jevgenijs S.
Simply great!
My speakers never sounded this good! A very clear and open sound without being fatigue! The tone controls are very effective!
Reinhardt S.
VIABLUE EPC-4 Silver Balanced Interconnect Cable Ø3.9mm
sehr gute Qualität,sehr empfehlenswert
Reinhardt S.
NEUTRIK NC4MX-B 4 Gold Plated
Customers reviews - There are 20865 reviews.
bernard g.
EIZZ EZ-205F Female 3 Poles XLR Connector PTFE Platinum Plated Ø9mm Red (Unit) This Eizz EZ-205F 3-pin female XLR connector is carefully designed for good signal transmission. Its contacts are made of Copper alloy and Platinum plated. A PTFE insulation...
cablage xlr
des connecteur de bonne facture pour faire des trés bon cable
monté en gamme pour les connecteurs eizz pour faire un cable exceptionnel
bernard g.
NEOTECH STDCT-20 Hook-up wiring multi strands UP-OCC SIlver PTFE 20AWG This Neotech silver multi-strand cable with PTFE insulation isthe best deall for rewiring and enhancing tube amplifiers, or any high-end Hifi device with wiring in the air. A...
cablage xlr
produit de haute qualité en montage avec des connecteur eizz sans soudure la qualité sonor est au rendez vous cable d exception
Manuel C.
Steel Shielding Cover for Toroidal Transformer 140x64mm This black steel cover allows you to hide a toroidal transformer while acting as shielding to considerably reduce harmful EMI disturbances. The internal dimensions of this cover...
arrivé abimé
capot abimé, mais utilisable
Tomasz C.
Pack WiiM Ultra Streamer Grey + Audiophonics AP300-S250NCX amplifier + Audiophonics Wire RCA Cables 30cm + Trigger Cable We offer you a WiiM x Audiophonics product pack comprising the Wiim Ultra Network Player, an AP300-S250NCX amplifier, a pair of RCA modulation cables and a trigger cable. This...
Powerful combination
The Wiim Ultra Streamer has all the bells and whistles in terms of connecting TV's, Record Player and all the streaming services. Not only that but pretty powerful room correction, which can help with sound in problematic rooms. Super cool!
The HDMI ARC input works really well, even with my older LG TV. Wiim device turns on very quickly and starts outputting to the Amp.
The Audiophonics NCoreX Amp in this combo really has a lot of raw power. The Amp plays my Quad Z2 with authority and at 84 dB sensitivity they are not the easiest to drive.
The only complaint I would have for this combo is the 30 cm short cables. This way you have to stack the devices on top of each other. They cannot stand side by side, because the trigger cable socket is on one side of the Amp while the signal inputs are on the other side. So they are just shy from being able to put the Amp and Wiim next to each other. Not the end of the world as I have plenty of other cables in the drawer, but good to know for other buyers.
I do not regret at all buying this set.
Jean Jacques R.
VIABLUE STONE Braided Sleeve Ø13-26mm This Viablue Stone braided sleeving accepts cable diameters ranging from 13mm to 26mm, providing effective protection against mechanical stress. Its fine braiding ensures a...
gaine large
j'ai du re-commander cette dimension pour mettre 2x cables de diam 7mm, je pensais que la gaine 7-14 pouvait faire 14mm de diam et donc que 2 cables cote à cote étaient possibles !!!
Dommage que les extrémités s'effilochent autant, sinon bonne qualité.
Jean-François G.
FOSI AUDIO K5 PRO DAC Headphone Amplifier NE5532 24bit 192kHz With the K5 Pro, Fosi Audio offers a compact, versatile and affordable DAC/headphone amplifier. With its microphone input on the front panel, the K5 Pro is designed to fit into...
Nouvelle TV, nouvelle connectique: pas de sortie audio analogique ni de prise casque. L’utilisation de ce petit appareil a réglé le problème. Le son passe par la sortie optique et je peux utiliser un casque ou la sortie analogique RCA pour alimenter mes enceintes via le petit amplificateur Fosi BT 20 A que j’utilisais sur mon ancienne télé.
À noter que le K5 est alimenté par une prise USB de la télé et qu’il est possible d’utiliser à la fois le casque ET les enceintes, bien que ça ne serve pas à grand chose.
Seul bémol, la LED bleue en façade du K5 est très lumineuse et je suis obligé de la cacher pour profiter pleinement de la somptueuse image de ma télé toute neuve.
