David C.
Avant de...
Niels G.
Solid performer
Miguel O.
Satisfaction totale
Le gain est...
Customers reviews - There are 19668 reviews.
Pascal L.
Très bon produit, recommandable sans hésitation.
Produit de qualité professionnelle, bon verrouillage. Respect du message sonore. Permet d’utiliser une sortie Dac, pré ampli ou lecteur CD , lecteur réseau pour se raccorder à un élément ne possédant que des entrées RCA en utilisant n’importe quel câble RCA / RCA du commerce. Très bon résultat audio obtenu avec des câbles de plusieurs fabriquants reconnus dans le monde audiophile. Accessoire recommandé en l'absence de possibilité de raccordement total en XLR.
Patrick V.
White SPI / IIC 256x64 OLED 3.12" screen Here is a very elegant 3.12 "256x64 OLED screen with superb brightness and excellent readability. It is already mounted on its PCB with a soldered connector.
My review on the White SPI display
Nice display, once I got it to work. if you use this display with an RPI4 equipped with Volumio or Roon or LMS it is probably a breeze to get it to work. Plug and play. One thing to look out for is the 16 pins flatcable connector that can be fitted in two ways on the display. The cable keying (triangle indicating pin 1 on the connector) should be connected to pin 15 of the display. something to look out for.
I tested the display using the python luma driver with the following test code:
from luma.core.interface.serial import spi
from luma.core.render import canvas
from luma.oled.device import ssd1306, ssd1322,ssd1325, sh1106
from time import sleep
import RPi.GPIO as GPIO
serial = spi(device=0,port=0,gpio_DC=27,gpio_RST=24)
device = ssd1322(serial, rotate=0)
# Box and text rendered in portrait mode
with canvas(device) as draw:
draw.rectangle(device.bounding_box, outline="white", fill="black")
draw.text((10, 10), "Hello World", fill="white")
sleep(10)
The GPIO pins mentioned in the code above were determined after measuring the pins from CN4 all the way to the Pi pins.
An improvement would be to add a column to the display specs on the website indicating what PI pins are used. Now I had to measure them myselve.
Jean-François V.
AUDIO-GD MASTER 1 Pure Class A RCA XLR ACSS Balanced Preamplifier With this Master-1, Audio-GD offers one of the best preamplifiers in the world, integrating the quintessence of audio technolohy KEY POINTS: Symmetrical design Class...
Oui, mais !
Eh bien voilà, j’ai ce pré-ampli qui obtient toujours des louanges dithyrambiques sur les forums, pour le moment j’en suis satisfait, mais hélas, pas totalement !
Il y a comme un manque dans la retranscription de la musique ou tout du moins, dans certaines….
En effet, comme souvent dans les produits chinois, le haut médium/ aigu est très satisfaisant. C’est clair, net, précis, jamais agressif (ouf)très ample, mais en ce qui concerne le bas médium ainsi que les basses, je reste un peu sur ma faim. Mon précèdent pré-ampli à tubes pourtant faisait mieux, ça descendait plus bas, les basses étaient plus abondantes
Moralité, si vous voulez écouter du gros son, ce n’est pas ce matériel qu’il faut choisir…
Patrick V.
AUDIOPHONICS Kit Aluminium case and accessories for EVO-SABRE DAC Black Housing & accessory kit to install and give a professional finish to your DIY projects based on the balanced DAC EVO SABRE Audiophonics. 100% aluminum construction.
Well designed robust case
This is a perfectly designed and robust case. The DAC board, the two displays and the Pi fit like a glove when assembled. The kit has been delivered completely without any missing parts, like screws spacers washers. I will place a review on the DAC board and white screen seperately.
Robert g.
Very nice DIY budget chassis with slim profile
This galaxy GX348, is very well designed and finished product.
When assembled, it fits to perfection, with no glitches. Aluminum parts are finished very well. Side could be flipped just for desing variations, and could be used as heatsinks. Front and back plates are well brushed and anodized, and easily to drill/mill.
This is my second GX chassis I purchased - for an AKM 4499 DAC project - and I am very content of both (first hosts a full valve phono stage).
Only one problem: the last chassis was not well packed ( weak protection on the sides ), and 2 corners of the bottom plate were slightly bent at transport :((
Hope next time audiophonics will be more careful when dispatching these GX chassis, to properly protect them inside the box !
