Mohammed B.
Im Vergleich zu Mundorf...
Mohammed B.
Mohammed B.
die
sylvain a.
ECO 280x250x80
Coffret simple et robuste
Bonne finition
Rien a redire
sylvain a.
ECO 320x250x100
Bonne finition
Rien a redire
WBT-0681CU 24k Gold Plated OFC Pure Copper Spades Nextgen Ø7mm (Set x4) These WBT-0681Cu forks made of pure OFC Copper with 24k gold plating provide excellent conductivity and a practical and durable clamping system.
Montées sur du cable mogami 3104 en 2x2 conduteurs reliés ensembles pour alimenter une paire de B&W 803D3 a partir d'un E-470 Accuphase . Nette amélioration par rapport au cable nu en direct sur les borniers !!!!. Accepte les deux brins dans une fourche sans problème.
Michel L.
Amazing ... A very good investment ...
I bought this amplifier 1 week ago after had tested a friend's one ... Cleraly a very good product with some very strong audio characteristics and sound restitution capabilities.
Used on USB input, with 2 Boston CR75 speakers, PC output set on 96 Khz, the sound is incredible with a light rectification of treeble (+2 db) and bass (+3db). I do not use the equalizer, no need to benefit from a sound with a lot of presence, dynamics and clearness.
So a really good choice.
Florent F.
SHUGUANG TREASURE 6CA7-T Pentode Amplification Tubes (Matched Pair) Shuguang's 6CA7-T amplifier tubes offer a high quality manufacturing quality that allows for incredible sound performance and incomparably natural sound reproduction. These...
Le meilleur tube 6ca7 -El34 qualité,son et performances exeptionelles.il a transcendé mon ampli audiomat aria.A consommer sans modération.
Francis L.
Fait son travail
Eva M.
Custom Toroidal Transformer
Excellent product and on time shipment, THANK YOU! all requested voltages are as close to what is possible to specification, the total maximum load exceeds order specification (nice!). all around a very nice shopping experience, HIGHLY RECOMMENDED!
Alain G.
Suite a la lecture de l' avis de Dominique Tanguy sur UNE PASSION AUDIOPHILE , j' ai passé commande de ce petit dac après avoir commandé le DP3 de chez SMSL . Rapport qualité prix assez incroyable et envoi très soigné . Je recommande vivement
Gilles C.
Intéressant ! Cependant
Que 4 étoiles ✨sur ce produit car 2 vis "torx" type t5 ou t6 serrent le câble.
Très inhabituel et si vous n'êtes pas équipé... Vous allez galèrer.
Sinon, belle fiches, lourdes et brillantes.
♥ Le système de verrouillage par vissage.
Gilles C.
VIABLUE Braided Sleeve Neon 13-26mm The Viablue "Neon" sheath protects the cables from everyday wear such as scratches, pinching or light rays. Your cables in their envelope are thus protected from external...
Class !
C'est personnel mais j' ♥ bien cette gaine.
Cependant, pour le fini, avec quelle couleur de gaine thermor assemblerie-vous l'ensemble?
J'hésite avec noir ou vert... Quand pensez-vous ?
Gilles C.
Rien à dire
Conforme à la prestation.
Très joli fini.
Et comme tjrs, attention aux longueurs selon les diamètres de câbles
Luc S.
bon achat
bon produit utilise avec une bonne alimentation descriptif juste dommage pour le conditionnement, ampli reçu avec un chimique CMS dessoudé
Hugues L.
Excellent DAC.
Des conseils au top qui m'ont permis d'acquérir cette belle machine qui fait revivre ma installation à l'ancienne (JM Lab et Nad). Que du bonheur.
OLIVIER P.
Panel Mount Male Micro USB-B to Female Micro USB-B 30cm This 30cm long cable deports the Micro USB 2.0 output of a device. This panel mount cable is particularly useful in any project requiring the integration of an electronics...
Pratique mais !
Pratique mais je ne comprends pas que les oreilles de fixation soient sur le même plan que la prise USB. Il serait plus judicieux qu'elles soient en retrait pour que seule la prise USB traverse la cloison, j'ai remédié à cela en limant les deux oreilles sur 2 mm d'épaisseur.
Neutralité avant tout
Son propre et détaillé , pas d'agréssivité , écoute neutre dans le bon sens du terme . Laisse passer le son sans rien ajouter.
Fais son job
Bonne réception à 10 métres sans rupture de liaison . Son correct ( l'essentiel est là ), associé à une batterie de smartphone qui permet une automie très importante .
