Martin Å.
Great for the price!
Zacharias L.
Very good but...
Pavol B.
Anders L.
ELECAUDIO FC-104 24K Gold Plated Pure Copper Flat Spade Ø5.8mm (Unité) This flat Elecaudio FC-104 spade will allow you to complete the design of your speaker cables while ensuring a very good quality of reproduction. This one has a pure copper...
Good value
Good spade that fits well on 8mm posts. The copper is quite thick but soft enough to make crimping easy. Very good value.
Laurent z.
simple efficace et pas chère
pour ce qui ne veulent pas se ruiner en câbles secteur mais qui ne veulent pas brider les appels de courant de leurs amplis, c'est parfait. aucune couleur sonore donc très polyvalent
Anders L.
Best cleaning kit
I got this kit the clean all my analogue and digital connections. I was pleasantly surprised by the results. It removed more oxides than I had expected. To my ears, there is also an audible improvement. I would describe it as a calmer and more detailed sound (i.e. less distorsion). Previously, I used isopropyl, but it's clear that alcohol only removes grease and dust, while leaving oxides that still impede the contact. So, from now on, it's Deoxit for me.
Oleg K.
Oleg
Excellent product.
Very good sound quality.
The sound is neutral, unpainted and very detailed.
There is no fatigue from sound. No excess brightness.
If someone uses RCA, you can use the wire XLR to RCA.
By sound, this low-cost power amplifier matches Class A / AB amplifiers worth more than 1,500 -2000 euros.
René I.
Qualité/prix/rapidité
Le matériel reçu est conforme aux photographies.
Très bonne qualité, Prix raisonnable, Rapidité de l'expédition excellente, Emballage parfait. Je recommande chaudement.
Attention la tôle du coffret ne doit pas dépasser 3mm.
De plus, si vous soudez vos fils, faites le avec les bornes non montées sur le coffret, sinon la soudure est difficile voire impossible (masse à chauffer trop importante) et les isolants rouge et noir risquent la destruction. C'est facile à faire. L'autre solution consiste à utiliser une cosse à souder dorée, pour ma part je préfère cette solution.
VERHULST A.
B
Très beau produit. Un peu difficile quand-même de câbler du 2,5 mm; j'espérais des bornes de connection.
Savvas P.
Belle surprise
Produit facile à utiliser et efficace malgré son prix abordable par rapport à la concurrence.
Regis b.
alimentation
tres satisfait plage reglable parfaite alimentation pour ventilation meuble sono
Regis b.
preampli
tres bon produit remplacement des AOP pour un contrôle parfait utilisation caisson de bass sono
Michel K.
Ahurissant
Nécessite quelques heures avant de donner son meilleur.
A mon avis il vaut mieux mettre l'égaliseur sur OFF.
En comparaison avec un ampli LAVARDIN (très réputé), j'hésite, la sonorité n'est pas la même, mais lequel est le plus agréable? (meilleur ne veut rien dire)...
L'AD18 est vraiment un cas!
Cela vaut la peine de l'écouter ...
Jean-Pierre E.
Parfait pour réaliser ses câbles HP.
Jean-Pierre E.
Très belle gaine
Parfait pour réaliser les câbles HP
Fabien L.
Tissu de qualité...
Tissu de très bonne qualité.
J'ai commandé 3m reçu en 3 paquets sous blister de 1m x 1.80m.
Reçu très rapidement.
Je recommande ce produit.
Oleg K.
Oleg
Quality goods.
Neutral but detailed sound. Fast and very low bass
No brightness. The sound is not tiring.
Its rating is comparable with analog class a / ab amplifiers over 1000-3000 euro.
Works fine with wire XLR to RCA.
You can connect directly to the DAC if you adjust the volume using the DAC
jean-luc P.
VIBORG CM201 (G) Male 3 Poles XLR Socket Silver / Gold 24k 3µ Plated Pure Copper (Unit) This XLR 3 pin male CM201(G) XLR socket benefits from a very high quality design and the use of quality materials. Thus, the contacts are made of Copper with triple plating...