That's why I will give 4 * only rating.
Robert g.
Decent looking solid aluminum feet
Nice decent black finish, and good anti-slick patches on top/bottom.
Maybe not the ultimate surface finish, but theses are under the base plate.
Good deal for the price.
Robert g.
Good power on/off button with nice finish
Well build (full aluminum case), not obtrusive design, flat profile as seen from the side, nice and smooth click feeling, and nice black finish. It comes with a silicon o-ring for perfect mounting. Could fit even a 10 mm face plate, if needed. Recommended.
Robert g.
Amazing value USB /SPDIF interface for DAC
Me and my friend bought this module when catching a promo. Until that moment I was using GUSTARD U12 32Bit / 384KHz USB XMOS DSD. I just build a small thick walled (4mm) alu chassis for this module, and served the power supply voltage separated from the USB cable, by using an audiophonics usb separator cable, and an external no-fancy well made smps wall power supply. The module need some serious burn in , be aware. Once this settled, the sound quality is top notch.
First of all, what pleased me was the resolution, control and the depth of the lowest register! Also, the dynamics rendering is superb. Soundstage is very correctly rendered, with no exaggeration, you could detect easily instruments locations (separation of sound sources is good), with a very good sense of depth. The timbres of acoustic instruments are reproduced faithfully, a must in classical music auditions. The attack on aggressive well mastered tracks (percussion instruments, or plucked classical instruments) is as should be. Human voices sound natural, without being harsh or on the analytical side. Also, large scale recordings ( big classical orchestras) are a joy to listen.
Just a brief example: the first track on Erato CD 'Joyce DiDonato - 2014 - Stella di Napoli' it's enough to check for making an idea on how Hecate LT knows how to shine. This Hecate LT thrashed away the good old Gustrad, which was a good companion.
Be aware, this Hecate LT works very well on I2S, as me and my friend tested it with top DAC, if wanted to implement inside the DAC chassis.
If wanted just for the SPDIF use, buy the finished in chassis version, it worth the difference :)
For Daphile/ Roon users: Hecate LT works like a charm on Linux based audio players without drivers.
Highly recommended!!!
Robert g.
Top class chassis full aluminum
This is a very nice designed full aluminum chassis, with a remarkable quality of finishes, both for the solid thick aluminum faceplate and for the anodizing of the rest of the case plates. Also, the shape and finish of the massive ALU knobs (delivered in the package) is outstanding. For the front plate, the cut-out is exactly dimensioned for 'TEK Vomit backlight white dB with calibration module' (but check with the store support for accuracy), as the front plate has the exactly window cut-out for the TEK Vu-meters, but it also has the necessary cut-out milled on the back of the front panel for the shape of the VU-meter plastic box.
The bottom and back plates are not hard, but very easy to drill/mill for the needed holes. In my case, the chassis hosts a led biased Mu-follower line preamplifier based on E88CC.
Highly recommended!
Robert g.
Decent sturdy chassis for big amps
This is a perfect low cost/ high quality DIY chassis for big projects, if you are using amp modules that have already the PCB mounted onto the heatsinks. Internal volume for 4U- 300mm/400mm depth is so big, that you could build a 5+1 amplifier inside easily by using ready heat-sinked modules. I was using it to re-box an Anthem 225 amplifier, and all the elements has space to cool inside. I was using the spare top
'HIFI 2000 Perforated housing cover 19 "300mm' to allow air circulation.
As the box cannot bear a massive weight on it's own in basic version, my advise is to use this spare bottom: 'HIFI 2000 Inner baseplate 425x260mm (300mm Series)', or to reinforce the chassis base with some L aluminum profiles. It was not my case, as the bottom was reinforced by the 2 massive heat-sinks of Anthem modules. The finish of the 4mm face plate is top notch! Also, the black matte anti-scratch paint of the top/bottom covers is of good quality. The bottom and back-plate steel is easy to process (drilling, milling), as the material does not have a high hardness. Despite the chassis seems to flex without the top cover mounted, when assembled, the whole structure become rock solid! My project weights about 15 Kg, and the box is like a rock-stone once assembled. Highly recommended for tight budget projects.
jean jacques m.