Raul P.
DAYTON AUDIO PC83-4 Speaker Driver Full Range 30W 4Ω 86.8dB 80Hz-20kHz Ø7.6cm The Dayton Audio PC83-4 full-range driver features a woven fiberglass composite diaphragm, rubber surround and a powerful motor. The design allows for very good diaphragm...
Good speaker
For that price speaker is relay good in full range. To get 80Hz like described you need a biger box.
yvon C.
Audiophonics AP 310
Je trouve cet audiophonics AP 310 excellent. Aussi bon que mon Xindak CA-1 avec moins de souffle et plus défini que mon Vincent SA-T1. Avec mon système sonore très sensible, sur base très haut rendement Altec, JBL et Fostex, j'obtiens le meilleur résultat en posant une masse de 125 grammes sur son capot. Une masse inférieure me donne trop d'aigus et une masse supérieure me donne trop de graves.
Julien K.
AUDALYTIC DR70 DAC R2R Streamer Roon AirPlay UPnP Bluetooth 5.0 32bit 768kHz DSD512 Silver The Audalytic DR70 is a high-end network DAC designed for demanding audiophiles, combining discrete R2R architecture, advanced network connectivity, and extensive compatibility...
Quel upgrade! Quel rapport qualité prix!
Cela fait 2-3h qu'il tourne, à peine sorti de boîte on passe à un sacré niveau supérieur ! (remplace Chord Mojo + Octavio Stream)
On peux dores et déjà dire que c'est addictif, beaucoup de détails perçus à bas volume c'est très agréable!
Les voix ont l'ar très réaliste et les basses sont puissantes et propres! j'ai déjà envie de ré-écouter tous mes favoris car oui il y à vraiment quelque chose en plus!
Après le rodage je testerais une alim 12v de qualité et peut être les AOP sparkos ou burson mais à se demander si ce truc peut faire encore mieux??
Alain M.
SMSL PL150 CD Player CS43198 Black The SMSL PL150 is a CD player based on a CS43198 DAC chip, a Philips mechanism and a PLL (Phase Locked Loop) circuit for high-quality playback and conversion of your favorite CDs.
Lecteur Cd SMSL
Lecteur CD livré sans son alimentation, après conseil du SAV , j'ai mis une alimentation de de 3A 5V parfait, tout marche. connexion sur DAc Toppping en ooptique. Son mieux défini qu'en analogique.
Audiophonics touours au top.
Etrange...
Système considéré : NAD C326 BEE et FOCAL CHORA 806 (pareil avec ELTAX monitor III), pièce de 10 m2.
Scène exceptionnelle en ampleur, précision, profondeur... Basses présentes et correctes, aigus limite agressivité mais propres, nets.
Bref, que du bon, voire très bon sauf que... une impression de trous dans la bande passante (au niveau des mediums ? ) d'où une sensation d'absence d'homogénéité, surtout sur des grands ensembles, le son devenant sec, criard... un manque de moelleux à mon goût.
Vraiment dommage, car mes oreilles passent là près d'une grande réussite...
Georgios D.
sounds great and work as intended
perfect little device for active speakers without volume control, sounds better for the cost, works flawlessly with the TV (LG HDMI ARC), no problems at
Oscar S.
Association qui marche très bien. Agreablement surpris para la qualité de fabrication de l'ampli, puissance plus que suffisante.
Zdravko K.
Very good. Works as described.
Zdravko K.
FOSI AUDIO P4 Preamplifier The Fosi Audio P4 preamplifier is a compact and versatile solution. With its three stereo RCA inputs, volume control with motorised potentiometer, tone control, gain selection...
Very good little preamp. Excellent sound.
Laurent F.
Qualité supérieure et constante
J'utilise Mogami pour tous mes câbles de liaison , depuis des années .Un fiabilité sans faille . Ici , j'utilise cette référence pour raccorder mes enceintes Atlantis Lab AT18 pro , pas de soucis et reste souple malgré la section .
Sûr que de la gaine caoutchouc noire apparente , ça ne fait pas "audiophile" ,lol , mais c'est le son qui compte non ?… Alors oui , j'ai ajouté de la gaine "déco"+ des terminaisons thermo-rétractables sur ce qui est apparent . Ça fait "classe" et câble " à pas de prix" , alors que non ….
Eric G.
