Krzysztof K.
Good HDMI Cable, indeed!
Hey, folks!
Urtsua R.
Fine
Ruben P.
Audiophile grade +
Customers reviews - There are 19423 reviews.
quelle belle couleur !
recâblage complet 6 cordons, 50cm, avec XRL amphenol, sur système trois amplis pilotés par minidsp: la conception de ce câble est tout simplement étonnante. et le résultat musical ne l'est pas moins. superbe de naturel et de justesse.
antoine L.
cable secteur viablue x 40
c'est vrai que lors dés premieres ecoutes, ce cable désoriente un peu, il y a le coté violon désaccordé, assez long à roder, actuellement j'en suis entierement satisfait , il est branché sur un ampli à tubes qui alimentent deux enceintes Martin Logan, les hauts mediums sont trés lumineux sans aucune agressivité, il est évident qu'un cable secteur ne va pas corriger un système qui est mal équilibré,
Paulo A.
Fantastic DAC
This an absolute huge sounding dac! This small and budget dac it's a true bargain. The sound is warm, pure and a joy. I use it with an fiio br 13 streamer with ldac and it sounds great, with an cd player and greater. It is crystal clear sound ... absolutely amazing in treble and mids ... not basier but you'll notice the bass. In terms of soundstage is also very good. I simply love this dac. My small and budget system sound much better with it: Fiio Br 13 streamer, xduuo 605 tube amp, and Roth Audio speakers. So If you need an budget dac with great, warm, rich, controlled sound buy this one, and you will ear the diference in sound as soon as you turn it on.
Paulius S.
Naturally sounding connector.
Benjamin M.
What a DAC!
After reading a lot of reviews and videos... I made the jump from my sub 1.000€ to this one. A friend of mine was so kind to give me for comparing a +/- 2.500€ R2R DAC.
Apart from the none existing input selection and the on/off button... the Cyan 2 is just better sounding.
It's clearer, deeper soundstage, more control and dryer punch in the Bass and more detailed (less laid back).
A fantastic device from Holo Audio!
Benjamin M.
Yes!
I was looking for a nice USB cable and in touch with David Albert from the support team. He told that I should go for a silver cable, even with the digital ones.
Ok, so I looked and found this Audiophonics own USB cable. For a reasonable price and an awesome finish.
This cable makes a difference to my OFC copper one that I had before. It's just better!
Thanks!
Benjamin M.
Just... awesome!
I was looking for a good XLR cable and in touch with David Albert from the support team. Thanks to his explanation I made the jump from a 100€ to this real high end cable. And the result is awesome! This cable is crystal clear, spacious, dynamic and with deep punch sounding. Well sounding is the wrong word for a cable, this one just let the music flow how it should be.
Fantastic!
ALEXANDROS M.
.. with babyface pro, need to upgrade the cable that comes with
Jb A.
Très qualitatif, quelques manips à faire pour Roon cependant
La hifi étant un monde de requins, il est difficile de trouver un streamer, dont le rôle est pourtant simple, qui ne soit pas une boîte vide ou remplie de trucs inutiles à des milliers d'euros, ou à l'inverse un tas de plastique avec un adaptateur secteur 12V pourri.
Merci donc à HOLO pour cette brique massive, proprement alimentée, relativement facile d'usage et qui tient presque toutes ses promesses. Je dis "presque" car contrairement à ce qui est indiqué, il n'est pas Roon Ready (en tout cas pas chez moi), à moins d'installer Ropieee. Si cela fait peur à certains d'entre vous, comme cela m'effrayait (aucune envie de faire de l'informatique), Audiophonics m'a guidé et ça prend 5 minutes. Il faut flasher une carte SD (15 euros de matériel) et voilà, vous avez un OS pour Roon et un OS pour les autres protocoles, il suffit de démarrer la machine avec la carte qui vous convient insérée à l'arrière. Si vous aimez passer rapidement de Roon à l'UPNP, ce ne sera peut-être pas la machine idéale. Si vous utilisez UN logiciel (Audirvana dans mon cas), vous pouvez y aller les yeux fermés. J'ai du mal à comprendre pourquoi il faudrait dépenser plus, à moins de vouloir un traitement du signal numérique au niveau du streamer, ce que je ne veux pas. La machine transpire la qualité.
Stephane R.
EIZZ EZ-901 Fuse Holder Silver Plated 5x20mm 250V 15A This high quality 5x20mm Eizz EZ-901 fuse holder uses silver plated contacts, ensuring excellent conductivity and durability. Its spring-loaded center pin promotes optimal contact.
