smooth and full sounding! But YMMV, my system is little more complicated now, starting PC + Altor USB Isolator + iFi iPurifier 3 + SMLS PO100 2024 + Audiophonics DigiRescue, all this powered by iFi iPower X 5v + some supercapaticors, coaxial to Topping E70V and Audiophonics HA-B6102 + Burson V6 Vivid + Quad Era-1 / Audio Technica WP900. And I am really impressed how my headphones sounds now, thank you Audiophonics! Peace.
Guillaume d.
très content
V2 avec alim 12V, franchement pour le prix il n'y a rien à redire.
- BT 16b 44KHz volume par potar et logiciel pc/tel
- USB 16b 48KHz volume uniquement au potar
Il y a un léger souffle constant dans les enceintes peu importe le volume fort ou pas fort. Mais c'est inaudible dans mon environnement (faut vraiment être au calme pour l'entendre). Utilisation avec des bibliothèque sur pc, c'est très bien. Et comme je ne monte pas le volume fort, pas besoin de puissance non plus.
Vraiment top
Serge V.
USB4 Cable Male USB-C to Male USB-C USB-PD 240W 40Gbps 8K 60Hz 1m This 1m USB-C cable uses the very latest version of this standard, USB4. Designed to be universal, it imposes the USB-C format and is capable of transferring audio and video...
câble magic pour les dac audio
Connecté entre un 3D-Lab Transport signature et mon PC en USB-C 3.2 Gen 2, l'effet waouh est garanti, en tout cas sur mon installation; harmoniques et micros détailles sont apparues comme par magie ...
En tant qu'ingé informaticien Je n'y croyais pas trop mais force est de constater que 40 Gbps sont nécessaires pour les transferts isochrones des fichiers audio. Pas mécontent de cette upgrade.
Paul M.
NEUTRIK NA2MPMM Male XLR Male to Male RCA Adapter This Neutrik NA2MPMM adapter consists of a male 3-pin XLR connector and a male RCA connector. It has a professional quality metal body and is particularly robust.
Rock solid Neutrik adapter
Bough these to supplement my stock of connection adapters. Neutrik feel and Neutrik quality: rock solid build and connections. No signal degradation that I can hear. Recommended!
Paul M.
Rock solid Neutrik quality adapter
Paul M.
AUDIOPHONICS WIRE Interconnect Cable Stereo RCA OFC Copper Gold Plated 75cm The Audiophonics Wire serie offers a selection of affordable yet high performance cables, hand assembled in our workshop in France. The Audiophonics Wire RCA cable consists of a...
Solid quality cables - all you need
I use these cables between a streamer/dac and a power amplifier. The Mogami cable is supple and easy to route, also in the smallest of places. The Amphenol rca connector has a metal body and feels very solid. The Amphenol makes a tight (but not too tight) connection with the rca connections on both sides. Audiophonics is skillful in putting these cables together. Just choose the cable length you need and enjoy the music!
Paul M.
AUDIOPHONICS WIRE Interconnect Cable Stereo RCA OFC Copper Gold Plated 1.5m The Audiophonics Wire serie offers a selection of affordable yet high performance cables, hand assembled in our workshop in France. The Audiophonics Wire RCA cable consists of a...
Clive S.
AIYIMA A70 MONO Mono/Subwoofer Class D Amplifier TPA3255+NE5532 1x300W 4 Ohm The Aiyima A70 Mono is a Class D amplifier based on a chipset comprising a TPA3255 amplifier chip and a NE5532 OPA. It is capable of delivering power up to 300W @ 4 ohm....
Great little amplifier
It's kind of embarrassing for my old class AB amplifier
This little thing is connected to a 15 inch subwoofer and it makes the house shake. I'm considering buying another one just to try it in stereo mode with full range speakers.
Thierry V.
RAMM AUDIO ZEUS SI 15 Power Cable Schuko C15 OCC Copper Triple Shielding 1.5m Ramm Audio offers with the Zeus SI 15 a high quality audiophile power cable. It features an exceptional design with high purity OCC copper conductors for maximum conductivity....
surprenant
Veritable aubaine a son prix, j ai des CS bien plus chers, ce Ramm les concurrence sans problème merci Audiophonics de nous donner accès à ce type de produit au RQP incroyable
Robert C.
