didier N.
ok
Benoit d.
Robert C.
It is difficult to...
Customers reviews - There are 19629 reviews.
Stefano C.
Not a good experience for me
I’m sorry to give a negative review on what seems to be a very high quality and well thought out product, but I have to share my experience. I have used this cables to connect my Benz Micro Glider SL to an Ortofon LH9000 headshell. Compared to the wires that come with the shell (I guess the ortofon 6N headshell leads), the 1877phono ones led to a more sterile presentation, less precise imaging, less threedimensionality and body, bass less controlled, highs a bit fatiguing, less dynamic. The clips on the shell side were a bit too large, but they allowed a sufficient grip on the pins and I don’t think that is the problem leading to the lesser presentation. I think the problem is most likely the rhodium plating. in my experience rhodium plating on audio signal connectors lead to sterile and harsh sound, this is the third time I have bad experience with rhodium, the other two being Ramm spades and Neotech XLR connectors. In all cases I had to switch back to gold or silver plating even giving time to break in. I have all power connector furutech rhodium plated but for audio signal now I’m really done with rhodium, I’ll try no more. To give context I have a Garrard 401 TT with modified SME 3009 II improved, Mark Levinson 26 and 23.5, and Tuscanini planar magnetic speakers (very revealing of any insignificant defect along the audio chain as in this case).
F M.
WONDOM AA-AB32221 Stereo Amplifier Board Class D TAS5613 2x150W 4 Ohm The Wondom AA-AB32221 is a stereo amplifier module capable of delivering 2x140W of power at 4Ω. Featuring a Class D architecture based on a TAS5613 amplifier chip, it...
Impressionnant (suite)
Je reviens car mon avis a été tronqué...
Je confirme donc l'efficacité de ce module qui envoie du lourd. La puissance est bien là (sous 36 volts), certes diminuée dans du 8 ohms, avec un son percutant est clair.
Normunds Z.
Recommend
Great device!
Normunds Z.
HDMI 2.1 Cable 8K 60Hz 48Gbps HDR eARC ALLM Dolby 2m This high-performance HDMI 2.1 cable supports video transmissions in 8K 60Hz and 4K 120Hz with a bandwidth of 48Gbps. Its conductors ensure an excellent signal transmission and...
Recommend
Excellent cable, noticeably improved the picture from computer to TV.
Insulated Female Blade Terminal 4.8mm Ø3mm (x10) These lugs accept cables up to 3mm and will allow you to easily connect your speakers. In addition, they are made of a Copper alloy to ensure good electrical conductivity. Each...
Adhesive Cable Tie 20x20mm Black This adhesive cable tie simply attaches to a wall to allow you to group your cables together. The base of the cable tie is adhesive and can therefore be easily attached to any...
Pratique
Très pratique et colle bien aux parois.
Je me suis lancé sur la construction diy d' un ampli classe d a partir de ce module 3e audio.
Ayant déjà eu un ampli 3255 en remplacement de mon tube parti en Sav, celui est incomparable !
Beaucoup plus nuancé, musical, silencieux et précis. Il représente sans doute l' avenir de la classe d , bien conçu et incontournable.
A ce prix, pas d' hésitation a avoir.
Je recommande sans réserve.
MP-H250S48 SMPS Switching Mode Power Supply Module 250W 48V 5A PFC This SMPS MP-H250S48 switch-mode power supply module is capable of delivering 48V, 5A current and 250W of power. It is also equipped with a PFC (Power...
Bonne alim.
Simple et efficace pour une implantation réussie. Fonctionne parfaitement.
Pas ouf
Assez déçu par ce boitier dont le système de fixation des capot est mal conçu selon moi. De plus, les petites vis de fixation sont trop courtes pour atteindre l' écrou dans la rainuré. Y' a mieux.
Step Drill Steel HSS-4241 15 Steps Ø4-32mm This 15-step drill, from 4mm to 32mm, is made of HSS-4241 steel and can drill through materials such as iron, aluminum or plastic. It has a hexagonal shank for quick tightening.
Nickel !!
Fait des trous avec précision . Dans de l' alu 3mm, c' est comme dans du beurre..je recommande
IEC C14 Plug with ON-OFF Toggle Switch and Fuse Gold Plated Pure Copper 250V 10A This IEC C14 socket is ideal for integration into a DIY device as a power connector.  The socket incorporates an ON/OFF toggle switch for powering your device and a fuse to...