Qualité !
Très bonne qualité que ce porte fusible : remplacé sur mon parasound A21, le diamètre est parfaitement adapté la soudure en périphérie se fait sans difficulté majeur. L'isolant central blanc est en téflon donc sans déformation au moment de la soudure. Quand on utilise un fusible de qualité (comme pour moi) il est a mon avis plus que souhaitable d'avoir le porte fusible en conséquence.
Michel V.
Correct
Fait son job mais pas de quoi se relever la nuit, non plus. Le grave manque de modulation et les voix sont très larges. Pas très crédible. Mais c’est ok comme petit Dac de dépannage.
George C.
Best Overall
Excellent again all the transaction with the shop.
Attila R.
XANGSANE DC05 Power Cable Jack DC 2.1mm to Jack DC 2.1mm Gold-plated 0.5m This 0.5-meter jack DC 5.5/2.1mm to Jack DC 5.5/2.1mm power cable features an OCC silver-plated copper core for maximum conductivity. PVC insulation is added before a textile...
OK, but not gold plated
This cable is good quality. I have replaced my old cable from the supercapacitors to my ethernet switch and it brought surprisingly a better sound to the system. I don't know why, but it helped.
The connectors on the end are NOT gold plated, so I cannot give 5 stars. For the money, this is definitely a good buy though.
Attila R.
Transparency!!!
I have replaced my old RCA interconnects with this cable, terminated with ETI Brio (Rhodium plated) connectors. I have used the blue pair as signal conductor, and the solid copper red wire for the grounding connection. I have used a tiny silver cable soldered to the shielding of the cable to SEPARATELY ground the shielding. (I have a grounding terminal on my Puritan power conditioner so it was easy to drain the sheild there.)
It is very very good quality as you might expect. It is also easy to work with, it was relatively painless to build my own RCA cable.
As for the sound, one word comes to mind: TRANSPARENCY. It lowered the noise floor and have brought more separation to the "layers" of sounds, more detail too. At first it sounds like it has a bit less bass but in reality it tightened the bass and have provided more realism. As you can tell I am super happy with this cable and I will buying more to building XLR cables in the future.
I highly, highly recommend the NEI-3001G if you need a transparent, high-end sound.
Attila R.
Perfect!
I use it for grounding connection and it is AMAZING. Easy to bend, can be stripped easily and has amazing quality. I will surely buy more, cannot beat it for the price.
Mathieu S.
Remplace allègrement mes câbles très haut de gamme
Sur les recommandations d'un amis , j'ai équipé tous mes composants avec ce câble , et après une période de Rodage d'une vingtaine d'heure , ces câbles ont tous simplement changer radicalement mon système.
Les graves , le détourage des instruments et la scene sonore ont tous été bonifiés de façon extrêmement significative. Bref mes câbles précédent ont été renvoyés au rang de reliques. Merci à audiophonics !
jean michel G.
Embout de bonne qualité, facile à sertir.
Avis
Câble très bien conçu,et très qualitatif.
Avis
alain F.
FOSI AUDIO M03 Class D Amplifier Mono + Subwoofer TPA3255 120W 4 ohm The Fosi Audio M03 subwoofer amplifier is an affordable, compact and powerful compact device. It features a TI TPA3255D2 amplifier chip delivering 120W power at 4 ohms. It...
Ce petit ampli me donne entièrement satisfaction et vient en complément des Supravox 215RTF qui ne descendent pas très bas dans les graves.Je l’utilise avec un caisson de grave passif.Ce petit plus dans le grave est appréciable notamment dans l’écoute du jazz.
En outre, très facile à trouver les bons réglages.
Wayne M.
evo oil
i must say these really bring the crossover sound to another level, they are precise accurate and fast, down side is the size other than that they sound like new speakers
Wayne M.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 33µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
Jantzen
i find the Jantzen caps an all rounder,they make a big differance in the upgrade of speaker crossovers, my fist choice in trust
Wayne M.
Oil caps
i must say these really bring the sound to another level, crossover is precise accurate and fast, sound like new speakers
Wayne M.
Oil caps
i must say these really bring the sound to another lever precise accurate and fast, sound like new speakers
Sandy G.
ENCHANTEE
Très contente de cet achat, la classe A ça s'entend, !..
2x50w sous 8 ohms , garantis en classe A, c'est suffisant .