EVERSOLO T8 Streamer Digital Transport WiFi 6 DLNA UPnP Roon Ready Bluetooth 32bit 768kHz DSD512 The Eversolo T8 network transport allows you to connect your HiFi system to a network so you can enjoy high-resolution digital sources. Specially designed to deliver a digital...
Stunning music streamer
Pros:
Excellent audio signal output (especially I2S).
Easy configuration (in 10 minutes unit is ready for use).
List of supported music streaming services, apps and connectivity.
Silent unit (zero noise, black background).
Fast and stable mobile app.
Software updates.
Cons:
Upsampling feature (preferable in DSD) in future software releases.
Eemeli T.
OK.
A very simple preamp with good number of inputs. Enclosure is robust and it looks good. Unfortunately I received mine with a defective display but it was fixed.
Only bigger issue is the frustrating volume control when using the remote: at first the volume changes slooowlyyy... and then after a second or so it starts to run fast AF. Why no make it linear? Impossible to change the volume quickly. The rotary encoder on the device is responsive and precise but devices like this are usually operated with the remote.
Soundwise I have no complaints.
Eemeli T.
AUDIOPHONICS Active Trigger Sequencer 1 IN / 4 OUT 12V This active trigger sequencer is hand-assembled in our Audiophonics workshop. It avoids plocks and current peaks in order to switch on and off a chain of several Hi-Fi devices.
Just the thing I have been looking for!
A simple and cheap solution to a problem of not having enough trigger outputs on my preamp. Now I can power on all my devices at once. The slightly delayed "soft start" is nice addition! Perfect little box and works just as promised.
David H.
Une révélation ! Le pilier de mon système haut de gamme
Configuration : Holo Audio RED (USB) DAC Audiomat Maestro 3 Ampli Aria EL34 NOS Carbon Cabasse Pacific SCS.
Avis détaillé :
J'ai intégré le Holo Audio RED en tant que Pont Réseau / DDC dans mon système Hi-Fi très exigeant. Je cherchais à optimiser la qualité du flux numérique avant mon DAC Audiomat.
Le résultat a dépassé toutes mes attentes.
1. Magie Opérée : Le son est devenu instantanément plus organique et réel. Le RED apporte un fond sonore plus noir qui permet aux micro-informations d'émerger sans effort. C'est le contraire d'un son "numérique" ou froid.
2. Synergie parfaite : Il a permis à mon DAC Audiomat Maestro 3 de s'exprimer pleinement, en lui fournissant un signal dépourvu de jitter et d'une stabilité irréprochable. La fluidité et la richesse des timbres de mon ampli à tubes (EL34 NOS Carbon ) sont sublimées.
3. Impact sur l'écoute : L'image stéréo (déjà excellente avec mes Cabasse Pacific SCS) est désormais plus tridimensionnelle et stable. La musique gagne en vie et en présence.
En conclusion : Le Holo Audio RED n'est pas un simple streamer, c'est un purificateur de signal numérique essentiel. Si vous possédez un DAC de qualité, cet appareil est un investissement justifié qui maximise le potentiel de toute votre chaîne. Un produit absolument sublime !
Gabriel G.
NEOTECH NEUB-3020 Cable USB-A Male/USB-B Male 2.0 Gold plated 24k OCC 1m The Neotech NEUB-3020 USB AUDIO class 2.0 cable offers superb digital playback quality using innovative technologies that challenge the hierarchy of high-end USB cables.
Naturel
J'ai les deux versions, argent et cuivre, de ce câble Neotech. Sur un DAC Audio-gd R1, je préfère utiliser le cuivre à l'argent en mode NOS. Extrêmement naturel, la musique coule sans frustration.
David H.
Fait parfaitement le travail
Un peut dure de rentre le 4mm2
David H.
Excellent fiche banane
J'ai choisi ces fiches bananes Dynavox pour leur bon rapport qualité-prix et leur placage or. Elles font parfaitement le travail et assurent une excellente connexion entre mon ampli et mes enceintes. Le système à double vis de serrage est efficace pour maintenir le câble en place, même avec une forte section.
