Nikolaus S.
Parfait sur un bureau
MICHAEL K.
Recommended
Customers reviews - There are 19273 reviews.
Olivier B.
De bien meilleur qualité de finition que mon ancienne multiprise standard. J'ai branché un équipement HDG HC et TV OLED. Honnêtement, je n'ai pas vu ou entendu de différence.
alexandr k.
great product!
Buying a second time, now to my friend.
Great packaging, great service!
But my wife does not like it)))
Bruno G.
Il n'est pas nécessaire de faire de longues comparaisons pour entendre les indéniables qualités de ce câble : relief, naturel, dynamique... bref sur tous les points les différences sautent aux oreilles par rapport au câble livré avec l'ampli iamd v200. Cela met également en exergue que ces petits fda méritent des câbles (et des enceintes) de qualité pour exprimer leur potentiel. Achat recommandable.
Gareth W.
RASPDIGI LTE LVDS V2 Streamer I2S LVDS HDMI Allo Kali Reclocker Audio-GD Compatible We propose you a model updated of our RaspDIGI LTE with this version V2. This takes advantage of the solid base of the first version, namely the management of the I2S signal and...
A great piece of kit
I brought this for my Audio-GD R8 dac and it's been great, its a step up from the USB out of my silent PC into the Audio-GD, I can follow instruments better now, before they would get slightly lost in the mix, there is better separation between instruments and the music sounds ever so slightly more organic.
It benefits slightly from a good linear power supply, I'm using the Allo Shanti to not only power the Raspdigi but also my external 2TB SSD, and the highs are slightly cleaner now with more extension and air around them, on first listen the bass seemed a bit weaker, but it turned out the bass had tightened up a bit and was less bloated giving the impression there was less bass.
I'm running picoreplayer because I think it sounds slightly better than Volumio, Dietpi and Moode, plus because it runs in ram I can just power off the unit without risk of corrupting the SDCard.
I highly recommend this product, its fantastic value, its slightly cheaper than a Gustard U16 USB to i2s converter, and on top of that its also a streamer and player, so you have access to hundreds of internet radio stations, streaming services, youtube and so on.
Reçu dans les temps et bon produit
Ravi d'avoir trouver ce produit de cette qualité, introuvable ailleurs.
Brech M.
Avis recepteur
Excellent produit. Correspond parfaitement à la description. Très bonne portée comparé au logitech par exemple. Attention, nécessite un dac. Exactement ce que je voulais...
Steven K.
Absolutely terrible
Massive hifrequency distortion from clipping. Wish I could return.
loric L.
Top produit!
J'ai acheté ce préampli grâce aux avis positifs. Et j'ajoute le mien !
Petit, bien fini, ultra simple d'utilisation un enfant pourrait s'en servir.
RCA + bluetooth, télécommande ou boutons de façade tout y est.
A côté de ça une qualité d'écoute vraiment impressionnante pour le prix. Aucun bruit parasite à l'utilisation.
Je devais l'utiliser sur un système DIY mais finalement il drive une paire de B&O active avec brio.
Yves C.
VIABLUE EP-7 Ethernet RJ45 Cat6A Cable Silver Plated OFC Copper Shielding 5m Viablue EP-7 RJ45 Cat4A cable guarantees extremely clean signal transmission, effectively protecting the signal from interference and distortion. Supporting the Gigabit standard...
Câble hi-fi
Confirme à la qualité de mes Kef LS50 wireless
Nicolas A.
Une étonnante petite carte. Ça marche vraiment très bien!
Branché derrière une RPi3B-Hifiberry Digi+ sous Volumio (ampli Densen et enceinte triangle)
Initialement alimenté avec l'alim d'une Google Chromecast, j'ai testé la batterie externe 10.000mAh et c'est nettement mieux.
Certains forums recommandent une alim régulée sur base d'un simple 7805 et mettent en garde contre cascader les LDO (alim LDO ext + LDO de la carte).
Un boîtier alu est indispensable pour la protéger.