Même avis que pour l'embase XLR femelle
Lire l'avis sur l'embase XLR femelle
jean-luc P.
connexion à ne pas oublier
L'embase XLR en métaux nobles ne doit pas être négligée. Si en aval on met des câbles de modulation sophistiqués et onéreux, le résultat sera limité par le maillon le plus faible. Pour diminuer le prix du préampli ou de l'ampli, les constructeurs mettent des embases de premier prix en métal mauvais conducteur. fil d'argent et soudure 10% argent complètent la mise en place. Travail délicat: les soudures doivent être bien faites, c'est important pour une écoute de haute qualité. Le résultat en vaut la peine. On ne met pas des pneus rechapés sur une Ferrari.
jean francois F.
alimentation 12v
excellent produit, nette amélioration de l'écoute sur mes deux convertisseurs FX audio. On est pas encore au niveau de sérénité d'une écoute sur batteries mais on approche et le côté pratique est un plus (possibilité d'alimenter deux appareils). Attention cet appareil mérite des cordons de qualité, celui vendu par audiophonics (jack -jack 2,1) est excellent
Francis G.
Un réel plaisir
J’ai récemment fait l’acquisition d’un SMSL 18 AD V3.1, car les critiques sur ce minuscule FDA me rendaient perplexe. J’ai donc décidé de m’en procurer un pour avoir ma propre opinion, et bien, j’ai été agréablement surpris, même bluffé par la qualité musicale qui sortait de mes HP. Je possède le IDA 8 de Nuprime, sincèrement le 18 AD n’a pas à rougir devant celui-ci. J’ai associé le SMSL 18 AD à des Eltax Monitor 3 ainsi qu’à des Q Acoustics 3050.
Concernant le colis, il est arrivé rapidement et en excellent état ce dont on attend d’un fournisseur, merci.
SHUGUANG TREASURE 6CA7-T Pentode Amplification Tubes (Matched Pair) Shuguang's 6CA7-T amplifier tubes offer a high quality manufacturing quality that allows for incredible sound performance and incomparably natural sound reproduction. These...
The best
En matiere de tubes de puissance EL34 ou 6CA7 il y a ce SHUGUANG TREASURE 6CA7-T et puis le reste.
J'en ai essayé un paquet de tubes, ce qui est assez ruineux, mais c'est le seul moyen de savoir.
Les chinois n'ont jamais cessé de fabriquer des tubes et pour cause, ils n'ont eu accès au transistor que tardivement.
SHUGUANG est certainement la plus grosse fabrique de tubes au monde et certains tubes d'autres marques viennent de chez eux.
Les tubes actuels sont et calculés et fabriqués avec des outils de notre époque.
Désolé pour les Old stock ou autres reliques, mais une Peugeot 208 GTI de 2019 est plus performante qu'une Porsche Carrera des années 70
Ce sont à ma connaissance les seuls à fabriquer des tubes dédiés HIFI, et celui ci en fait parti.
Doux, moelleux, basses rondes ou séches, c'est votre musique qui décide et pas le tube.
Il restituera le son de maniere trés naturelle, sans en rajouter.
Son petit frére en version SHUGUANG TREASURE 6CA7-Z n'est pas mal non plus, mais celui ci est au dessus, légèrement.
Perso je régle le bias à 45ma et c'est le Nirvana.
Stéphane G.
septique
salut !
je ne suis pas un geek audiophile intégriste, mais mes oreilles fonctionnent assez bien. Je voulais un DAC 32 bits pour remplacer une carte son hyper chère (pour ce que c'est une ASUS ROG Xonar Phoebus donnée pour 24bits a 192kHz).
C'est claire qu'elle fonctionne mieux que le chip audio intégré à la carte mère. Pas besoin d'être un fin limier des esgourdes.
J'utilise plus d'enceintes, juste des casques audio : AKG K702 et le Sheneiser HD380Pro.
Puis un jour j'ai acheté un smartphone LG G6 avec le fameux quad DAC 32bits signé par B&O... Pff... c'est encore mieux à l'oreille, le son est plus chaud , plus profond, plus détaillé sur du FLAC, rien à voir... Bon bah je cherche un DAC 32 bits équivalent, mais je ne suis pas près à gâcher encore 350 euros dans une carte son bidon. Je test ce DAC donné pour 32bits et 384khz, normalement il est surdimensionné pour les sources audio dont je dispose.