Point à améliorer :
Le seul petit bémol concerne la gaine thermo-rétractable fournie. Avec mon câble de 4.0 mm2 (qui a un diamètre externe important), la gaine est un peu juste et ne permet pas d'avoir un serrage ou une isolation parfaitement ajustée à la sortie de la fiche.
Malgré ce détail esthétique et de finition, la performance électrique n'est pas affectée. C'est un excellent produit si l'on est prêt à accepter ce petit ajustement ,Recommandé pour le prix !
David H.
Meilleur choix home cinéma longue distance
Le meilleur choix pour le Home Cinéma et les longues distances !
Note : 5/5 (Excellent rapport performance/prix)
Ma configuration : Marantz Cinema 50 (7.1.2) et enceintes Cabasse iO2/Ki (Total 73 mètres de câble).
Mon expérience :
J'ai longtemps hésité avec des câbles audiophiles très coûteux, comme le Viard Audio Premium HD 4 mm2 (qui coûte environ 27€/m soit 8 à 9 fois le prix de l'Elbac).
Mon verdict est clair : L'Elbac HP240 est le choix le plus intelligent et performant pour un système Home Cinéma.
1. Techniquement Supérieur pour la distance : Pour mes longueurs (jusqu'à 11m)le critère le plus important est la faible résistance du câble. L'Elbac est conçu pour une faible perte de puissance, garantissant que mon Marantz garde un contrôle total des basses et de la dynamique. Sur ce point technique essentiel, l'Elbac est un excellent produit PRO.
2. Qualité d'écoute : Le rendu est dynamique, précis et maîtrisé. Les différences subtiles promises par le Viard (clarté des aigus, etc.) sont, au mieux, totalement imperceptibles dans un contexte multicanal 7.1.2, surtout lorsque l'ampli utilise la correction acoustique (Audyssey).
3. Le prix : Dépenser (1700€ de plus pour 73 m) de câble Viard qui n'apporterait aucun gain sonore garanti.
Michael S.
7HZ TIMELESS II In-Ear Monitors IEM Planar Magnetic Ø14.5mm 15.2 ohm 108dB 5Hz-40kHz The 7HZ TIMELESS II in-ear monitors, an evolution of the brand's TIMELESS range, are planar-magnetic IEMs featuring a new 14.5mm diameter driver. This driver is itself driven by...
Einfach super
Habe meine Bestellung gut verpackt und schnell nach Deutschland erhalten.
Der InEar ist von Preis/ Leistung top!!
Der Klang ist von tiefen Bass über Mitten bis hin zu den Höhen
präzise und ausgewogen,homogen.
Er benötigt jedoch etwas mehr Ausgangsleistung an meinem
Astel&Kern (Kann Max).Beste Grüße an audiophonics.fr M.S.
Jonas R.
Digital Interface USB Amanero / Bluetooth 5.0 to AES / SPDIF / I2S 32bit 192kHz DoP128 This small, high-performance digital interface takes a Bluetooth 5.0 or USB signal as input and then outputs it in I2S (via HDMI), AES, Toslink Optics or Coaxial. The Bluetooth...
Good USB to AES interface
Good Device. Plug and play.
Do note that if you plan to use Bluetooth as primary input you would have to select that on the box with a button every time the device has been turned off.
For my use case it is perfect.
Georges C.
HATTOR AUDIO THE BIG Balanced Passive Preamplifier Talman REX Black / Silver Hattor Audio presents us here with a high-end balanced passive preamplifier offering incredible performance thanks to an equally exceptional design.
Hattor Audio The Big TakmanRex
Excellent appareil d'emploi très pratique ,musicalement encore supérieur à mon précédent" Music First Audio", particulièrement du point de vue de l'ouverture de la scène sonore. A recommander sans restriction. Merci à la maison de m'avoir fait découvrir une telle solution à mes embarras...
A la livraison, les deux cartons étaient en parfait état, mais curieusement la valise montrait une marque de choc et une fracture de la fragile paroi de façade, le préampli n'ayant en rien souffert
Gorazd K.
FIIO DM13 BT CD Player Ripper on Battery 2xCS43198 Black FiiO's DM13 BT is a portable CD player with a sleek design and undeniable internal component quality. Its aluminum body houses two DAC chips from Cirrus Logic to offer a...