Vincent D.
Automatic Input Selector 4 Stereo RCA Inputs This module automatically switches between 4 stereo sources. The selection of sources is carried out fully automatically from a signal of at least 0.2V.
Pas pour le classique.
A bannir absolument pour les amateurs de musique classique, dès que la musique est trop basse (le voltage), le dispositif coupe la musique et impossible de le reprogrammer. Bonne qualité audio cependant.
Jan R. S.
Jan R. Smit
A very nice power supply. Quiet, also mechanically.
Danilo L.
Fantastic little DAC
Have nothing negative to say about it so far. High quality build. Small and portable, you won't feel it on your earphones at all. Powers my earphones very well, bass sounds much stronger, didn't know you could achieve such bass on tiny earphones. It can ever power my HD650 to a respectable level, although it's not ideal.
Just remember to download the APK from the iBasso website, this should have been clarified on the booklet you receive with the device.
I can't offer an in-depth analysis into the audio quality, this is just a layman's opinion.
Can't comment on the durability as of now, as I just received the device a week or so ago. Very happy overall and well worth the €50.
Hugues B.
Transofrmez votre smartphone en baladeur Hi-Res pour un prix ridicule !
Fidèle de la marque iBasso depuis plus de 10 ans, j'écoute beaucoup de musique en mode "nomade". Le smartphone et l'application Qobuz en sont les premiers maillons. L'ajout de ce DAC externe a été une révélation.
Ma référence est pourtant un baladeur DX200 d'iBasso couplé à l'AMP9 à tubes Korg miniaturisés, les fameux tubes à vide fluorescents Nutube.
Après à peine 10h de rodage, ce combiné DAC + ampli symétrique s'est soudainement ouvert pour le plus grand bonheur de mes écoutes.
Légèrement déçu par un test des convertisseurs AKM (p.e. sur le baladeur iBasso DX150) que j'ai trouvé, à l'époque, manquant de densité, de grave et de largeur de scène, quelle ne fut pas surprise d'entendre l'ouverture brutale de ce convertisseur AK4493 !
Il a pris de la densité, de la profondeur dans les graves, les médiums restant à leur bonne place et les aigus toujours aussi doux, précis et présents ! Et la scène est devenue très large, même en écoute avec casque fermé (Meze 99 Classics en noyer).
Ce nouvel équilibre est de nature à réjouir beaucoup d'audiophiles exigeants, et très franchement pour 49€, transformer son smartphone en baladeur Hi-Res, aucune raison de s'en priver !
Petite astuce Android, il faut activer la prise en charge OTG de la prise USB C (dans les paramètres système) pour que ce DAC externe soit immédiatement reconnu et pris en charge. L'installation de l'aplli d'iBasso pour régler finement le volume et 2 paramètres supplémentaires est recommandée.
A vos écoutes, ce DAC est devenu l'extension obligatoire de mon smartphone !
Hugues B.
Pour les amoureux du son "ampli à lampes" !
IBasso, je les connais depuis plus de 10 ans. Cette société s'est taillé une réputation sur le marché du Hi-Res avec un rapport qualité/prix exemplaire.
J'ai, depuis sa sortie, le baladeur DX200, utilisé essentiellement avec un casque Meze 99 Classics en noyer, et une connectique OCC symétrique.
Amoureux de la chaleur et des harmoniques des lampes, je lui tout naturellement adjoint l'AMP9 à sa sortie.
au bout d'environ 10h de rodage, le son a pris une épaisseur charnelle incroyable, une densité organique, une intimité (oui c'est intie comme rendu, cela referme un peu la scène sonore restituée). Les graves sont devenus abyssaux, pyramidaux dans leur assise, permettant une envolé de tous les autres registres qui confine au sublime.
Le rodage va continuer, et je reviendrai partager avec vous mes ressentis !