Excellente embase
Très bonne embase. Bonne résistance mécanique. Excellente résistance au soudage. Connecteur arrière bien dimensionné pour une multitude d'option de soudage. Donc excellent rapport qualité/prix.
Gilles C.
VIABLUE FILTER 11 Filtering Ferrite Reducer Ø10.5mm to Ø10mm Viablue Ferrite Reducers eliminate high-frequency electromagnetic interference (EMI) and the noise it induces within your audio cables. This is essential for designing high...
visuellement flatteur
lourd et bien fini la ferrite n'apporte pas, de mon point de vue, une quelconque modification du son... tant mieux. Assurez-vous d'avoir bien pris vos dimensions avant d'acheter ce produit, les côtes sont serrés.
très joli rendu visuel, ça fait sérieux.
Gilles C.
Quelle douceur !?
Visuellement flatteur, la sensation du touché n'est pas en reste non plus.
idéal pour présenter un câble high end.
Gilles C.
Quelle douceur !?
Gilles C.
Remarquable
Connexion de très bonne facture.
lourde et bien fini pour parfaire un travail d'excellence
Gilles C.
Remarquable
Gilles C.
Pratique
Un très large choix de diamètre avec des longueurs suffisantes pour bien finir ses montages.
Cette gaine reste blanche et bien blanche je déconseille l'utilisation du briquet pour un fini impeccable... respecter votre travail !
Pedro P.
Absolument transparent
Testé en bypass sur mon système haut de gamme (https://www.youtube.com/watch?v=okY49cgvKnU) via fichier Flac sur PC et en comparaison directe avec le CD, j'avais des doutes mais ce DSP est totalement transparent, tout y est, la qualité des aigus, la dynamique, les timbres, la scène sonore… Et cela pour même pas le prix d'une capa de très bonne qualité… Bravo Ti et Dayton ! Ah oui, pas réservé aux voitures comme écrit plus bas, c'est du très haut de gamme sans compromis !
Couple IEC fiche et embase
Ces deux là, se marient à merveille, ( la fiche IEC et l'embase cuivre pur )
le câble secteur est constitué des fiches Schuko , IEC Viborg et du câble Viborg RISR 5N OFC Copper 6mm Litz Power Cord Wire
Je ne pensais pas que ces fiches et câble pouvaient améliorer la définition de mon système, je n'en reviens toujours pas, les musiciens sont là, dans mon salon, les timbres des instruments sont restitués à la perfection, l'image est des plus réaliste. Bravo pour cette prouesse pour un câble secteur qui revient à moins de 100€
Gareth J.
Réalisation parfaite
Un poil plus large que les dimensions annoncées mais très bien réalisé. Merci Audiophonics.
Lennart H.
Unité BT au top
D'abord la polyvalence de cet appareil. Il propose des sorties numériques et analogiques. Beaucoup de codecs BT, dont les HD avec le LDAC et le Huawei notamment.
J'ai essayé sur sorties analogiques RCA, le décodage passe par le dac interne à base de Sabre du Zen Blue.
En numérique je suis passé par la sortie coaxiale RCA du Zen Blue, avec câble Canare/Audiophonics vers un dac Soekris 1541.
Comme sources connectées, une tablette Samsung S4 sortant en LDAC, et un PC portable sortant sur une clé usb BT Avantree "limitée" à l'Aptx.
Dans les 2 cas de figure c'est très très bon, avantage à la S4 avec le LDAC, mais l'Aptx reste dans le coup je veux rassurer c'est nettement meilleur que du SBC.
Au départ sur le mode de fonctionnement en sortie coaxiale vers le dac Soekris, la S4 nouvellement reliée au Zen Blue était en SBC par défaut, ouh le passage en LDAC est sans appel... vers la qualité sonore plus élevée bien sûr, ça s'entend...
Sur le Soekris par comparaison avec mon PC audio sur liaison usb, le Ifi Audio tient tout à fait la route sur l'ensemble des qualités de restitution (équilibre, détail, précision, transparence, spatialisation, etc...), en étant légèrement en retrait par rapport à mon PC, le point le plus faible concernant la dynamique par comparaison. Sur des matériels plus petits le Zen Blue ne m'a pas semblé manquer de dynamique, mais ça justifie le travail que j'ai effectué sur mon PC qui alimente un gros système qui ne pardonne pas les défauts!
Le mode de sortie analogique du Zen Blue, reposant sur le travail de son dac interne à puce Sabre est convaincant. Je ne trouve pas le son quelquefois caractéristique des Sabre, l'aigu ici reste naturel et les qualités d'ensemble présentes, pour me laisser aller aux écoutes sans couper au bout d'une heure par manque de quelque chose.