As always, full praise to Audiophonics for their excellent packaging and fast delivery. The CD player is well-built and neatly packed, complete with a user manual. The aluminum body feels solid, and the buttons have a nice tactile feedback — overall, handling it gives the impression of a quality product.
The user experience, however, could be better. To change outputs, you have to go through a sequence of button presses. It’s not an issue for me since I’m a bit of a tech enthusiast, but for a less experienced user, it might be confusing.
When you plug in wired headphones, it doesn’t automatically switch from Bluetooth — you need to manually select the desired output. Another thing I miss is a Stop button. I’m not sure why it’s missing, but it would make the operation more complete.
Apart from that, everything else is fine — the sound quality is good and matches the price point.
Ratings:
Audiophonics: (5/5)
Build Quality: (4/5)
Ease of Use: (3/5)
Sound Quality: (3.5/5)
Mathias K.
AUNE AR5000 Open-back Dynamic Headphone Ø50mm 28Ω 108dB 5Hz-41Khz Aune's AR5000 are open-back headphones with a dynamic MLD ("Multi-Layer Distributed") driver of no less than Ø50mm. Thanks to its innovative driver, high-tilt acoustic...
Très bon !
Je suis pleinement satisfait de ce casque ouvert facile à piloter, d'une bonne qualité de fabrication, plutôt léger et très agréable à porter. Il délivre un son clair, précis, très détaillé et réaliste. Je recommande.
Mathias K.
TOPPING DX5 II DAC 2xES9039Q2M Headphone Amplifier X-Hybrid Bluetooth 32bit 768kHz DSD512 White With the DX5 II, Topping presents the direct heir to its famous DX5 DAC and headphone amplifier. This new version features a host of changes, improving on its predecessor in...
Excellent à tout point de vue
Pour un prix somme toute abordable, ce petit boitier réunit un excellent ampli casque et un DAC tout ce qu'il y a de plus transparent, aux performances exceptionnelles. Il intègre en plus des possibilités d'égalisation que je n'ai pas encore testé. Un sans faute.
Francis F.
SMSL PA-X Stereo / Mono Amplifier Infineon GaN 2x250W 4 Ohm / 1x500W 8 Ohm The SMSL PA-X is an innovative amplifier that uses Gallium Nitride (GaN) transistors to offer 2x250W amplification at 4Ω. Its versatility also enables it to operate in...
Ampli PA-X smsl
Je me suis informé, lu et écouté tous les avis possible que j ai pu trouvé avant de me décider à l acheter car c est un budget .
A ma grande surprise beaucoup de petits problèmes énoncés, n existe pas sur mon exemplaire . Il est relié à mes enceintes Davis Acoustics Klarence MV3 , et c est un vrai régal sonore . Je l ai comparé à mes anciens ampli class AB et il faut admettre qu il est plus détaillé et avec nuances et grave très présentés.
Il est piloté par un Viim pro , l ensemble est parfait . Un très bon achat , merci Audiophonics pour la livraison sans problème .
Daniel D.
très bon rapport qualité/prix
suite à mon commentaire précédent, j'apporte les précisions suivantes. Pour pas cher, la scène sonore s'est encore améliorée légèrement en largeur , profondeur, détourage et vivacité en plaçant sous chaque contre pointe un sandwich de matériaux amortissants différents. A savoir sur les pieds avant de mes thiel CS 3.7 qui sont des enceintes closes avec face avant en aluminium et caisson en bois multiplis, 1 rondelle de 2mm découpée dans une semelle de chaussure, marque Noen, 1 rondelle de 5 mm en feutre un peu dur, 1 rondelle de 5 mm en feutre souple + 1 rondelle en liège souple de 1cm (déjà évoquée précédemment). Sur les pieds arrière, 1 rondelle en silicone dur de 15mm, 1 rondelle en feutre dur de 5 mm. La différence d'amorti pieds avant, pieds arrière influe uniquement sur la vivacité du rendu. Le sandwich permet d'amortir différentes fréquences. Faites vos propres essais...
OYAIDE NRF-005T Noise Suppressor Adhesive Tape Pulshut 4m Oyaide NRF-005T is a noise suppression tape using PULSHUT® (high performance non-woven textile) material developed by Asahi Kasei Corporation. This is a revolutionary...
ETONNANT !