Cela atténue un peu le côté analytique de l'architecture double Sabre du DX200. Donc en plus de la richesse des détails et de leur détourage au scalpel chirurgical, on gagne dans cette association un rendu vivant, littéralement, car encore une fois, ces tubes à vide miniaturisés font merveille, apportant une chaleur argentique et des harmoniques qui dansent à merveille.
Pour les puristes du son "fidèle à la prise", il y a ici l'apport évident des lampes. Donc une certaine "coloration".
En entrée sur un un ampli Marantz pur numérique en classe A, on se retrouve dans un auditorium piloté par les tubes, mes enceintes Kef Q300 coaxiales en tremblent encore de plaisir !
Au tarif chez Audiophonics, faites plaisir à vos oreilles et à votre baladeur, offrez leur cet mise à jour, permettez-moi le mot, "jouissive" !
christophe R.
SUPER GEL NETTOYANT VINYLS
le meilleur nettoyant des disques vinyls du monde.
s'il reste des bruits après, il n'y a plus rien à faire.
c'est un gel qui nettoie en profondeur et enlève toutes les particules de poussières incrustées au fil du temps avec l'humidité.
Christian M.
Extracteur Audio HDMI/SPIDF
Impeccable ! Branché sur la sortie HDMI zone 2 de mon préampli, me permet de récupérer directement le flux digital pour attaquer un interface numérique (OpenDRC DI)...aucune perte..aucun décrochage...parfait!
Johann a.
Super!
Très bonne conductivité, rajoute du détail (testé sur soudure de câbles cinch, câblage hi-end sur casque Électrostatiques), je recommande
Johann a.
Efficace!
Apres la fabrication d’un bloc multiprises (à trois sorties), j’ai mis deux filtres sur avant deux prises femelles, la troisième sortie est restée sans filtre (pour comparer). Le résultat est concluant, du silence et une aération dès la première écoute. Testé sur ampli à tube et lecteur CD vintage (Marantz Cd80), casque à ruban chez Fostex. Moins de fatigue auditive. A acheter les yeux fermés
Vincent D.
Marche aussi en DC
J'ai acheté le même ailleurs et il marche aussi en DC. Le 12V semble un bon compromis. Dommage qu'il y ai des tic tics d'impulsion qd il n'y a pas de son aux entrées. A part ça, il faut avouer que c'est bien pratique ... Très bon son.
Albert H.
ALLO KATANA 1.2 SOUND QUALITY DAC for Raspberry Pi ES9038Q2M 6x AOP SparkoS Labs SS3601 32bit 384kHz DSD128 With its Katana, a master DAC for Raspberry Pi, Allo offers an extremely powerful high-end solution, at a contained price and directly competing with equipment sold at higher...
best dac ever
I have the katana playing for a few days with two power supplies and this is the best Raspberry Pi Dac there is,if you can then buy it.
Adrien F.
Excellent rapport Q/P
J'avais depuis quelques années la version - AUDIOPHONICS U-Sabre Desktop K2M DAC / Ampli Casque 24bit/96kHz SA9023 / ES9018 - dont j'était pleinement satisfait avec mon Pionner hdj2000mk2. J'ai eu un coup de chance sur un audio technica ath-sr9 et j'ai souhaité lui associer un DAC de premier choix sans me ruiner tout comme le casque. J'ai suivi vos conseils et avant de l'utiliser, j'ai ouvert le capot et je l'ai laissé tourner une douzaines d'heures pour le roder. Le mariage est très bon et j'ai grimpé d'un niveaux au niveau auditif, je dirais plus de présence et d'ampleur. En tout cas, proposer un xmos, deux aop de qualité et une alimentation linéaire à ce prix là, c'est cadeaux.
Jean-Luc B.
Multiprise d'Audiophonics :
J'en ai plusieurs dans la maison ,bureau ,home cinéma ,
Bien construite , et d'une bonne longueur ,elle s'installe facilement , matériel de pro ! Je recommande .
Jean-Luc B.
The Astoria :
D'une bonne longueur il sait se mettre en place facilement ;
pour vous laisser redécouvrir vos éléments hifi !
Un câble qui se laisse oublier , je recommande !