Préampli
Basse lourdes, medium brouillons et aigus très faibles, à part le potentiomètre de volume qui est élevé dès le départ.
Laurent F.
MINIDSP POCKETADC ADC Converter ES9821Q RCA to Coaxial / Optical Toslink 24bit 192kHz The MINIDSP Pocket ADC is an analog-to-digital converter featuring a stereo RCA analog input and two digital outputs, a Toslink optical output and a coaxial SPDIF output. Thanks...
Mini mais fait le max'
Rien à redire . Utilisé pour relier le pré-ampli de ma platine vinyle à un Eversolo A8 . Pas de perte de qualité à l'écoute des mes albums" test" , rassurant .La possibilité de réglages est appréciable . A voir la fiabilité dans le temps . Une chose certaine : son format ridicule permet une discrétion à toute épreuve .
Françoise B.
SAV Audiophonics au top
Suite à la réception d’un exemplaire du purifier en panne, grâce au Sav d’Audiophonics je recevrai à peine 8 jours plus tard un exemplaire testé. Installé entre la box et le streamer, dés les premières secondes le son est transfiguré et cela se renforce au fil des heures.
Tout est mieux plus musical.
Adepte du vinyle et nouveau dans la musique dématérialisee j’en étais arrivé à mettre le streamer de côté ( pourtant assez haut de gamme). Grâce au ifi purifier pro la matière et la scène sonore sont crédibles.
Indispensable !
Hassan B.
SILKLINE T8 Tuner Radio FM / DAB / DAB+ The Tonemax T8 is an FM / DAB / DAB+ tuner equipped with an RDS decoder that allows you to broadcast analog FM radio as well as DAB + digital radio, which is more recent and...
H B
Tuner de très bonne facture son de qualité mais la télécommande reçue avec n'est pas celle de la photo, il n'y a que 9 touches, et sur le mode d'emploi, la télécommande est bien celle de la photo, je recommande ce tuner.
Rilo Blanco J.
Fantastic with IeGO 8085 (Gold) nd Furutech FI-28 (Rodio)
After testing, it outperformed all the Furutech cables (21.31, etc.), as well as the Kimber Kable PK10 and PK11, Duelund 12AG.
With Schuko IeGO 8085 gold connect to Vibex power distributor (rhodium). And IEC Furutech FI-28 (rodio) connect
In my setup, I've found that Furutech rhodium connectors (F1-28, etc.) with gold-plated terminals inlet (amplifier and phono stage) work very well. .
But I’m keeping a Kimber PK10 in my setup—the Vibex distributor—because at least one Kimber cable gives me a lot of space, a concert hall feel, and a sense of openness.
Rilo Blanco J.
In my setup, all the inlets—both for the amplifier and the Furutech Pure Copper Gold phono preamp—are fantastic, producing magical results when paired with the Furutech F1-28 Rhodium IEC connector and the IeGO 8085 Gold Schuko plug. The power distributor features all-rhodium Vibex connectors.
I’ve found that Furutech’s rhodium (F1-28, F1-15) combined with Furutech’s pure gold inlets works incredibly well, in my humble opinion.
And that using IeGO—even just a few throughout the entire system, but at least one—makes a big difference.
After testing, it outperformed all the Furutech cables (21.31, etc.), as well as the Kimber Kable PK10 and PK11.
(sorry my bad english, )
Donald S.
FIIO WARMER R2R DAC R2R Tube Buffer E88CC 32bit 384kHz DSD256 Black The FiiO Warmer R2R is a DAC combining discrete R2R conversion, a JJ E88CC tube stage and a linear power supply, all housed in a retro-style chassis equipped with a mechanical...
Tube Bliss
Discount any Youtube reviews denigrating this unit's sound as 'opaque". Yes, it is ever so slightly less defined then, say, an ESS solid state DAC, but that 's the point And to top it off the price, compared to much of it's competition within the crazy audiophile world is almost free.
Jean Claude L.
Bonne qualité.
Bonne tenue une fois serti.
diamètre exact
Jean Claude L.
Bonne qualité.
Jean Claude L.
Qualité top
Fait parfaitement le job.
Bonne tenue sur le câble après sertissage
YANN P.
La technologie au service de la musicalité
Après avoir intégré le Neotech NEP-3003G dans mon système, le rapport prix/performance est tout simplement exceptionnel pour un câble de cette technicité.