Même pour maitriser mes enceintes ELIPSON Legacy 3230, qui descendent pourtant assez bas en impédance, et dans les basses.
Associé à un préampli MUSICIAN MONOCEROS, avec utilisation de ses sorties Symétriques et des entrées symétriques, bien sûr, de l'ampli AUDIO GD. C'est peut être le petit reproche à faire à cet ampli, de ne pas posséder d'entrés RCA. Mais AUDIO GD a également une autre entrée "en modulation de courant" ICSS , redoutable parait il...(il faut acheter le préampli associé, de la marque AUDIO GD )pour pouvoir utiliser cette liaison ICSS...Marketing, marketing.!!..)
SUPER PRODUIT.
Patrice P.
LHY AUDIO OCK-2S Master Clock OCXO 10MHz Black The LHY Audio OCK-2S is a high-precision master clock with ultra-low phase noise, designed to minimize sampling errors on high-resolution streams. This clock features six...
Génial !!!
Connectée sur mon streamer RS130 et Dac RD160 de chez Hifi Rose, le gain est significatif. J'utilise des câble coax Amphenol PMR400, c'est tellement mieux que certains câble plus chers que j'ai essayé. Si utilisation en mode sinusoïdale, je conseille de mettre des filtre pas bas BLP-10.7+ au niveau des équipements connectés, l'apport est incroyable.
Patrice P.
Vraiment une bonne prise secteur
Aussi bizarre que cela puisse paraitre, elle remplace sa grande sœur NCF, qui n'était pas du tout "compatible" avec mes câbles Audioquest Hurricane ou Firebird. J'ai retrouvé du calme, plus de sibilances dans les aigues, un bien meilleur équilibre tonal et un son très chaleureux.
La version NCF doit convenir à d'autres câbles, mais certainement pas Audioquest et ses prises en argent
Anthony S.
Great service
Exellect comms, first class delivery (2 days to the UK!), product quality also very good, easy to complete purchase simple GUI, would definiately purchase again
LINDY BLACK LINE Male USB-C 3.1 to Male USB-A 3.1 Cable Gold Plated SuperSpeed+ 10Gbps 5A 0.5m Lindy's Anthra Line cables are high quality products, ideal for professional installations. It is a USB-C male to USB-A male cable. The new USB standard has the USB 3.1 standard...
Excellent câble, 50 cm et 5 ampères c'est parfait
Fini les câbles inutilement trop longs. De plus les audiophiles apprécieront son rapport qualité prix pour relier leurs précieux disques durs aux DAC's et autres streamers.
Frantz G.
IFI AUDIO UNO USB DAC Headphone Amplifier ES9219MQ 32bit 384kHz DSD256 MQA The iFi Audio Uno is a compact DAC and headphone amplifier that easily and efficiently enhances the sound quality of a standard digital source such as a smartphone, tablet or...
IFI AUDIO UNO DAC USB
Ce petit boitier est vraiment indispensable pour écouter de la musique dans de bonnes conditions à partir d'un PC standard, c'est à dire équipé d'un carte son native (ou bien ordinaire). En ce qui me concerne, j'ai l'impression de m'approcher de la qualité CD. Personnellement, je ne replacerai jamais mes CD et vinyles par de la musique en ligne dans le cadre d'une écoute "de salon", mais lorsque je travaille dans mon atelier, c'est vraiment top et ça change vraiment tout !
michel m.
Dac SU-1
Quand même ça marche bien, sous Linux, rien à installer en bit perfect .
Après quelques mois, à l'écoute les basses sont charpentées avec un medium exaltant et un aiguë très naturel.
- Essai avec hiface 1 (que je n'arrive pas à me séparer) sous XP et oui... en kernel streaming, écoute engageante.
Mais une préférence pour l'usb ...
Thomas L.
MINIDSP ADEPT ADC ES9842 Phono Preamplifier with DSP 32bit 192kHz miniDSP ADept is an ADC with phono preamplifier and DSP. It is based on an XMOS interface and an ESS ES9842 Pro conversion chip. This enables it to convert analog signals up to...
Using it with Audacity on Linux to transfer from MD. Care to be taken to have project sample rate matching the source, and the system not loaded with other tasks during recording.
Balázs A.
SMSL DO200 PRO Balanced DAC 12x CS43131 XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD256 MQA/MQA-CD With its DO200 PRO, SMSL breaks new ground and unveils an ultra-high-performance DAC incorporating no less than twelve Cirrus Logic CS43131 DAC chips and an XMOS XU316 USB...