Produit très efficace qui apporte une précision d'écoute indéniable . Attention toutefois à appliquer au fur et à mesure car trop de ce produit à tendance à assécher le son . Après plusieurs essais sur câbles de modulation et secteur , seuls deux rubans ont étaient appliqués sur le premier câble secteur de ma barrette . Ne pas hésiter à tester plusieurs endroits de votre système et à en retirer si besoin . Idéal pour optimiser un système déjà upgradé ; ce sera la touche finale .
Franck y.
De la puissance et de la finesse !
J'ignore qui a dit "sans maîtrise la puissance n'est rien" (cf Pirelli TV-Ad), mais Audiophonics a tout compris en choisissant ces modules Hypex. Ce qui m'a rassuré dans mon choix, ce sont les protections que cette carte intégre en cas de surchauffe, de surtensions et court-circuits.
La team Audiiophonics a fait un excellent travail avec cet ampli. Bravo et merci à eux. Comme d'habitude, j'ai été livré en 48 h.
Après 10 jours d'écoute, avec deux types de DAC, le SMSL DO200pro et le Fosi ZD3, et à la source des fichiers numériques essentiellement - compressés au minimum : flac et mp3 à 320Kbps - pour alimenter une paire de Prestige 4i - une colonne pése 30 kg - je redécouvre mes morceaux.
Je remarque de nouveaux détails ici et là sur la totalité du spectre. C'est une grande fenêtre qui s'ouvre à moi. Par exemple, le refrain de Proud Mary version I&T. Turner ne me fait plus mal aux oreilles. À ce moment du morceau, j'avais tendance à baisser le volume, quelque soit l'ampli. Les envolées funk rock devenaient trop brillantes/bruyantes.
Mais avec le S500NC d'Audiophonics, les aigus et les medium sont doux, détaillés, aérés et jamais criards.
Et l'intro sur ce même morceau, où le couple Turner vont chanter chacun à leur tour, la première chose qu'on remarque, c'est la puissance et la maîtrise dans le bas du spectre quand Ike déroule son "rooOOOooolling". Le timbre de ce "rolling" m'a tout de suite fait penser à un vieil ampli de classe A. J'avais un Linn qui pesait 12 kg et qui chauffait une pièce de 20 m2 l'hiver mais d'une musicalité envoûtante voire mystique. Chaque note coulait comme du bon miel chaud. On avait l'impression d'être dans le studio. Ou sur la scène entre le bassiste et les choristes.
Les transitoires propres et maitrisées du S500NC rappellent la linéarité des classe A, avec du jus, de la réserve en plus et de loin un meilleur rendement. Sans compter qu'il chauffe à peine, qu'il pése 2 kg et qu'il prend très peu de place.
Pour résumer, un ampli puissant qui délivre au moins 250 W sous 8 Ohms bien propres et quasiment sans distorsion - par canal - avec un son neutre et maitrisé, des aigus fins et précis, jamais agressifs, des medium clairs et fermes et des graves bien charpentés et planants en hifi comme home-cinéma à 699 euros, avec des composants et un assemblage de qualité, dans un beau châssis ni trop petit ni trop grand, c'est un cadeau qu'on aurait tort de se refuser.
Le meilleur compromis serait un petit ampli classe D pour la TV et la musique de tous les jours et un ampli classe D XXL pour une session d'écoute hebdomadaire ou mensuelle raffinée et de qualité. Pour conclure, avec un tel ampli et avec de bonnes colonnes, un caisson de basses est superflu.
pascal v.
FURUTECH LAN-8 NCF PLUS Ethernet RJ45 Cat8 Cable S/FTP 1.2m Furutech LAN-8 NCF Plus is a beautifully designed Category 8 RJ45 Ethernet cable with S/FTP shielding for high-speed signal transfer. This new generation of Furutech LAN-8 NCF...
Un cable ethernet vraiment transparent
Câble furutech LAN8-plus acheté en remplacement d'un câble Ugreen 8.1 qui se trouve entre ma box et mon intégré Roksan Attessa. Après 1 semaine d'utilisation bilan très positif, la musique se libère , sur les bons enregistrements on a l'impression que cela respire entre les instruments. Du coté des voix cela sonne plus naturel. Ce câble est hautement recommandable, mais attention au système qui tire vers le haut, je pense que cela pourrait être désagréable. Mon Roksan au son typé Anglais (rond) est devenu beaucoup plus clair.