Jean-Luc B.
Fiches banane !
Très facile d'utilisation pour un très bon résultat !
Je recommande .
Gérard G.
super
l'entrée USB n'est pas terrible,mais avec une interface Mutec (USB vers AES),ça devient franchement imbattable,avec,contrairement à un avis précédent,des graves extrêmement présents et percutants.Peut-être une dynamique demandant plus de temps pour s'installer?
Auralic Aries Mini-mutec-Topping D70-Hattor intégré-Audio Physic Scorpio II
Vincent D.
excellent, je recommande aussi.
Par contre le module peut fonctionner avec du courant continu aussi, ce qui chez moi a fait disparaître un grésillement incontrôlable lorsque le volume de mon ampli était partiel. la remarque concernant l'inversion des entrées et sorties est aussi juste, essai qui confirme ... comme quoi les chinois peuvent fabriquer de très bons produits mais indiquent parfois n'importe quoi dans leurs "specs" ou sur leurs cartes électroniques.
Cédric N.
Rk 27 Alps
En remplacement de la pièce d’origine de mon Rega Elex de 1997, parfait.
Cédric N.
Lot gaines thermo
Parfait, se rétracte proprement résultat impeccable.
Cédric N.
Lot gaines thermo
Didier C.
Excellent boitier
Parfait pour réaliser soi-même sa multiprise secteur pour moitié prix d’un modèle pré-assemblé. Et on peut opter pour une connexion parallèle ou série des prises selon ses convictions ! J’ai choisi les prises schuko classiques de très bonne qualité, de préférence aux Furutech trop chères à mon goût. Boitier bien fabriqué, belles finitions et visserie inox complète. Mention spéciale pour les pieds en aluminium avec insert caoutchouc de qualité.
Vincent D.
Bon ampli
Attention, plusieurs recommandations : la meilleure tension d'alimentation est du 24V continu. J'ai beaucoup galéré pour trouver la bonne valeur du potentiomètre de volume et après de multiples essais, la seule qui semble parfaite est du 5KOhms en linéaire. A part ça je suis impatient de le rôder et vais peut-être lui adjoindre un préampli pour avoir un peu de choix dans la sonorité. Je vous ferai part de mes impressions dans quelques semaines, ...
Alexey G.
Good sound, too little glue.
DAC was tested on Windows 10 pc and LG G7 with Etymotic ER3XR and Capfire Andromeda.
It sounds a bit better than Hires DAC in LG G7, especially in bass range and voices. With Andromeda the background remains sufficient quiet.
The internal body part from one side was not glued at all.
An epoxy glue for metal helped.
On Windows works DAC without iBasso driver but with the drivers it sounds better.
Incidentally, I advise the drivers not to install, because after deinstallation, was, for example, WLAN card for Windows not visible any more. I had to do network reset.
Mathias M.
Organique
Emballage très soigné à la livraison, enroulé dans du papier bulles. J'avais envie de changer un peu de son. Cette lampe ne m'a pas déçue. Dans mon préampli guitare (un Soldano X88R) en V1 et V2 il a rendu mon son plus épais, plus articulé, plus riche, plus vivant. C'est pour l'instant les meilleures positions que j'aie trouvé. Une excellente lampe !
Minh Tuan N.
Magnifique
Suite à 1 utilisation « intensive », je peux le dire que c’est le meilleur DAP que j’ai eu jusqu’à présent... 1 merveilleuse expérience musicale pour 1 amateur de musique comme moi...
Très bien !
Bonjour , acheté en remplacement d'un Elecaudio pour alimenter mon ampli (Audia 3S) , monté avec des prises furutech Cu, et bien c'est positif , meilleur équilibre tonal , plus d'ampleur et d'aération , des silences plus profonds (ça fait bizarre d'écrire ça mais c'est vraiment ce que je ressens...). Le rapport qualité/prix me semble excellent !
Christopher S.
Bonne qualité , mais ...