L'alimentation fournie m'a irrité, j'espérais avoir la Ipower 5v pour le prix, Ifi Audio met un adaptateur beaucoup plus petit, mais ça ne semble pas impacter le résultat sonore? il faudrait que j'essaye une Ipower pour comparer...
Au total unité Bluetooth très convaincante, la qualité de restitution est là sur les 2 modes / dac interne et externe. Elle se connecte facilement aux sources, la couleur de la led à droite en façade indique sur quel codec BT on fonctionne. Pas d'interrupteur de marche-arrêt par contre.
Qualité au RV
Je confirme les autres avis positifs.
Excellentes qualités de restitution avec ce câble.
Rien à dire, à ce prix abordable le rapport qualité prix à mon avis est très favorable.
Essayé sur un gros système avec dac Soekris 1541. J'ai comparé sur le même dac avec ma source PC reliée en usb = les qualités d'ensemble et l'équilibre restent comparables. Les 2 sources étaient différentes, en coaxial un Zen Blue de chez Ifi Audio fonctionnait en BT LDAC avec une tablette Samsung S4. Essentiellement seule la dynamique est inférieure de manière la plus flagrante entre les 2 sources, mais je pense que ce n'est pas dû au câble Canare/Audiophonics. Évidemment ça justifie le travail effectué sur mon PC comme source audio, par rapport à une source portable passant en BT, mais ça tient la route et reste tout à fait écoutable sur mon gros système, mention aussi au Ifi Zen Blue qui fait fort comme unité BT.
Très bonne surprise!
J'ai comparé ce câble avec le Neotech Nemoi 3220 UP OCC cuivre.
Le câble RCA Audiophonics a l'essentiel des qualités du Neotech. Il est un peu plus "facile" côté équilibre, favorisant très légèrement le médium plus bas que le Neotech, avec un aigu légèrement plus doux, et légèrement plus rond en bas. Oui je donne du "légèrement" à répétition car les différences sont peu marquées en fait, j'ai alterné plusieurs fois de l'un à l'autre sur un même système et mêmes morceaux. Le Neotech va quand même plus loin, à mon avis plus justifié sur des gros systèmes pour qui veut davantage, pour nettement plus cher.
Donc le rapport qualité-prix est top pour ce câble qui procure des qualités de restitution proches d'un Neotech, assez proches pour ne pas ressentir de manque lorsque l'on passe du Neotech à cet Audiophonics à base de conducteurs et fiches Elecaudio.
Pour moi c'est hautement à recommander pour les budgets modestes!
Un choix de longueurs plus grandes que 30cm serait bienvenu, on peut toujours demander une commande personnalisée.
VASILESCU F.
hifi looks
Great quality case, but be sure you have the tools to cut that 10mm hard aluminium face. (if you need to cut it)
Alain R.
Excellent produit.
C'est un connecteur d'allure "cossue" Il est massif, costaud. et très facile à câbler car très ouvert, il y a de la place. Une gaine thermo sur le câble à l'endroit où la pince va serrer le câble et la tenue est bonne.
Christophe M.
A essayer sans arrière pensée!
C'est la FURUTECH FI-E11-N1 (G) qui m'a incité a chercher une nouvelle schuko (Cf. commentaire), j'ai après échange avec l'équipe Audiophonics jeté mon dévolu sur cette Elecaudio.
Quelle surprise à l'écoute, le sentiment d'un robinet ouvert, de plus de tout, la musique coule sans agressivité, son plein, dynamique et transparent. Une belle association avec le Belden 19364.
Guy A.
Pour le prix c’est parfait.Aussi efficace qu’un câble 5 fois plus onéreux.
Taro I.
Very satisfied
I read a lot about Hypex NCore amp modules, and I went with this economical, pre-built module, with 12v trigger-in. I placed my order in late December, and received it about a month later, after waiting for some back-order. The sound from this amplifer, with TOPPING DX7 Pro DAC feeding the input, and B&W 685 on the output is so much better than what I had with Marantz NR1403 I used previously. There is so much more base, and everything sounds clearer, with more information. This is motivating me to consider buying a new set of speakers.
Cernat G.
Very good driver
Used this for a bluetooth speaker - very good bass response from a small box.
Arnaldo S.
modulo atraso
bom produto funciona em pleno
Arnaldo S.
interruptor aluminio
bom produto e muito funcional
DENIS F.
Upgrade des lampe un plus audiophile
Les lampes 5654 sont des US très bien pour une écoute audiophile...