Had a Topping E50 before. This is way more natural sounding, especially in the highs and the mids. Instruments have a realistic timbre. Also has better details and a bigger, more precise soundstage. This is the sound that I wanted. Fantastic DAC!
Gérard M.
DAYTON AUDIO H6512 Wave Guide High Frequencies 16.5 x 30.5cm This horn allows you to tune a high-frequency driver to your listening space without distortion thanks to its unconventional geometric shape and low expansion rate. It ensures...
Belle qualité de fabrication avec un insert en laiton pour le filetage. Aspect de surface très agréable et bien fini.
Résultat très probant. Utilisé avec une compression Perless pas d'effet de projection.
Je recommande !
ISOACOUSTICS GAIA III Vibrations Absorbers Isolators 32kg Ø43x39mm (Set x4) IsoAcoustics Gaia III vibration absorbers improve clarity and soundstaging for speakers or subwoofers weighing 32kg or less. They feature a machined stainless steel body with an...
Depuis que je les ai Installés sous un caisson SVS 3000 la fusion du registre grave avec les enceintes est absolument parfaite , sans aucune modification des réglages ,on peux dire qu'ils ont fait disparaitre le caisson !
robert m.
Robert M
I bought this product for the HDMI-ARC connection. With this SMSL box I could not control the volume level with the remote control of my LG TV. When I checked the small user manual, it is indeed stated that it is not possible to control the volume level with this box. It would be nice if Audifonics could give a more complete description of the products they sell.
Daniel M.
TOPPING PRE90 Balanced / Single-Ended Preamplifier NFCA Black Topping's Pre90 is a high-performance preamplifier based on a fully balanced circuit and high-performance NFCA modules. It also benefits from a high quality volume attenuator...
Pre90
Transparent, dynamic, neutral and easy to listen to with nice strong bass.
One thing that gets in the way is the remote control
Vadim P.
Amazing, unique device
The Topping LA90D amplifier impresses with its excellent sound quality and solid construction. With its powerful features and precise sound reproduction, it is a real asset for every hi-fi enthusiast. What is particularly impressive is the wide sound space and the clear bass reproduction, which takes the listening experience to a new level. It is truly one of the best amplifiers in the world. Recommendation !
DIMOKRITOS D.
Dynamic and very detailed but excessively bright in midrange and highs
It’s a very good option for powered subwoofers, due to its powerful and very well controlled bass, and that is the only reason I gave it three stars. Otherwise, it is a disappointment. Overly bright in the midrange and high frequencies, in an unnatural and unpleasant way, even after long braking-in period. For general use, better go for the Elecaudio CS-361B which remains the emperor of the affordable power cords, being much more balanced, very detailed but in a natural and pleasing way and with phenomenal 3D imaging.
Marcus L.
SMSL DO100 PRO Balanced DAC 2xES9039Q2M XMOS XU316 Bluetooth 5.1 32bit 768kHz DSD512 MQA The SMSL DO100 PRO balanced DAC is an evolution of the DO100 offered by the brand. The DO100 PRO benefits from numerous improvements. It features two ES9039Q2M DAC chips and a...
Amazing value
The performance of this DAC is exceptional for the price - amazing value! It beats most of the DAC’s I’ve either owned or auditioned with the previous generation ESS 9038 Pro. Gone is the hardness in the treble and flat soundstage the held many of them back. Superb!
Just a couple of years ago the performance of this SMSL DO100 Pro would have been associated with exclusive DAC’s from established ”audiophile” brands. If you have a high performance system but with an older DAC or CD you owed to yourself to try this SMSL DO100 Pro. ;-)
Konstantinos L.
TOPPING MX3S Class D Amplifier Infineon Headphone Amplifier DAC Bluetooth aptX Adaptive 2x50W 4 Ohm 24bit 192kHz Black The Topping MX3S is a true swiis army knife of audio, acting as both an amplifier and a headphone amplifier with integrated AK4377 DAC and Bluetooth receiver. An ideal model for...
Another happy customer
After 30 years of enjoying my father's premium JVC amplifier for my home PC setup, I finally decided it was time for an upgrade. After about a week of researching products, reading reviews, and watching videos, I settled on the MX3s. It offered exactly what I was looking for at a great price.
