AUDIOPHONICS Active Trigger Sequencer 1 IN / 4 OUT 12V
This active trigger sequencer is hand-assembled in our Audiophonics workshop. It avoids plocks and current peaks in order to switch on and off a chain of several Hi-Fi devices.
Reference : 20930
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 01-12-2026.
Audiophonics Active Trigger Sequencer1 IN / 4 OUT 12V
Photo du Audiophonics Trigger Séquenceur Actif
This active trigger sequencer is hand-assembled in our Audiophonics workshop. It avoids plocks and current peaks in order to switch on and off a chain of several Hi-Fi devices. It features two operating modes: SLOW/FAST, depending on the desired effect. To avoid plocks and current peaks, it's best to use the SLOW mode. To simply avoid a current peak, FAST mode is sufficient.
This active sequencer trigger also has two other advantages:
    • Even if you input 5V, you can output 12V on all outputs.
    • Output current is also boosted. While your source device delivers a low current via its trigger out connector, the active trigger sequencer delivers a current that depends on its power supply. For example, the supplied power supply delivers a current of 1A, so you'll find 250mA per trigger output. If you need more, you can go up to 1A per trigger output by changing the power supply. In this case, opt for a 12V 4A power supply. This can be used, for example, to power LED lighting or a home cinema screen.
L'intérieur du Audiophonics Trigger Séquenceur Actif
Audiophonics active trigger sequencer overview
Aperçu du Trigger Séquenceur Actif Audiophonics
1Trigger input 3.5mm jack 2V-20V
2#1 Trigger output jack 3.5mm 12VV
3#2 Trigger output jack 3.5mm 12V
4#3 Trigger output jack 3.5mm 12V
5#4 Trigger output jack 3.5mm 12V
6SLOW/FAST mode switch
712V power supply
Sequence times
Trigger output #1 starts instantly in any operating mode. In SLOW mode, #2 will activate 2 seconds later, followed by #3 and #4 at intervals of 1 second each. In FAST mode, outputs #2 #3 #4 will each activate at 300 millisecond intervals.
Sequence time diagram
Product typeTrigger sequencer
Input1x 3.5mm jack 2V-20V trigger input
Outputs4x 3.5mm  jack 12V trigger output
Operating modeSLOW/FAST
Sequence timingSLOW: 2sec - 1 sec - 1 sec
FAST: 300ms - 300ms - 300ms
Alimentation12V via jack DC
Dimensions80 x 50 x 25cm
Weight65g
Package1x Audiophonics trigger active sequencer
1x 12V 1A power adapter
6 reviews
Fantastic device
I needed to trigger two amplifiers at the same time, and the preamp trigger had not enough power, with this device power is more than enough and the problem is solved, been working for some time flawlessly. Thank you
This review has been posted for AUDIOPHONICS Active Trigger Sequencer 1 IN / 4 OUT 12V
Small but a life saver
Plug it and works flawlessly, jack 1 trigger imediatly , jack 2 has 2 sec delay, 3 and 4 plus 1 second delay each. Awesome feature. Tested one port 200mA can trigger 2 fosi ZA3 at the same time which means 100mA each. Box is small also nice
I am very satisfied with the purchase. I had to slightly modify the device by increasing the capacitance of capacitor C1 in order to delay the trigger activation. It would benefit from having a potentiometer to allow for such adjustment (I needed an 8-second delay). However, for the price, the device itself is very neatly and solidly made. It has an aluminum enclosure and LEDs indicating the activation of individual outputs. I definitely recommend it. Also, the shipping to Poland was fast.
Smart little helper
Very well designed and built simple little tool to start all your equipment at once but in the order desired.
Too bad it does not want to turn on my Aiyama T20 pre-amp with its notoriously picky trigger function. Any solutions to this would be very welcome!
Just the thing I have been looking for!
A simple and cheap solution to a problem of not having enough trigger outputs on my preamp. Now I can power on all my devices at once. The slightly delayed "soft start" is nice addition! Perfect little box and works just as promised.
This active trigger sequencer is hand-assembled in our Audiophonics workshop. It avoids plocks and current peaks in order to switch on and off a...