Oui, mais....
Adapté pour une épaisseur maxi de 1,5 mm. Sinon, bonne connections et qualitatif.
Cablage interne ampli
Utilisé en cablage interne d' un ampli classe d 3 E audio, c' est très bien.
Cablage interne
Utilisé pour un cablage interne d' un ampli 3e audio stéréo, très bon résultat.
DURATOOL D03048 Digital Multimeter 500V 5A 2MOhm This Duratool D03048 digital multimeter features all standard measurement functions and is suitable for any professional or DIY electronics project.
Fait très bien ce pour quoi il est conçu.
Speaker Terminals 24k Gold Plated Ø19mm x 50mm (Pair) These speaker terminal blocks offer excellent design quality at an affordable price. Their contacts are made of 24k gold-plated copper alloy, ensuring...
Parfaits
C' est lourds, solide, bien fabriqué et très sérieux, très bons borniers.
pascal P.
Déçu
Après avoir lu nombre d'avis élogieux sur ce câble, j'étais très bien disposé, mais je suis très déçu. Médium creux et froid, aigu métallique, le grave est très (trop ?) présent. Courbe en V physiologiqie. P
Gerard T.
Des les premières écoute le Gustard fait de la très belle musique
Mais avec un coté un peu glacé
Il faut être très patient.
Mais une fois rodé je confirme que ce Dac est vraiment fantastique la musique est libérée aucune coloration.
Et encore meilleur avec un drive extérieur 3Dlab.
Bravo..!
Edmond H.
LPSU25
Achetée pour améliorer mon Raspberry DAC PRO 2,
Je suis ravi du résultat obtenu. Graves mieux tenus, reproduction douce et puissante du spectre, possibilité de monter le volume sans distortion si je compare à l'alimentation de base. Un vrai et grand plus pour moi. Merci Audiophonics
FURUTECH CF-202 NCF (R) Banana Plugs Rhodium Plated Pure Copper NCF Alpha Treatment Ø5.5mm (Pair) With the CF-202 NCF (R), Furutech unveils high-end banana plugs offering excellent transmission performance with contacts made of rhodium-plated pure copper. This is the brand's...
Pas de Surprises
Après avoir acheté, monté avec bonheur les fiches RCA, de la même catégorie.(FURUTECH CF-102 NCF), je me suis décidé a changer les fiche bananes de mon câble d'enceinte( Crystal Cable Ultra) , qui avait de simples bananes Furutech cuivre rhodium visée , par ces magnifique Bananes, qui sont d'une fabrication incroyable, qui ont apporté , un gain de finesse, de micros-détails , et un recul du bruit de fond, un petit plus de véracité, mais cela ne fait qu'une semaine , quelles 'tournent' le rodage n'est pas terminé. J'avoue que la remise des soldes d'hiver, mon décidé , à effectuer cet achat qui et quand même conséquent, au vu de la multiplication des prises!!!
Eric J.
SBOOSTER BOTW P&P MKII Regulated Linear Power Supply 12V 3A / 13V 2.25A / 13.5V 2.1A With the SBooster BOTW P&P ECO MKII regulated linear power supply, purification of the electrical signal begins immediately where the polluted current enters the power supply....
Je l'emploie pour alimenter ma box internet THD Redbox by SFR. L'alimentation est bien fabriquée et inspire confiance. Elle chauffe peu; consommation: une petite trentaine de watts.
Jacky D.
Bon câble
Câble qualitatif. Souple et facile à dénuder. Rendu sonore très correct, à confirmer après rodage. Livraison ultra rapide, bravo Audiophonics !
Jacky D.
Top qualité
Belle qualité. (fiche et vis). Elles tiennent très bien dans la prise. Pourquoi dépenser plus..!
Amélioration : séparation visuelle du + et - (rouge et noir) trop faible. Il manque un cerclage de couleur (que j'ai fait avec ruban adhésir de 2mm de large). Livraison ultra rapide, bravo Audiophonics
HERVE H.
Livraison rapide.
Petit accessoire malin qui fait parfaitement le job.
Après, il y aura toujours le débat: Laisser ses électroniques sous tension afin d'éviter les chocs à l'allumage et garder la bonne température de fonctionnement pour une meilleure écoute...ou tout éteindre...