The package arrived in-time and well-protected in a larger box with extra-thick paper cushioning, and everything was in perfect condition. Once installed, the difference in sound quality was immediately noticeable! I could hear details in my favorite tracks that I had never noticed before—the audio quality truly feels like a whole new level.
I'm using it with my two 4ohm 30Wrms diy monitor speakers in a nearfield setup, and it’s simply perfect. The MX3s not only delivers exceptional performance but also looks sleek and stylish. I couldn’t be more satisfied with this upgrade!
LHY AUDIO LPS-A8 230V Linear Power Supply Module for EverSolo DMP-A8 The LPS-A8 linear power supply module, developed by LHY Audio, has been specially designed to improve the power supply stage of EverSolo DMP-A8 network players by replacing the...
Aide au montage kit
Une (voire plusieurs) vidéo de montage existe sur YouTube dont celle-ci : https://youtu.be/EMOg57Ogp2M?si=zPhZQrFUvQWlmw92
Laurent M.
Protection modules for stereo speakers 12V 16A (Pair) This double mono protection module consisting of two cards will allow you to properly protect your speakers.
Excellent et implantation ingénieuse pour projet dual mono
Pratique à installer sur la face arrière de votre boitier DIY
Moi j'utilise une carcasse d'amplificateur en panne ey donc les orifices des anciens borniers HP. Pour utiliser les borniers proposés par Audiophonics il faut les démonter complètement, ils sont faciles à adapter sur les cartes ensuite. Je suis très satisfait de mon acquisition. Laurent
Laurent M.
Excellent registre aigu
Par rapport aux L20V10 d'Audiophonics je trouve un manque de basses flagrants et un medium trop dans la retenue. Par contre l'aigu est fabuleux ! Les essais ont été faits exactement dans la même configuration en interchangeant les modules avec la même alimentation. Peut-être qu'un amateur éclairé pourra m'expliquer comment compenser le manque de basses en modifiant des composants... Laurent
Marko M.
AP310-PREAMP
The preamplifier is simple and practical, the design matches the rest of the AP300... series. I am satisfied with the functionality and connection options, perfect for those who need a bridge between the sound source and the power amplifier...Excellent service, fast processing and delivery of the product. Heartily recommended!
Marko M.
AP300-M450ET
Excellent service, fast processing and delivery of the product. Hearty recommendation for anyone looking for a simple, powerful, high-quality amplifier without unnecessary philosophy ;).
norman p.
Top ;)
fonctionne bien pour un canapé 3 places
David S.
Excellent cable interconnect RCA
Associé à des connecteurs NEUTRIK NF2CB2 et soudé à l'étain avec 4% d'argent, enterre mon câble RCA à 350 EUR soit disant audiophile. Un exemple de neutralité sur toutes les fréquences. Attention un peu rigide et très long à dénuder pour retrouver proprement les 3 petits conducteurs à chaque fois, mais l'effort est mérité. J'ai utilisé le fil rouge pour l'âme centrale, le blanc pour la masse et le blindage connecté coté source. De plus le câble est fléché donc je reconnais facilement le coté ou le blindage est branché sur la masse. Du coup je vais remplacer 1000 EUR de RCA par ces câbles DIY!
Jean Pierre b.
Excellent !!!
Après écoute , ce câble remplace avec brio un câble HP 7x plus cher, d'une marque américaine dont je ne siterai pas le nom et qui sonne à côté de lui comme "légèrement plus étouffé" avec une bande passante plus large, plus propre, plus réussit en faveur du Ludic.
Ce qu'il y a de rassurant, c'est que dans les 2 cas nous sommes dans la même esthétique sonore mais désolé le Ludic va plus loin.
J'entends plus de détails aussi.
Pour moi, le rapport qualité/prix est juste bluffant.
Je conseille vivement!
Michel V.
FOSI AUDIO T3 Amplificateur à Tubes Class AB 2x 6F2 Bluetooth 5.0 2x50W 4 Ohm The Fosi Audio T3 is a small tube amplifier allowing to enjoy the sound signature of this round and warm type of amplification at a low price. It is thus equipped with two 6F2...
Surprenant petit ampli.
Il est léger et a une puissance moyenne.
La réception BT est de bonne qualité.
Comme audiophile, en général je ne choisis pas des amplis qui ont des réglages de tonalité. Mais, là je m'y retrouve en l'utilisant avec avec mes HP large-bande que j'ai fait avec des Alpair. Ils ne font que 88dB, mais j'arrive quand même bien à sonoriser mon séjour avec ce Fosi T3.