Mais voilà, les deux pc de folie dont je dispose ne le reconnaissent que en 24bits et 192kHz... J'ai mis un moment à découvrir que la fiche produit avait un onglet "téléchargement"... désolé, ça saute pas aux yeux. (j'ai quand même passé 3h à éplucher le net pour trouver des pilotes xmos d'évaluation...)
bref ! mes ordis ne reconnaissent pas ce DAC comme un 32bit ! où est ce que je me suis trompé ?
sinon j'ai vu des gens parler de remplacer les AOP, appellation d'origine protégée? Ampli op... c'est chinois quand même pour moi...
Je veux un son pure et propre, défini, clair et dynamique, respectant ce que l'artiste voulait me faire écouter ;
Bouse, Bites'audio etc... sans moi.
Du coup je devrais choisir quoi comme AOP ?
Pourriez-vous m'éclairer s'il vous plait, chui encore noob, j'ai besoin de conseils et d'aide. Ça me chiffonne d'être bloqué en 24bits alors que je suis sensé m'être équipé d'un 32 bits.
Je ne peux pas encore juger du rendu puisque je n'ai pas 24 heures de rodage. Le son est correct déjà comme ça, mais mon téléphone est toujours mieux.
mercii
Henri F.
superbe
que dire sur ce casque puisque tant de choses ont été écrites (voir les différents forums). Oui ce casque est beau, très beau mais pas que ! il révèle de véritables qualités acoustiques. Attention il nécessite une bonne période de rodage entre 40H et 50H dirais je. Donc ne pas se fier aux premières écoutes. Ensuite il révèle toutes ces qualités, il s'ouvre et les lignes de basses sont mieux tendues et précises. Je viens d'un AKG Q701 et je dois dire franchement que je prends beaucoup plus de plaisir à écouter ma musique avec le Meze. Il peut paraitre moins précis, moins neutre, mais quelle musicalité. Certains albums au son assez métallique (some girls des Rolling stones par ex) passent tellement mieux avec le Meze. C'est un casque ou on se prend pas la tête et avec lequel on prend juste beaucoup de plaisir à écouter sa musique. C'est bien la l'essentiel ! Tout style est très bien retranscris. Il a le sens de vous faire partager le rythme, la musicalité et l'âme d'une chanson. En plus aussi bien utilisable à la maison sur un bon ampli casque qu'à l'extérieur sur son baladeur ou Smartphone. Bravo à Meze qui réussit ce tour de force d'allié beauté, durabilité et musicalité avec ce casque. Et vu son prix c'est certainement un ou le meilleur rapport qualité prix du moment ! Alors si vous cherchez un excellent casque polyvalent avec un budget maitrisé, n'hésitez pas. Je pense vraiment pas qu'il y ait mieux dans cette gamme de prix.
Super prise
Prise montée sur un Yarbo et ça marche très bien, voir mon avis dans le câble SP-1100PW.
Parfaite
Prises schuko et iec montées sur un Yarbo SP1100PW pour avoir une ligne tout cuivre pur pour mon ampli; L'ensemble marche très bien et on s'en tire pour pas très cher, 115€. Je ne sais pas si les prises y sont pour beaucoup mais ça marche, et c'est bien l'essentiel. Je recommande vu le prix.
Efficace&
Câble monté avec des prises simples pour mon écran pc, les couleurs sont plus belles, le contraste aussi, bref pour une vingtaine d'euros on est gagnant. Je recommande.
Formidable&
Câble monté avec des Viborg en cuivre pur pour mon ampli YBA Intégré DT et le son s'est transformé. Des attaques de notes plus nettes, spatialisation élargie, timbres encore meilleurs. Inconvénient il est assez rigide. Pour 115€ au total j'ai presque changé d'ampli !!
Giovanni S.
Très très bon produit
j'ai un système réseaux depuis plus de 10 ans, avec un lecteur réseaux Linn akurate DS. Testé en premier sur mon switch netgear, il y a une différences au niveau du son. Plus de détails, meilleur focalisation des voix, aération de la scène sonore tout ça sans perte de dynamique.
Je l'ai testé ensuite sur mon disque dur NAS Qnap, et là il y a pas photo!!! tout est encore plus net et précis, j'y crois pas mes oreilles!