Très bon cable coaxial
Je recommande sans hésiter.
jean jacques m.
extraordinaire carte son
superbe carte avec une sonorité époustouflante.
livraison super rapide.Je recommande+++
Olivier R.
Produit plus en stock mais remplacé rapidement par son petit frère en 3m par Audiophonics (merci pour la réactivité !)
A l'air solide et de bonne facture, fonctionne bien, très satisfait.
Olivier R.
Fonctionne très bien
Acheté pour sonoriser deux PC sans encombrer (un sur l'entrée USB et l'autre sur l'entrée AUX), ça fonctionne très bien.
Petit bémol, impossible de configurer la sortie numérique coaxiale sous Windows 10 (son saturé qui craque), mais la même machine s'en sort parfaitement sous Linux donc à priori pas un problème de l'ampli. On s'en sort avec l'entrée AUX qui suffit largement à mon usage.
Très satisfait.
Holger B.
TINYSINE AUDIO-B PLUS TWS Bluetooth Audio Receiver Module TWS aptX Stereo / Double Mono If you want to build a Bluetooth amplifier simply and stream your music from your smartphone, then the TinySine AudioB Plus module is an excellent choice. Its particularity is...
bitz
Works.
But beware, the aux in is a simple (mechanical) switch on the aux plug. This is different than the i2s module from tinysine. Works only on the module, you can't use a extention cable.
Marc F.
Isolation de charge indispensable
Ce transfo est indispensable pour toute conversion de montage As/symétrique . C'est un transfo audio transparent du signal entre niveaux hauts/bas. Il autorise le montage en inverse avec brio. Interrupteur de boucle de masse à prévoir. Très bon Item
Marc F.
Haute Qualité du micro de mesure
J'ai chargé le fichier de calibration sur le site de Dayton, cet équipement se combine parfaitement avec REW6 comme outil de mesure. J'ai vérifié la mesure origine avec un calibrateur de micro et multimètre Labo , tout identique. Coffret complet.
Giuseppe B.
Ottima
Costa il giusto e suona molto bene (nel mio caso simile ad un modello rodiato).
Ottimo soundstage e controllo sul basso.
So bene che non è rame ma il mio udito ha dato il responso e paragonata ad altre spine ben più costose spesso si lascia preferire.
Juergen N.
Great device!
This is a great tool for the raspberry pi. I even used it with an Allo USBridge Signature. connecting to a DAC with I2S sounds even better than with USB. Just ordering the FiFo from IAN Canada to get a precise clock.
MICHEL B.
NEOTECH NEMOI-1220 Dual Shielded UP-OCC Silver Interconnect Cable RCA-RCA Ø 10mm 2m (Pair) The NEMOI series from the manufacturer Neotech is the result of extensive research in the field of audio cable. The Neotech NEMOI 1220 modulation cable, combining PTFE...
Excellent câble RCa, mais cher
Ce câble est très neutre, c'est parfait, et sa résolution sur les voix est absolument extraordinaire.
Les personnes qui parlent semblent présentes dans la pièce (auditorium de 34 m2).
Les instruments de musique brillent par leur présence.
Donc le plus par rapport à un câble Sommercable Epilogue est bien là, mais la différence de prix aussi.
Je pense que cela vaut la peine sur du matériel très haut de gamme (Cabasse Colonne 135 et amplis McIntosh).
Merci à Audiophonics pour le suivi de l'approvisionnement qui a posé quelques problèmes suite à cet afreux virus COVID 19.
Franck L.
Serrage inefficace.
Personnellement je les soude et là j'en suis satisfait.
Jean-David R.
Très content
Utilisé dans un système full tube déjà conséquent après avoir essayé de câbles de marques bien connu et plus chère, j'approuve au vu de son prix ce HP-25OCC.
- Il a complétement effacer cette dureté dans les aigus, sans enlever de dynamique ou de détails.
- Les voix et les instruments se place et se distingue mieux sans confusion même avec beaucoup de son. Meilleur placement.
- Les basses sont tenu et percute sans excès.
Globalement c'est un câble plutôt posé, analytique et facile à intégrer. il ressemble plus à une écoute de mélomane que de hifiste mais n'Est-ce pas la l'intérêt ? écouter sans ce poser de question !!!! ce câble les fait ROYALEMENT !!!!!!