Neotech confirme ici son statut de leader dans la fabrication de conducteurs. L'utilisation du Graphene (le "G" de la référence) combinée au cuivre UP-OCC marque une réelle évolution par rapport aux versions précédentes. Pour le prix, bénéficier d'une telle recherche sur les matériaux est une opportunité rare en Haute-Fidélité.
Monté en DIY avec des connecteurs Monosaudio E109G / F109G, l'opération est très facile grâce à la souplesse relative du câble malgré sa section sérieuse.
Blindage : La qualité de construction saute aux yeux dès le dénudage. Le blindage est exemplaire, assurant une protection totale contre les pollutions électromagnétiques, un point crucial pour l'alimentation secteur.
Finition : L'ensemble une fois assemblé respire la robustesse et le haut de gamme.
Utilisé sur mon amplificateur Audio Analogue Puccini Settanta Rev 2, le résultat est immédiat et impressionnant. On bascule clairement dans un rendu très haut de gamme :
Transparence et Détails : Une multitude de micro-informations font leur apparition. Les attaques de notes sont franches et d'une grande précision.
Équilibre Tonal : Le grave est parfaitement délié et tenu, sans aucune boursouflure. Les aigus, quant à eux, sont d'un soyeux remarquable, sans la moindre agressivité.
Scène Sonore : L'image gagne en profondeur et en aération.
En résumé, qualité et technologie a un prix encore abordable, je recommande.
Fabien A.
RQP imbattable
Venant d'une barrette Audiophonics avec le câble Olflex en 2.5mm² (l'ancien modèle), je souhaitais monter en gamme dans mon rendu sonore et c'est chose faite avec cette barrette d'un RQP incroyable compte tenu de sa qualité de fabrication et des composants utilisés. A l'écoute un son plus riche, plus naturel, fluide et aéré qu'avec ma précédente barrette, et sans être trop montant/brillant. Un très bon choix en ce qui me concerne. Je l'ai couplé à un câble Furutech S22N + Shucko Viborg 502 Rodium et IEC Charlin Carbon (équivalent soniquement à une Furutech 38G). Merci Audiophonics.
Fabien A.
Excellente alimentation
Alimentation combinée avec un streamer Zen Stream. Je trouvais le rendu sonore de ce streamer trop brillant avec la prise d'origine (basique) et une fois combinée avec l'alimentation elite, je découvre tout le potentiel de ce streamer : Un son riche, fluide, aéré, une scène sonore ou tout est détouré. Je l'ai branché sur ma barrette secteur (MPC5 audiohonics) avec un câble Furutech TSC21 monté avec une prise iec Furutech NCF et une shucko Charlin Carbon (très proche soniquement d'une Furutech iec 28G), cette association est tout à fait adaptée pour obtenir un rendu sonore tel qu'indiqué plus haut, je suis ravi.
YANN P.
Un rapport performance/prix imbattable pour le DIY
J'ai choisi ce connecteur Viborg VF503G pour un update d'un de mes câbles secteur et le constat est là : pour un prix très abordable, on accède à une qualité de conception indéniable.
Les points forts :
Prix très abordable : C'est l'un des meilleurs rapports qualité/prix du marché. On équipe ses câbles avec du matériel sérieux sans exploser son budget.
Montage ultra-pratique : Très facile à assembler, les passages de câbles sont larges et les vis de serrage inspirent confiance. C'est un bonheur pour le montage DIY.
Matériau technique (Polycarbonate Bayer-2805) :
Au premier regard, la coque peut paraître un peu "cheap" ou légère visuellement. Pourtant, c'est un choix technique de premier ordre. Ce plastique haute performance possède de réelles propriétés audiophiles (neutralité vibratoire, isolation thermique et stabilité électrique) que l'on retrouve sur des connecteurs bien plus onéreux.
Rendu et Finition :
Le placage Or est propre et apporte cette fluidité caractéristique à l'écoute. Bien que l'aspect esthétique soit sobre (on est sur du plastique fonctionnel), l'essentiel est à l'intérieur : la conductivité et la gestion des résonances sont excellentes.
YANN P.
VIABLUE Heat-Shrink Tubing for Cables V2 (Set x4) These Viablue heat shrink sleeves are marked with an arrow to indicate the direction of a cable. They are particularly suitable for Viablue SC-2 and SC-4 cables. They are...
Utile pour le repérage, mais marquage trop fragile
J'ai fait l'acquisition de ce set de gaines thermorétractables Viablue dans un but bien précis : indiquer visuellement le sens de conductivité de mes câbles audio après montage.