Mark M.
Great sounding connector at a great price!
I built a cable with Belden 4694R 12G video cable for ,
my. Merason Frerot DAC. Awesome sound; so life like and real. I am buying more!
bien mais...
Nette amélioration d'un point de vue sonore, le médium est bien plus ouvert, c'est plus précis aussi sur le reste du spectre.
Il y a bel et bien une différence avec une prise Legrand.
L'embase est qualitative et upgrade réellement mon système.
Je regrette juste que les produits Furutech aient autant augmenté...ça devient dissuasif en dépit de leur efficacité et de leur qualité.
Par ailleurs, l'installation n'est dans mon cas pas achevée puisqu'elle ne s'encastre pas dans un boitier mural standard (prise Legrand mozaic), et dépasse de 3 cm. Elle tient aux 2 vis latérales du boitier.
Les conducteurs sont positionnés en haut et en bas, à la verticale, et non à l'arrière de l'embase, ce qui va m'obliger à élargir l'emplacement plus tard. A prendre en considération si vous avez des murs en béton ou en pierre par exemple...
Eric J.
Inspire confiance
J'emploie cette alimentation pour mon box internet thd red by sfr. Elle semble bien fabriquée, les nombreux adaptateurs sont pratiques. Elle alimente bien la box en chauffant peu. Consommation une petite trentaine de watts.
D2R
The elegant, very musical DAC surprised me with its sound clarity, its range and space of sound delivery, fast and accurate high-resolution sound delivery, excellent setting options, only when switching the type of sound resolution, you can hear a slight banging, but that will definitely be solved by later controls, I extremely satisfied with this thing
LAURENT L.
Quel ampli
Moi, qui recherche toujours des test a gauche ou à droite avant de choisir.... Ce coup ci j'y suis allée un peu a l arrache, le son est formidable avec mon focal celestee, de plus le s.a.v répond très rapidement. Première commande et sans doute pas la dernière. Encore merci
Henry G.
HYPEX SMPS1200A400 Switching Power Supply Module 1200W 2x64V The SMPS1200 switched-mode power supply is a very high efficiency model capable of developing a nominal power of 1200 Watts in an extremely small footprint. It has been...
Acheté en remplacement d'une alim similaire cramée après 6 ans de bons et loyaux services suite à une mauvaise manipulation.
Excellente qualité de fabrication, composants de qualité, notice très détaillée. Bien sous tout rapport.
Jani R.
AUDIOPHONICS Trigger Cable Male USB-A to Mono Male Jack 3.5mm 1m Extremely practical, this USB-A to Jack 3.5mm mono trigger cable, assembled in France in our workshops, lets you control the automatic switching of your devices using the 5V...
Just works
I looked for a product like this for years and haven't seen anyone else sell one.
Affordable AVRs don't have trigger outs but they often have a USB port. Arendal Subwoofers need a trigger signal to wake up and stay on at low levels.
This cable is the solution and it works great. I just wish there were options for longer cables and 90-degree USB-connectors.
Philippe L.
Utilisé pour relier un laptop HP de 10 ans d'age à mon tout récent Eversolo DMP-A8 via sa prise OTG: reconnaissance et mise en liaison immédiate entre les appareils, transfert de 2 répertoires HiRes de 1.4 et 0.9Go en moins d'1 minute et sans accroc ! Perso, je préfère utiliser le câble physique plutôt qu'un protocole Samba.
Philippe L.
Raffinement sonore
Utilisé sur un AKG Q701 en remplacement de l'original, le Furutech est un câble souple, bien construit et de longueur idéale, en écoute comparative, les détails sont bien présents dans une scène sonore mieux maîtrisée. Je recommande.
Harry H.
very good solder
I was looking for a premium quality silver solder, (before I used WBT silver solder, easy flowing but less pure then Oyaide)
I think this is one of the best, as their tin quality is better than any other solder and their silver content is high.
Used it to solder Neotech rectangular UP-OCC silver interconnect and the sound is very good.
Bert D.
TOPPING DX5 LITE DAC 2x ES9068AS NFCA Headphone Amplifier XMOS Bluetooth 32bit 768kHz DSD512 Black Topping offers with its DX5 Lite a DAC and headphone amplifier combo benefiting from both an exceptional conception and a resolutely modern design. At its heart is a...