Qualité d'écoute correct, impression de plus de puissance par rapport a un ampli AudioGD au même nombre de watts.
Problème de détection avec Volumio sur raspbery pi 3, pas de détection du dac (bruit et sur l'écran SMLS "DSD"de l'ampli ??), obligé de switcher de source ou relancer une lecture dans Volumio pour que sa joue comme il faut.
Pour l'utilisation avec un caison je ne sais pas trop comment le faire, car quand j'active la sortie préout le son est coupé. Du coup sortie haut niveau.
Guillaume F.
Amp9 Excellent !
Avec cet ampli, le matériel laisse place à la musique... à la différence que cette fois, peut importe le registre musical.
Mais attention au matos utilisé.
On quitte la neutralité de l'amp1/amp3 avec un contrôle démentiel sur le registre des grave, médium et aiguë.
Cette neutralité sonore si excellente pour les bon mix, mais impardonnable sur les moins bon, laisse place à une présentation plus douce, suffisamment détaillé, et parfaitement 'flexible' au regard des différents mixage de musique.
Matos utilisé - Dx200/Amp9 avec :
- It04 (cable CB13) Parfait - tout style musicaux
- Focal Elear (cable d'origine) - Parfait - pareil
- Focal Listen - problème avec connexion jack 3.5 /4-contact ? (léger parasite dans le son)
Pour aller plus loin :
- Focal Clear : On touche la limite de ce combo. Ne pardonne pas aussi bien les mauvais mix et n'arrive pas du tout à la hauteur de l'amp3 sur le registre du classique (grande aération, contrôle des basses / infra basse et un large scène sonore)
Conclusion :
Combiner avec un matos 'Milieu de gamme' cet ampli peut représenter une énorme value, mais ça ne reste que mon avis ! à vous de tester...
Recommande fortement !
Denis L.
Version améliorée du bluesound 2
Le son toujours aussi magique. La version précédente est hs après 2 ans et...4 mois? d'écoute bien agréable. Le rapport qualité prix top fait que je récidive avec l'achat de la nouvelle mouture. Un gain sensible pour la lecture de fichiers HD Un son fluide moins numérique que son ancêtre.
Mais encore un sérieux bémol ! ! Toujours pas de bouton d'arrêt : Après une coupure de courant l'animal en veilleuse se réveille tout seul ainsi que votre disque dur. Penser à le mettre hors circuit après usage. (Je retire une étoile )
Xavier L.
Acheté pour éventuellement remplacer un audio gd 19.
Devant les critiques et valeurs excellentes d'audio science review, je me suis posé la question de remplacer un dac 19 dsp1 qui n'avait pas une bonne note sur le même site (certes c'est un modèle sans DSP qui est testé).
La différence entre les 2 dacs n'est pas évidente et nécessite de la concentration et un fort volume.
Le D50 est eut être un peu plus contrasté et un poil excessif dans le haut du spectre à mon gout comparativement au 19 qui reste un poil plus doux et qui ne manque en tout cas pas de détail contrairement à ce que pourrait laisser penser les chiffres.
En tout cas pour le prix le D50 s'en tire de très belle manière!
Tim C.
Excellent linear power supply
This is a real bargain! Currently using it with two Pro-Ject Audio products (the S2 DAC and the S2 headphone amp). Sound quality significantly improved and, due to the low amp demand of the two S2 boxes, the Shanti really never goes beyond mildly warm :-)
I think the use of super capacitors makes a big difference.
OK...it's a long box but you don't have to look at!
Initial order was dead on arrival - I think Allo have had some quality control issues - but Audiophonics replaced this straight away. Excellent customer service from Audiophonics.
This LPS is HIGHLY recommended. I did try it with my Pi/Digione combo, and it worked just fine. However, I got better results by continuing to power the Pi/Digione using an iFi 5v power supply and dedicating the Shanti to the DAC/Amp S2 boxes. Your mileage might vary....as ever.
Porte fusible
Utilisé pour la protection du primaire transfo d'alimentation.