Ils sont très bien pour la protection mécanique et la finition esthétique, mais décevant pour le marquage technique qui ne tient pas dans le temps. Si vous les manipulez souvent, le repère de sens risque de disparaître.
YANN P.
VIABLUE T6S SCREW RCA Connectors Gold Plated Ø8mm (Pair) These Viablue T6S RCA connectors benefit from an impeccable manufacturing quality. With their 24-carat gold-plated contacts, they offer very good audio signal conductivity while...
ViaBlue T6S & Neotech NEI-3004G
Montés sur du Neotech NEI-3004G en modulation, ces connecteurs confirment la qualité allemande : les vis et pas de vis sont d'une précision irréprochable.
Côté sonorité, je suis agréablement surpris par un rendu très neutre et doux. Une excellente affaire, surtout avec les promos Audiophonics .
YANN P.
Un rapport qualité/prix exceptionnel, en sub comme en modulation
Excellent rapport qualité/prix pour ce NEI-3004G.
Le montage en DIY est particulièrement aisé, notamment avec les connecteurs ViaBlue T6s (Screw) qui permettent un montage par vissage direct.
Pour mon caisson de basses, j'ai opté pour un montage en double section (conducteurs rouge et bleu couplés sur le point chaud, tresse de blindage pour la masse). L'apport du graphène est immédiat : on gagne en impact et en vitesse, tandis que la structure UP-OCC garantit une grande transparence.
Écouté en modulation dans ces mêmes conditions, il excelle également. Le recul du seuil de bruit de fond apporte une image mate (absence de brillance artificielle) et un son nettement plus détouré. À moins de 50 €, c’est une véritable aubaine pour optimiser son système avec précision.
YANN P.
Du NCF accessible
En remplacement de l'IEC FI-06 d'origine d'une barrette MPC5 Stealth, cet upgrade est très facile à réaliser.
Cette IEC est légèrement plus profonde que la FI-06.
Les améliorations du rhodium et du NCF sont tout de suite évidentes.
La scène sonore s'élargit, le son semble gagner en précision.
Le rodage est très long, au moins 400 h.
À moins de 50 €, c'est une aubaine.
Françoise B.
Panne
Arrivé en panne ( pas de découplage optique)retour à audiophonic très réactif, en attente de réception d’un autre exemplaire. Sav audiophonic au top mais réserve sur la fiabilité de l’appareil.
laurent C.
sans doute un bon AOP malheureusement le tarif est conséquent
Remplacement du traditionnel AOP 5532 du Fosi v3 mono par le Sparkos SS3602. J'ai seulement remplacer le deuxième comme préconisé, sur les deux que possède le v3 mono. Conclusion: avec un seul 3602 cela n'apporte que peu d'amélioration audio. Peut être quand remplaçant les deux cela apporterai plus de précision ? mai vu le tarif plutôt élevé du Sparkos 3602, je reste perplexe !
Bruno G.
AUDALYTIC DR70 DAC R2R Streamer Roon AirPlay UPnP Bluetooth 5.0 32bit 768kHz DSD512 Black The Audalytic DR70 is a high-end network DAC designed for demanding audiophiles, combining discrete R2R architecture, advanced network connectivity, and extensive compatibility...
Complément
Après essai avec m connect, je constate que cela fonctionne a priori sans accroc et avec une très bonne qualité.
Frank v.
OPA828 Dual OPA DIP8 (Unit) The OPA828 operational amplifier features a JFET input and a high slew rate of 150Hz.
Transparent, detailed and spacious
The OPA828 is a fantastic-sounding operational amplifier. It is completely transparent and delivers an extremely clear and detailed sound that is very pleasant and causes no listening fatigue even after a full day of listening. The soundstage is enormous and spacious.
Gilles C.
DOUK AUDIO VU56PRO RGB LED VU Meter Mic + Line The DOUK Audio VU56PRO is an RGB LED VU meter with 8 display effects, operating effectively on the 20Hz-20KHz frequency band. The signal input is via stereo RCA or 3.5mm Aux...