Balèze
Ce câble sort du lot. A la fois transparent et rapide mais surtout dispose d'un medium plein et organique. Son seul défaut : Rigide ! Monté vite fait avec une shuko IEGo or et iec Viborg or qui trainait pour adoucir tout ça et roule ma poule ! selon la formule galvaudée, je réécoute tous mes disques. Des notes posées des silences habités... J'ai des frissons en écoutant Stille Nacht de Cantate domino, une merveille de prise de son que je connais depuis 40ans quand-même. Dernière chose, il marche tout aussi bien sûr ampli que sur dac, donc polyvalent.
olivier r.
Mauvais
Son brouillon et oxydation du revêtement cuivre.
olivier r.
Cable fabuleux.
Permet d'accéder à des détails et de la finesse en profondeur. Médium à la fois étoffé et différencié. Mérite les meilleurs connecteurs. Enterre les bricoles bruyants à base de Duelund, Belden etc... Surpasse un Xsangsane argent 9001 grâce à davantage de structure et de matière tout en restant très fin.
Système déjà bien abouti à base de triodes et enceintes 94db.
Alexandre B.
SHANLING ONIX OVERTURE XM5 Digital Audio Player DAP ES9039PRO 2x TPA6120 32bit 768kHz DSD512 Shanling's Onix Overture XM5 is a high-end DAP designed with state-of-the-art components to deliver the best possible performance. In fact, the Overture XM5 incorporates a...
Un petit bijou
Superbe DAP. La qualité de fabrication est excellente, très largement meilleure que celle du iBasso DX180 que je possède aussi. Tout est bien finit et bien pensé, particulièrement la roue de volume et le placement des entrées casque au bas de l'appareil. Côté son c'est du très bon, avec un fond sonore très noir, un son plutôt chaud, et une excellente musicalité. La batterie est excellente, l'OS aussi. Attention par contre, pas d'Android, c'est un lecteur essentiellement fait pour écouter des fichiers FLAC à partir de la carte SD. Seul Tidal est disponible pour le streaming audio, et en version basique qui ne permet pas de télécharger des morceaux pour une écoute hors ligne. Ce qui correspond exactement à ce que je cherchais. Livraison très rapide par Audiophonics.
Eric R.
OYAIDE DST-75R V2 Coaxial Cable RCA SPDIF 75 Ohm 102SSC Rhodium Plated 1m The OYAIDE DST-75R V2 cable is a very high quality 75Ω RCA coaxial cable with a unique architecture and assembled with high-end connectors. These RCA...
Est ce bien utile
bonjour
J'ai tenté l'expérience afin de ne pas passer à coté de quelque chose
J'ai donc fait la comparaison avec un câble optique à 10 balles afin de raccorder mon Technics SL G700M2 à l'ampli SU G700 , le tout raccordé sur des Triangle Magellan Quatuor anniversaire
Et bien ....... aucune différence ça reste du numérique , et c'est l'ampli qui fait le job pour passer en analogique , l'influence du câble , dans ce cas de figure, relève plus de psycho-acoustique qu'autre chose
Après c'est un câble bien assemblé , permettant une liaison propre , de qualité et sans doute durable
Il ne faut pas s'attendre à autre chose , pour cela j'accorde une étoile , pas plus , le reste étant du discourt marketing
Alessandro S.
VIBORG VE512G Schuko Type E/F Power Connector Silver / Gold Plated Pure Copper Ø20mm This Viborg VE512G Schuko power connector is of exceptional design quality, using only the highest quality materials to ensure the best possible signal transmission. The...
De qualité mais compliqué
La prise est certainement de très bonne qualité, mais connecter le cable, surtout si de diamètre un peu important, est pas mal compliqué. Je crois qu'on aurait pu la concevoir mieux. Le coté IEC est beaucoup plus simple.
Ramiro F.
Cabo digital preciso e transparente
Excelente construção e transmissão limpa, com palco sonoro mais definidoe fundo silencioso.
Ligação estável e sem coloração-ótimo upgrade
Ramiro F.