Franck S.
AUDIOPHONICS BT60DSP Amplifier TPA3116 Bluetooth 2x50W / 4 Ohm The BT60DSP is a revised and corrected version of the excellent BT60W amplifier, with elements of DSP processor and without volume control.
Bluffant
Pour amplifier une paire de QA3010 comme système Hifi de bureau. Il est connecté à un convertisseur USB Fostex équipé d'un contrôleur de volume.
Extra vu le budget.
Aurélien D.
Très correct pour le prix
Petit préamp sans prétention qui dépanne bien. J'ai essayé 4-5 paires de tubes dessus (Mullard, RCA,...) et des opamp plus haut de gamme pour le fun et il se défend bien. Contrairement à d'autres avis je ne pense qu'il fasse mieux que mes autres préamplis.
Face à un rotel RC972: Le FX-Audio a un bruit de fond sensiblement plus élevé et moins de dynamique. Il est un peu plus "rond" suivant les tubes. Différent mais clairement pas mieux.
Face à Luxman CL34 : Le tube-03 ne lui arrive pas à la cheville. Tout est moins bien. Le prix est beaucoup plus faible que le Luxman mais ca s'entend.
En résumé c'est un bon petit préamp compact et économique mais ca s'arrête là. Pensez à allumer votre ampli en dernier et à l'éteindre en premier si vous souhaitez éviter un "plop" désagréable dans vos haut parleurs.
Bruno C.
ALLO boitier pour DigiOne et Pi 3
Le rapport qualité / prix est très bien.
Je suis pas très bon bricoleur, mais sur Internet on peut trouver des video de montage ... bref, montage facile et clair.
Seul petit regret : non transparent : suivi visuel des leds impossible.
Enea S.
Not bad at all
I needed a digital out to feed my external DAC. I used Spdif cable (have not tried the optical) and it sounds pretty good. Before I was using the hdmi cable through the tv optical out, It definetry improved the sound: more detailed. bass very accurete and deep. I think it needs somme time to wear out ...
FREDERIC G.
Très bon dac
Je suis satisfait du résultat et donc de l'association avec mes JMR bliss.
Le son est très propre et précis. Les basses sont également très bonnes.
Je l'utilise principalement en usb mais je le trouve aussi très bon en bluetooth (En partant du principe qu'il y a une compression). En effet le son garde sa clarté ce qui est très appréciable sur ce mode (tv connecté dans ce mode). Curieusement je le trouve moins clair et précis sur l'optique (console connecté).
Dans l'ensemble je suis donc très satisfait et quelle présence quand le son sort des enceintes !
Compléments
Je suis toujours aussi satisfait de ce DSP.
Avec le recul, je complèterais mon avis en revenant sur l'interface androïde dont l'utilisation n'est pas des plus précise, surtout lors de l'utilisation des curseurs gain +/- ou facteur Q où il n'est pas possible à l'instar du réglage des fréquences, de renter une valeur.
Il est possible de choisir l'unité pour le réglage du delay en ms ou en cm (en " aussi).
En ms il y a le possibilité d'incrémenter de 385 réglages différents par pas de 0.0208ms alors qu'en cm, cette incrémentation est de 277 par pas de 1cm.
Je croyait que les deux évoluaient symétriquement, mais non.
Le réglage en ms est donc plus "précis" (de la à percevoir des différences)
Plus dans le domaine des suggestions, 3 voies et 10 fréquence pour chacune, j'aurais réparti les fréquences différemment en attribuant plus de fréquence au médium.
Par exemple sur les 30 dispos j'en aurais réservé 7 pour le grave qui demande dans mon cas moins d'intervention, 16 pour le médium qui demande lui plus fréquence et 7 pour l'aigu.
Pour une configuration active avec des coupures à 300/4000HZ par exemple je pense que ça aurais pu le faire.
Je suis en trois voies, mais en passif sur le passe bas et passe haut du médium/aigu, je dois donc utiliser une voies du DSP pour le mid/high donc ma coupure basse étant à 100hz 10 bandes de 100hz à 20khz, c'est un peu juste, ça oblige à faire des choix.