It works
It works and the sound is perfect. The only thing is that it does make little noises when changing programs on my computer. Its not disturbing. If I start Roon there are some noises when its opening.
Pierre G.
Beau et bon
Très satisfait de cet appareil qui vient remplacer avantageusement un Micromega trio CD qui m’a lâché après près de 30 ans de bons et loyaux services.
Il est très beau, sonne très bien dès la sortie de la boîte et de mieux en mieux en quelques jours.
La fonction lecture de CD ne pose aucun problème mais j’ai trouvé le processus de lecture des fichiers externes à partir de l’entrée USB plutôt difficile à mettre en oeuvre à partir de l’application Eddict Player sur mon téléphone. Toutefois, une fois le processus compris, le résultat est très satisfaisant, équivalent à la lecture directe des CD ou par l’intermédiaire d’Audirvana.
Quant à la fonction Bluetooth (lecture des radios ou des bonnes vidéos de YouTube à partir du téléphone ou d’une tablette), sa sonorité est bluffante avec le codec LDAC.
Je suis ravi de cet achat et je remercie l’équipe d’Audiophonics pour le choix proposé et l’efficacité du traitement des commandes.
David T.
Super produit Simracing
J'ai pris ce produit pour un fauteuil de Simracing, ces enceintes sont très efficaces,.
Bravo aussi pour le délai de livraison malgré le réappro.
je conseille le produit et le site.
Jacques T.
Belle alimentation
J ai acheter cette alimentation pour couper un boucle de masse et surtout pour alimenter correctement un mini PC dédié a l'audio.
Le résultat est la...plus de boucle de masse. Mon système est devenu parfaitement silencieux et les alimentation du pc rien avoir c est propre et silencieux.Le 5V des ports USB et maintenant bien régulé.
isolation galvanique et alim linéaire parfaitement régulee..c est la base du silence
Florent P.
Extraction directe au format DSD 2.8Mbits des SACD sur optique/coax à condition de le coupler avec une carte additionelle
Pour ceux qui n'ont pas d entrée HDMI sur leur DAC, j ai couplé ce dispositif au module additionel Interface / DAC ES9038Q2M I2S vers SPDIF / RCA vendu chez audiophonics également (https://www.audiophonics.fr/fr/modules-interfaces/module-interface-dac-es9038q2m-i2s-vers-spdif-rca-p-17046.html) via le connecteur I2S fourni. Résultats : flux DSD 2.8Mbits reconnu par mon DAC Teac UD701N depuis un lecteur blueray Sony UBP X500. Prévoir 2 alim 12V (https://www.audiophonics.fr/fr/adaptateurs-secteur/ifi-audio-ipower-mk2-adaptateur-secteur-alimentation-audio-faible-bruit-12v-18a-p-15500.html) pour alimenter le module. Parfait
Pedro Fernando P.
Service efficace, livré dans un délai acceptable.
Quant aux câbles que j'ai achetés, au vu de leurs performances, le chapitre des câbles de haut-parleurs dans ma chaîne hi-fi est clos.
Jean-Marie C.
Puissance et droiture au rendez-vous, simplicité d'utilisation, design, que demander de mieux à ce prix !
Bernard B.
Fabrication particulièrement soignée et bien conçue. Réalisation et esthétique quasi luxueuses pour ce petit adaptateur. Fonctionnement Parfait ! aucune dégradation constatée lors de l'écoute. Certes un peu cher, mais par ailleurs, introuvable en 6.35 M/4.4 F. Parfait pour mes casques Sivga et Sendy.
Erik J.
Great warmth to the sound
A softer type of cable really like it to some systems, no signs of fatigue or sibilance.
Bass I really good
Fabrice j.
OYAIDE NRF-005T Noise Suppressor Adhesive Tape Pulshut 4m Oyaide NRF-005T is a noise suppression tape using PULSHUT® (high performance non-woven textile) material developed by Asahi Kasei Corporation. This is a revolutionary...
completely transcendental deductive stuff
i was somehow inspired by a *zoviet-france* picture...highest recommendation if you're into maniac options or prone to sensitive side-effects...i will ask my japanese friends to make an aroma-diffuser version...seriously, it is the most low cost highly adaptable detail (together with the furutech nano liquid)
thanks to audiophonics people for their excellent prestation, as usual
Jordan R.