Produit bien fini qui donne de la vie à mon système audio. il me rappelle les vumètres des platines cassettes. Livré dans un super emballage qui fait très pro. Raccordé à la sortie RCA de mon lecteur réseau il offre une bonne indication du niveau et le choix des différents modes avec la télécommande est un plus. il manque juste un bouton marche/arrêt en façade car il faut bien penser à l'arrêter avec la télécommande avant d'éteindre les appareils audio. C'est un détail car c'est un appareil de qualité à un prix correct qui n'apporte aucune amélioration du son mais qui donne une touche sympathique et fait "danser" la musique.
Didier a.
Balanced Regulated Phantom Power Supply Module 48V 5V +15/0/-15V This regulated phantom power module is ideal for powering a microphone at 48V DC. The module has the particularity of also providing additional outputs at 5V and 2x15V. The...
Alimentation performante
J'ai voulu utiliser cette alimentation pour tester la réalisation DIY d'un préampli à très faible bruit de Douglas Self et le résultat a été concluant à 100% (bien que le test ait été effectué sur table donc sans boitier). A noter que le module peut délivrer plus de 15V symétrique en fait (17V dans mon cas). Je recommande donc vu son prix très attractif.
Pour un usage axé sono c’est correct. Pour un usage audiophile passez sur autre chose. RQP imbattable
DAVID M.
Super câble je recommande
nathanael d.
Très bien!
Bluffé par la qualité de ce petit récepteur bluetooth. Cela capte très bien.
nathanael d.
PSVANE EL84 HiFi Series Tubes (Matched Pair) The PSVane EL84 is a high-performance preamplifier/amplifier tube. These tubes are part of the brand's classic standard range, and provide excellent musicality....
Des tubes efficaces
Un paire de tube très bon rapport qualité prix. Silencieux et efficace.
nathanael d.
ATAUDIO KING WOLF RCA Interconnect Cable 6N OFC Copper Shielded Gold Plated 1m (Pair) These ATAudio King Wolf RCA cables feature quality construction with OFC 6N insulated copper conductors for excellent signal transmission. The braided copper shielding...
Un bon cable
Une paire de câble RCA efficaces et silencieux.
Claus B.
VIBORG VS702 Pure Copper Spades Ø4.5mm (Set x4) Viborg VS702 are high-quality spades that ensure optimum connection and conductivity. These models are made from pure copper, guaranteeing excellent electrical conductivity....
Ideal für Kupferkabel bis 2,5 mm. Sehen schön aus und sind hochwertig
Claus B.
Wie alle Stecker von Viborg, die ich habe. Schön anzusehen, sehr gut verarbeitet, gute Haptik. Ideal für Kupferkabel mit Durchmesser bis 2,5 mm
Claus B.
Bruno G.
Recommandé
Donner son avis sur un élément de la chaîne hi-fi fait s'avère toujours un exercice délicat tant il repose sur la subjectivité. Alors, après une période de rodage (sujet à caution et pourtant...), et en toute subjectivité, je peux dire que j'apprécie particulièrement ce dac. Par rapport à mon dac smsl d300, j'ai l'impression de mieux suivre la musique et ainsi de mieux ressentir l'émotion. Sans doute est-ce pour cette raison que l'on rapproche la technologie r2r de la lecture analogique d'une platine vinyle. En revanche, je suis moins enthousiaste sur la partie pont réseau que j'ai tenté d'utiliser avec audirvana en mode upnp; son fonctionnement est en effet aléatoire.
Michel L.
FOSI AUDIO ZH3 DAC Preamplifier Balanced Headphone Amplifier AK4493SEQ 32bit 768kHz DSD512 The ZH3 from Fosi Audio is a preamp and headphone amplifier that also includes a DAC function. This versatile device is based on four OPA1612 chips to provide 2570 mW of...
J’ai attendu de l’avoir utilisé quelques semaines avant de donner mon avis
L’usage comme amplificateur casque est le principal atout du ZH3 . Associé à mon Final sonorous il propose une scène musicale large et un style analytique précis mais sans excès.
Naturellement limité dans les graves mais à ce tarif….
Utilisé comme DAC pur il montre ses limites avec mon système amplificateur à tube streamer Volumio : l’image sonore n’est pas très stable même si les timbres restent justes. La puce AK fait un travail remarquable
Bref très bien pour le bureau ou un système secondaire mais avec un système plus ambitieux il faudra un appareil plus consistant
Ce FOSI ZH3 demeure une bonne affaire et semble s’´inscrire dans la philosophie de la marque qui propose des appareils d’entrée de gamme pour le tarif mais aux performances comparables à des produits européens bien plus chers
M.L