Dernières précisions, si vous voulez intervenir sur le 20khz, il faut lorsque l'on tape sur le clavier virtuel la fréquence, rentrer 19999.
J'ai intégré mon DSP avec sa clef bluetooth dans un coffret métallique, cela limite chez moi la porté BT à quelques mètres 5 environ.
Gilles J.
Boitier capot
Belle fabrication, facile à travailler, taille réduite, excellent rapport Q/P.
Joanny B.
Potentiomètres ALPS 50K log
Très bien.
Livraison très rapide de Audiophonics en Colissimo. Colis livré, le surlendemain de la commande, dans la boîte aux lettres, sans signature.
Emballage de qualité.
Cyril M.
Efficace et pas cher, c'est Canare que je préfère.
Je voulais un câble isolé pour relier mon DAC arcam rPac et mon ampli SMSL SA300. Après m'être pris la tête pour savoir quelle était la meilleur option (du pas cher jusqu'à des prix franchement abusifs), j'ai contacté le service client Audiophonics qui m'a conseillé cette solution.
Pour 40€, rapport Q/P impeccable. Je recommande chaudement ce câble ET les conseils d'Audiophonics.
Jonathan D.
Excellente prise qui se démonte complètement pour facilité le montage de gros câble (rigide sur une petite longueur) dans mon cas le YARBO SP-1100PW, très satisfait.
A B.
Je suis parti sur cet cable pour relier mon Bluesound Node 2i et Dac Soncoz SGD1. Le son est très équilibré neutre et bien raffiné avec un charme analogue. Un équilibre général et un plaisir d’ecoute.
Luis G.
Produit exceptionnel.
Il diffère des auteurs DAC par une qualité sonore supérieure. Grâce au FPGA ALTERA MAX2 avec deux cristaux 44,1x et 48x. supprimer le jitter des entrées USB, Raspberry PI ou Bluetooth.
De nos jours, c'est un grand avantage d'avoir un DAC avec entrée IP sans jitter. Avec radio Internet et musique NAS.
C'était très facile à faire pour moi.
A B.
Fiches de qualité et facile à monter, vraiment très belle finition. Le système blocage banane est efficace. Je les utilise personnellement avec Audioquest Rocket 11 et j'ai obtenu des très bonnes résultats. Un petit rodage de deux jours est nécessaire.
Bruno P.
Ce câble prends place à des Sommercable Ele­phant de 6 ans et tout vient de se réveiller sur mes Elipson Prestige 5(2008) en bi-ampli et mes klipsch rb-81 mk2(2014) bi-ampli. Le son est équilibré doux aéré, un son vivant qui fait du bien de l'aigu au grave. Les yeux fermés vous pouvez.
Patrick R.
TUNG-SOL 12AU7 / ECC82 Tubes (Unit) The Tung-Sol 12AU7, manufactured in Russia, ensures very low noise. It has been designed to mimic the performance of American NOS 6189 tubes. This one proposes an open...
Superbe restitution
En remplacement d'un tube Sylvania (déjà très supérieur à un autre tube Chinois "no name"), ce Tung-Sol après quelque heures m'apparait comme étant très détaillé, précis et dynamique. Installé dans un ampli casque mono-lampe.
Jonathan D.
Pour moi le Top
Très bon câble d'une très bonne qualité de fabrication, très satisfait. Merci à Audiophonics.
Jonathan D.
Très bon câble d'une très bonne qualité de fabrication, très satisfait. Excellent rapport qualité prix.
Jonathan D.
Au top
Très belle prise d'une très bonne qualité de fabrication, très satisfait.
Jonathan D.
Jonathan D.
Jonathan D.
Damien G.
Pour particulier.....
Pour un usage dans le cadre particulier, ces connecteurs sont de bonnes qualités et ils font très bien le job....il n'y a plus qu'à choisir un bon conducteur (câble) .....
Samuel L.
Superbe Jumper
Livraison rapide, produit au top, mes enceintes fonctionnent encore mieux, le son est plus détaillé, je recommande.
Enceintes : BW 703S2
jean-philippe g.
vraiment top rien a dire
Antoine F.
Power Supply Module 9V 1.3A 12W This small power module delivers a voltage of 9V and a current of 1.3A. Ideal for feeding small systems.