J'ai upgrade mon préampli, mon ampli creek sonne nettement mieux avec mon large bande. Ces tubes récupèrent un grave, cela assis mieux la charpente du spectre... Et avec mon Rega Brio sur des baffles plan, idem cela réhausse le bas du spectre...Toujours aussi agréablement surpris par ce petit module :)
(j'ai gardé les paires de tubes d'origine pour une utilisation media sur le démodulateur Tnt, pour la télé je ne vois pas de différence au bureau)
Laurent L.
Fait parfaitement le job comme attendu. Switch 3 voies plus récepteur Bluetooth en prime. Aucun souffle perceptible et construction alu professionnelle. Le bouton de face avant sert à la fois pour la sélection de la voie active (appui) ou de contrôle rotatif sans fin pour le volume.
alain C.
VH 3.96mm Female Casing 2 Channels White (Unit) This connector type VH 3.96mm female has two poles. It will allow you to simply create 3.96mm VH cables to take advantage of simpler and faster PCB mounting with 3.96mm VH...
bon matériel comme toujours
Jean Pierre B.
TINYSINE AUDIO-B PLUS Bluetooth 5.0 Receiver Module aptX Stereo RCA This Bluetooth 5.0 receiver module includes a Stereo RCA output for direct connection to a DAC or amplifier. It is therefore possible to use this module to stream your music...
Parfait pour supprimer un long cable
J'ai acheté ce produit pour supprimer un long cable de 5m et pouvoir commander à distance cette liaison. A fonctionner du premier coup sans intervention de ma part sauf d'affecté sur mon Mac la sortie audio à cet interface après avoir brancher le Bluetooth du mac et valider l'interface à celui ci.
je suis bien d'accord avec Franck P se préampli phono rest vraiment extraordinaire le tube monté dessus n'est certainement pas là pour faire joli je conseillerais simplement de changé le tube d'origine chinoise qui lui effectivement n'est pas terrible par un tube NOS us ou européen pour le transcender et cerise sur le gâteau on peut même remplacé le tube 12AU7 par un 12AX7 .
avec ma cellule bleue point EVO III MC 2,5mV il fait des miracles!!
A bon entendeur...
Istvan M.
SUPTRONICS X20-DAC DAC Module I2S RCA ES9028Q2M 32bit 384kHz 1x AOP NJR MUSES 8920 This X20-DAC module will allow you to benefit from a very powerful DAC with I2S input, while being compact. Thus, you can upgrade your DIY audio system based on a Raspberry Pi...
X20
Although they are still maturing, they have a very nice sound, high quality Dac panel. Easy to install. It deserves better coupling capacitors, say Elna Silmic. Unfortunately, the Volumio IS2 DAC is not listed or officially supported. Identifies Hifiberry as DAC. But it still works. It is a question of making the most of its potential. Moode, on the other hand, supports it.
Istvan M.
SUPTRONICS X10-PWR Regulated Linear Power Supply Module for X10 / X20 Modules This X10-PWR module will allow you to enjoy a quality regulated linear power supply to power the other modules of the X10 or X20 series and your Raspberry Pi. A set of modules...
X10-PWR
Very good panel, but it's a shame that it's not ready for full service on the Raspberry pi 4, even though it's been available for over half a year. A 5.2 V branch instead of 2.5 A would be good if you knew 3 A. Still maturing, but very promising.
Jacques D.
Prof
Excellent amplifier at a *very* good price. I've seen amps built around the same Hypex module selling for hundreds more. Speedy (1 week) delivery to the USA.
Pas mal
Module compact, belle réalisation, facile à alimenter, fiable en liaison BT, facile d’appairage, bruit de fond pas trop important bien que présent dans le silence.
Par contre la sonorité est assez sourde, des graves riches (un peu trop ) et des aigus trop étouffés.
Je vais essayer de trouver mieux.
pourquoi s'en passer
Augmente considérablement la portée de mes récepteurs BT.
Le connecteur fonctionne parfaitement.
Alors vu le prix pourquoi s'en passer.
Trés content
J'ai déjà parlé de ce module plus haut, ce doit être le 5eme que j’achète, donc tout va bien.
LED Fuse Lamp Warm White for Vu-Meter / Tuner 6.3V This 3 LED shuttle light bulb emits a warm white light. Ideal for illuminating the meters of a HiFi device or as a replacement for a defective bulb. This one is powered by 6.3V
C'est parfait
Très bonne luminosité, mème un peu forte pour moi (je mets une résistance en série pour la chuter un peu)
éclairage à 180° température de blanc chaud, et comme elle ne chauffe pas on peut mettre sans soucis un correcteur de tinte collé dessus.