Un produit qui fera vraiment la différence pour un prix plus que correct. Indispensable sur les systèmes réseaux dans le milieu de l'audio (disque dur, switch, routeur...)
Jean Marc L.
Rien à redire, c'est vraiment très bon. Les micro détails ressortent très bien, la diaphonie est excellente et la dynamique époustouflante ! Il mérite un très bon ampli et de très bonnes enceintes pour lui rendre honneur. Meilleur que des DAC du commerce coutant + de 10 fois son prix.
Florin M.
FURUTECH CF-735SM (R) Rhodium Plated Copper Stereo Jack 3.5mm Connector Alpha Treatment This Furutech CF-7355M(R) 3.5mm stereo jack connector offers a neat design based on high quality materials. This one therefore includes pure Copper contacts with Rhodium plating...
Expensive but class sound
Five stars for the sound reproduction!You can get a very natural and rich sound upgrade with them.Very hard to solder thought,I guess because of the rhodium plating, but it is worthing to spend 44 euros!
Very happy with the result.
Bi cablage
Comme je possédais à la fois des cables VIABLUE SC-2 et MOGAMI W3103 et vue que mes Tannoy précision 6.4 ont un double bornier, j'ai tenté le double câblage.
Le VIABLUE SC-2 sur le bornier HF et le MOGAMI W3103 sur le bornier BF.
Mais quel heureux mariage, ils sont vraiment faits l'un pour l'autre.
Que dire: les médiums / aigus sont plus riches et les bas médiums / basses plus fournis. L'image sonore s'est élargie.
Bi cablage
Hervé T.
Dépanne bien
Produit satifaisant, on pourrait lui reprocher un taux de rétractation un peu faible ( 2 ) mais le prix aurait été bien différent.
Hervé T.
Erreur de casting
J'ai acheté ce cable pour refaire certaines liaisons dans mon amplificateur. J'ai trouvé ce cable très raide, difficile à souder malgré un fer tout neuf et dont la tresse et encore plus difficile à défaire tellement elle est serrée et malgré l'utilisation d'une épingle la plus fine possible. J'ai acheté un modèle pro et rien à redire.
Jan T.
Very good product
Ik ordered the Shanti at the beginning of september and received the order in 3 days in the Netherlands.
I use my Shanti supply on a Raspberry Pi 4 and a Allo Digione Signature board on top of it.
It sounds wonderfull and tooks the sound quality to the highest level.
Very smooth en open sound with no sharpness.
I also ordered a Shanti for a friend of mine on the 14thd of october. The delivery should be at the beginning of november. Unfortunately the Shanti has not delivered yet.
Encore mieux que mieux
Suite à un changement d'enceintes je me permets de revenir sur ce dac sont j'ai déjà fait l'éloge.
Avec mes enceintes TANNOY XT8, le son était déjà merveilleux d'image sonore, de timbres et détails.
Mais là avec les TANNOY précision 6.4 c'est inouie.
Là ou j'entendais un peu la difference entre les divers modes du DAC, pour le coup c'est flagrant.
Chacun y trouvera son compte à son gout.
Pour moi c'est le mode NOS 1.
On entendrais même les mouches voler dans le studio tellement ce dac extrait le moindre détail des enregistrements et le tout sans ce son numérique désagréable.
On a vraiment le groupe devant soi.
QOBUZZ Hi-res
Audirvana
Ampli à Tubes
Et les cables qui vont bien
A acheter sans hésiter
Dragos P.
Tres bonne qualite de fabrication, au niveau sonore cable neutre , rendu correct sur toute la gamme de frequence.
Un concentré de musicalité
Tout d'abord le matériel utilisé : ampli QULOOS QA690 avec entrée USB et cable USB Mercury 3.0, enceintes Bruno Henry HB200 lestée plomb et sable cable HP DIY argent pur 2X1mm + 2X0.6mm de diamètre isolé coton et tressés. Player Daphile et mini pc Intel NUC DD normal.