Bloc d'alimentation
Parfait pour remplacer un bloc d'alimentation défectueux. Audiophonics toujours top.
A.j. v.
Impressed
I am using the 2x4HD for a 2.2 system, 2 subwoofers and 2 full range DIY speakers. I found the miniDSP quite easy to install and setup, functionality is outstanding and in terms of sound quality it seems transparent (at least enough for me).
A.j. v.
Excellent value
Very good sounding amplifier and no quality issues detected. I received it within a week which was a welcome surprise.
yannick a.
Caâle USB de bonne facture, que l'on peut rendre très bon !
Genèse d'un câble USB qui apporte un réel plus, à base d'éléments de chez Audiophonics...
Il y a 7 m entre la sortie de mon PC qui assure le rôle de source et l'entrée USB du DAC.
Le but est de concevoir un câble d'une seule pièce, puis de gagner en restitution sonore.
Mission accomplie !
Première étape :
Cable USB OFC PTFE Double Blindage Plaqué Argent Ø7.8mm
VIBORG UA201 Connecteur USB-A 2.0 Mâle Plaqué Or 24k Ø8.5mm
VIBORG UB201 Connecteur USB-B 2.0 Mâle Plaqué Or 24k Ø8.5mm
Je relie le blindage au connecteur uniquement du coté USB A, comme il est d'usage.
Musicalement à ce stade, c'est bon mais il n'y a encore rien d'extraordinaire.
Sur mon installation, j'ai toujours ce petit bruit numérique qu'on entend en poussant un peu le volume de l'ampli :
sans signal délivré par le PC, il y reste ce voile de son.
Je me dis qu'il y doit y avoir moyen d'améliorer cela.
La magie va venir d'un concept de blindage que j'ai voulu tester : JSSG 360
Petite recette DIY pour un câble USB qui a changé mon installation : plus d'ouverture, de dynamique.
Plus de finesse dans les instruments, de micro détails qui apparaissent et un bruit de fond réduit à néant.
NB : le plus simple est de faire toutes les opérations qui suivent avant de souder les connecteurs USB-A et USB-B.
Deuxième étape :
Glisser autour de la gaine jaune du câble USB une 1ère gaine de blindage tressée.
ELECAUDIO GC-0410 Gaine de blindage tressée 100% Cuivre 4-10mm
La gaine de blindage ne doit toucher ni les extrémités du câble, ni les (futures) prises USB.
C'est curieux, un blindage qui n'est relié électriquement à rien...
Justement !
J'ai laissé environ 1 cm sans gaine de blindage à chaque extrémité du câble USB.
(prévoir plus d'1 cm si vous soudez les prises après et que vous avez besoin de dénuder le câble USB pour accéder aux 4 fils Vcc, d+, d- et 0V).
On peut utiliser de la gaine thermorétractable ou du scotch électrique pour fixer les extrémités de cette 1ère gaine de blindage à l'isolant jaune du câble USB.
Ensuite, on glisse au dessus une gaine isolante, plus courte.
ELECAUDIO SG-03 Gaine Tressée Extensible Nylon (PET) 06-11mm
J'ai laissé environ 5 cm de gaine de blindage non recouverte à chaque extrémité.
J'ai donc maintenant 5 cm de gaine de blindage visible à chaque extrémité du câble.
Là encore, scotch ou gaine thermo pour fixer les extrémités de cette gaine isolante.
Puis par dessus la 2ème gaine de blindage, qui doit recouvrir entièrement la 1ère gaine de blindage.
scotch, gaine thermo...
Et enfin, la dernière gaine isolante qui recouvre toute la longueur du câble USB cette fois.
Gaine thermo pour que ça soit joli et que rien ne bouge, et en longueur suffisante pour bien écraser les 5 cm de gaine de blindage en dessous.
En résumé, on crée autour du câble USB un blindage double, connecté électriquement à ses 2 extrémités, mais flottant.
Flottant, c'est à dire qu'il n'est connecté à aucun potentiel électrique.
Ni à la masse.
A rien.
Ce type de montage peut aussi s'utiliser sur les câbles réseau, et on trouve dans le commerce des câbles tous prêts (mais à prix conséquents) avec ce double blindage flottant.
Bonne écoute !