Mise en place facile Perçage en 12.5 (comme spécifié) de 3mm d'alu.
Fixation solide sans jeu...
Les contacts se soudent sans problème, isolation par gaine thermo.
Recommandé compte tenu du prix, de la mise en oeuvre aisée et bien-sûr de la sécurité apportée !
Olaf V.
AUDIOPHONICS PA-M250NC Amplifier Mono Class D NCore 1x250W 4 Ohm The Audiophonics PA-M250NC incorporates a Hypex Ncore NC250MP power amplifier module. This is a solid basis to build a high-performance mono HiFi system, capable of delivering...
Excelent power amp in my system
I am very content with these amplifiers. The system in my living room:
Qobuz - Bluesound Node 2 - Mytek Brooklyn DAC - 2x Audiophonics PA-M250NC - 2x Mordaunt Short Performance 6 (8 Ohm). The Audiophonics PA-M250NC deliver a detailed, clear and transparent sound in my living room (appr. 5x6 m) with enough power. I like their compact design.
For a larger room more power would be welcome (Audiophonics PA-S500NC Stereo?).
Olaf V.
AUDIOPHONICS PA-S125NC XLR Class D Stereo Amplifier NCore 2x75W 8 Ohm The Audiophonics PA-S125NC XLR integrates a Hypex NCore NC122MP power amplification module. This is a solid basis for building a high-performance stereo HiFi system, capable of...
I am very content with this amplifier. The system in my dining room:
Qobuz - Bluesound Node 2 - Mytek Brooklyn DAC - Audiophonics PA-S125NC XLR - 2x ATL 3-way floorstanders (4 Ohm). The Audiophonics PA-M250NC XLR deliver a detailed, clear and transparent sound in my dining room (appr. 5x5 m) with more than enough power for my 4 Ohm 3-way floorstanders. I like the compact design.
Milen .
Julien M.
Que du bonheur !
Je n'ai pas commandé les Sparkos sur ce site mais directement chez le fabricant et je les ai installé sur ma carte son STX II 7.1 et carte fille depuis maintenant déjà 1 an mais je tenais à laisser un avis enthousiasment sur audiophonics.
J'ai remplacé les 12 AOP d'origine des deux cartes par les SS3602 afin de profiter au maximum du changement sur l'ensembles des 8 canaux analogiques. J'ai vraiment bien fait, le son s'est libéré, plus de crispation, c'est moins sec et beaucoup plus fluide et détaillé, le même son que mon ancien préampli Home cinema très haut de gamme à plus de 10.000€, le fameux Anthem D2V...donc n'hésitez plus, sautez le pas sans réfléchir !
support de tube céramique
Aucun problème avec ces supports. Bon rapport qualité prix
Denis S.
VIABLUE SC-6 AIR BAN Silver Plated OFC Copper Speaker Cable with Banana Plugs 3m (Pair) Viablue SC-6 cables feature a high-end design, ensuring maximum conductivity for an optimal audio experience. Each cable includes 6 insulated OFC Copper conductors placed in a...
Après 4 mois de test je suis satisfait de ces câbles HP, j'avais auparavant les SC-4...qui étaient très bien et avec plus de raffinement plus de détail...mais j'ai quand même attendu un rodage..J'ai corrigé le manque de détail par des tubes pré-ampli plus raffinés..Je garde les SC-6 et vendu les SC-4 ..je les recommandes ...Merci a Audiophonics pour la rapidité et le délai de livraison !
Denis S.
Loin d'être le meilleur
Après test de 2 mois en comparaison des FULL MUSIC, SILVANIA NOS, JJ TESLA, la meilleur et plus musicale reste la Full Music..
Pour moi et sur mon ampli, la psvane est terne, plate, pas musicale, pas raffinée...ELLE NE CHANTE PAS..pas de timbre !
Ces prises sont vraiment excellentes sur tous les points. Bien pensées elles sont faciles à mettre en œuvre. C’est vraiment très sérieux avec en plus un prix très intéressant
N’hésitez pas