ISOACOUSTICS ZAZEN I Vibrations Absorber Platform 432x381x30mm 11.3kg The IsoAcoustics zaZen, named after a method of sitting meditation, is a vibration-absorbing platform designed to be paired with vinyl turntables, tube amplifiers or other...
Isolamento eficaz e elegante
A IsoAacoustics Zazen I melhora claramente a estabilidade e definição sonora, reduzindo vibrações sem complicações.
Acabamento de qualidade e instalação simples- excelente upggrade para equipamentos sensiveis, em particular o Mutec REF1O S120.
Ramiro F.
ISOACOUSTICS ISO-PUCK MINI Vibrations Absorber Ø44x24mm (Set x8) The ISO-PUCK series offers an innovative approach to the isolation of Hi-Fi equipment such as speakers, studio monitors or other sensitive audio systems. This ISOAcoustics...
Bom isolamento em tamanho compacto
Os IsoAcoustics ISO- PUCK MINI oferecem uma melhoria audivel na clareza e definição de som, reduzindo vibrações e ressonâncias indesejáveis.
São discretos , eficazes e fáceis de usar.
Uma solução excelente para equipamentos leves ou colunas de estante.
Yves M.
Génial
Je ne connaissais ni le produit ni même la marque avant cette acquisition. Le WiiM Mini est parfait pour redonner vie à des enceintes bibliothèque un peu vieillissantes, la diffusion depuis un Mac via Airplay 2 (et câble optique) étant franchement impressionnante. Belle finition, appli impeccable, que du bonheur.
Joseph P.
Tube E-Harmonix 12AT7WC
Très bon tube acheté pour tenter de le mixer avec un Philips JAN 12AT7 WC. Ce E-Harmonix produit un son plus chaud et rond la scène sonore est large et stable. Les percussions sont franches et profondes il envoie plus de volume sonore, mais il lui manque ce plus de finesse et de détails produits par le couple de Philips que j'ai préféré pour la beauté de ses aigus, (mais qui reste en retrait dans les décibels restitués). Très bon tube pour ceux qui préfèrent un son rond et chaud. Reçu super bien protégé et emballé, Grand merci à toute l'équipe d'Audiophonics .
Joseph P.
Très bonnes fiches Banane Viborg
Ressemblent beaucoup aux fiches Nakamichi. Elles sont un poil plus dures à insérer dans les plots ce qui garanti un excellent contact sans perte de signal. Par contre leur rapport qualité/ prix est imbattable. Merci Audiophonics
François D.
Ravi
J'ai renoncé à la sortie analogique et j'ai connecté le BerryBak sur mon DAC Topping E30ii via la sortie optique. Je suis ravi du résultat.
En outre, appairage Bluetooth facile et de très bonne qualité qui ne décroche même pas entre 2 étages !
Pierre J.
Speaker Front Panel Mounting Clip Plastic (Unit) This clip will allow you to simply and efficiently attach the covers of your speakers to the front panel.
remplacant idéal...
J'ai commandé ces clips pour pouvoir remplacer ceux qui étaient présent sur le panneau de protection des HP pour une enceinte colonne Klipsch.
En effet, ceux d'origine étant en plastique dur, ils se sont cassés un par un à force de de déposer en remettre le panneau de protection.
J'ai percé des trous plus grands pour pouvoir insérer ces clips et iles remplacent parfaitement ceux d'origine avec un meilleur maintien du panneau de protection HP.
gilles b.
Vraiment bon et bien conçu pour le prix ^^
Ce petit boitier Fosi X5 remplace avec efficacité un pré ampli phono Cambridge Azur 551P qui a un étage de pré amplification en classe A, ce X5 en version d'origine rivalise sans aucun soucis avec le 551P en plaçant le gain sur 38, si je commute le gain sur 48 j'obtiens une meilleure dynamique pour aborder mon pré ampli Lpass2 Prime (classe A) et en effet le X5 avec ce gain variable lui permet de se distinguer et d'obtenir un meilleur rendu selon la sensibilité de la cellule mais aussi de mieux s'adapter aux périphériques en aval (pré ampli et ampli de puissance), donc je trouve judicieux de la part de la marque Fosi d'avoir mis un sélecteur de gain qui rend le X5 plus flexible.