Cable secteur au son rond et chaud
J'ai acheté ce câble secteur pour le monter avec des VIBORG VE & VF 502G, en vue de remplacer un "LC-2 EVO" pour calmer les ardeurs d'un Atoll IN300. À ce jour le câble à 120 h, beaucoup parlent de 500 h et plus de rodage pour qu'il donne sont pleins potentielle.
J'ai obtenu le résultat voulu avoir un son plus chaud et plus rond, un beau bas médium et des basses plus présente sans pour autant perdre sur le reste. À voir dans le temps le résultat final.
Jordan R.
Rapport Qualité Prix au rendez-vous
Excellent câble, belle qualité de fabrication, utilisation de connecteur haut de gamme. Ce câble RJ45 rivalise avec des câbles de grande marque bien plus chère. Bande passante très étendue, on obtient de beaux timbres.
Un petit sac par câble ce n'est pas très utile, mais le packaging est là sans réel impact sur le prix.
Christian M.
AUNE SC1 Clock 10MHz OCXO Sine Signal / Square Signal Silver The Aune SC1 is a high performance external clock embedding an optimized audio architecture, including the use of an OCXO oscillator and an FS-1 frequency synthesizer designed...
Indispensable!
J'ai déjà laissé un avis très positif sur l'horloge Aune SC1 noir que j'ai acheté en Décembre 2023....tellement content que j'ai acheté une seconde horloge Aune en silver pour mon second système....c'est dire! A signaler qu'il ne faut jamais débrancher l'horloge...elle met très longtemps à retrouver son optimum....et si vous pouvez l'alimenter avec une alimentation extérieur de qualité, c'est encore meilleur!
L'Aune silver est branchée sur mon second Teac ud701n, mais je l'ai testée aussi sur un Esoteric N-05XD...superbe!!
Sylvain d.
ARYLIC BP50 Preamplifier DAC ES9023P Bluetooth 5.2 aptX HD aptX Adaptive 24bit 192kHz Arylic proposes with its S50 Pro+ a connected stereo preamplifier, having the particularity to take advantage of a complete connectivity with WiFi and Bluetooth 5.0 reception....
Génial
Parfaite musicalité à tous points de vue. Ne démérite pas mê dans un système haut de gamme. Seul problème: l'appli ne reconnait pas mon
Francois L.
1MII LAVAUDIO DS200 PRO Bluetooth 5.0 Receiver aptX LDAC CSR8675 DAC ES9018 Black The 1Mii DS200Pro is a compact and powerful Bluetooth 5.0 receiver, using a Qualcomm CSR8675 Bluetooth chip. This one is compatible with the codecs of high resolution...
Super son ! pas déçu du tout !
Son d’enfer. Je redécouvre mes morceaux et albums MP3 320Kb
+ Plus de coupure ou de saut de la connexion (Bluetooth 5.0) et plus de ralentissement bizarres pouvant survenir pendant l'ecoute
Heureux !
Mahé P.
FIIO K7 BT DAC Headphone Amplifier 2x AK4493S THX AAA-788+ 32bit 384kHz DSD256 Bluetooth 5.1 LDAC AptX HD FiiO's K7 BT is a high performance  desktop DAC and Headphone Amplifier combo , demonstrating an exemplary design for an audio reproduction marked by great transparency,...
Volume résolu
Le problème de volume mentionné précedemment était du à un réglage du Bluetooth sur Android. Il a suffit de désactiver le "controle de volume absolu" dans les options bluetooth, pour retrouver un niveau normal. La connexion en USB n'est pas affectée. Je suis pleinement satisfait et corrige ma note à la hausse.
Mahé P.
Volume trop faible en Line Out / Pre-amp
Dommage, car le son me semble bon. Le réglage du gain H/L n'a aucun effect audible dans la configuration testée.
Systeme testé:
- Input: Bluetooth (Kobuz Hi-res + LDAC)
- Output: Line Out et Pre
- Amp: Audiophonics MPA S250NC (2x250W !)
- Speakers: ELAC DBR62
Autre critique: ces petits leviers "mécaniques" de sélection OUT / Gain m'avaient attiré avant l'achat mais ils sont en fait un peu ridicules car tout petits et pas tres pratiques.
Bref, deux étoiles en moins qui ne touchent pas au coeur du travail (DAC), que je suis bien incapable de juger. Peut-etre que c'est un excellent ampli casque...