Sur le morceau de Michael Jackson Thriller en WMA Lossless les petits arrières bruit sont hallucinants, rien n'est laissé de côté. C'est criant de vérité. La dynamique, tout du grave a l'aigu est en fil droit. Je l'ai comparé avec un NAD FDA à 1200e, ce dernier est enterré sans problème. Il a juste plus de connectique il faut le reconnaître. Aucune raideur numérique en tout cas avec Daphile tout coule comme de l'analogique.
António G.
A recommander vivement
Améliore incontestablement le son. On retrouve de fait un message musical expressif, puissant, libéré et bone graves.
António G.
Patrick D.
Cable de haute qualité
Cable optique de grande qualité, la finition est superbe et donne une réelle impression de solidité. Il n'est pas super souple mais ça reste quand même facilement utilisable. En 5m ce câble remplit parfaitement son rôle, le son est très détaillé fluide et puissant. Un très bon rapport qualité prix.
Jean-Charles M.
Il remplace un Qed que je trouvais déjà excellent mais là ça va plus loin dans les détails, le son est décrispé, moins numérique. Attention tout de mème au rayon de courbure un peu pénalisant.
Il est placé entre une lIVEBOX (SSD 1To inside) et un SBC ODROID C2 (Volumio).
Dans tous les cas pour tirer les meilleurs résultats possibles de ce type de config, il faut soigner l'alimentation de la LIVEBOX et du SBC au maximum et supprimer toutes les leds (génératrices de bruits elec) en particulier celles des embases rj45 (couper les 4 pattes soudées a l’arrière des embases), GROSSE DIFFÉRENCE AUDIBLE !
Sylvain J.
Un silence pour faire son
Pour l'instant en remplacement de mon câble DIY pour alimenter ma barrette secteur.
Il m’apporte surtout un plus au niveau du « silence musical ».
BAZAN J.
OLFLEX 110CY Power cable shielded 3x1.5mm² Ø9mm
Idéale pour une alimentation de qualité sur ampli guitare à lampes.expédition rapide et emballage sérieux
HENRY D.
Disponibilité et expédition rapide.
fournisseur sérieux qui dispose de matériel spécifique non disponible ailleurs et à des prix compétitifs Je recommande!
Jean-Claude E.
Câble modulation
Câble solide et résistant, bonne section de cuivre, selon moi, adapté aux grandes mongueurs. Par contre, Audiphonics recommande des fiches RCA, ce n'est pas pour moi le bon choix. Il faut leur préférer des fiches XLR. Personnellement, j'utilise des fiches Yarbo. Les cordons réalisés vont me permettre de connecter mes enceintes actives sur les sorties XLR de mon préampli.
Frederic S.
Du bonheur
Comment dire...Ce fil adhère en moins de deux aux surfaces; laiton sur laiton, cuivre sur cuivre brut et je ne parle pas des connections; presque un plaisir.
Frederic S.
La Base
Très bien assemblé, belle finition, pour le son; il n'est pas fait pour ajouter quoi que ce soit, il file droit. Une excellente base pour tout système pro ou audiophile.
Frederic S.
Pour les montages en "masse flottante", rien de mieux.
Frederic S.
Ne bouge pas
Très résistant, peut rester en chauffe pendant des heures sans altérations, top.
Frederic S.
Soldering Iron High Quality 60W 350°C Ø 6.4mm This non-adjustable soldering iron offers a power of 60W allowing it to rise up to a temperature of 350°C. The tip of the iron has a diameter of 6.4mm. It is however...
Très belle surprise, chauffe rapide, manche bien isolé qui ne chauffe pas. L'interrupteur plus le voyant est un garant de sécurité.
Elsa A.
bons connecteurs
Belle qualité de composants, toutefois le montage pose quelques problèmes :
-soudage du point chaud difficile malgré l'emploi de flux à soudure (c'est peut-être le flux qui a fait une allergie au traitement de plaquage?), j'ai du chauffer au fer 80W , mais heureusement l'isolant diélectrique est de qualité impeccable comme du téflon,
-le remontage des 2 micro-vis du manchon est un jeu à rendre dingue , sans chanfrein sur les vis de cette taille les engager dans le pas de vis de 1mm d'épaisseur tient du jeu de loto,je plains les monteurs des zavfino en ligne production de câbles.
Pour les écoutes et la sonorité, j'attends la fin du rodage...