Je n'ai pas pu résister à la tentation de le faire évoluer, en remplaçant le banal opa 5532 qui est monté sur un socket dip8 et si vous êtes méticuleux je vous invite à le faire car l'opération d'ouverture du boitier reste assez simple, mais avant tout bénéfique quand on a la possibilité d'avoir en stock plusieurs types d'opa, j'ai donc testé 2 opa soit le LM49720 et le Burr Brown 2134.
Pour effectuer ce comparatif, j'ai choisi un morceau assez chargé en quantité d'instruments, et surtout avec une excellente prise de son, j'ai utilisé le logiciel Audacity avec ma carte son Roland et j'ai donc enregistré 2 fichiers audio en WAV que j'ai pu par la suite comparer en ouvrant les 2 fichiers dans un lecteur et en switchant de l'un à l'autre, puisque la commutation entre les 2 fichiers était rapide et efficace car mon comparatif a été concentré sur les 30 premières secondes du morceau qui comportait une introduction à la trompette et d'autres instruments qui venaient se greffer pour compléter la scène sonore.
J'ai exclus l'opa 5532 monté d'origine car il n'a aucun intérêt dans ce comparatif, toutefois le 5532 me servira de point de repère pour constituer une comparaison entre: 5532 VS LM49720 / 5532 VS BB2134 / et LM4972 VS BB2134.
5532 VS LM49720: le LM49720 apporte une dynamique largement supérieure au 5532, plus de matières mais le LM49720 propose à peine plus de précision et de détails car même si il est plus dynamique, le placement des instruments reste à l'identique du 5532, c'est plat et bien droit comme message sonore projeté mais çà manque de vie, en déduction le LM49720 apporte guère mieux que le 5532 hormis la dynamique et à peine plus de précision, le choix de mettre LM49720 dans le Fosi X5 ne me semble pas cohérent pour une si faible amélioration.
5532 VS BB2134: le BB2134 est sensiblement identique en dynamique au 5532, par contre il apporte tellement plus dans sa manière de détailler la musique que je ne vais pas m'étendre plus que çà car le 5532 n'est pas du tout à la hauteur pour tenter de rivaliser avec le BB2134 qui fait tellement mieux !! déjà on peut vite constater les limites du 5532 qui a mon goût est loin d'être assimilable à la catégorie de la musique haute définition, toutefois on trouve de nos jours le 5532 dans 90% des appareils d'entrée de gamme mais il bride tout simplement les performances.
LM49720 VS BB2134: le LM49720 conforte son aspect dynamique supérieur au BB2134 tout comme avec le 5532, mais c'est le seul point fort pour celui ci puisque je trouve que le LM49720 est trop brouillon en le comparant au BB2134, le morceau choisit débute avec un jeu de batterie qui passe de la gauche vers la droite puis il est suivi par la trompette avec des notes qui raisonnent avec un bel effet de sustain (maintien de la note jouée) et j'avais ce point repère grâce à la version CD qui respecte ces détails, cas de figure avec le LM49720 l'effet de stéréo de la batterie qui passe de gauche à droite est quasiment inexistant mais le pire c'est qu'il écourte la durée des notes de la trompette et là c'est la catastrophe car çà ne sonne pas naturel, pour autant le 5532 fait exactement la même chose avec une dynamique moindre.
Le BB2134 respecte la musique, en reproduisant à la perfection l'effet stéréo du jeu de la gauche vers la droite de la batterie, en maintenant la résonnance de chaque note de la trompette et surtout en respectant le timbre de la trompette qui sonne vraiment en merveille, car avec mes enceintes KLIPSCH RF5 (filtres full tweak Mundorf Suprême) une trompette qui sonne mal timbré avec les pavillons d'aigu et le haut rendement ! çà peut vite devenir difficile à écouter.
En conclusion, je suis très satisfait de ce Fosi X5 et encore plus enjoué quand je l'écoute avec le BB2134 qui apporte une belle évolution sonore, donc pour ma part je le considère comme un très bon rapport qualité surtout si on rajoute la modeste somme déboursée pour se procurer un opa BB2134, cet ensemble à faible coût n'a aucun soucis pour se distinguer de la concurrence quand on tient compte de la qualité des composants embarqués et en tenant compte aussi du sélecteur de gain qui est utile et rend le Fosi X5 adaptable dans un grand nombre de configuration possible.
